Test Adapter shuttercontrol v1.6.x
@amg_666 Bitte alles intensiv testen. Da in shuttercontrol inzwischen zu viele Funktionen hinzu kamen und der Adapter in seinen Code Bausteinen explodierte, habe ich alles umgeschrieben ... Hoffe der Fehlerteufel hat sich dabei nirgends eingeschlichen
shuttercontrol.0 4889 2021-12-01 13:30:02.109 debug status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false shuttercontrol.0 4889 2021-12-01 13:30:02.109 debug start pendingAlarm to check if an alarm is currently pending (exept frost) shuttercontrol.0 4889 2021-12-01 13:30:00.046 debug Sun Elevation: 14.4° shuttercontrol.0 4889 2021-12-01 13:30:00.045 debug Sun Azimut: 202.5° shuttercontrol.0 4889 2021-12-01 13:30:00.045 debug calculate astrodata ... shuttercontrol.0 4889 2021-12-01 13:28:07.643 debug status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false shuttercontrol.0 4889 2021-12-01 13:28:07.643 debug start pendingAlarm to check if an alarm is currently pending (exept frost) shuttercontrol.0 4889 2021-12-01 13:28:05.642 debug insidetemperature changed: mihome.0.devices.weather_v1_158d0002321724.temperature Value: 18.54 shuttercontrol.0 4889 2021-12-01 13:28:02.558 debug status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false shuttercontrol.0 4889 2021-12-01 13:28:02.558 debug start pendingAlarm to check if an alarm is currently pending (exept frost) shuttercontrol.0 4889 2021-12-01 13:28:00.557 debug insidetemperature changed: mihome.0.devices.weather_v1_158d000249074a.temperature Value: 19.87 shuttercontrol.0 4889 2021-12-01 13:27:44.046 debug status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false shuttercontrol.0 4889 2021-12-01 13:27:44.046 debug start pendingAlarm to check if an alarm is currently pending (exept frost) shuttercontrol.0 4889 2021-12-01 13:27:42.046 debug outsidetemperature changed: viessmannapi.0.241772.0.features.heating.sensors.temperature.outside.properties.value.value Value: 6.1 shuttercontrol.0 4889 2021-12-01 13:27:22.681 debug status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false shuttercontrol.0 4889 2021-12-01 13:27:22.681 debug start pendingAlarm to check if an alarm is currently pending (exept frost) shuttercontrol.0 4889 2021-12-01 13:27:20.680 debug insidetemperature changed: mihome.0.devices.weather_v1_158d000224ce57.temperature Value: 16.07 shuttercontrol.0 4889 2021-12-01 13:27:11.534 debug status alarm pending for hm-rpc.0.OEQ1299293.1.LEVEL: false shuttercontrol.0 4889 2021-12-01 13:27:11.534 debug start pendingAlarm to check if an alarm is currently pending (exept frost)
ich habe nen auch v1.4.1 instlliert und bekomme ständig diese Meldung
@banditfg Ja ist ja der debuglog. Da wird alles was im Adapter passiert angezeigt. So wie es ausschaut, reagiert der Adapter nur auf Änderungen deines Temperatursensors ...
ich hab auch mit v1.4.1 das Problem das der Wert von Alarm Frost Höhe verschwindet.
und zwar so reproduzierbar:
ich öffne über den Schraubenschlüssel bei der Shuttercontrol Instanz die Einstellung --> Extra Einstellungen -> Alarm Einstellungen -> gebe dort bei Alarm Frost Höhe den Wert 15 ein und klicke unten auf SPEICHERN
dann gehen ich auf Haupteinstellungen wähle einen Rollladen über den Stift aus, schaue mir die Einstellungen da an und klicke unten wieder OK
gehe ich dann wieder dort hin wo der Wert für Alarm Frost Höhe eingeben wird ist das Feld leer!!!
mach ich irgendwas falsch????
PS: nicht nur das Feld für Alarm Frost Höhe, sondern auch die anderen 5 Werte sind weg...
