  4. [gelöst] Backup und Restore
    6.5k
59 Beiträge 16 Kommentatoren 38.3k Aufrufe
    SigiMOE
    keine Ahnung, ob man es muss…..
    aber bei mir geht es definitiv nicht....
    weder als root
    root@raspberrypi:~# iobroker backup
    /opt/iobroker/node_modules/tar.gz/node_modules/bluebird/js/main/generators.js:62
            var maybePromise = tryConvertToPromise(value, this._promise�;
    SyntaxError: Invalid or unexpected token
        at Object.exports.runInThisContext (vm.js:76:16)
        at Module._compile (module.js:542:28)
        at Object.Module._extensions..js (module.js:579:10)
        at Module.load (module.js:487:32)
        at tryModuleLoad (module.js:446:12)
        at Function.Module._load (module.js:438:3)
        at Module.require (module.js:497:17)
        at require (internal/module.js:20:19)
        at module.exports (/opt/iobroker/node_modules/tar.gz/node_modules/bluebird/js/main/promise.js:721:1)
        at Object. <anonymous>(/opt/iobroker/node_modules/tar.gz/node_modules/bluebird/js/main/bluebird.js:9:39)
        at Module._compile (module.js:570:32)
    root@raspberrypi:~#</anonymous>
    und auch als pi
    user
    pi@raspberrypi:~ $ iobroker backup
    fs.js:640
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
    Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
        at Error (native)
        at Object.fs.openSync (fs.js:640:18)
        at Object.fs.writeFileSync (fs.js:1333:33)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:253:24
        at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:150:27)
        at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
        at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
        at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
        at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    pi@raspberrypi:~ $</anonymous></anonymous>
    leider kein erfolg ….
    was kann ich noch machen ?
      @SigiMOE:
      was kann ich noch machen ? `
      vorher in den Installationsordner wechseln:
      cd /opt/iobroker
      und danach dann ein:
      sudo iobroker backup
      du bist ja nur "pi"
      • C Offline
        chemieka
        Also ich konnte mit Putty auch ohne in den Ordner zu wechseln nur mit den einen Befehl.
        Mit root eingeloggt.
        Zusätzlich bin ich mit WinScp drauf gegangen und habe mir eine zip Datei vom Ordner opt gemacht.
        Damit sollte ich auf der sicheren Seite sein.
          SigiMOE
          @Homoran:
          @SigiMOE:
          cd /opt/iobroker
          du bist ja nur "pi"
          Rainer `
          hat leider nicht geklappt :-(
          root@raspberrypi:~# cd /opt/iobroker
          root@raspberrypi:/opt/iobroker# sudo iobroker backup
          root@raspberrypi:/opt/iobroker#</anonymous>
          Noch eine Idee ?
          als pi user geht es auch nicht…
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ sudo iobroker backup
          pi@raspberrypi:/opt/iobroker $</anonymous>
          • C Offline
            chemieka
            Ich glaube ich habe den Befehl ohne sudo eingegeben.
              Sven2013
              @mariohbs:
              Hi Leute,
              ich habe gerade nach der Anleitung aus den FAQ ein Backup vom IoBroker erstellt und per SFTP vom Raspi geholt. `
              Hallo Mario,
              ich habe das Backup bereits erstellt, hänge aber an dem oben genannten Punkt per SFTP vom raspi geholt.
              Kannst du mir vielleicht nochmal kurz beschreiben wie du die Daten von deinem Raspi auf beispielsweise die Synology bringst?
              Ich hatte mal eine funktionierende Lösung, bekomme diese aber leider nicht mehr zum laufen.
              Danke dafür Gruß Sven
                mariohbs
                Hi Sven,
                also ich habe es nur auf meinem Windows PC geholt, dass ganz einfach mit FileZilla.
                Genau ist es hier beschrieben: https://jankarres.de/2015/01/raspberry- … filezilla/
                Viele Grüße
                Mario
                • chucky666C Online
                  chucky666C Online
                  chucky666
                  @Solear:
                  ja das ist richtig so.
                  Ich habe es eben durchprobiert mit einem Umzug von VM zu Raspi.
                  Du erstellst ein Backup mit folgender Eingabe im Terminal:
                  iobroker backup
                  Jetzt ist im Verzeichnis /opt/iobroker/backups eine tar.gz Datei. Die sicherst du dir am besten weg. Da die so klein ist, kann man die auch an sich selbst per Mail ab und an senden. Nichts ist schlimmer als seine ganzen Skripte zu verlieren, also ruhig machen.
