  4. Test Adapter Sprinkle Control 0.1.4 Latest
    6.0k
gartenbewässerungwetterabhängig
241 Beiträge 35 Kommentatoren 65.5k Aufrufe 46 Beobachtet
  • E e-i-k-e
    Abend,
    ich habe soeben von 0.2.5 auf 0.2.7 aktualisiert.
    Und erhalte leider sehr viele Meldungen.
    sprinklecontrol.0	2021-10-17 22:06:18.603	warn	(1765) Terminated (UNCAUGHT_EXCEPTION): Without reason
    sprinklecontrol.0	2021-10-17 22:06:18.602	info	(1765) terminating
    sprinklecontrol.0	2021-10-17 22:06:18.600	info	(1765) cleaned everything up...
    sprinklecontrol.0	2021-10-17 22:06:18.596	error	(1765) mandatory property type missing!
    sprinklecontrol.0	2021-10-17 22:06:18.595	error	(1765) Error: mandatory property type missing! at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2335:17) at Adapter.setObject (/opt/iobroker/nod
    sprinklecontrol.0	2021-10-17 22:06:18.592	error	(1765) unhandled promise rejection: mandatory property type missing!
    sprinklecontrol.0	2021-10-17 22:06:18.589	error	(1765) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    sprinklecontrol.0	2021-10-17 22:06:18.587	error	(1765) setObject sprinkle.Beet_Küche/Wald_STATE.actualSoilMoisture mandatory property type missing!
    sprinklecontrol.0	2021-10-17 22:06:17.299	info	(1765) state sprinklecontrol.0.control.parallelOfMax changed: 0 : 2 (ack = true)
    sprinklecontrol.0	2021-10-17 22:06:17.298	info	(1765) state sprinklecontrol.0.control.restFlow changed: 1500 (1500 Grundwasser) (ack = true)
    sprinklecontrol.0	2021-10-17 22:06:15.323	info	(1765) #1.0 => Set ID: Beet_Küche/Wald_STATE(7) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprink
    sprinklecontrol.0	2021-10-17 22:06:15.322	info	(1765) #1.0 => Set ID: Beet_Mitte_STATE(6) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Be
    sprinklecontrol.0	2021-10-17 22:06:15.321	info	(1765) #1.0 => Set ID: Beet_Brunnen_STATE(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.
    sprinklecontrol.0	2021-10-17 22:06:15.320	info	(1765) #1.0 => Set ID: Beet_Terrasse_STATE(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle
    sprinklecontrol.0	2021-10-17 22:06:15.319	info	(1765) #1.0 => Set ID: Rasen_Küche(grün)_STATE(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.spri
    sprinklecontrol.0	2021-10-17 22:06:15.318	info	(1765) #1.0 => Set ID: Rasen_Wald(rot)_STATE(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprink
    sprinklecontrol.0	2021-10-17 22:06:15.316	info	(1765) #1.0 => Set ID: Rasen_Brunnen(blau)_STATE(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sp
    sprinklecontrol.0	2021-10-17 22:06:15.314	info	(1765) #1.0 => Set ID: Rasen_Terrasse(gelb)_STATE(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.s
    sprinklecontrol.0	2021-10-17 22:06:15.244	info	(1765) starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.sprinklecontrol, node: v12.22.7, js-controller: 3.3.18
    sprinklecontrol.0	2021-10-17 22:05:42.993	warn	(1735) Terminated (UNCAUGHT_EXCEPTION): Without reason
    sprinklecontrol.0	2021-10-17 22:05:42.992	info	(1735) terminating
    sprinklecontrol.0	2021-10-17 22:05:42.989	info	(1735) cleaned everything up...
    sprinklecontrol.0	2021-10-17 22:05:42.985	error	(1735) mandatory property type missing!
    sprinklecontrol.0	2021-10-17 22:05:42.984	error	(1735) Error: mandatory property type missing! at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2335:17) at Adapter.setObject (/opt/iobroker/nod
    sprinklecontrol.0	2021-10-17 22:05:42.971	error	(1735) unhandled promise rejection: mandatory property type missing!
    sprinklecontrol.0	2021-10-17 22:05:42.970	error	(1735) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    sprinklecontrol.0	2021-10-17 22:05:42.969	error	(1735) setObject sprinkle.Beet_Küche/Wald_STATE.actualSoilMoisture mandatory property type missing!