@banditfg Die Funktion habe ich nicht eingebaut und muss ich mir anschauen ... Aber ich habe eine Vermutung
@simatec alle 5 Werte verschwinden so, nur die Auslöser Objekt IDs bleiben drin.
@banditfg Kann ich bestätigen. Ich nutze die Alarme nicht und da standen irgendwelche Defaultwerte drin (Bei Frosthöhe war es 80). Ich habe jetzt genau die Schritte von dir nachvollzogen und jetzt sind da alle Werte leer.
Und weil ich Firefox nutze habe ich sicherheitshalber auch nochmal den Cache gelöscht, das hat aber nix gebracht, scheint ein bug im Adapter zu sein. -
@amg_666 Wird gefixt ...
@amg_666 Bugfix ist bereits auf Github und kommt mit der nächsten Version
Hi, habe das Problem das wenn das Fenster zum Zeitpunkt des Öffnen oder Schließen offen ist, der Rolladen nach dem schließen des Fensters immer in die entgegengesetzte Richtung fährt.
Er wird aber zum eingestellten Zeitpunkt hoch oder auch runter gefahren. Der jeweilige Auto State geht dann von "up/down" auf "None". Der Fensterkontakt liefert nur 2 Zustände. Habe daher die ergänzte Einstellung für "Wert des Fenster/Tür Sensors im angekippten Zustand" auf keins gestellt. Das Problem existiert seitdem diese Option ergänzt wurde. -
@fortune95 Bitte poste deine Config und dem Debuglog vom Vorgang vom Fenster öffnen und schließen.
Dazu bitte die installierte Version -
@simatec
Installiert ist die neuste v1.4.1.
Reicht das so oder benötigst du die gesamte Config als Export?2021-12-01 17:43:21.270 - info: shuttercontrol.0 (11888) Button openLiving Set ID: Büro value: 0% 2021-12-01 17:43:21.304 - debug: shuttercontrol.0 (11888) shutterUpButton Büro old height: 100% new height: 0% 2021-12-01 17:43:27.286 - debug: shuttercontrol.0 (11888) start buttonAction 2021-12-01 17:43:27.296 - debug: shuttercontrol.0 (11888) shutterUpButton Büro already up at: 0% - setting current action: up 2021-12-01 17:43:52.354 - debug: shuttercontrol.0 (11888) TriggerID changed: alias.0.Büro.Fensterkontakt_Buero.ACTUAL Value: 1 2021-12-01 17:43:52.358 - debug: shuttercontrol.0 (11888) Büro - shutter conversion is:true 2021-12-01 17:43:52.372 - debug: shuttercontrol.0 (11888) Büro - shutter trigger drive-up is:70 2021-12-01 17:43:52.373 - debug: shuttercontrol.0 (11888) Büro - shutter trigger change is:upDown 2021-12-01 17:43:52.374 - debug: shuttercontrol.0 (11888) #2 save trigger action: up for device: Büro 2021-12-01 17:43:52.375 - debug: shuttercontrol.0 (11888) #2 save trigger height: 0% for device: Büro 2021-12-01 17:45:00.050 - debug: shuttercontrol.0 (11888) check in time 01.03. 30.09. 2021-12-01 17:45:00.052 - debug: shuttercontrol.0 (11888) Start Mon Mar 01 2021 2021-12-01 17:45:00.053 - debug: shuttercontrol.0 (11888) End Thu Sep 30 2021 2021-12-01 17:45:00.053 - debug: shuttercontrol.0 (11888) we are not in period, after start Mon Mar 01 2021 and before end Thu Sep 30 2021 2021-12-01 17:45:00.055 - debug: shuttercontrol.0 (11888) check xmas for Büro 2021-12-01 17:45:00.101 - debug: shuttercontrol.0 (11888) calculate astrodata ... 