  4. Xiaomi Smartmi Air Humidifier2
121 Beiträge 23 Kommentatoren 24.4k Aufrufe 21 Beobachtet
  • M Maxim-777
    @thomas-braun du meinst diese Adapter?
    #84
    @maxim-777 Ja. Auf den setzt das skript auf.
    M 2 Antworten Letzte Antwort
      Maxim-777
      #85
      @thomas-braun aha, den habe ich nicht installiert 😤 probiere ich abends. Danke für dein Tipp 🤝
        Maxim-777
        #86
        @thomas-braun mal blöde frage: muss "Xiaomi MiHome Gateway" Adapter grün leuchten? Brauche ich dafür ein MiHome Gateway??
        Nach den Installation "Xiaomi MiHome Gateway" Adapter habe ich folgende LOG (keine Fehler mehr, aber trotzdem keine werte):
        javascript.0	2021-04-23 21:52:48.525	info	(8102) script.js.Test: Setting trigger #0 for deerma.humidifier.jsq
        javascript.0	2021-04-23 21:52:48.524	info	(8102) script.js.Test: Init Device# 0 - device="deerma.humidifier.jsq"
        javascript.0	2021-04-23 21:52:48.093	info	(8102) script.js.Test: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"239969578","address":"192.168.178.63","token":"47555d87e284070b8920da3b129e1ede","protocol":"local","refr
        javascript.0	2021-04-23 21:52:48.089	info	(8102) script.js.Test: Now creating device for deerma.humidifier.jsq / 239969578 / 192.168.178.63 / 47555d87e284070b8920da3b129e1ede / 10000
        javascript.0	2021-04-23 21:52:48.058	info	(8102) script.js.Test: Device Mi Smart Antibacterial Humidifier is supported, creating DataPoints
        javascript.0	2021-04-23 21:52:48.057	info	(8102) script.js.Test: Now searching for supported Devices...
        javascript.0	2021-04-23 21:52:48.056	info	(8102) script.js.Test: RoboCop
        javascript.0	2021-04-23 21:52:48.054	info	(8102) script.js.Test: Mi Smart Antibacterial Humidifier
        javascript.0	2021-04-23 21:52:48.053	info	(8102) script.js.Test: Found 2 MiHome Devices, those are:
        javascript.0	2021-04-23 21:52:47.907	info	(8102) script.js.Test: Retrieving your in de registered MiHome Devices
        javascript.0	2021-04-23 21:52:45.084	info	(8102) script.js.Test: registered 0 subscriptions and 0 schedules
        javascript.0	2021-04-23 21:52:45.036	info	(8102) script.js.Test: Starting AllMyMi V.0.2.11
        javascript.0	2021-04-23 21:52:44.865	info	(8102) Start javascript script.js.Test
        javascript.0	2021-04-23 21:52:44.800	info	(8102) received all states
        javascript.0	2021-04-23 21:52:44.795	info	(8102) received all objects
        javascript.0	2021-04-23 21:52:44.523	info	(8102) requesting all objects
        javascript.0	2021-04-23 21:52:44.521	info	(8102) requesting all states
        javascript.0	2021-04-23 21:52:44.408	info	(8102) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
        host.raspberrypi	2021-04-23 21:52:41.793	info	instance system.adapter.javascript.0 started with pid 8102
        host.raspberrypi	2021-04-23 20:52:39.294	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        javascript.0	2021-04-23 20:52:38.693	info	(7866) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        javascript.0	2021-04-23 20:52:38.691	info	(7866) terminating
        javascript.0	2021-04-23 20:52:38.677	info	(7866) Stop script script.js.Test
        • M Maxim-777
          #87
          @maxim-777
          Ich habe beides. Also ein Gateway und einen grün leuchtenden Adapter.
          Ich weiß aber nicht wie weit die Unterstützung durch das Skript für die Hardware gehen sollte.
