Test Coronavirus Statistics for ioBroker
@christian-sandkaulen
Hmmm. Dann stell mal bitte auf debug und leg die komplette Log rein. Vllt kann ich da was rauslesen. -
@jlssmt sagte in Test Coronavirus Statistics for ioBroker:
Hmmm. Dann stell mal bitte auf debug und leg die komplette Log rein. Vllt kann ich da was rauslesen.wie stell ich das debugen ein?
danke
coronavirus-statistics.0 2021-11-22 18:30:38.131 debug Data from COVID-19 API received : [object Object] coronavirus-statistics.0 2021-11-22 18:30:21.821 debug Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":true,"getGermanyCities":false,"getGermanyCounties":false,"getAllGermanyFederalStates":false,"getAllGermanyCities":false,"getAllGermanyCounties":false,"loadAllCountrys":false,"selectedGermanyFederalStates":[],"selectedGermanyCities":[],"selectedGermanyCounties":[],"countries":[]} coronavirus-statistics.0 2021-11-22 18:30:21.734 info starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18 coronavirus-statistics.0 2021-11-22 18:30:18.846 debug Plugin sentry Initialize Plugin (enabled=true) coronavirus-statistics.0 2021-11-22 18:30:08.225 debug statesDB connected coronavirus-statistics.0 2021-11-22 18:30:08.224 debug States connected to redis: 127.0.0.1:9000 coronavirus-statistics.0 2021-11-22 18:30:08.186 debug States create User PubSub Client coronavirus-statistics.0 2021-11-22 18:30:08.182 debug States create System PubSub Client coronavirus-statistics.0 2021-11-22 18:30:08.160 debug Redis States: Use Redis connection: 127.0.0.1:9000 coronavirus-statistics.0 2021-11-22 18:30:08.157 debug objectDB connected coronavirus-statistics.0 2021-11-22 18:30:08.145 debug Objects connected to redis: 127.0.0.1:9001 coronavirus-statistics.0 2021-11-22 18:30:08.118 debug Objects client initialize lua scripts coronavirus-statistics.0 2021-11-22 18:30:08.116 debug Objects create User PubSub Client coronavirus-statistics.0 2021-11-22 18:30:08.114 debug Objects create System PubSub Client coronavirus-statistics.0 2021-11-22 18:30:08.108 debug Objects client ready ... initialize now coronavirus-statistics.0 2021-11-22 18:30:07.995 debug Redis Objects: Use Redis connection: 127.0.0.1:9001 coronavirus-statistics.0 2021-11-22 18:15:36.831 debug Write value : false coronavirus-statistics.0 2021-11-22 18:15:36.830 debug Create_state called for : global_totals.deaths with value : 5171700 coronavirus-statistics.0 2021-11-22 18:15:36.730 debug Write value : false coronavirus-statistics.0 2021-11-22 18:15:36.729 debug Create_state called for : global_totals.todayCases with value : 268721 coronavirus-statistics.0 2021-11-22 18:15:36.660 debug Write value : false coronavirus-statistics.0 2021-11-22 18:15:36.660 debug Create_state called for : global_totals.cases with value : 258107112 coronavirus-statistics.0 2021-11-22 18:15:36.613 debug Write value : false coronavirus-statistics.0 2021-11-22 18:15:36.611 debug Create_state called for : global_totals.updated with value : 1637600864486 coronavirus-statistics.0 2021-11-22 18:15:36.563 debug Data from COVID-19 API received : [object Object] coronavirus-statistics.0 2021-11-22 18:15:13.866 debug Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":true,"getGermanyCities":false,"getGermanyCounties":false,"getAllGermanyFederalStates":false,"getAllGermanyCities":false,"getAllGermanyCounties":false,"loadAllCountrys":false,"selectedGermanyFederalStates":[],"selectedGermanyCities":[],"selectedGermanyCounties":[],"countries":[]} coronavirus-statistics.0 2021-11-22 18:15:13.819 info starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18 coronavirus-statistics.0 2021-11-22 18:15:13.406 debug Plugin sentry Initialize Plugin (enabled=true) coronavirus-statistics.0 2021-11-22 18:15:12.645 debug statesDB connected coronavirus-statistics.0 2021-11-22 18:15:12.643 debug States connected to redis: 127.0.0.1:9000 coronavirus-statistics.0 2021-11-22 18:15:12.601 debug States create User PubSub Client coronavirus-statistics.0 2021-11-22 18:15:12.599 debug States create