  4. Slave-Installation - reassign instance falsch [SOLVED]
34 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • Dennis.BD Dennis.B
    pi@pi:~ $ iobroker setup custom
    Current configuration:
    - Objects database:
      - Type: file
      - Host/Unix Socket: 0.0.0.0
      - Port: 9001
    - States database:
      - Type: file
      - Port: 9000
    - Data Directory: ../../iobroker-data/
    Type of objects DB [(f)ile, (r)edis, ...], default [file]: file
    Host / Unix Socket of objects DB(file), default[0.0.0.0]: 0.0.0.0
    Port of objects DB(file), default[9001]: 9001
    Type of states DB [(f)file, (r)edis, ...], default [file]: file
    Host / Unix Socket of states DB (file), default[0.0.0.0]: 0.0.0.0
    Port of states DB (file), default[9000]: 9000
    Data directory (file), default[../../iobroker-data/]:
    Host name of this machine [pi]: pi
    updating conf/iobroker.json
    pi@pi:~ $ sudo reboot now
    Connection to pi closed by remote host.
    Connection to pi closed.
    pi@rp-surveillance:~ $ iobroker setup custom
    - Objects database:
      - Type: file
      - Host/Unix Socket: 192.168.101.99
      - Port: 9001
    - States database:
      - Type: file
      - Port: 9000
    Host / Unix Socket of objects DB(file), default[192.168.101.99]: 192.168.101.99
    Host / Unix Socket of states DB (file), default[192.168.101.99]: 192.168.101.99
    Host name of this machine [rp-surveillance]: rp-surveillance
    pi@rp-surveillance:~ $ sudo reboot now
    Connection to rp-surveillance closed by remote host.
    Connection to rp-surveillance closed.
    nach neustart beider hosts geht es leider immer noch nicht.
    pi1
    2021-11-24 10:08:37.364  - info: host.pi iobroker.js-controller version 3.3.19 js-controller starting
    2021-11-24 10:08:37.381  - info: host.pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-11-24 10:08:37.383  - info: host.pi hostname: pi, node: v14.18.1
    2021-11-24 10:08:37.385  - info: host.pi ip addresses: fe80::9ca0:7208:2eb7:69f7
    2021-11-24 10:08:38.466  - info: host.pi connected to Objects and States
    2021-11-24 10:08:38.538  - info: host.pi added notifications configuration of host
    2021-11-24 10:08:41.434  - info: host.pi 3 instances found
    2021-11-24 10:08:41.462  - info: host.pi starting 3 instances
    2021-11-24 10:08:41.601  - info: host.pi instance system.adapter.admin.0 started with pid 956
    2021-11-24 10:08:45.573  - info: host.pi instance system.adapter.discovery.0 started with pid 1014
    2021-11-24 10:08:49.559  - info: host.pi instance system.adapter.backitup.0 started with pid 1075
    2021-11-24 10:08:49.922  - info: discovery.0 (1014) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.1, js-controller: 3.3.19
    2021-11-24 10:09:02.964  - info: admin.0 (956) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.1, js-controller: 3.3.19
    2021-11-24 10:09:03.131  - info: admin.0 (956) requesting all states
    2021-11-24 10:09:03.136  - info: admin.0 (956) requesting all objects
    2021-11-24 10:09:04.510  - info: admin.0 (956) received all objects
    2021-11-24 10:09:05.848  - info: admin.0 (956) http server listening on port 8081
    2021-11-24 10:09:05.863  - info: admin.0 (956) Use link "http://localhost:8081" to configure.