            @maxim-777
            Maxim-777
            #88
            @thomas-braun ach... dann geht es ohne Gateway wahrscheinlich nicht
            Thomas BraunT P 2 Antworten Letzte Antwort
            • M Maxim-777
              #89
              @maxim-777 Das kann ich dir nicht sagen.
              Wobei das Gateway eigentlich nur für Zigbee-Komponenten erforderlich sein sollte. Die Wifi-Geräte kommen ja darüber in das Netz.
              • M Maxim-777
                Pittini
                #90
                @maxim-777 sagte in Xiaomi Smartmi Air Humidifier2:
                Weder braucht man ein Gateway, noch den MiHome Adapter. Das Skript setzt viel früher an, und meldet sich selber an der Cloud an, bzw. die node-mihome, daran liegts nicht das is mal sicher.
                  Maxim-777
                  #91
                  @pittini Guten Abend,
                  hab gerade noch mal "node-mihome" installiert, jetzt bekomme ich keine Fehler in log, aber immer noch keine Werte in Datenpunkte, mal ne Idee?
                  javascript.0	2021-04-25 21:41:19.221	info	(1688) script.js.Test: Setting trigger #0 for deerma.humidifier.jsq
                  javascript.0	2021-04-25 21:41:19.220	info	(1688) script.js.Test: Init Device# 0 - device="deerma.humidifier.jsq"
                  javascript.0	2021-04-25 21:41:18.837	info	(1688) script.js.Test: Created device {"_events":{},"_eventsCount":0,"_maxListeners":100,"id":"239969578","address":"192.168.178.63","token":"eb8d9d423828ac5240b14c348142c5ff","protocol":"local","refr
                  javascript.0	2021-04-25 21:41:18.834	info	(1688) script.js.Test: Now creating device for deerma.humidifier.jsq / 239969578 / 192.168.178.63 / eb8d9d423828ac5240b14c348142c5ff / 10000
                  javascript.0	2021-04-25 21:41:18.805	info	(1688) script.js.Test: Device Mi Smart Antibacterial Humidifier is supported, creating DataPoints
                  javascript.0	2021-04-25 21:41:18.805	info	(1688) script.js.Test: Now searching for supported Devices...
                  javascript.0	2021-04-25 21:41:18.804	info	(1688) script.js.Test: RoboCop
                  javascript.0	2021-04-25 21:41:18.803	info	(1688) script.js.Test: Mi Smart Antibacterial Humidifier
                  javascript.0	2021-04-25 21:41:18.801	info	(1688) script.js.Test: Found 2 MiHome Devices, those are:
                  javascript.0	2021-04-25 21:41:18.645	info	(1688) script.js.Test: Retrieving your in de registered MiHome Devices
                  javascript.0	2021-04-25 21:41:15.918	info	(1688) script.js.Test: registered 0 subscriptions and 0 schedules
                  javascript.0	2021-04-25 21:41:15.871	info	(1688) script.js.Test: Starting AllMyMi V.0.2.11
                  javascript.0	2021-04-25 21:41:15.597	info	(1688) Start javascript script.js.Test
                  javascript.0	2021-04-25 21:41:15.533	info	(1688) received all states
                  javascript.0	2021-04-25 21:41:15.529	info	(1688) received all objects
                  javascript.0	2021-04-25 21:41:15.252	info	(1688) requesting all objects
                  javascript.0	2021-04-25 21:41:15.250	info	(1688) requesting all states
                  javascript.0	2021-04-25 21:41:15.137	info	(1688) starting. Version 5.1.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
                  host.raspberrypi	2021-04-25 20:41:12.283	info	instance system.adapter.javascript.0 started with pid 1688
                  host.raspberrypi	2021-04-25 20:41:09.856	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  javascript.0	2021-04-25 20:41:09.252	info	(1537) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  javascript.0	2021-04-25 20:41:09.249	info	(1537) terminating
                  javascript.0	2021-04-25 20:41:09.243	info	(1537) Stop script script.js.Test
                  P 1 Antwort Letzte Antwort
                  • M Maxim-777
                    Pittini
                    #92
                    @maxim-777 Wenn Du node-mihome neuinstallierst, must Du die deerma.humidifier.jsq.js aus meinem Git Verzeichnis da wieder reinkopieren.
                    • JackDanielJ Offline
                      JackDanielJ Offline
                      JackDaniel
                      #93
                      wie kann ich die "node-mihome" nochmal installieren?
                      wird das nicht automatisch erledigt wenn ich das modul im js adapter eintrage?
                      Carpe diem
                      • JackDanielJ JackDaniel
                        Pittini
                        #94
                        @jackdaniel sagte in Xiaomi Smartmi Air Humidifier2:
                        Normalerweise ja, aber spätestens bei nem update des js Controller wird die neuinstalliert. Und manuell geht offenbar natürlich auch, is ja ein npm Packet.
                        R 1 Antwort Letzte Antwort
                        • P Pittini
                          ramses
                          #95
                          @pittini
                          Ich habe einen flatschneuen Smartmi P1 purifier. Über den Alexa2 Adapter kann ich Ihn zumindest an und ausschalten.
                          Hast du eine Idee, wie der beste Weg ist den zu integrieren?
                          Im Gegensatz zum Smartmi FAN und anderen Smartmi Produkten, läuft dieser nicht über die Xiaomi MiHome-App sondern über eine eigenständige (Smartmi Link).
                          Das Gerät hat WLAN und zumindest den Port 80 offen.
                          Mehr Infos zum Gerät
                          https://www.indiegogo.com/projects/smartmi-p1-purifier-cleaner-freshen-air-in-10-mins
                          Wäre für ein paar Ideen dankbar.
                          P S 2 Antworten Letzte Antwort
                          • R ramses
                            @pittini
                            Pittini
                            #96
                            @ramses Wenn man den nicht in die Xiaomi App kriegt, kann ich Dir da nich helfen, mein Skript baut auf die node-mihome auf, is ein Gerät da nicht drin, gehts nicht, zumindest nicht mit meinem Skript. Aber evtl. kannste den ja in die App kriegen, z.B. die YeeLights haben auch ne eigene App, lassen sich aber AUCH in die Xiamoi App einbinden.
                            • P Pittini
                              ramses
                              #97
                              @pittini
                              Nope, leider bisher keine Chance den da rein zu kriegen.
                              Zum Glück sind die Dank indiegogo nicht so zickig wie die Xiaomi-Deppen.
                              Xiaomi ist absolut Anti-API wie man an der Xiaomi Bedside Lamp 2 merken konnte.
                              Ich bin vermutlich einer der 100 glücklichen Idioten die eine Firmware dafür gekriegt haben die eine LAN Steuerung ermöglichen.
                              Riesiges, ganz böses Thema. (https://forum.yeelight.com/t/topic/22664/ - Hier wird auf 400 Beiträgen gebettelt Lan-Control wieder anzuschalten).
                              Dieses wird nur ein Beispiel sein was uns bei Chinaprodukten-Hersteller bevorsteht. Xiaomi wird ein ganz ganz übles Thema werden.
                              Whatever, das war nur Hintergrund-Info, Smartmi wird wohl irgendwie noch eine API öffnen. Und wenn ich se nerven muss bis ich sterbe :)
                              Hoffe du kannst dann später weitere Unterstützung bieten.
                              Zum Air Purifier, hatte bisher mehrere (5) 3H von Xiaomi , die Smartmi Produkte sind um so einiges besser.
                              Falls es wen interessiert der P1 reinigt den Raum fast doppelt so schnell wie der Xiaomi Purifier 3H und ist halb so laut dabei. Die Größe ist vermutlich auch 1/3 kleiner.
                              Über die Optik rede ich nicht. Ob jemand den hässlichen 3H schön findet überlasse ich jedem selbst. Der P1 ist sehr portabel dank schönem Lederriemen.
                              Solange das Projekt auf Indiegogo noch läuft, nerve ich den Hersteller mit API API API :-)
                              • R ramses
                                @pittini
                                Stadtschloss
                                schrieb am zuletzt editiert von Stadtschloss
                                #98
                                @ramses Hast du schon eine Lösung gefunden, den P1 einzubinden?