                  Zur Wiederherstellung habe ich ein jungfräuliches iobroker auf dem Raspi nach der bekannten Anleitung erstellt:
                  http://www.iobroker.net/docu/?page_id=5106&lang=de
                  Dann die Backupdatei wieder einkopiert (der Backup-Ordner existiert noch nicht, ihn also da bei /opt/iobroker/backups anlegen).
                  Jetzt im Terminal die Befehle eingeben (https://github.com/ioBroker/ioBroker/wi … ker-backup):
                  sudo iobroker stop
                  sudo iobroker restore 0 [restore 0 sagt, nehme letzte Backup]
                  iobroker start all [Adapter werden aktiviert]
                  sudo iobroker start
                  Jetzt eine Weile warten! Ganz wichtig! Man kann sich auf die admin-Webseite einloggen und sieht im Log dann, wie er nach und nach die Adapter automatisch installiert. Wenn sich alles beruhigt hat, die Adaptereinstellungen nochmal durchgehen. Ich musste nur beim Adapter hm-rpc die richtige CCU2-IP auswählen. Und in der Telegramm App das Passwort noch einmal neu bestätigen.
                  Es sind alle Einstellungen, Adaptereinstellungen und Skripte fehlerfrei bei mir übernommen worden. Wie das mit VIS aussieht weiß ich nicht, ich nutze VIS nicht. `
                  Wie kann man sich das Backup per Mail schicken?
                    Solear
                    @chucky666:
                    Wie kann man sich das Backup per Mail schicken? `
                    Vom Raspi aus per Terminal?
                    Erstmal Mailfunktionen installieren:
                    sudo apt-get install ssmtp
                    sudo apt-get install mailutils
                    sudo apt-get install mpack
                    Danach die Mailkonfiguration (Beispiel Gmail) anpassen:
                    sudo nano /etc/ssmtp/ssmtp.conf
                    root=meine@gmail.com
                    mailhub=smtp.gmail.com:587
                    hostname=raspberrypi
                    rewriteDomain=gmail.com
                    AuthUser=meine@gmail.com
                    AuthPass=GmailPasswort
                    FromLineOverride=YES
                    UseSTARTTLS=YES
                    Jetzt kann man die Datei mailen:
                    mpack -s "iobroker Backup" /opt/iobroker/backups/xxxDateinamexxx.tar.gz empfänger@domain.com
                    Nicht getestet, sollte aber funzen.
                    Das wäre eigentlich ein toller Cronjob für den Raspi. Jede Nacht oder wöchentlich iobroker beenden, backup erzeugen, iobroker starten, mail senden.
                    iobroker als LXC unter Proxmox
                    • chucky666C Online
                      chucky666C Online
                      chucky666
                      Danke teste es nachher
                        Solear
                        Es klappt. Habs gerade mit einer all-inkl. Mailadresse ausprobiert :mrgreen:
                          Sven2013
                          ich erstelle momentan immer das Backup per Hand und sichere es dann per Hand auf meiner synology.
                          Diesen Vorgenag hatte ich schonmal automatisiert. Leider habe ich nach einem Systemausfall den Raspi gegen ein Cubieboard getauscht.
                          Nunhabe ich leider keine Ahnung mehr wie ich das damals (mit der Hilfe von Brati) geschafft habe.
                          Ich hatte vorher folgenden Ablauf:
                          io broker stop
                          backup iobroker
                          daraus entstand die Datei: /opt/iobroker/backups/2017_03_10-09_27_20_backupiobroker.tar.gz
                          Nun weiß ich nicht mehr genau, ob die Synology die Datei auf dem cubie abgeholt hat oder ob der cubie die Dtei automatisch an die Synology geschickt hat.
                          Es wurden dann 7 Sicherungen gespeichert und dann überschrieben.
                          Kann mir da nochmal jemand weiterhelfen um das wieder eingerichtet zu bekommen?