    sprinklecontrol.0	2021-10-17 22:05:41.684	info	(1735) state sprinklecontrol.0.control.parallelOfMax changed: 0 : 2 (ack = true)
    sprinklecontrol.0	2021-10-17 22:05:41.683	info	(1735) state sprinklecontrol.0.control.restFlow changed: 1500 (1500 Grundwasser) (ack = true)
    sprinklecontrol.0	2021-10-17 22:05:39.691	info	(1735) #1.0 => Set ID: Beet_Küche/Wald_STATE(7) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprink
    sprinklecontrol.0	2021-10-17 22:05:39.690	info	(1735) #1.0 => Set ID: Beet_Mitte_STATE(6) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.Be
    sprinklecontrol.0	2021-10-17 22:05:39.689	info	(1735) #1.0 => Set ID: Beet_Brunnen_STATE(5) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.
    sprinklecontrol.0	2021-10-17 22:05:39.688	info	(1735) #1.0 => Set ID: Beet_Terrasse_STATE(4) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle
    sprinklecontrol.0	2021-10-17 22:05:39.687	info	(1735) #1.0 => Set ID: Rasen_Küche(grün)_STATE(3) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.spri
    sprinklecontrol.0	2021-10-17 22:05:39.685	info	(1735) #1.0 => Set ID: Rasen_Wald(rot)_STATE(2) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprink
    sprinklecontrol.0	2021-10-17 22:05:39.684	info	(1735) #1.0 => Set ID: Rasen_Brunnen(blau)_STATE(1) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.sp
    sprinklecontrol.0	2021-10-17 22:05:39.683	info	(1735) #1.0 => Set ID: Rasen_Terrasse(gelb)_STATE(0) hinzugefügt - {"startFixDay":null,"startDay":null,"enabled":true,"booster":false,"endIrrigation":true,"autoOn":true,"autoOnID":"sprinklecontrol.0.s
    sprinklecontrol.0	2021-10-17 22:05:39.632	info	(1735) starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.sprinklecontrol, node: v12.22.7, js-controller: 3.3.18
    sprinklecontrol.0	2021-10-17 22:01:38.496	warn	(1701) Terminated (UNCAUGHT_EXCEPTION): Without reason
    Dirk PeterD Offline
    Dirk PeterD Offline
    Dirk Peter
    schrieb am zuletzt editiert von Dirk Peter
    #120
    @e-i-k-e
    hier ist beim schreiben des Objekts sprinkle.Beet_Küche?Wald_STATE.actualSoilMoisture ein Fehler aufgetreten. Ich kann aber nicht nachvollziehen warum. Entweder du löschst dieses Objekt und startest dann den Adapter, oder du löschst den Adapter und installierst ihn dann wieder neu. Diese Funktion wurde seit 0.2.5 jedenfalls nicht geändert.
    Schau mal, vielleicht liegt es ja an den Namen ( Beet_Küche ? Wald_STATE ) des Kreises den du vergeben hast. Ersetze mal den Slash durch ein Minus Zeichen.
    Kann dir anders leider nicht weiterhelfen,
    Dirk Peter
    E 1 Antwort Letzte Antwort
    • Dirk PeterD Dirk Peter
      @e-i-k-e
      Dirk Peter
      e-i-k-e
      #121
      @dirk-peter said in Test Adapter Sprinkle Control 0.1.4 Latest:
      Hallo Dirk-Peter,
      danke für den Tipp!
      Ich habe die Datei einfach gelöscht, den Adapter neu gestartet und habe weiterhin Meldungen erhalten.
      sprinklecontrol.0	2021-10-19 21:31:42.167	error	(21189) TypeError: Cannot read property 'name' of undefined at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.sprinklecontrol/main.js:966:47) at processImmediate (internal/timers.j
      sprinklecontrol.0	2021-10-19 21:31:42.166	error	(21189) uncaught exception: Cannot read property 'name' of undefined
      sprinklecontrol.0	2021-10-19 21:31:39.028	info	(21189) starting. Version 0.2.7 in /opt/iobroker/node_modules/iobroker.sprinklecontrol, node: v12.22.7, js-controller: 3.3.18
      sprinklecontrol.0	2021-10-19 21:30:56.584	warn	(21172) Terminated (UNCAUGHT_EXCEPTION): Without reason
      sprinklecontrol.0	2021-10-19 21:30:56.583	info	(21172) terminating
      sprinklecontrol.0	2021-10-19 21:30:56.581	info	(21172) cleaned everything up...
