  • BanditFGB BanditFG
    shuttercontrol.0
    4889	2021-12-01 13:30:02.109	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
    shuttercontrol.0
    4889	2021-12-01 13:30:02.109	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    4889	2021-12-01 13:30:00.046	debug	Sun Elevation: 14.4°
    shuttercontrol.0
    4889	2021-12-01 13:30:00.045	debug	Sun Azimut: 202.5°
    shuttercontrol.0
    4889	2021-12-01 13:30:00.045	debug	calculate astrodata ...
    shuttercontrol.0
    4889	2021-12-01 13:28:07.643	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
    shuttercontrol.0
    4889	2021-12-01 13:28:07.643	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    4889	2021-12-01 13:28:05.642	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d0002321724.temperature Value: 18.54
    shuttercontrol.0
    4889	2021-12-01 13:28:02.558	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
    shuttercontrol.0
    4889	2021-12-01 13:28:02.558	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    4889	2021-12-01 13:28:00.557	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d000249074a.temperature Value: 19.87
    shuttercontrol.0
    4889	2021-12-01 13:27:44.046	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
    shuttercontrol.0
    4889	2021-12-01 13:27:44.046	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    4889	2021-12-01 13:27:42.046	debug	outsidetemperature changed: viessmannapi.0.241772.0.features.heating.sensors.temperature.outside.properties.value.value Value: 6.1
    shuttercontrol.0
    4889	2021-12-01 13:27:22.681	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
    shuttercontrol.0
    4889	2021-12-01 13:27:22.681	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    shuttercontrol.0
    4889	2021-12-01 13:27:20.680	debug	insidetemperature changed: mihome.0.devices.weather_v1_158d000224ce57.temperature Value: 16.07
    shuttercontrol.0
    4889	2021-12-01 13:27:11.534	debug	status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false
    shuttercontrol.0
    4889	2021-12-01 13:27:11.534	debug	start pendingAlarm to check if an alarm is currently pending (exept frost)
    ich habe nen auch v1.4.1 instlliert und bekomme ständig diese Meldung
    simatecS Offline
    simatecS Offline
    simatec
    #3980
    @banditfg Ja ist ja der debuglog. Da wird alles was im Adapter passiert angezeigt. So wie es ausschaut, reagiert der Adapter nur auf Änderungen deines Temperatursensors ...
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • BanditFGB Offline
      BanditFGB Offline
      BanditFG
      schrieb am zuletzt editiert von BanditFG
      #3981
      @simatec
      ich hab auch mit v1.4.1 das Problem das der Wert von Alarm Frost Höhe verschwindet.
      und zwar so reproduzierbar:
      ich öffne über den Schraubenschlüssel bei der Shuttercontrol Instanz die Einstellung --> Extra Einstellungen -> Alarm Einstellungen -> gebe dort bei Alarm Frost Höhe den Wert 15 ein und klicke unten auf SPEICHERN
      dann gehen ich auf Haupteinstellungen wähle einen Rollladen über den Stift aus, schaue mir die Einstellungen da an und klicke unten wieder OK
      gehe ich dann wieder dort hin wo der Wert für Alarm Frost Höhe eingeben wird ist das Feld leer!!!
      mach ich irgendwas falsch????
      PS: nicht nur das Feld für Alarm Frost Höhe, sondern auch die anderen 5 Werte sind weg...
      simatecS amg_666A 2 Antworten Letzte Antwort
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        #3982
        @banditfg Die Funktion habe ich nicht eingebaut und muss ich mir anschauen ... Aber ich habe eine Vermutung
        BanditFGB 1 Antwort Letzte Antwort
        • simatecS simatec
          BanditFGB Offline
          BanditFGB Offline
          BanditFG
          #3983
          @simatec alle 5 Werte verschwinden so, nur die Auslöser Objekt IDs bleiben drin.
            @simatec
            amg_666A Offline
            amg_666A Offline
            amg_666
            #3984
            @banditfg Kann ich bestätigen. Ich nutze die Alarme nicht und da standen irgendwelche Defaultwerte drin (Bei Frosthöhe war es 80). Ich habe jetzt genau die Schritte von dir nachvollzogen und jetzt sind da alle Werte leer.
            Und weil ich Firefox nutze habe ich sicherheitshalber auch nochmal den Cache gelöscht, das hat aber nix gebracht, scheint ein bug im Adapter zu sein.
            simatecS 2 Antworten Letzte Antwort
            • amg_666A amg_666
              simatecS Offline
              simatecS Offline
              simatec
              #3985
              @amg_666 Wird gefixt ...
