  5. Anleitung Blockly für DAU
80 Beiträge 6 Kommentatoren 7.8k Aufrufe 4 Beobachtet
  • J Jan1
    @gluecksmann
    So sollte das schon funktionieren:
    <block xmlns="https://developers.google.com/blockly/xml" type="on" id="6`eH)U7+-CU%ym1p@{bY" x="88" y="-37">
     <field name="OID">netatmo.0.Wetter-(Indoor).Indoor.CO2.CO2</field>
     <statement name="STATEMENT">
       <block type="controls_if" id="W[NL;,zccoR^se){{N-d">
         <value name="IF0">
           <block type="time_compare_ex" id="i^Vp;_4+ya7Q%126=]~t">
             <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
             <field name="USE_ACTUAL_TIME">TRUE</field>
             <field name="OPTION">between</field>
             <value name="START_TIME">
               <shadow type="text" id="?O@j]!Ewf1D7BWQWBbE[">
                 <field name="TEXT">11:00</field>
               </shadow>
             </value>
             <value name="END_TIME">
               <shadow type="text" id="Lp.!/*1@?.RZwa~Vzqj}">
                 <field name="TEXT">22:00</field>
               </shadow>
             </value>
           </block>
         </value>
         <statement name="DO0">
           <block type="controls_if" id="95}Ru)T(c0Q6}5*c)3~l">
             <value name="IF0">
               <block type="logic_compare" id="T0E[xlA3Z7]p)8yH_,r`">
                 <field name="OP">GTE</field>
                 <value name="A">
                   <block type="on_source" id="-c)@?/aSgL4!gf^~oIZk">
                   </block>
                 </value>
                 <value name="B">
                   <block type="math_number" id="wRa$ZtA-m:irh/tFhwBg">
                     <field name="NUM">1000</field>
                   </block>
                 </value>
               </block>
             </value>
               <block type="control" id="ttfG(apHb|e~MufP5;Vx">
                 <field name="OID">alexa2.0.Echo-Devices.db670fafbbfc4ff5b16223f5d7b07624.Commands.speak</field>
                 <value name="VALUE">
                   <block type="text" id="5}z]W4Jp7;x+QSeVM9jg">
                     <field name="TEXT">Bitte lüften</field>
                   </block>
                 </value>
               </block>
             </statement>
             <value name="IF1">
               <block type="logic_compare" id="h.uqxN}$lcB*F,acfezc">
                 <field name="OP">LTE</field>
                 <value name="A">
                   <block type="on_source" id="%6(`%udQuy3)OiV3HUr_">
                   </block>
                 </value>
                 <value name="B">
                   <block type="math_number" id="~wN({SOxMAV!QktCs@Oo">
                     <field name="NUM">600</field>
                   </block>
                 </value>
               </block>
             </value>
             <statement name="DO1">
               <block type="control" id="a%ce$OCgX7NTP]EXCi@n">
                   <block type="text" id="O+IXDD=rL;`ix6yDLs^Q">
                     <field name="TEXT">Fenster kann zu</field>
                   </block>
                 </value>
               </block>
             </statement>
           </block>
         </statement>
       </block>
     </statement>
    </block>
    gluecksmann
    @jan1
    OK; danke... das versthe ich dann noch...aber bei zwei Datenpunkten steige ich gedanklich aus...
    • G gluecksmann
      @jan1
      Jan1
      @gluecksmann
      Sag wo es klemmt und ich erklär Dir wie es geht und funktioniert das jetzt überhaupt wie gewünscht?
      G 1 Antwort Letzte Antwort
      • J Jan1
        @gluecksmann
        gluecksmann
        @jan1
        Jep, funktioniert...hierfür schon mal danke... ich überlege noch irgendwie einen Tür-Fensterkontakt einzubauen...bin mir aber noch unsicher wie/wo ... wenn ich einen Bewegungsmelder habe...könnte ich den z.B. als äußeren trigger setzen? Wenn keiner in der Nähe ist, braucht er nix zu sagen...