                          Gruß Sven
                            klassisch
                            Auf meinem Raspi habe ich jetzt einen Effekt wie obe schon mal beschrieben:
                            root@Raspi-2-1-iobroker:/opt/iobroker# sudo iobroker backup
                            /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/node_modules/read-pkg-up/node_modules/read-pkg/node_modules/load-json-file/node_modules/graceful-fs/polyfills.js:216
                                  } filally {
                            SyntaxError: Missing catch or finally after try
                                at exports.runInThisContext (vm.js:53:16)
                                at Module._compile (module.js:373:25)
                                at Object.Module._extensions..js (module.js:416:10)
                                at Module.load (module.js:343:32)
                                at Function.Module._load (module.js:300:12)
                                at Module.require (module.js:353:17)
                                at require (internal/module.js:12:17)
                                at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/node_modules/read-pkg-up/node_modules/read-pkg/node_modules/load-json-file/node_modules/graceful-fs/graceful-fs.js:2:17)
                                at Module._compile (module.js:409:26)
                            root@Raspi-2-1-iobroker:/opt/iobroker#</anonymous>
                            Habe in der Vergangenheit schon etliche backups gemacht, aber so etwas hatte ich noch nie. Was kann ich tun? Ich will vom Raspi auf einen OrangePi umziehen.
                            • chucky666C Online
                              chucky666C Online
                              chucky666
                              Hallo
                              Kann man das Backup auch per Telegram verschicken ?
                              Gesendet von iPad mit Tapatalk Pro
                              • kmxakK Offline
                                kmxakK Offline
                                kmxak
                                du könntest über ein Button sowas auslösen
                                on({id: 'taster hier hin', val: true}, function() {
                                sendTo('telegram', '/opt/iobroker/backups/*.tar.gz');
                                log("Backup verschickt");
                                Ungetestet den trigger kann man bestimmt noch ändern. Und das send to anpassen das er immer die letzte datei nimmt oder vor dem backup halt den ordner säubern.
                                ob *.tar.gz geht oder ob da der genaue dateiname stehen muss weiß ich auch nicht+
                                das script an sich funktioniert aber mit dem datein senden.
                                Auch weiß ich nicht wieviel mb verschickt werden können.
                                Gruß Alex
                                • chucky666C Online
                                  chucky666C Online
                                  chucky666
                                  Klappt leider nicht
                                  • kmxakK Offline
                                    kmxakK Offline
                                    kmxak
                                    was genau klappt nicht?
                                    kann telegram überhaupt ein archiv verschicken?
                                    Gruß Alex
                                    • Espace0401E Offline
                                      Espace0401E Offline
                                      Espace0401
                                      Lassen sich eigentlich auch von einzelnen Adapter backups erstellen und wiederherstellen? Die Frage bezieht sich in erster Linie auf yahka, weil man dort immer eine Menge Arbeit reinstecken muss, falls man von Hand alles neu einrichten muss.
                                      Iobroker in LXC-Container auf Proxmox 8 - Sicherung auf PBS - Homematic CCU2 - Netatmo Wetterstation und Thermostat
                                      • Mr. BurnsM Offline
                                        Mr. BurnsM Offline
                                        Mr. Burns
                                        ich möchte gerne ein Backup in ein neues System einspielen.
                                        Ich hatte einen Raspberry Pi 2 B und jetzt einen Raspberry Pi 3B+. Die alte installation ist noch vorhanden läuft aber nicht mehr rund.
                                        Ich habe ein Backup erstellt und wollte dies gerne einspielen:
                                        sudo ioBroker stop
                                        sudo mkdir /opt/iobroker/backup/
                                        per Cyberduck, die Backup-Datei in den o.g. Ordner übertragen
                                        cd /opt/iobroker/backup/
                                        iobroker restore 0 (alternativ auch mit dem Dateinamen probiert)
                                        ich erhielt folgendes zurück:
                                        host.ioBroker Cannot find /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/2018_07_09-11_46_19_backupiobroker.tar.gz
                                        Das update wurde nicht eingespielt, ich habe zumindest keine Werte, Adapter oder VIS Bilder in der neuen Installation.
                                        Weiß einer von euch was ich evtl. falsch mache?
                                        Thomas
                                          @Mr. Burns:
                                          Weiß einer von euch was ich evtl. falsch mache? `
                                          Yepp!
                                          @Mr. Burns:
                                          sudo mkdir /opt/iobroker/backup/ `
                                          ~~@[url=http://www.iobroker.net/docu/?page_id=2380⟨=de:~~
                                          ~~Doku"]~~man ruft in der Konsole unter /opt/iobroker den Befehl auf: ./iobroker backup
                                          Daraufhin erstellt iobroker in dem Verzeichnis /opt/iobroker/backups eine gepackte Datei mit Datum im Dateinamen, z.B.: 2015_04_17-22_30_47_backupIoBroker.tar.gz `
                                          Dir fehlt zumindest ein S