System PubSub Client coronavirus-statistics.0 2021-11-22 18:15:12.577 debug Redis States: Use Redis connection: 127.0.0.1:9000 coronavirus-statistics.0 2021-11-22 18:15:12.574 debug objectDB connected coronavirus-statistics.0 2021-11-22 18:15:12.562 debug Objects connected to redis: 127.0.0.1:9001 coronavirus-statistics.0 2021-11-22 18:15:12.485 debug Objects client initialize lua scripts coronavirus-statistics.0 2021-11-22 18:15:12.483 debug Objects create User PubSub Client coronavirus-statistics.0 2021-11-22 18:15:12.480 debug Objects create System PubSub Client coronavirus-statistics.0 2021-11-22 18:15:12.475 debug Objects client ready ... initialize now coronavirus-statistics.0 2021-11-22 18:15:12.397 debug Redis Objects: Use Redis connection: 127.0.0.1:9001jetzt habe ich noch mal alle instanzen gelöscht und neu installiert... jetzt komme ich nicht mal in die config rein...
danke
moin,
habe noch mal alles gelöscht und dann erst die 0.8.7 installier und dann über den link die 0.8.8.
coronavirus-statistics.0 2021-11-23 08:10:28.611 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:28.610 debug (13076) Create_state called for : global_totals.tests with value : 4217355433 coronavirus-statistics.0 2021-11-23 08:10:28.490 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:28.489 debug (13076) Create_state called for : global_totals.deathsPerOneMillion with value : 664 coronavirus-statistics.0 2021-11-23 08:10:28.370 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:28.370 debug (13076) Create_state called for : global_totals.casesPerOneMillion with value : 33159 coronavirus-statistics.0 2021-11-23 08:10:28.333 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:28.332 debug (13076) Create_state called for : global_totals.critical with value : 80585 coronavirus-statistics.0 2021-11-23 08:10:28.277 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:28.276 debug (13076) Create_state called for : global_totals.active with value : 19347150 coronavirus-statistics.0 2021-11-23 08:10:28.217 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:28.216 debug (13076) Create_state called for : global_totals.todayRecovered with value : 91155 coronavirus-statistics.0 2021-11-23 08:10:27.755 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:27.754 debug (13076) Create_state called for : global_totals.recovered with value : 233946445 coronavirus-statistics.0 2021-11-23 08:10:27.677 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:27.676 debug (13076) Create_state called for : global_totals.todayDeaths with value : 1078 coronavirus-statistics.0 2021-11-23 08:10:27.614 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:27.613 debug (13076) Create_state called for : global_totals.deaths with value : 5175770 coronavirus-statistics.0 2021-11-23 08:10:27.580 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:27.578 debug (13076) Create_state called for : global_totals.todayCases with value : 59461 coronavirus-statistics.0 2021-11-23 08:10:27.372 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:27.370 debug (13076) Create_state called for : global_totals.cases with value : 258469365 coronavirus-statistics.0 2021-11-23 08:10:27.253 debug (13076) Write value : false coronavirus-statistics.0 2021-11-23 08:10:27.251 debug (13076) Create_state called for : global_totals.updated with value : 1637650667675 coronavirus-statistics.0 2021-11-23 08:10:27.191 debug (13076) Data from COVID-19 API received : [object Object] coronavirus-statistics.0 2021-11-23 08:10:09.321 debug (13076) Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":true,"getGermanyCities":false,"getGermanyCounties":true,"getAllGermanyFederalSt coronavirus-statistics.0 2021-11-23 08:10:09.249 info (13076) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18der scheint jetzt zu laufen, aber ich habe keinen Index ..
worann könnte es liegen?
moin,
@christian-sandkaulen warte mal ab... bei mir dauerte es über das Wochenende und nun habe ich die Werte ohne weiteres zutun.
