  4. Raspberry OS lite Image for/with ioBroker
191 Beiträge 37 Kommentatoren 149.2k Aufrufe 33 Beobachtet
    @beekeeper
    Doch, es schadet, weil es nämlich genau die Rechte verfummeln kann. Finger weg von root-Rechten, wenn man keine braucht.
    Bitte Konsolentext in CodeTags posten. Und bitte auch vollständig. Inkl. Login prompt.
    iobroker stop
    iobroker fix
    iobroker start
    B
    B
    Beekeeper
    #88
    @thomas-braun Habe alles nochmal durchlaufen lassen:
    login as: pi
    pi@192.168.0.80's password:
    Linux raspberrypi 5.10.52-v7l+ #1440 SMP Tue Jul 27 09:55:21 BST 2021 armv7l
    permitted by applicable law.
    Last login: Tue Oct  5 20:05:46 2021
    SSH is enabled and the default password for the 'pi' user has not been changed.
    This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
    pi@raspberrypi:~ $ iobroker stop
    pi@raspberrypi:~ $ iobroker fix
    library: loaded
    Library version=2021-08-05
        Welcome to the ioBroker installation fixer!
        Script version: 2021-04-07
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://deb.nodesource.com/node_14.x buster InRelease
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ iobroker status
    Objects type: file
    States  type: file
    pi@raspberrypi:~ $ iobroker list instances
    + instance is alive
    pi@raspberrypi:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.1.25
    pi@raspberrypi:~ $
    Leider noch keine Besserung
    • B Beekeeper
      login as: pi
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      Objects type: file
      States  type: file
      + instance is alive
      pi@raspberrypi:~ $
      Thomas BraunT
      Thomas BraunT
      #89
      @beekeeper
      iobroker add admin
      Und änder das Standardpasswort.
        @beekeeper
        iobroker add admin
        B
        B
        Beekeeper
        #90
        @thomas-braun said in Raspberry OS lite Image for/with ioBroker:
        iobroker add admin
        Vielen Dank, dass hat geklappt. Passwort ändere ich jetzt auch noch
        • andreA andre
          [EDIT] Dieser Thread ist veraltet. Hier geht es mit v2 weiter: https://forum.iobroker.net/topic/70852/iobroker-raspberry-os-image-v2
          Aktuelle Version v1.2.0
          Veröffentlichungsdatum 23.09.2021
          Github Link https://github.com/buanet/ioBroker.raspberry-os
          Nachdem unsere SBC Images auf der iobroker.net Website veraltet waren und nun den Weg ins Nirvana angetreten haben, habe ich mich mal an die automatisierte Erstellung solcher Images gewagt. Angefangen mit dem Chef im Ring, dem Raspberry Pi.
          Ziel ist es ein Script zu erstellen, dass dann am Ende automatisiert ein vollständig vor konfiguriertes Raspberry Pi OS Image mit vorinstalliertem ioBroker ausspuckt welches wir dann zum Download zur Verfügung stellen können.
          Aktuell habe ich "einfach erstmal los gelegt" und das Ganze Konstrukt zum Rennen gebracht. Das unten verlinkte Image habe ich bereits auf meinem Raspberry Pi 4 erfolgreich getestet. Würde mich freuen wenn sich ein paar willige Tester finden, die das Image ebenfalls mal in Augenschein nehmen und ggf. von ihren Erfahrungen berichten.
          Aktuell habe ich folgende Konfigurationsparameter gewählt, welche ich hier auch gerne zur Diskussion stellen würde:
          • Image basiert auf dem aktuellen Raspberry Pi OS (Buster) Lite
          • beim ersten Start werden die Partitionen automatisch an die SD Karte angepasst
          • SSH ist automatisch aktiviert
          • nach dem Boot wird auch ohne Login die IP-Adresse angezeigt
          • ioBroker ist bereits installiert und startet automatisch
          • der Hostname lautet "iobroker-pi"
          • standard Login: pi / raspberry
          • default locale ist "en_GB.UTF-8"
          • Zeitzone ist "Europe/London"
          • Tastatureinstellungen sind auf gb
          • Image bootet in run level 3 (boot target - seit v0.0.2)
          • GPU verwendet 16 MB (memory split - seit v0.0.2)
          ToDos aus Feedback
          • Image neben der default (Sprach)Version (GB) auch in einer deutschen Version zum Download bereit stellen
          Weitere Parameter füge ich bei Bedarf gerne hinzu.
          Natürlich wäre es später auch möglich das Image in verschiedenen Versionen anzubieten. Etwa bezüglich der Zeitzonen/ Sprachen/ Tastatureinstellungen oder wahlweise auch mit vorinstallierter Desktop Oberfläche. Lasst dazu gerne eurer Feedback da!
          Das aktuellste Image bekommt ihr immer hier:
          https://download.buanet.de/latest-rpios-iobroker/
          Oder mit etwas Versatz natürlich auch hier:
          https://www.iobroker.net/#de/download
          MfG,
          André
          PS: Das hier wird (hoffentlich) keine Diskussion ob ein Image wirklich sinnvoll ist, wenn doch zur Installation nur ein einzelner Befehl notwendig ist.
          Ja, mit ist diese Meinung geläufig, ihr seid hiermit erhört. :)
          Fakt ist: Viele User erwarten solch ein Image, vor allem als absolute Einsteiger!
          MfG,
          André
          F
          F
          fischer_slarcor.de
          #91
          Hallo, ich bekomme die Vis nicht zum laufen, was soll ich tun?