    2021-11-24 10:09:07.848  - info: backitup.0 (1075) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 3.3.19
    2021-11-24 10:09:08.046  - info: backitup.0 (1075) [iobroker] backup was activated at 02:40 every 1 day(s)
    2021-11-24 10:10:11.726  - info: host.pi stopInstance system.adapter.admin.0 (force=false, process=true)
    2021-11-24 10:10:11.765  - info: admin.0 (956) Got terminate signal TERMINATE_YOURSELF
    2021-11-24 10:10:11.769  - info: admin.0 (956) terminating http server on port 8081
    2021-11-24 10:10:11.772  - info: admin.0 (956) terminating
    2021-11-24 10:10:11.775  - info: admin.0 (956) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-24 10:10:11.800  - info: host.pi stopInstance system.adapter.admin.0 send kill signal
    2021-11-24 10:10:11.812  - info: host.pi stopInstance system.adapter.discovery.0 (force=false, process=true)
    2021-11-24 10:10:11.835  - info: discovery.0 (1014) Got terminate signal TERMINATE_YOURSELF
    2021-11-24 10:10:11.839  - info: discovery.0 (1014) terminating
    2021-11-24 10:10:11.842  - info: discovery.0 (1014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-24 10:10:11.886  - info: host.pi stopInstance system.adapter.backitup.0 (force=false, process=true)
    2021-11-24 10:10:11.894  - info: host.pi stopInstance system.adapter.discovery.0 send kill signal
    2021-11-24 10:10:11.903  - info: backitup.0 (1075) Got terminate signal TERMINATE_YOURSELF
    2021-11-24 10:10:11.907  - info: host.pi stopInstance system.adapter.backitup.0 send kill signal
    2021-11-24 10:10:11.907  - info: backitup.0 (1075) cleaned everything up...
    2021-11-24 10:10:11.909  - info: backitup.0 (1075) terminating
    2021-11-24 10:10:11.912  - info: backitup.0 (1075) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-24 10:10:12.369  - error: host.pi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2021-11-24 10:10:12.370  - info: host.pi Do not restart adapter system.adapter.admin.0 because desired by instance
    2021-11-24 10:10:12.440  - error: host.pi instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2021-11-24 10:10:12.442  - info: host.pi Do not restart adapter system.adapter.discovery.0 because desired by instance
    2021-11-24 10:10:12.508  - error: host.pi instance system.adapter.backitup.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2021-11-24 10:10:12.509  - info: host.pi Do not restart adapter system.adapter.backitup.0 because desired by instance
    pi2
    2021-11-24 10:09:54.486  - info: host.rp-surveillance iobroker.js-controller version 3.3.19 js-controller starting
    2021-11-24 10:09:54.495  - info: host.rp-surveillance Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-11-24 10:09:54.496  - info: host.rp-surveillance hostname: rp-surveillance, node: v14.18.1
    2021-11-24 10:09:54.497  - info: host.rp-surveillance ip addresses: 192.168.102.188 fe80::865:3498:6aae:1eb7
    2021-11-24 10:09:54.794  - info: host.rp-surveillance connected to Objects and States
    2021-11-24 10:09:54.891  - info: host.rp-surveillance added notifications configuration of host
    2021-11-24 10:09:55.528  - info: host.rp-surveillance Reassign instance admin.0 from pi to rp-surveillance
    2021-11-24 10:09:55.616  - info: host.rp-surveillance Reassign instance discovery.0 from pi to rp-surveillance
    2021-11-24 10:09:55.695  - info: host.rp-surveillance Reassign instance backitup.0 from pi to rp-surveillance
    2021-11-24 10:09:55.762  - info: host.rp-surveillance Delete host system.host.pi
    2021-11-24 10:09:55.803  - info: host.rp-surveillance Delete state "system.host.pi.notifications.system"
    2021-11-24 10:09:55.826  - info: host.rp-surveillance Delete state "system.host.pi.plugins.sentry.enabled"
    2021-11-24 10:09:55.892  - info: host.rp-surveillance Delete state "system.host.pi.compactModeEnabled"
    2021-11-24 10:09:55.912  - info: host.rp-surveillance Delete state "system.host.pi.compactgroupProcesses"
    2021-11-24 10:09:55.931  - info: host.rp-surveillance Delete state "system.host.pi.instancesAsProcess"
    2021-11-24 10:09:55.954  - info: host.rp-surveillance Delete state "system.host.pi.instancesAsCompact"
    2021-11-24 10:09:56.025  - info: host.rp-surveillance Delete state "system.host.pi.cpu"
    2021-11-24 10:09:56.047  - info: host.rp-surveillance Delete state "system.host.pi.cputime"
    2021-11-24 10:09:56.114  - info: host.rp-surveillance Delete state "system.host.pi.mem"