                                Hab den Hersteller auch kontaktiert zwecks Api
                                • S Stadtschloss
                                  ramses
                                  #99
                                  @stadtschloss
                                  Das kannst du vergessen. Du wirst keine API Informationen bekommen. Bin schon seit Wochen dabei Smartmi Infos aus der Nase zu ziehen.
                                  Ich habe jetzt einfach erst mal die "Minimallösung" genommen. Habe ihn via Alexa Skill eingebunden und kann somit über Iobroker zumindest an und aus steuern.
                                  Wenn das Gerät auf Automatikmodus steht reicht das eigentlich auch aus.
                                  Den "Schlafmodus" halte ich für unsinnig (entspricht Stufe 1). Das mag in China mit deren verdreckter Luft vielleicht Sinn machen, aber bei uns ist das Gerät nachts sowieso aus bzw. ruhig wenn die Luft einmal gereinigt ist.
                                  Ein Pollenallergiker wird zur Pollenzeit wohl kaum nachts die Fenster aufreißen und wer ne Katze hat die Nachts durchs Schlafzimmer fetzt und Staub aufwirbelt hat halt auch Pech gehabt.
                                  Außer wenn ich mal einen Raucher/Dampfer zu besuch habe lasse ich das Ding im manuellen Modus dauerlaufen, sonst reicht Automatik,
                                  Interessant ist, dass das Gerät einen ESP32 verbaut hat für die Steuerung und WLAN. Somit sollte er auch mit Tosmato-Firmware laufen und somit wunderbar im vollem Umfang via Sonoff-Adapter steuerbar sein.
                                  Leider reichen meine Kenntnisse nicht aus um sowas zu erstellen, aber laut Indiegogo-Kommentare, beschäftigt sich schon jemand damit.
                                  • H Offline
                                    hotze78
                                    schrieb am zuletzt editiert von hotze78
                                    #100
                                    Ich scheitere am Versuch einen Xiaomi Smartmi Air Humidifier2 einzubinden. Was ist der aktuellen Stand? Was wird benötigt? Schritt für Schritt.
                                    Habe Adapter installiert und Instanz manuell erstellt. Für Andere Konsole: "iobroker add ioBroker.mihome-humidifier"
                                    Schade geschieht dies nicht automatisch. Dies ist mein erstes mal wo ich vor diesem Problem stand und schon einiges aus Git getestet.
                                    In der verzweiflung ioBroker.miio und iobroker-nodemihome installiert keine möglichkeit gefunden.
                                    Token mit diesem herausgelesen github.com/Maxmudjon/Get_MiHome_devices_token
                                    Einstellungen mit Name und IP ergänzt. Bleibt auf Rot ohne Verbindung.
                                    zhimi.humidifier.ca4
                                    Region: de
                                    Node.js v12
                                    Fehlermeldung: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    unhandled promise rejection: adapter.objects.getObject is not a function
                                    TypeError: adapter.objects.getObject is not a function at setNameInstanceAdapter (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:59:21) at main (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:32:5) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-humidifier/main.js:28:5) at Adapter.emit (events.js:314:20) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8606:34
                                    • H hotze78
                                      Region: de
                                      Node.js v12
                                      #101
                                      @hotze78
                                      Etwas OT: Mein Geheimtipp für die Token ist es, den mihome-vacuum Adapter zu nehmen. Der liest alle möglichen Token aus dem mi-Umfeld aus
                                      H 2 Antworten Letzte Antwort
                                        @hotze78
                                        hotze78
                                        #102
                                        @thomas-braun Wie genau? den habe ich schon länger. Damals muste ich den Token noch selber einfügen.
                                          @hotze78
                                          hotze78
                                          #103
                                          @thomas-braun Hehe. ja, wenn was einfach funktioniert und die Weiterentwiklung nicht bemerkst. COOL! an dessen Coders: Habt ihr toll gemacht!
