  5. Anleitung Blockly für DAU
80 Beiträge 6 Kommentatoren 7.8k Aufrufe 4 Beobachtet
  • G gluecksmann
    @jan1
    Hoffe jetzt? der zweite Block stehst noch frei im Raum... dient lediglich zur Lieferung der Werte..
    Jan1
    @gluecksmann
    So sollte das schon funktionieren:
    <block xmlns="https://developers.google.com/blockly/xml" type="on" id="6`eH)U7+-CU%ym1p@{bY" x="88" y="-37">
     <field name="OID">netatmo.0.Wetter-(Indoor).Indoor.CO2.CO2</field>
     <statement name="STATEMENT">
       <block type="controls_if" id="W[NL;,zccoR^se){{N-d">
         <value name="IF0">
           <block type="time_compare_ex" id="i^Vp;_4+ya7Q%126=]~t">
             <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
             <field name="USE_ACTUAL_TIME">TRUE</field>
             <field name="OPTION">between</field>
             <value name="START_TIME">
               <shadow type="text" id="?O@j]!Ewf1D7BWQWBbE[">
                 <field name="TEXT">11:00</field>
               </shadow>
             </value>
             <value name="END_TIME">
               <shadow type="text" id="Lp.!/*1@?.RZwa~Vzqj}">
                 <field name="TEXT">22:00</field>
               </shadow>
             </value>
           </block>
         </value>
         <statement name="DO0">
           <block type="controls_if" id="95}Ru)T(c0Q6}5*c)3~l">
             <value name="IF0">
               <block type="logic_compare" id="T0E[xlA3Z7]p)8yH_,r`">
                 <field name="OP">GTE</field>
                 <value name="A">
                   <block type="on_source" id="-c)@?/aSgL4!gf^~oIZk">
                   </block>
                 </value>
                 <value name="B">
                   <block type="math_number" id="wRa$ZtA-m:irh/tFhwBg">
                     <field name="NUM">1000</field>
                   </block>
                 </value>
               </block>
             </value>
               <block type="control" id="ttfG(apHb|e~MufP5;Vx">
                 <field name="OID">alexa2.0.Echo-Devices.db670fafbbfc4ff5b16223f5d7b07624.Commands.speak</field>
                 <value name="VALUE">
                   <block type="text" id="5}z]W4Jp7;x+QSeVM9jg">
                     <field name="TEXT">Bitte lüften</field>
                   </block>
                 </value>
               </block>
             </statement>
             <value name="IF1">
               <block type="logic_compare" id="h.uqxN}$lcB*F,acfezc">
                 <field name="OP">LTE</field>
                 <value name="A">
                   <block type="on_source" id="%6(`%udQuy3)OiV3HUr_">
                   </block>
                 </value>
                 <value name="B">
                   <block type="math_number" id="~wN({SOxMAV!QktCs@Oo">
                     <field name="NUM">600</field>
                   </block>
                 </value>
               </block>
             </value>
             <statement name="DO1">
               <block type="control" id="a%ce$OCgX7NTP]EXCi@n">
                   <block type="text" id="O+IXDD=rL;`ix6yDLs^Q">
                     <field name="TEXT">Fenster kann zu</field>
                   </block>
                 </value>
               </block>
             </statement>
           </block>
         </statement>
       </block>
     </statement>
    </block>
    G 2 Antworten Letzte Antwort
    • J Jan1
      @gluecksmann
           <value name="IF0">
                 </shadow>
               </value>
                 </shadow>
               </value>
             </block>
           </value>
               <value name="IF0">
                   <value name="A">
                     </block>
                   </value>
                   <value name="B">
                     </block>
                   </value>
                 </block>
               </value>
                     </block>
                   </value>
                 </block>
               </statement>
               <value name="IF1">
                   <value name="A">
                     </block>
                   </value>
                   <value name="B">
                     </block>
                   </value>
                 </block>
               </value>
                     </block>
                   </value>
                 </block>
               </statement>
             </block>
           </statement>
         </block>
       </statement>
      </block>
      gluecksmann
      @jan1
      OK; danke... das versthe ich dann noch...aber bei zwei Datenpunkten steige ich gedanklich aus...
      • G gluecksmann
        @jan1
        Jan1
        @gluecksmann
        Sag wo es klemmt und ich erklär Dir wie es geht und funktioniert das jetzt überhaupt wie gewünscht?
