  4. Admin 1.7.0 Fehler
Admin 1.7.0 Fehler
36 Beiträge 12 Kommentatoren 6.9k Aufrufe
  • vauvau07V Online
    vauvau07V Online
    vauvau07
    Es kann auch einwandfrei funktionieren.
    Gruß Volkmar
    • N Offline
      N Offline
      Nepomukl
      Der Aufruf mit
      "iobroker start admin.0"
      brachte wieder Leben in meinen Broker. Er hat sich aber gefühlt sehr zäh wieder hoch geschraubt obwohl auf einem Cubie.
      Anfangs kamen etliche Fehlermeldungen
      vis.0	2017-03-08 20:09:58.568	error	at ontimeout (timers.js:365:14)
      vis.0	2017-03-08 20:09:58.568	error	at Timeout._onTimeout (/ssd/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2581:27)
      vis.0	2017-03-08 20:09:58.568	error	at new ObjectsInMemServer (/ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2734:7)
      vis.0	2017-03-08 20:09:58.568	error	at /ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2727:9
      vis.0	2017-03-08 20:09:58.568	error	at _initWebServer (/ssd/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2629:24)
      vis.0	2017-03-08 20:09:58.568	error	at Server.listen (net.js:1391:5)
      vis.0	2017-03-08 20:09:58.568	error	at listen (net.js:1295:10)
      vis.0	2017-03-08 20:09:58.568	error	at Server._listen2 (net.js:1259:14)
      vis.0	2017-03-08 20:09:58.568	error	at exports._exceptionWithHostPort (util.js:1045:20)
      vis.0	2017-03-08 20:09:58.568	error	at Object.exports._errnoException (util.js:1022:11)
      vis.0	2017-03-08 20:09:58.568	error	Error: listen EADDRINUSE :::9001
      vis.0	2017-03-08 20:09:58.568	error	^
      vis.0	2017-03-08 20:09:58.568	error	events.js:160 throw er; // Unhandled 'error' event
      telegram.0	2017-03-08 20:09:42.552	error	no connection to objects DB
      sayit.0	2017-03-08 20:09:27.174	error	no connection to objects DB
      ical.0	2017-03-08 20:09:24.182	error	no connection to objects DB
      text2command.0	2017-03-08 20:09:23.250	error	no connection to objects DB
      hm-rpc.0	2017-03-08 20:09:18.981	error	no connection to states DB: Connection timeout
      scenes.0	2017-03-08 20:09:15.894	error	no connection to states DB: Connection timeout
      javascript.0	2017-03-08 20:09:08.355	error	no connection to states DB: Connection timeout
      web.0	2017-03-08 20:08:57.330	error	no connection to states DB: Connection timeout
      vis.0	2017-03-08 20:08:56.952	error	no connection to states DB: Connection timeout
      denke aber das da das Timing nicht gepasst hat. Jetzt ist Ruhe und es lüppt wie es soll (denke ich).
      Den hm-rpc musste ich als einzigen per Hand noch einmal durch starten, der hatte irgendwie geklemmt.
      Andreas
      • N Offline
        N Offline
        nobse
        Hallo
        habe auch das Update 0.16.2 problemlos durchgeführt.
        C:\ioBroker>npm -v
        3.10.10
        C:\ioBroker>node -v
        v6.10.0
        Mein ioBroker läuft auf einem Windows Server 2012 und nach Start vom ioBroker werden 7 NODE Fenster gestartet. Wenn ich diese dann schliesse stürtst ioBroker ab.
        Wie kann ich verhindern das diese 7 Fenster geöffnet werden.
        Vielen Dank
        Gruß Norbert
        CCU2 • Raspberry für Wetterstation • CMS http://www.exv2.de • HP ProLiant MicroServer Gen8 12GB RAM, 2x3TB, Windows Essentials Server 2016 mit ioBroker
        • BluefoxB Offline
          BluefoxB Offline
          Unter windows läuft ioBroker wie ein Service. Wenn ein Fenster angezeigt wird, heißt es iobroker wird als Program gestartet.
          Am Besten du stoppst iobroker service
          net stop iobroker
          Schließt auch alle Fenster
          und dann wieder den Service startest
          net start iobroker
          starten stoppen geht nur als Administrator.
          • BluefoxB Offline
            BluefoxB Offline
            @Nepomukl:
            Der Aufruf mit
            Andreas `
            Hast du vom update ioBroker gestoppt? Sieht so aus als nicht.
            • N Offline
              N Offline
              nobse
              @Bluefox Vielen Dank jetzt sind die Fenster weg. Das war aber erst nach dem Update so. Vorher ging es immer ohne Fenster.
              Gruß Norbert
              • N Offline
                N Offline
                Nepomukl
                Jo Bluefox,
                war gestoppt. Den ersten Updateversuch hatte ich von der Weboberfläche gestartet.
                Da blieb er ja hängen. Obwohl da stand iobroker gestoppt oder so ähnlich.
                Auf der Konsole konnte ich ihn dann nochmals stoppen.
                Alle weiteren Schritte waren dann nur noch Konsole.
                Die Fehlermeldungen kamen dann als die Weboberfläche wieder erreichbar war.
                • N Offline
                  N Offline
                  Nepomukl
                  So, ich glaube ich habe das Problem bei mir identifiziert.
                  Sobald ich in der Konfig des Admin Adapters von allen IP-Adressen auf die IP-Adresse des Cubies umstelle
                  geht nichts mehr.
                  Beim speichern und schließen des Konfigdialoges bleibt dieser auch stehen.
                  Im Anschluss bleibt die Weboberfläche weg. Im Hintergrund läuft noch alles.
                  Kann die Einstellung so bleiben auf alle IP's?
                  Und wo kann ich die Konfig zurück stellen? Welches File speichert die Werte?
                  Denn wenn ich ein Backup zurück hole ist es das gleiche Spiel. Es sei denn es ist ein ganz altes.
                  Gruß Andreas
                  • N Offline
                    N Offline
                    Nepomukl
                    Hat keiner eine Idee?
                    hab schon in iobroker-data/files/admin.admin weg gelöscht und den Admin Adapter neu installiert.
                    Komme immer noch nicht auf die Weboberfläche.
                    Sagt mir wenigstens wo die Javascripte gespeichert sind. Das ich die nicht alle neu machen muss, welchen Ordner muss ich seperat sichern.
                    Für die ganzen Views muss ich ja nur iobroker-data/files/Vis sichern, oder?
                    Dann kann ich nämlich auch mit einer alten Datensicherung leben.
                    • apollon77A Offline
                      Versuch doch mal iobroker add admin … dann gibts im Zweifel ne neue Admin instanz die tut :-) vorher ggf mit iobroker stopn admin.0 die nicht gehende ausmachen.
                      War das nicht so das man "0.0.0.0" wählen muss beim Bindung weil sonst komische Dinge passieren ?!
                      • N Offline
                        N Offline
                        Nepomukl
                        Besten Dank
                        Admin.1 läuft. Konnte jetzt Admin.0 weg löschen.
                        Werde dann noch probieren auf die 0 zurück zu kommen.
                        Woher soll man denn das wissen mit dem 0.0.0.0 ?
                        Da sollte zumindest die Auswahl gesperrt werden.
                          @Nepomukl:
                          Woher soll man denn das wissen mit dem 0.0.0.0 ? `
                          http://www.iobroker.net/?page_id=5473&l … figuration
                          Ist sogar rot!
                          • N Offline
                            N Offline
                            Newmiraculix
                            Hallo zusammen.
                            ich hab auch Probleme und jetzt mit Hilfe dieses Posts und der Anleitung auf der Webseite versucht diese zu lösen.Leider ohne Erfolg :(
                            Ich habe jetzt über die Konsole versucht js-controller und admin Adapter zu updaten. Js-controller war auch kein Problem. Aber wenn ich versuche admin zu aktualisieren bekomme ich folgende Meldung:
                            iobroker.core@0.1.0 /opt/iobroker
                            └── (empty)
                            npm ERR! code 1
                            Ich habe auch schon versucht eine zweite Admin Instanz anzulegen, aber ich kann einfach nicht auf über den Browser zugreifen.
                            Markus
                            CCU2 mit noch nicht ganz so vielen Aktoren :D
                            RaspberryPi2 für SmartHome mit ioBroker
                            RaspberryPi3 für SmartHome Mit iobroker (Multihost)
                            Logitech Harmony Hub
                            RaspberryPi3 mit openELEC
                            Amazon Echo, Echo Dot und Echo…
                            • H Offline
                              hater
                              Selbes Problem bei mir, ich kriege allerdings die Fehlermeldung bei jeglicher Operation am ioBroker.
                              ! events.js:141
                              ! throw er; // Unhandled 'error' event
                              ! Error: listen EADDRINUSE :::9001
                              ! at Object.exports._errnoException (util.js:907:11)
                              ! at exports._exceptionWithHostPort (util.js:930:20)
                              ! at Server._listen2 (net.js:1250:14)
                              ! at listen (net.js:1286:10)
                              ! at Server.listen (net.js:1382:5)
                              ! at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2629:24)
                              ! at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2727:9
                              ! at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2734:7)
                              ! at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2581:27)
                              ! at Timer.listOnTimeout (timers.js:92:15)
                              Eine Neuinstallation des jscontrollers hat ebenfalls keinen Erfolg gezeigt.Eine Neuinstallation des Admin Adapters schlägt mit der genannten Meldung ebenfalls fehl.
                              Basissystem: Synology Docker.
                              CCU2 mit Wärme, Licht und div. anderem.
                              Synology DS916+ mit ioBroker Docker
                              Alexa Echo Dot
                                Dazu gibt es einen separaten Thread.
                                Sollte es jedoch bei deiner Installation in Docker auf ??? Wirklich der Fall sein, dass der port 9001 vergeben ist hilft der Workaround nicht!
                                zuerst iobroker im Installationsverzeichnis stoppen mit sudo iobroker stop
                                Dann die Installation durchführen
                                Dann iobroker wieder starten
                                  Vorher ein "iobroker stop" gemacht und geschaut das keine Prozesse mehr laufen?
                                  • PatrickP Offline
                                    PatrickP Offline
                                    Patrick
                                    Nach dem Update kann ich iobroker nicht Mal.mehr über die Kommandozeile starten ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201703 ... 81fd65.jpg">https://uploads.tapatalk-cdn.com/20170311/41f5086c07c0e536806c626dbe81fd65.jpg</link_text>" />
                                    Hat noch jemand dieses Problem?
                                    Oder sogar ne Lösung?
                                    Gesendet von meinem EVA-L09 mit Tapatalk~~
                                      ENOSPC!
                                      Deine Speicherkarte ist voll
                                      • PatrickP Offline
                                        PatrickP Offline
                                        Patrick
                                        Nachtrag node -v 6. 9.4
                                        Npm 3.10.10
                                        • PatrickP Offline
                                          PatrickP Offline
                                          Patrick
                                          @Homoran:
                                          ENOSPC!
                                          Rainer `
                                          Hmm ok irgendwas müllt da die Speisekarte voll nach dem ich was lösche ist es kurz drauf wider voll