              • amg_666A amg_666
                simatecS Offline
                simatecS Offline
                simatec
                #3986
                @amg_666 Bugfix ist bereits auf Github und kommt mit der nächsten Version
                F 1 Antwort Letzte Antwort
                • simatecS simatec
                  Fortune95
                  #3987
                  @simatec
                  Hi, habe das Problem das wenn das Fenster zum Zeitpunkt des Öffnen oder Schließen offen ist, der Rolladen nach dem schließen des Fensters immer in die entgegengesetzte Richtung fährt.
                  Er wird aber zum eingestellten Zeitpunkt hoch oder auch runter gefahren. Der jeweilige Auto State geht dann von "up/down" auf "None". Der Fensterkontakt liefert nur 2 Zustände. Habe daher die ergänzte Einstellung für "Wert des Fenster/Tür Sensors im angekippten Zustand" auf keins gestellt. Das Problem existiert seitdem diese Option ergänzt wurde.
                  • F Fortune95
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #3988
                    @fortune95 Bitte poste deine Config und dem Debuglog vom Vorgang vom Fenster öffnen und schließen.
                    Dazu bitte die installierte Version
                    • simatecS simatec
                      Fortune95
                      #3989
                      @simatec
                      Installiert ist die neuste v1.4.1.
                      Reicht das so oder benötigst du die gesamte Config als Export?
                      2021-12-01 17:43:21.270 - info: shuttercontrol.0 (11888) Button openLiving Set ID: Büro value: 0%
                      2021-12-01 17:43:21.304 - debug: shuttercontrol.0 (11888) shutterUpButton Büro old height: 100% new height: 0%
                      2021-12-01 17:43:27.286 - debug: shuttercontrol.0 (11888) start buttonAction
                      2021-12-01 17:43:27.296 - debug: shuttercontrol.0 (11888) shutterUpButton Büro already up at: 0% - setting current action: up
                      2021-12-01 17:43:52.354 - debug: shuttercontrol.0 (11888) TriggerID changed: alias.0.Büro.Fensterkontakt_Buero.ACTUAL Value: 1
                      2021-12-01 17:43:52.358 - debug: shuttercontrol.0 (11888) Büro - shutter conversion is:true
                      2021-12-01 17:43:52.372 - debug: shuttercontrol.0 (11888) Büro - shutter trigger drive-up is:70
                      2021-12-01 17:43:52.373 - debug: shuttercontrol.0 (11888) Büro - shutter trigger change is:upDown
                      2021-12-01 17:43:52.374 - debug: shuttercontrol.0 (11888) #2 save trigger action: up for device: Büro
                      2021-12-01 17:43:52.375 - debug: shuttercontrol.0 (11888) #2 save trigger height: 0% for device: Büro
                      2021-12-01 17:45:00.050 - debug: shuttercontrol.0 (11888) check in time 01.03. 30.09.
                      2021-12-01 17:45:00.052 - debug: shuttercontrol.0 (11888) Start Mon Mar 01 2021
                      2021-12-01 17:45:00.053 - debug: shuttercontrol.0 (11888) End Thu Sep 30 2021
                      2021-12-01 17:45:00.053 - debug: shuttercontrol.0 (11888) we are not in period, after start Mon Mar 01 2021 and before end Thu Sep 30 2021
                      2021-12-01 17:45:00.055 - debug: shuttercontrol.0 (11888) check xmas for Büro
                      2021-12-01 17:45:00.101 - debug: shuttercontrol.0 (11888) calculate astrodata ...