        G 1 Antwort Letzte Antwort
        • J Jan1
          @gluecksmann
          gluecksmann
          @jan1
          Jep, funktioniert...hierfür schon mal danke... ich überlege noch irgendwie einen Tür-Fensterkontakt einzubauen...bin mir aber noch unsicher wie/wo ... wenn ich einen Bewegungsmelder habe...könnte ich den z.B. als äußeren trigger setzen? Wenn keiner in der Nähe ist, braucht er nix zu sagen...
          • J Jan1
            @gluecksmann
                 <value name="IF0">
                       </shadow>
                     </value>
                       </shadow>
                     </value>
                   </block>
                 </value>
                     <value name="IF0">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                     <value name="IF1">
                         <value name="A">
                           </block>
                         </value>
                         <value name="B">
                           </block>
                         </value>
                       </block>
                     </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </statement>
            </block>
            gluecksmann
            @jan1
            Das Script läuft supeer...hatte die Idee es mit dem Fensterkontakt zu kombinieren... so als UND Block wenn Datenpunkt des Fensterkontaktes True ist... aber das scheint man nich einfach anhängen zu können, oder?
            • G gluecksmann
              @jan1
              Jan1
              @gluecksmann
              Du kannst als Bedingung so viele UND dran hängen wie Du willst
              • J Jan1
                @gluecksmann
                gluecksmann
                @jan1 würde ich gern tun...kann es aber Blockly nicht beibringen... gibt ja einen UND Block, aber das mit dem Datenpunkt des sensors bekomme ich nicht auf die reihe
                • G gluecksmann
                  Jan1
                  @gluecksmann
                  poste doch das Blockly und sag wo Du was mit UND drin haben willst
                  • J Jan1
                    @gluecksmann
                    gluecksmann
                    @jan1 Das ist das das Du mir am 28. gebaut hast.... möchte halt das er das mit dem Lüften nur sagt wenn der Wert übeschritten ist UND das Fenster zu ist...
                    • G gluecksmann
                      Jan1
                      @gluecksmann
                      welchen Wert hat der DP wenn das Fenster zu ist, true oder false?
                      • G Offline
                        gluecksmann
                        @jan1 False
                        • G gluecksmann
                          @jan1 False
                          Jan1
                          @gluecksmann
                          Den DP des Fenster Kontakt eintragen,fertig ;)
                          • J Jan1
                            @gluecksmann
                            gluecksmann
                            #66
                            @jan1 Ahhh...hab das UND immer hinten dranhängen wollen...
                            • G gluecksmann
                              Jan1
                              #67
                              @gluecksmann
                              Laut sprechen was gemacht werden soll und genau in der Reihenfolge die Blöcke setzten. Ist ne Logik und somit auch logisch ;)
                              Du meinst so:
                              Was mit dem ersten Blockly identisch ist und nur die Eingaänge des UND auf extren gewechselt, weil es so übersichtlicher ist.
                              • J Jan1
                                @gluecksmann
                                Du meinst so:
                                gluecksmann
                                #68
                                @jan1 wäre es auch gewesen mit dem UND hintereinander.... bekomme den UND Block nicht gebaut...
                                • G gluecksmann
                                  Jan1
                                  #69
                                  @gluecksmann
                                  rechte Maustaste und externe Eingänge. Gleiche Funktion, bessere Übersicht
                                  • G Offline
                                    gluecksmann
                                    #70
                                    @jan1
                                    OK...also hinten dran hängen finde ich übersichtlicher... Aber raffe es noch nicht ganz...wieso kommt da nix mit true oder false?
                                    • G gluecksmann
                                      @jan1
                                      Jan1
                                      #71
                                      @gluecksmann
                                      Weil die FALLS immer auf true prüft und und "nicht false" ist nun mal true, somit brauchst keine zwei mal true
                                      G HomoranH 2 Antworten Letzte Antwort
                                      • J Jan1
                                        @gluecksmann
                                        gluecksmann
                                        #72
                                        @jan1 Und das sind die vielen kleinen Sachen die ich nicht weis
                                        • G gluecksmann
                                          Jan1
                                          #73
                                          @gluecksmann
                                          Jetzt schon ;)
                                          Schau mal, selbe Funktion und ein Block mehr:
