  4. Xiaomi Smartmi Air Humidifier2
121 Beiträge 23 Kommentatoren 24.4k Aufrufe 21 Beobachtet
    Maxim-777
    #91
    @pittini Guten Abend,
    hab gerade noch mal "node-mihome" installiert, jetzt bekomme ich keine Fehler in log, aber immer noch keine Werte in Datenpunkte, mal ne Idee?
    javascript.0	2021-04-25 21:41:19.221	info	(1688) script.js.Test: Setting trigger #0 for deerma.humidifier.jsq
    javascript.0	2021-04-25 21:41:19.220	info	(1688) script.js.Test: Init Device# 0 - device="deerma.humidifier.jsq"
    javascript.0	2021-04-25 21:41:18.837	info	(1688) script.js.Test: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"239969578","address":"192.168.178.63","token":"eb8d9d423828ac5240b14c348142c5ff","protocol":"local","refr
    javascript.0	2021-04-25 21:41:18.834	info	(1688) script.js.Test: Now creating device for deerma.humidifier.jsq / 239969578 / 192.168.178.63 / eb8d9d423828ac5240b14c348142c5ff / 10000
    javascript.0	2021-04-25 21:41:18.805	info	(1688) script.js.Test: Device Mi Smart Antibacterial Humidifier is supported, creating DataPoints
    javascript.0	2021-04-25 21:41:18.805	info	(1688) script.js.Test: Now searching for supported Devices...
    javascript.0	2021-04-25 21:41:18.804	info	(1688) script.js.Test: RoboCop
    javascript.0	2021-04-25 21:41:18.803	info	(1688) script.js.Test: Mi Smart Antibacterial Humidifier
    javascript.0	2021-04-25 21:41:18.801	info	(1688) script.js.Test: Found 2 MiHome Devices, those are:
    javascript.0	2021-04-25 21:41:18.645	info	(1688) script.js.Test: Retrieving your in de registered MiHome Devices
    javascript.0	2021-04-25 21:41:15.918	info	(1688) script.js.Test: registered 0 subscriptions and 0 schedules
    javascript.0	2021-04-25 21:41:15.871	info	(1688) script.js.Test: Starting AllMyMi V.0.2.11
    javascript.0	2021-04-25 21:41:15.597	info	(1688) Start javascript script.js.Test
    javascript.0	2021-04-25 21:41:15.533	info	(1688) received all states
    javascript.0	2021-04-25 21:41:15.529	info	(1688) received all objects
    javascript.0	2021-04-25 21:41:15.252	info	(1688) requesting all objects
    javascript.0	2021-04-25 21:41:15.250	info	(1688) requesting all states
    javascript.0	2021-04-25 21:41:15.137	info	(1688) starting. Version 5.1.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
    host.raspberrypi	2021-04-25 20:41:12.283	info	instance system.adapter.javascript.0 started with pid 1688
    host.raspberrypi	2021-04-25 20:41:09.856	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    javascript.0	2021-04-25 20:41:09.252	info	(1537) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    javascript.0	2021-04-25 20:41:09.249	info	(1537) terminating
    javascript.0	2021-04-25 20:41:09.243	info	(1537) Stop script script.js.Test
    P 1 Antwort Letzte Antwort
    • M Maxim-777
      Pittini
      #92
      @maxim-777 Wenn Du node-mihome neuinstallierst, must Du die deerma.humidifier.jsq.js aus meinem Git Verzeichnis da wieder reinkopieren.
      • JackDanielJ Offline
        JackDanielJ Offline
        JackDaniel
        #93
        wie kann ich die "node-mihome" nochmal installieren?
        wird das nicht automatisch erledigt wenn ich das modul im js adapter eintrage?
        Carpe diem
        • JackDanielJ JackDaniel
          Pittini
          #94
          @jackdaniel sagte in Xiaomi Smartmi Air Humidifier2:
          Normalerweise ja, aber spätestens bei nem update des js Controller wird die neuinstalliert. Und manuell geht offenbar natürlich auch, is ja ein npm Packet.
          R 1 Antwort Letzte Antwort
          • P Pittini
            ramses
            #95
            @pittini
            Ich habe einen flatschneuen Smartmi P1 purifier. Über den Alexa2 Adapter kann ich Ihn zumindest an und ausschalten.
            Hast du eine Idee, wie der beste Weg ist den zu integrieren?
            Im Gegensatz zum Smartmi FAN und anderen Smartmi Produkten, läuft dieser nicht über die Xiaomi MiHome-App sondern über eine eigenständige (Smartmi Link).
            Das Gerät hat WLAN und zumindest den Port 80 offen.
            Mehr Infos zum Gerät
            https://www.indiegogo.com/projects/smartmi-p1-purifier-cleaner-freshen-air-in-10-mins
            Wäre für ein paar Ideen dankbar.