      Nun fehlte lediglich die "Methode zur Kontrolle der Bodenfeuchtigkeit" bei dem Kreis. Nachdem ich diese ausgewählt hatte, wurde der Adapter grün! :)
      Erhalte jetzt nur noch folgendes.
      sprinklecontrol.0	2021-10-19 21:31:42.180	warn	(21189) Terminated (UNCAUGHT_EXCEPTION): Without reason
      sprinklecontrol.0	2021-10-19 21:31:42.178	info	(21189) terminating
      sprinklecontrol.0	2021-10-19 21:31:42.176	info	(21189) cleaned everything up...
      Dirk PeterD 1 Antwort Letzte Antwort
      • E e-i-k-e
        Hallo Dirk-Peter,
        danke für den Tipp!
        Dirk PeterD Offline
        Dirk PeterD Offline
        Dirk Peter
        #122
        @e-i-k-e
        dann ist alles wieder i.O.. Die 3 Meldungen erhellst du immer, wenn der Adapter neu startet.
        Dirk Peter
          @e-i-k-e
          Dirk Peter
          Mike Hellracer
          schrieb am zuletzt editiert von Mike Hellracer
          #123
          @dirk-peter
          Hi, ich setzte die Bewässerungscomputer von Lidle am Zigbee Adapter ein.
          Diese kann man leider nur einschalten. Sie laufen dann ca. 60sec und schalten sich automatisch wieder ab.
          Optional kann man einen Timer über einen Zigbee DP setzen, oder man triggert alle 45sec den DP zum einschalten.
          Könntest du ggf. die Timer DP im Adapter wählbar machen?
          Auch bekomme ich Fehler wenn ich keine Pumpen einsetze, und keinen Helligkeitssensor habe.
          Error in sprinklecontrol/main.js:1160:73
          Hast du dafür eine Lösung?
          achso Version des Adapter ist 0.2.7
          • M Mike Hellracer
            @dirk-peter
            Dirk PeterD Offline
            Dirk PeterD Offline
            Dirk Peter
            #124
            @mike-hellracer
            der Adapter passt die Bewässerungszeit automatisch Sekundengenau an und unterbricht auch die Bewässerung wenn die Booster-Funktion aktiv ist. Daher ist ein Ausschalten der Ventile über die den Adapter unbedingt notwendig.
            => Hier kann ich also deinen Wunsch nicht erfüllen.
            Wenn du die Funktion "Bewässerungssteuerung über Verdunstung" ausgewählt hast, so erhältst du eine Warnmeldung, da ohne Helligkeitssensor die Verdunstung nicht berechnet werden kann und somit eine Bewässerung nicht ausgelöst würde. Das soll so sein.
            Die Zeile Error in sprinklecontrol/main.js:1160:73 wird nur angesprochen, wenn du einen analogen Bodenfeuchte-Sensor ausgewählt und eingegeben hast. Wahrscheinlich ist das Feld nicht richtig befüllt.
            MfG Dirk Peter
              @mike-hellracer
              MfG Dirk Peter
              Mike Hellracer
              #125
              @dirk-peter
              Danke für die ausführliche Antwort
              Ich habe in der Tat die analogen Sensoren. Diese sind zur Zeit außerhalb und liefern "Null" und nicht 0 als Wert. Wie trage ich das ein.
              Was muss der Helligkeitssensor für einen Wert liefern? Lumen?
              Das mit der Bewässerungszeit habe ich verstanden. Nur leider hat der Bewässerung computer einen Timer Schalter der nach 60 sec abschaltet, wenn er vorher nicht nochmal betätigt wird.
              Schafft das der Adapter?
              • M Mike Hellracer
                @dirk-peter
                Dirk PeterD Offline
                Dirk PeterD Offline
                Dirk Peter
                #126
                @mike-hellracer
                die analogen Sensoren müssen Werte vom Typ String oder Number liefern. Der Wertebereich wird in der Konfiguration hinterlegt.
                Da dein Timer Schalter kein off-Signal besitzt, kann ich ihn nicht integrieren!
                Beim Helligkeitssensor, würde ich den von der Wetterstation verwenden. Alles andere hat keinen Sinn.
                Ich verwende hier die HomeMatic Wetterstation. Diese ist nicht auf Lumen geeicht.