          Habe bereits mehrer Images ausprobiert und auch manuell schon auf gesetzt nix geht - keine WEB Oberfläche
          Meine alte jedoch geht - jedoch Alexa Instanz veraltet.
          Bitte um Hilfe.
          Danke.
          F.S.
          Thomas BraunT X 2 Antworten Letzte Antwort
          • F fischer_slarcor.de
            Bitte um Hilfe.
            Danke.
            F.S.
            Thomas BraunT
            Thomas BraunT
            #92
            @fischer_slarcor-de
            Bitte eigenen Thread eröffnen. Das ist ein anderes Thema.
              Bitte um Hilfe.
              Danke.
              F.S.
              X
              X
              XWing
              #93
              @fischer_slarcor-de
              Ich habe das gleiche Problem. Es ließ sich alles installieren. Nur Vis und Flot wollen nicht. Es kommt die Fehlermeldung: Keine Versionsinfo für web.
              Das gleiche beim Flot Adapter.
              • X XWing
                @fischer_slarcor-de
                Thomas BraunT
                Thomas BraunT
                #94
                @xwing
                iobroker upload all
                mal probieren.
                X 1 Antwort Letzte Antwort
                  @xwing
                  iobroker upload all
                  mal probieren.
                  X
                  X
                  XWing
                  #95
                  Das hat leider nicht geholfen:
                  • X XWing
                    Thomas BraunT
                    Thomas BraunT
                    #96
                    @xwing
                    Bitte keine Screenshots, hier sind Rückmeldungen aus dem logfile oder dem Terminal gefragt.
                    iobroker update -i
                    • X XWing
                      #97
                      @xwing sagte in Raspberry OS lite Image for/with ioBroker:
                      läuft web überhaupt?
                        @xwing
                        iobroker update -i
                        X
                        X
                        XWing
                        #98
                        Habe gerade gemerkt, daß dies nicht der Fall war.
                        Jetzt läuft es, aber den Vis Adapter bekomme ich nicht installiert. Es kommt immer obige Fehlermeldung.
                        Im Protokoll gibt es leider keine Einträge, wenn ich eine Installation versuche. Es kommt ja auch zu keinem Installationsvorgang. Nach dem Abnicken der Lizenz kommt obige Meldung.
                        • X XWing
                          #99
                          @xwing mach mal einene forced refresh und versuch es noch mal
                          • X XWing
                            Thomas BraunT
                            Thomas BraunT
                            #100
                            Irgendwas kommt da mit Sicherheit...
                              X
                              X
                              XWing
                              #101
                              Da stand wirklich nichts.
                              Ich habe das Problem jetzt gelöst:
                              cd /opt/iobroker
                              npm uninstall iobroker.vis
                              Danach konnte ich den Adapter über die Oberfläche installieren.
                              • I
                                I
                                IORalf
                                #102
                                Ich habe das Image auf einem Nano 2 installiert.
                                Startet soweit bis zum login, keyboard etc. angepasst und WLan eingetragen
                                Im Startlog steht Starting LSB: starts IoBroker...
                                My IP Adress is 192.168.1.139
                                Starting OpenBSD ....
                                Wenn ich im Browser die IP Adresse eingebe kommt die Fehlermeldung
                                192.168.1.139 hat die Verbindung abgelehnt.
                                Per Putty/SSH kein Problem
                                • I IORalf
                                  Thomas BraunT
                                  Thomas BraunT
                                  #103
                                  @ioralf sagte in Raspberry OS lite Image for/with ioBroker:
                                  OpenBSD ist ein anderes Betriebssystem. Was hast du da installiert? Oder ist das nicht die komplette Meldung?
                                  Und warum installiert man nicht einfach ein Raspberry Lite selber und haut den ioBroker noch per Einzeiler hinterher? Werd ich wohl nie verstehen...
                                  I 1 Antwort Letzte Antwort
                                  • I
                                    I
                                    IORalf
                                    schrieb am zuletzt editiert von IORalf
                                    #104
                                    Ich kann meinen Eintrag leider nicht ändern,
                                    mit :8081 geht auch die Weboberfläche
                                    Starting OpenBSD ... - steht halt so im Log, oder was war die Frage
                                      I
                                      I
                                      IORalf
                                      #105
                                      ? Ich dachte das wäre der Thread - Raspberry OS lite Image for/with ioBroker-
                                      deswegen habe ich das auch so installiert wie am Anfang beschrieben.
                                      Und wollte nur eine Rückmeldung geben das es auch auf dem Nano 2 läuft.
                                      Thomas BraunT andreA 2 Antworten Letzte Antwort
                                      • I IORalf
                                        Thomas BraunT
                                        Thomas BraunT
                                        #106
                                        @ioralf
                                        Das Image ist aber nicht für einen nano irgendwas gedacht.
                                        Images setzen immer auf eine definierte Hardware auf.
                                        • I IORalf
                                          andreA
                                          andreA
                                          andre
                                          #107
                                          @ioralf Danke für die Rückmeldung. Meinst du mit Nano 2 den Pi Zero W?
                                          @Thomas-Braun Da das Image auf Basis des offiziellen Raspberry OS gebaut wird, sollte es eigentlich auf allen Einplatinencomputern der Raspberry Pi Foundation laufen. Zumindest ist das zum Raspberry OS im Internet zu finden. So lange ich aber nicht von jedem Modell ein Exemplar in meiner Schublade habe kann ich es natürlich nicht aus eigener Erfahrung bestätigen. :)
                                          Ob es im Fall von iobroker sinnvoll ist, gerade in Bezug auf RAM, steht dabei aber auf nem anderen Blatt...
                                          MfG,
                                          André