2021-12-01 17:45:00.102 - debug: shuttercontrol.0 (11888) Sun Azimut: 249° 2021-12-01 17:45:00.102 - debug: shuttercontrol.0 (11888) Sun Elevation: -11.2° 2021-12-01 17:45:00.119 - info: shuttercontrol.0 (11888) Living down #17 Set ID: Büro value: 100% 2021-12-01 17:45:00.135 - debug: shuttercontrol.0 (11888) last automatic Action for Büro: Down_LivingTime 2021-12-01 17:45:00.136 - debug: shuttercontrol.0 (11888) shutterDownLiving #1 Büro old height: 0% new height: 100% 2021-12-01 17:45:44.823 - debug: shuttercontrol.0 (11888) TriggerID changed: alias.0.Büro.Fensterkontakt_Buero.ACTUAL Value: 0 2021-12-01 17:45:44.825 - debug: shuttercontrol.0 (11888) Büro - shutter conversion is:true 2021-12-01 17:45:44.833 - debug: shuttercontrol.0 (11888) Büro - shutter current state.val is:100 2021-12-01 17:45:44.834 - debug: shuttercontrol.0 (11888) Büro - shutter current Height is:100 2021-12-01 17:45:44.834 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Height is:0 2021-12-01 17:45:44.835 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Action is:up 2021-12-01 17:45:44.835 - debug: shuttercontrol.0 (11888) Büro - shutter trigger Change is:upDown 2021-12-01 17:45:44.840 - info: shuttercontrol.0 (11888) Window is still closed -> drive to last height: Set ID: Büro value: 0% 2021-12-01 17:45:44.853 - debug: shuttercontrol.0 (11888) save back trigger action: up for device: Büro
@fortune95 danke dir … Ich schaue mir das mal an
@fortune95 Kannst du bitte Schritt für Schritt erklären, was wann bei dir passiert? Ich kann dein Fehler aktuell so nicht nachstellen und nachvollziehen.
Habe gestern mit der Version 1.4.1 nochmal die Weihnachtseinstellungen probiert und mich gefreut wie ein Schnitzel, denn alle Rollläden sind bei den entsprechenden Fenstern auf ihre Weihnachtsposition gefahren. Jedoch kam die Ernüchterung heute Morgen, denn 23Uhr sind die entsprechenden Rollläden dann leider nicht komplett wie eingestellt zu gefahren.
Werde es nochmal im Debug anschauen und berichten, evtl. fehlte eine Einstellung. -
@nightfly1983 Also bei mir funktioniert das tadellos. Sie fahren bei Sonnenuntergang auf 50% runter und so wie ich es eingestellt habe um 23 Uhr ganz runter. Ich bin begeistert. Das ging aber auch schon davor bei mir.
möchte auch eine kurze Rückmeldung geben.
Habe von der V. 1.1.5 auf die 1.38 jetzt 1.41 updatet. Ich hatte damals (im Januar ´21, siehe oben) Probleme mit den Fensterkontakten. Diese Probleme konnte @FoxRo lösen und die Lösung ist dann später in den Code mit eingeflossen. Die Steuerung funktionierte bis zum Update in der letzten Woche einwandfrei!
Nach dem Update fahren plötzlich nicht mehr alle Rolläden, also auch solche ohne Fensterkontakte. Und die mit den Kontakten funktionieren auch nicht mehr beim öffnen und schließen wie bisher.
Habe gegenwärtig leider überhaupt nicht die Zeit hier mehr zu liefern, also wichtige Logs und Debugs.... Ich möchte nur kurze Rückmeldung geben, dass die aktuelle Version wohl noch nicht rund läuft. Möchte aber auch sagen, dass ich mit Shuttercontrol bisher sehr zufrieden bin.
Danke @simatec für deine Arbeit.
lg
tom -
@simatec
Heute Morgen hat alles funktioniert! -
@tom-haase Hast du nach dem Update die Einstellungen der Rollläden angepasst? Hier sollten die Kippfunktionen der Fensterkontakte auch konfiguriert werden. Wenn du keine hast, dann auf "keins" stellen
@nightfly1983 Wie sehen deinen Einstellungen denn aus und welche Version ist installiert?