            P S 2 Antworten Letzte Antwort
            • R ramses
              @pittini
              Pittini
              #96
              @ramses Wenn man den nicht in die Xiaomi App kriegt, kann ich Dir da nich helfen, mein Skript baut auf die node-mihome auf, is ein Gerät da nicht drin, gehts nicht, zumindest nicht mit meinem Skript. Aber evtl. kannste den ja in die App kriegen, z.B. die YeeLights haben auch ne eigene App, lassen sich aber AUCH in die Xiamoi App einbinden.
              • P Pittini
                ramses
                #97
                @pittini
                Nope, leider bisher keine Chance den da rein zu kriegen.
                Zum Glück sind die Dank indiegogo nicht so zickig wie die Xiaomi-Deppen.
                Xiaomi ist absolut Anti-API wie man an der Xiaomi Bedside Lamp 2 merken konnte.
                Ich bin vermutlich einer der 100 glücklichen Idioten die eine Firmware dafür gekriegt haben die eine LAN Steuerung ermöglichen.
                Riesiges, ganz böses Thema. (https://forum.yeelight.com/t/topic/22664/ - Hier wird auf 400 Beiträgen gebettelt Lan-Control wieder anzuschalten).
                Dieses wird nur ein Beispiel sein was uns bei Chinaprodukten-Hersteller bevorsteht. Xiaomi wird ein ganz ganz übles Thema werden.
                Whatever, das war nur Hintergrund-Info, Smartmi wird wohl irgendwie noch eine API öffnen. Und wenn ich se nerven muss bis ich sterbe :)
                Hoffe du kannst dann später weitere Unterstützung bieten.
                Zum Air Purifier, hatte bisher mehrere (5) 3H von Xiaomi , die Smartmi Produkte sind um so einiges besser.
                Falls es wen interessiert der P1 reinigt den Raum fast doppelt so schnell wie der Xiaomi Purifier 3H und ist halb so laut dabei. Die Größe ist vermutlich auch 1/3 kleiner.
                Über die Optik rede ich nicht. Ob jemand den hässlichen 3H schön findet überlasse ich jedem selbst. Der P1 ist sehr portabel dank schönem Lederriemen.
                Solange das Projekt auf Indiegogo noch läuft, nerve ich den Hersteller mit API API API :-)
                • R ramses
                  @pittini
                  Stadtschloss
                  schrieb am zuletzt editiert von Stadtschloss
                  #98
                  @ramses Hast du schon eine Lösung gefunden, den P1 einzubinden?
                  Hab den Hersteller auch kontaktiert zwecks Api
                  • S Stadtschloss
                    ramses
                    #99
                    @stadtschloss
                    Das kannst du vergessen. Du wirst keine API Informationen bekommen. Bin schon seit Wochen dabei Smartmi Infos aus der Nase zu ziehen.
                    Ich habe jetzt einfach erst mal die "Minimallösung" genommen. Habe ihn via Alexa Skill eingebunden und kann somit über Iobroker zumindest an und aus steuern.
                    Wenn das Gerät auf Automatikmodus steht reicht das eigentlich auch aus.
                    Den "Schlafmodus" halte ich für unsinnig (entspricht Stufe 1). Das mag in China mit deren verdreckter Luft vielleicht Sinn machen, aber bei uns ist das Gerät nachts sowieso aus bzw. ruhig wenn die Luft einmal gereinigt ist.
                    Ein Pollenallergiker wird zur Pollenzeit wohl kaum nachts die Fenster aufreißen und wer ne Katze hat die Nachts durchs Schlafzimmer fetzt und Staub aufwirbelt hat halt auch Pech gehabt.
                    Außer wenn ich mal einen Raucher/Dampfer zu besuch habe lasse ich das Ding im manuellen Modus dauerlaufen, sonst reicht Automatik,
                    Interessant ist, dass das Gerät einen ESP32 verbaut hat für die Steuerung und WLAN. Somit sollte er auch mit Tosmato-Firmware laufen und somit wunderbar im vollem Umfang via Sonoff-Adapter steuerbar sein.
                    Leider reichen meine Kenntnisse nicht aus um sowas zu erstellen, aber laut Indiegogo-Kommentare, beschäftigt sich schon jemand damit.
                    • H Offline
                      hotze78
                      schrieb am zuletzt editiert von hotze78
                      #100
                      Ich scheitere am Versuch einen Xiaomi Smartmi Air Humidifier2 einzubinden. Was ist der aktuellen Stand? Was wird benötigt? Schritt für Schritt.
                      Habe Adapter installiert und Instanz manuell erstellt. Für Andere Konsole: "iobroker add ioBroker.mihome-humidifier"
                      Schade geschieht dies nicht automatisch. Dies ist mein erstes mal wo ich vor diesem Problem stand und schon einiges aus Git getestet.
                      In der verzweiflung ioBroker.miio und iobroker-nodemihome installiert keine möglichkeit gefunden.