        • J Jan1
          @gluecksmann
               <value name="IF0">
                     </shadow>
                   </value>
                     </shadow>
                   </value>
                 </block>
               </value>
                   <value name="IF0">
                       <value name="A">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                   <value name="IF1">
                       <value name="A">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                 </block>
               </statement>
             </block>
           </statement>
          </block>
          gluecksmann
          @jan1
          Das Script läuft supeer...hatte die Idee es mit dem Fensterkontakt zu kombinieren... so als UND Block wenn Datenpunkt des Fensterkontaktes True ist... aber das scheint man nich einfach anhängen zu können, oder?
          • G gluecksmann
            @jan1
            Jan1
            @gluecksmann
            Du kannst als Bedingung so viele UND dran hängen wie Du willst
            • J Jan1
              @gluecksmann
              gluecksmann
              @jan1 würde ich gern tun...kann es aber Blockly nicht beibringen... gibt ja einen UND Block, aber das mit dem Datenpunkt des sensors bekomme ich nicht auf die reihe
              • G gluecksmann
                Jan1
                @gluecksmann
                poste doch das Blockly und sag wo Du was mit UND drin haben willst
                • J Jan1
                  @gluecksmann
                  gluecksmann
                  @jan1 Das ist das das Du mir am 28. gebaut hast.... möchte halt das er das mit dem Lüften nur sagt wenn der Wert übeschritten ist UND das Fenster zu ist...
                  • G gluecksmann
                    Jan1
                    @gluecksmann
                    welchen Wert hat der DP wenn das Fenster zu ist, true oder false?
                    • G Offline
                      gluecksmann
                      @jan1 False
                      • G gluecksmann
                        @jan1 False
                        Jan1
                        @gluecksmann
                        Den DP des Fenster Kontakt eintragen,fertig ;)
                        • J Jan1
                          @gluecksmann
                          gluecksmann
                          #66
                          @jan1 Ahhh...hab das UND immer hinten dranhängen wollen...
                          • G gluecksmann
                            Jan1
                            #67
                            @gluecksmann
                            Laut sprechen was gemacht werden soll und genau in der Reihenfolge die Blöcke setzten. Ist ne Logik und somit auch logisch ;)
                            Du meinst so:
                            Was mit dem ersten Blockly identisch ist und nur die Eingaänge des UND auf extren gewechselt, weil es so übersichtlicher ist.
                            • J Jan1
                              @gluecksmann
                              Du meinst so:
                              gluecksmann
                              #68
                              @jan1 wäre es auch gewesen mit dem UND hintereinander.... bekomme den UND Block nicht gebaut...
                              • G gluecksmann
                                Jan1
                                #69
                                @gluecksmann
                                rechte Maustaste und externe Eingänge. Gleiche Funktion, bessere Übersicht
                                • G Offline
                                  gluecksmann
                                  #70
                                  @jan1
                                  OK...also hinten dran hängen finde ich übersichtlicher... Aber raffe es noch nicht ganz...wieso kommt da nix mit true oder false?
                                  • G gluecksmann
                                    @jan1
                                    Jan1
                                    #71
                                    @gluecksmann
                                    Weil die FALLS immer auf true prüft und und "nicht false" ist nun mal true, somit brauchst keine zwei mal true
                                    G HomoranH 2 Antworten Letzte Antwort
                                    • J Jan1
                                      @gluecksmann
                                      gluecksmann
                                      #72
                                      @jan1 Und das sind die vielen kleinen Sachen die ich nicht weis
                                      • G gluecksmann
                                        Jan1
                                        #73
                                        @gluecksmann
                                        Jetzt schon ;)
                                        Schau mal, selbe Funktion und ein Block mehr:
                                        • J Jan1
                                          @gluecksmann
                                          #74
                                          @jan1 sagte in Anleitung Blockly für DAU:
                                          @gluecksmann
                                          das ist aber nicht basics im Sinne für Anfänger.
                                          Das kann man später mache, wenn man fitter ist.
                                          J G 2 Antworten Letzte Antwort