@jlssmt leider wird die Hospitalisierungs-Inzidenz nicht aktualisiert (laut Screenshot) Hier könnte ich mir allerdings vorstellen das es daran liegt das es keinen Timestamp dafür gibt...? (als Laie, nicht hauen)
@blue231181
Was meinst du mit timestamp?
iobroker vergibt je state einen internen Timestamp und das Datum ist in deinem Screenshot unten doch auch?
Ganz ehrlich. Ich hab keine Ahnung warum es bei euch teilweise nicht funktioniert. Ich hab es produktiv am Laufen und da funktioniert es tadellos. Habe auch die Daten für heute. Es ist auch nahezu die selbe Logik wie für die Vaccination und Hospital Ordner/ Channel.
Ich warte mal auf @Dutchman. Vllt weiß der was... -
@jlssmt :
Servus,
wäre es möglich über diese Seite
[https://krankenhausampel.info/](Link Adresse)
die Datenpunkte für die Krankenhausampel abzugreifen und in den Adapter zu übernehmen?
Viele Grüße!
@blue231181
Ich warte mal auf @Dutchman. Vllt weiß der was...@jlssmt sagte in Test Coronavirus Statistics for ioBroker:
@blue231181
Ich warte mal auf @Dutchman. Vllt weiß der was...🤔 erhole mich gerade von ner ziemlich starken Erkältung schaue so schnell wie möglich
@blue231181
@dutchman sagte in Test Coronavirus Statistics for ioBroker:
Gute Besserung !!!
gute Besserung!
host.PI4 2021-11-25 09:48:33.861 info stopInstance canceled schedule system.adapter.coronavirus-statistics.0 host.PI4 2021-11-25 09:48:33.860 info stopInstance system.adapter.coronavirus-statistics.0 (force=false, process=false) host.PI4 2021-11-25 09:48:26.841 warn instance system.adapter.coronavirus-statistics.0 terminated due to SIGKILL coronavirus-statistics.0 2021-11-25 09:47:48.892 info (31947) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18 host.PI4 2021-11-25 09:47:44.660 info instance system.adapter.coronavirus-statistics.0 started with pid 31947 host.PI4 2021-11-25 09:47:44.600 info instance scheduled system.adapter.coronavirus-statistics.0 */15 * * * * host.PI4 2021-11-25 09:47:41.396 info stopInstance canceled schedule system.adapter.coronavirus-statistics.0 host.PI4 2021-11-25 09:47:41.386 info stopInstance system.adapter.coronavirus-statistics.0 (force=false, process=false) host.PI4 2021-11-25 09:45:12.773 warn instance system.adapter.coronavirus-statistics.0 terminated due to SIGKILL host.PI4 2021-11-25 09:45:00.104 warn instance system.adapter.coronavirus-statistics.0 already running with pid 30702 coronavirus-statistics.0 2021-11-25 09:44:36.612 info (30702) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18coronavirus-statistics.0 2021-11-25 09:50:22.921 debug (32672) Plugin sentry Initialize Plugin (enabled=true) coronavirus-statistics.0 2021-11-25 09:50:21.360 debug (32672) statesDB connected coronavirus-statistics.0 2021-11-25 09:50:21.358 debug (32672) States connected to redis: 127.0.0.1:9000 coronavirus-statistics.0 2021-11-25 09:50:21.323 debug (32672) States create User PubSub Client coronavirus-statistics.0 2021-11-25 09:50:21.321 debug (32672) States create System PubSub Client coronavirus-statistics.0 2021-11-25 09:50:21.294 debug (32672) Redis States: Use Redis connection: 127.0.0.1:9000 coronavirus-statistics.0 2021-11-25 09:50:21.291 debug (32672) objectDB connected coronavirus-statistics.0 2021-11-25 09:50:21.278 debug (32672) Objects connected to redis: 127.0.0.1:9001 coronavirus-statistics.0 2021-11-25 09:50:21.219 debug (32672) Objects client initialize lua scripts coronavirus-statistics.0 