                      2021-12-01 17:45:00.102 - debug: shuttercontrol.0 (11888) Sun Azimut: 249°
                      2021-12-01 17:45:00.102 - debug: shuttercontrol.0 (11888) Sun Elevation: -11.2°
                      2021-12-01 17:45:00.119 - info: shuttercontrol.0 (11888) Living down #17 Set ID: Büro value: 100%
                      2021-12-01 17:45:00.135 - debug: shuttercontrol.0 (11888) last automatic Action for Büro: Down_LivingTime
                      2021-12-01 17:45:00.136 - debug: shuttercontrol.0 (11888) shutterDownLiving #1 Büro old height: 0% new height: 100%
                      2021-12-01 17:45:44.823 - debug: shuttercontrol.0 (11888) TriggerID changed: alias.0.Büro.Fensterkontakt_Buero.ACTUAL Value: 0
                      2021-12-01 17:45:44.825 - debug: shuttercontrol.0 (11888) Büro - shutter conversion is:true
                      2021-12-01 17:45:44.833 - debug: shuttercontrol.0 (11888) Büro - shutter current state.val is:100
                      2021-12-01 17:45:44.834 - debug: shuttercontrol.0 (11888) Büro - shutter current Height is:100
                      2021-12-01 17:45:44.834 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Height is:0
                      2021-12-01 17:45:44.835 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Action is:up
                      2021-12-01 17:45:44.835 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Change is:upDown
                      2021-12-01 17:45:44.840 - info: shuttercontrol.0 (11888) Window is still closed -> drive to last height: Set ID: Büro value: 0%
                      2021-12-01 17:45:44.853 - debug: shuttercontrol.0 (11888) save back trigger action: up for device: Büro
                      • F Fortune95
                        @simatec
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #3990
                        @fortune95 danke dir … Ich schaue mir das mal an
                        • F Fortune95
                          @simatec
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #3991
                          @fortune95 Kannst du bitte Schritt für Schritt erklären, was wann bei dir passiert? Ich kann dein Fehler aktuell so nicht nachstellen und nachvollziehen.
                          • Nightfly1983N Offline
                            Nightfly1983
                            #3992
                            Habe gestern mit der Version 1.4.1 nochmal die Weihnachtseinstellungen probiert und mich gefreut wie ein Schnitzel, denn alle Rollläden sind bei den entsprechenden Fenstern auf ihre Weihnachtsposition gefahren. Jedoch kam die Ernüchterung heute Morgen, denn 23Uhr sind die entsprechenden Rollläden dann leider nicht komplett wie eingestellt zu gefahren.
                            Werde es nochmal im Debug anschauen und berichten, evtl. fehlte eine Einstellung.
                            B simatecS 2 Antworten Letzte Antwort
                            • Nightfly1983N Nightfly1983
                              biker1602
                              #3993
                              @nightfly1983 Also bei mir funktioniert das tadellos. Sie fahren bei Sonnenuntergang auf 50% runter und so wie ich es eingestellt habe um 23 Uhr ganz runter. Ich bin begeistert. Das ging aber auch schon davor bei mir.
                                Tom Haase
                                #3994
                                möchte auch eine kurze Rückmeldung geben.
                                Habe von der V. 1.1.5 auf die 1.38 jetzt 1.41 updatet. Ich hatte damals (im Januar ´21, siehe oben) Probleme mit den Fensterkontakten. Diese Probleme konnte @FoxRo lösen und die Lösung ist dann später in den Code mit eingeflossen. Die Steuerung funktionierte bis zum Update in der letzten Woche einwandfrei!
                                Nach dem Update fahren plötzlich nicht mehr alle Rolläden, also auch solche ohne Fensterkontakte. Und die mit den Kontakten funktionieren auch nicht mehr beim öffnen und schließen wie bisher.
                                Habe gegenwärtig leider überhaupt nicht die Zeit hier mehr zu liefern, also wichtige Logs und Debugs.... Ich möchte nur kurze Rückmeldung geben, dass die aktuelle Version wohl noch nicht rund läuft. Möchte aber auch sagen, dass ich mit Shuttercontrol bisher sehr zufrieden bin.
                                Danke @simatec für deine Arbeit.
                                lg
                                tom
                                • simatecS simatec
                                  Fortune95
                                  #3995
                                  @simatec
                                  Heute Morgen hat alles funktioniert! :-)
                                  • T Tom Haase
                                    lg
                                    tom
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #3996
                                    @tom-haase Hast du nach dem Update die Einstellungen der Rollläden angepasst? Hier sollten die Kippfunktionen der Fensterkontakte auch konfiguriert werden. Wenn du keine hast, dann auf "keins" stellen
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #3997
                                      @nightfly1983 Wie sehen deinen Einstellungen denn aus und welche Version ist installiert?
                                      Nightfly1983N 1 Antwort Letzte Antwort
                                      • simatecS simatec
                                        Nightfly1983
                                        #3998
                                        @simatec Version ist seit gestern 1.4.1
                                        Einstellungen würde ich heute Nachmittag mal reinstellen und nochmal kontrollieren, nicht dass durch das Update was deaktiviert wurde.
                                        • simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #3999
                                          Ab sofort steht die Version 1.4.2 auf Github und in kürze auch im latest zur Verfügung.
                                          Changelog
                                          1.4.2 (2021-12-02)
                                          • (simatec) Bugfix Alarm settings
                                          • (simatec) Bugfix move shutter after closing window
                                          • (simatec) better translation for all languages
                                          • (simatec) small Bugfixes