                MfG Dirk Peter
                  @mike-hellracer
                  MfG Dirk Peter
                  Mike Hellracer
                  #127
                  @dirk-peter
                  sie schalten halt nach 60 sec ab, damit der Garten nicht überschwemmt wird.
                  Aber ich habe mir jetzt mit einem kurzen Blockly geholfen welches die Funktion übernimmt.
                  Das mit dem Helligkeitssensor probiere ich noch aus.
                  Habe ja noch ein paar Tage bis wieder gegossen werden muss. ;)
                  • M Mike Hellracer
                    @dirk-peter
                    Dirk PeterD Offline
                    Dirk PeterD Offline
                    Dirk Peter
                    #128
                    @mike-hellracer
                    nur so zur Info! Wenn du Bodenfeuchte-Sensoren verwendest, so brauchst du für diesen Bewässerungskreis keine Umweltdaten (Helligkeit, Temperatur, Luftfeuchtigkeit, Windgeschwindigkeit).
                    MfG Dirk Peter
                      @mike-hellracer
                      MfG Dirk Peter
                      Mike Hellracer
                      #129
                      @dirk-peter
                      Danke für die Info.
                      Wenn ich die Ergebnisse meiner Tests richtig verstanden habe lässt das Script keinen Mischbetrieb zu.
                      Entweder alle ohne Wetterdaten dafür mit Feuchtigkeitsensor oder ALLE ohne Sensor, aber dafür mit Wetterdaten.
                      Vlt könntest du das noch mit wenig Aufwand einbauen.
                      Oder sollte das doch gehen?
                      • M Mike Hellracer
                        @dirk-peter
                        Danke für die Info.
                        Dirk PeterD Offline
                        Dirk PeterD Offline
                        Dirk Peter
                        #130
                        @mike-hellracer
                        du kannst für jeden Bewässerungskreis separat das Verfahren zur Ermittlung der nächsten Bewässerung auswählen und somit festlegen.
                        Ein Mischbetrieb ist also ohne weiteres möglich.
                        So wie du aber die Bodenfeuchtigkeit virtuell ermittelst, ist eine Wetterstation mit allen nötigen Fühlern notwendig.
                        MfG Dirk Peter
                          @mike-hellracer
                          MfG Dirk Peter
                          Mike Hellracer
                          #131
                          @dirk-peter
                          Super, danke für deine Hilfe
                          FenriswolfF 1 Antwort Letzte Antwort
                          • M Mike Hellracer
                            @dirk-peter
                            FenriswolfF Offline
                            FenriswolfF Offline
                            Fenriswolf
                            #132
                            Moin,
                            ich verfolge diesen Adapter nun schon einige Zeit. Bei den ganzen Konfigurationsmöglichkeiten fehlt mir allerdings die für mich wichtigste Einstellmöglichkeit.
                            Wenn ich es hier richtig verstanden habe, werden die Ventile hier nur mit "wahr" und "falsch" geschaltet.
                            Ich verwende nun aber die Ventile von Gardena in Verbindung mit Rainbird-Regnern. Die Gardena Ventile werden aber nicht mit wahr und falsch gesteuert, sondern direkt über eine Zeitangabe wie lange das Ventil geöffnet werden soll.
                            Gibt es da einen Lösungsansatz den ich ggf. überlesen habe?
                            mfg
                            Marc
                            • FenriswolfF Fenriswolf
                              Moin,
                              mfg
                              Marc
                              Dirk PeterD Offline
                              Dirk PeterD Offline
                              Dirk Peter
                              #133
                              @fenriswolf
                              Hallo Fenriswolf,
                              ich steuere meine 7 Ventile (übrigens auch Gardena) über HomeMatic HM-LC-Sw4-DR und das sehr zuverlässig.
                              Die Anfrage über das Schalten der Ventile mittels TimeOut hatte ich schon des Öfteren. Aber die Steuerung verlang, das der Betrieb eines Ventils auch unterbrochen werden kann (siehe Boost-Funktion). Daher ist mir noch keine sinnvolle Steuerung mittels TimeOut eingefallen.
                              MfG Dirk Peter
                              FenriswolfF 2 Antworten Letzte Antwort
                                @fenriswolf
                                Hallo Fenriswolf,
                                MfG Dirk Peter
                                FenriswolfF Offline
                                FenriswolfF Offline
                                Fenriswolf
                                #134
                                @dirk-peter sagte in Test Adapter Sprinkle Control 0.1.4 Latest:
                                Hallo Fenriswolf,
                                MfG Dirk Peter
                                Hallo Dirk Peter,
                                Danke für deine schnelle Antwort.