2021-11-25 09:50:21.216 debug (32672) Objects create User PubSub Client coronavirus-statistics.0 2021-11-25 09:50:21.214 debug (32672) Objects create System PubSub Client coronavirus-statistics.0 2021-11-25 09:50:20.814 debug (32672) Objects client ready ... initialize now coronavirus-statistics.0 2021-11-25 09:50:20.492 debug (32672) Redis Objects: Use Redis connection: 127.0.0.1:9001 coronavirus-statistics.0 2021-11-25 09:49:12.488 debug (32220) Write value : false coronavirus-statistics.0 2021-11-25 09:49:12.476 debug (32220) Create_state called for : global_totals.cases with value : 259822223 coronavirus-statistics.0 2021-11-25 09:49:12.420 debug (32220) Write value : false coronavirus-statistics.0 2021-11-25 09:49:12.419 debug (32220) Create_state called for : global_totals.updated with value : 1637829494275 coronavirus-statistics.0 2021-11-25 09:49:12.365 debug (32220) Data from COVID-19 API received : [object Object] coronavirus-statistics.0 2021-11-25 09:48:44.279 debug (32220) Configuration object before config load : {"deleteUnused":false,"getContinents":false,"getGermanyFederalStates":false,"getGermanyCities":false,"getGermanyCounties":false,"getAllGermanyFederal coronavirus-statistics.0 2021-11-25 09:48:44.218 info (32220) starting. Version 0.8.8-0 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.5, js-controller: 3.3.18mal mein log
nach mehreren Anläufen, bekomme ich in der Version 0.8.8. auch die Hospitalisierungsraten angezeigt. Vielen Dank für den Service!!!
Jedoch bleibt für Niedersachsen ein Problem: Die relevante Hospitalisierungsrate sind nicht die Werte des RKI, sondern wird seitens des Landes Niedersachsen gesondert berechnet. So beträgt diese 7,3 anstatt der RKI Zahl 2,5. Gibt es eine Möglichkeit, dies in dem Adapter zu berücksichtigen?
Hallo ich bekomme immer dieses "Fehler"/Warn angeziegt kann mir einer weiter helfen...
es sieht auch si aus als würden sich die zahlen nicht wirklich mehr updaten.mfg
instance system.adapter.coronavirus-statistics.0 already running with pid 6886@rmortan Es scheint schon ein Prozess zu laufen. Stoppe die Instanz im ioBroker und dann am besten den betroffenen Prozess killen.
Dazu folgendes über die Kommandozeile machen:ps auxww|grep ioDadurch werde alle relevanten ioBroker Prozesse aufgelistet. Dort sollte dann der betroffene Prozess mit der ID 6886 auftauchen.
Mitkill -9 6886sollte das Problem gelöst sein.
danke für das Zaunfeld...
na mal sehen wie lange es jetzt läuft ohne diese Fehler Meldung
grüße
ich bin bestimmt blind aber wo sehe ich in den Objekten die t tage inzidenz Deutschland ? Hatte das bis jetzt immer nur für meinen Landkreis ausgewertet...
Ist glaube ich nicht drin, da die Länderdaten von der JHU kommen und die JHU die 7-Tage inzidenz nicht ausgibt. Die 7tage inzidenz interessiert global auch keinen, bzw. wird nicht ausgewertet.@jlssmt sagte in Test Coronavirus Statistics for ioBroker:
Ist glaube ich nicht drin, da die Länderdaten von der JHU kommen und die JHU die 7-Tage inzidenz nicht ausgibt. Die 7tage inzidenz interessiert global auch keinen, bzw. wird nicht ausgewertet.mich ja auch nicht... aber die tageschau schon :-)
Ja gut. Wenn sie dich nicht interessiert, keine Maßnahmen auf Basis dieser Zahl entschieden werden und Gesundheitsexperten diese Zahl als nicht aussagekräftig für den Pandemiestatus sehen, dann kann sie ja draußen bleiben. Weil mich interessiert sie auch nicht ;-)