                      Token mit diesem herausgelesen github.com/Maxmudjon/Get_MiHome_devices_token
                      Einstellungen mit Name und IP ergänzt. Bleibt auf Rot ohne Verbindung.
                      zhimi.humidifier.ca4
                      Region: de
                      Node.js v12
                      Fehlermeldung: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      unhandled promise rejection: adapter.objects.getObject is not a function
                      TypeError: adapter.objects.getObject is not a function at setNameInstanceAdapter (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:59:21) at main (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:32:5) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:28:5) at Adapter.emit (events.js:314:20) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8606:34
                      • H hotze78
                        Region: de
                        Node.js v12
                        #101
                        @hotze78
                        Etwas OT: Mein Geheimtipp für die Token ist es, den mihome-vacuum Adapter zu nehmen. Der liest alle möglichen Token aus dem mi-Umfeld aus
                        H 2 Antworten Letzte Antwort
                          @hotze78
                          hotze78
                          #102
                          @thomas-braun Wie genau? den habe ich schon länger. Damals muste ich den Token noch selber einfügen.
                            @hotze78
                            hotze78
                            #103
                            @thomas-braun Hehe. ja, wenn was einfach funktioniert und die Weiterentwiklung nicht bemerkst. COOL! an dessen Coders: Habt ihr toll gemacht!
                            • H hotze78
                              #104
                              @hotze78
                              Ich glaube mit dem Adapter wirst du aber nicht weiterkommen. Der schaut tot aus.
                              H 1 Antwort Letzte Antwort
                                @hotze78
                                hotze78
                                #105
                                oje. Alternative ioBroker.miio? aber irgendwie kapier ich es da nicht.
                                • H hotze78
                                  Pittini
                                  #106
                                  @hotze78 sagte in Xiaomi Smartmi Air Humidifier2:
                                  Und warum magste mein Skript nicht verwenden?
                                  https://github.com/Pittini/iobroker-nodemihome
                                  H S 2 Antworten Letzte Antwort
                                  • P Pittini
                                    hotze78
                                    #107
                                    @pittini
                                    Hallo. komme leider nicht weiter mit dem iobroker-nodemihome. Javascript ausgeführt. Dateien in Ordner Kopiert. Zugangsdaten 100% richtig.
                                    Gerät erscheint in Objekte... sobald ich einen Wert umstellen will kommt folgendes im Log
                                    Error: command error at Object.reject (/opt/iobroker/node_modules/node-mihome/lib/protocol-miio.js:343:19) at MiIOProtocol._onData (/opt/iobroker/node_modules/node-mihome/lib/protocol-miio.js:239:11) at MiIOProtocol._onMessage (/opt/iobroker/node_modules/node-mihome/lib/protocol-miio.js:110:14) at Socket.<anonymous> (/opt/iobroker/node_modules/node-mihome/lib/protocol-miio.js:40:12) at Socket.emit (events.js:400:28) at UDP.onMessage (dgram.js:931:8)
                                    • P Pittini
                                      Sammyray
                                      #108
                                      @pittini said in Xiaomi Smartmi Air Humidifier2:
                                      Hi, frohes neues erstmal! :)
                                      Ich würde gerne dein Skript verwenden, hab auch versucht mich dann die Anleitung zu halten, bekomme aber folgende Fehlermeldung, sobald ich das Skript starte:
                                      javascript.0 2022-01-01 19:57:02.943 error at Init (script.js.Xiaomi:830:21)
                                      javascript.0 2022-01-01 19:57:02.943 error at MiCloudProtocol.getDevices (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:121:18)
                                      javascript.0 2022-01-01 19:57:02.943 error at processTicksAndRejections (internal/process/task_queues.js:95:5)
                                      javascript.0 2022-01-01 19:57:02.943 error at MiCloudProtocol.request (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-mihome/lib/protocol-micloud.js:107:13)
                                      javascript.0 2022-01-01 19:57:02.942 error script.js.Xiaomi: Error: Request error with status Unauthorized
                                      javascript.0 2022-01-01 19:57:02.086 info script.js.Xiaomi: Retrieving your in de registered MiHome Devices
                                      javascript.0 2022-01-01 19:57:01.167 info script.js.Xiaomi: registered 0 subscriptions and 0 schedules
                                      javascript.0 2022-01-01 19:57:01.150 info script.js.Xiaomi: Starting AllMyMi V.0.2.28
                                      javascript.0 2022-01-01 19:57:01.058 info Start javascript script.js.Xiaom
                                      Was mache ich falsch bzw. was muss ich ändern, damit es läuft? Kenne mich leider mit JS nicht wirklich aus :(
                                      Danke und beste Grüße!
                                      Node.js v14.18.2
                                      NPM v6.14.15
                                      javascript 5.2.13
                                      • S Sammyray
                                        Node.js v14.18.2
                                        NPM v6.14.15
                                        javascript 5.2.13
                                        Pittini
                                        #109
                                        @sammyray Da können wir beide nix machen, offenbar hat Xiaomi das Anmeldeverfahren geändert, da muß erstmal die node-mihome ein update kriegen. Siehe https://github.com/Pittini/iobroker-nodemihome/issues/56
                                        • P Pittini
                                          Sammyray
                                          #110
                                          @pittini
                                          Mist, das ist sehr schade, sah es doch so vielversprechend aus 😧
                                          Danke für die schnelle Antwort und dann hoffen wir mal, dass sich noch was tut. Schönen Sonntag noch!