                                Ich nutze zur Zeit zur Steuerung den Smartgarden-Adapter. Da ich auch die GARDENA Irrigation Control habe.
                                Zur Bewässerung verwende ich zur Zeit den Adapter Gartenbewässerung, der leider wohl nicht mehr weiterentwickelt wird. Daher war meine Überlegung ggf. umzusteigen.
                                Mit freundlichen Grüßen
                                Marc
                                  @fenriswolf
                                  Hallo Fenriswolf,
                                  MfG Dirk Peter
                                  FenriswolfF Offline
                                  FenriswolfF Offline
                                  Fenriswolf
                                  #135
                                  Hallo Fenriswolf,
                                  MfG Dirk Peter
                                  Ich nochmal:
                                  Der Timeout wird ja über Zeit in Sek angegeben, soll der abgebrochen werden, wird der Wert wieder auf „nul“ gesetzt.
                                  Falls du dich daran trauen solltest, würde ich versuche zu unterstützen, nur leider kann ich nicht programmieren, zumindest nicht hier.
                                  Marc
                                    Hallo Fenriswolf,
                                    MfG Dirk Peter
                                    Ich nochmal:
                                    Marc
                                    Dirk PeterD Offline
                                    Dirk PeterD Offline
                                    Dirk Peter
                                    #136
                                    @fenriswolf
                                    Hallo Fenriswolf, wenn ich anfangen würde Timeout zu integrieren, so müsste ich das auch für alle anderen (HomeMatic, Gardene, ...). Dies währen Sachen die ich gar nicht testen könnte. Ich glaube daher nicht, das ich das mal integrieren würde. Was einfacher währe ist, wenn du ein kleines Skript (javascript oder Blockly) dazwischen schalten würdest, um dein Timeout zu realisieren. Die maximale zeit einer Ventile kennst du ja.
                                    MfG Dirk Peter
                                    • BanditFGB Offline
                                      BanditFGB Offline
                                      BanditFG
                                      #137
                                      @Dirk-Peter
                                      ich habe im letzten Jahr eigentlich den Gartenbewässungs-Adapter genutzt. Leider wird dieser scheinbar nicht weiterentwickelt oder gepflegt..
                                      Nun bin ich auf diesen Adapter gestoßen, welche sehr interessant ist. 👍
                                      Ich hätte ein paar Fragen, hoffe ich hab das nicht nur überlesen...
                                      Ist es möglich die Ventile nach einander laufen zu lassen, bei mir ist der Wasserdruck leider zu gering?
                                      Bei mir kommt das Wasser aus der Leitung, kann ich den Adapter auch ohne Pumpe nutzen??
                                      danke schonmal für die Antwort.
                                      D Dirk PeterD 2 Antworten Letzte Antwort
                                      • BanditFGB BanditFG
                                        @Dirk-Peter
                                        D Nicht stören
                                        D Nicht stören
                                        dirkhe
                                        #138
                                        @banditfg deine Fragen beantwortet die Doku, siehe readme. Aber du brauchst keine pumpe, du definierst einfach deine zur Verfügung stehenden druck und was deine Kreise brauchen, den rest macht der Adapter von alleine, also ja, die Kreise werden in der Regel hintereinander beregnet.
                                          @Dirk-Peter
                                          Dirk PeterD Offline
                                          Dirk PeterD Offline
                                          Dirk Peter
                                          #139
                                          @banditfg
                                          Hallo, Wenn du den Wasserverbrauch deiner Ventile und die Wasserzufuhr deiner Wasserleitung (unter "maximale Pumpenleistung der Hauptpumpe in l/h") korrekt einträgst, so erkennt das System das nur ein Ventil geschaltet werden kann und sie schalten auch dann nacheinander. Zusätzlich kannst du "Maximaler Parallelbetrieb der Ventile" noch zur Sicherheit die eigentlich nicht notwendig ist auf 1 setzen.
                                          Die States für "Steuerspannung der Ventile" und "Hauptpumpe" einfach bei nicht gebrauch leer lassen. Sie werden dann auch nicht bedient.
                                          MfG Dirk Peter
                                          BanditFGB 1 Antwort Letzte Antwort