    2021-11-24 10:09:56.143  - info: host.rp-surveillance Delete state "system.host.pi.memHeapUsed"
    2021-11-24 10:09:56.179  - info: host.rp-surveillance Delete state "system.host.pi.memAvailable"
    2021-11-24 10:09:56.264  - info: host.rp-surveillance Delete state "system.host.pi.memHeapTotal"
    2021-11-24 10:09:56.306  - info: host.rp-surveillance Delete state "system.host.pi.memRss"
    2021-11-24 10:09:56.384  - info: host.rp-surveillance Delete state "system.host.pi.uptime"
    2021-11-24 10:09:56.404  - info: host.rp-surveillance Delete state "system.host.pi.load"
    2021-11-24 10:09:56.419  - info: host.rp-surveillance Delete state "system.host.pi.alive"
    2021-11-24 10:09:56.481  - info: host.rp-surveillance Delete state "system.host.pi.freemem"
    2021-11-24 10:09:56.496  - info: host.rp-surveillance Delete state "system.host.pi.inputCount"
    2021-11-24 10:09:56.511  - info: host.rp-surveillance Delete state "system.host.pi.outputCount"
    2021-11-24 10:09:56.526  - info: host.rp-surveillance Delete state "system.host.pi.eventLoopLag"
    2021-11-24 10:09:56.543  - info: host.rp-surveillance Delete state "system.host.pi.logLevel"
    2021-11-24 10:09:56.601  - info: host.rp-surveillance Delete state "system.host.pi.diskSize"
    2021-11-24 10:09:56.620  - info: host.rp-surveillance Delete state "system.host.pi.diskFree"
    2021-11-24 10:09:56.637  - info: host.rp-surveillance Delete state "system.host.pi.diskWarning"
    2021-11-24 10:09:56.686  - info: host.rp-surveillance 3 instances found
    2021-11-24 10:09:56.706  - info: host.rp-surveillance starting 3 instances
    2021-11-24 10:09:56.824  - info: host.rp-surveillance instance system.adapter.admin.0 started with pid 1111
    2021-11-24 10:10:00.815  - info: host.rp-surveillance instance system.adapter.discovery.0 started with pid 1693
    2021-11-24 10:10:01.942  - info: admin.0 (1111) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.1, js-controller: 3.3.19
    2021-11-24 10:10:02.138  - info: admin.0 (1111) requesting all states
    2021-11-24 10:10:02.139  - info: admin.0 (1111) requesting all objects
    2021-11-24 10:10:02.835  - info: admin.0 (1111) received all objects
    2021-11-24 10:10:03.350  - info: admin.0 (1111) http server listening on port 8081
    2021-11-24 10:10:03.351  - info: admin.0 (1111) Use link "http://localhost:8081" to configure.
    2021-11-24 10:10:19.816  - info: discovery.0 (1693) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.1, js-controller: 3.3.19
    2021-11-24 10:10:20.874  - info: host.rp-surveillance instance system.adapter.backitup.0 started with pid 1762
    2021-11-24 10:10:23.378  - info: backitup.0 (1762) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 3.3.19
    2021-11-24 10:10:23.485  - info: backitup.0 (1762) [iobroker] backup was activated at 02:40 every 1 day(s)
    @dennis-b
    Die Kisten der und in unterschiedlichen Netzen? Wird UDP da geroutet?
    Dennis.BD 1 Antwort Letzte Antwort
      @dennis-b sagte in Slave-Installation - reassign instance falsch:
      ist das der Master?
      und das der slave?
      Beim Master kein IPv4?
      Dennis.BD Offline
      Dennis.BD Offline
      Dennis.B
      beide gurkern haben ipv4 und sind im selben netz. Habe nur range 192.168.100.x bis 192.168.103.x
      pi1
      eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
              ether b8:27:eb:5a:93:30  txqueuelen 1000  (Ethernet)
              RX packets 0  bytes 0 (0.0 B)
              RX errors 0  dropped 0  overruns 0  frame 0
              TX packets 0  bytes 0 (0.0 B)
              TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
      lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
              inet 127.0.0.1  netmask 255.0.0.0
              inet6 ::1  prefixlen 128  scopeid 0x10<host>
              loop  txqueuelen 1000  (Local Loopback)
              RX packets 7431  bytes 6954458 (6.6 MiB)
              TX packets 7431  bytes 6954458 (6.6 MiB)
      wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 192.168.101.99  netmask 255.255.252.0  broadcast 192.168.103.255
              inet6 fe80::9ca0:7208:2eb7:69f7  prefixlen 64  scopeid 0x20<link>
              ether b8:27:eb:0f:c6:65  txqueuelen 1000  (Ethernet)
              RX packets 24241  bytes 14846082 (14.1 MiB)
              RX errors 0  dropped 1  overruns 0  frame 0
              TX packets 22505  bytes 20633425 (19.6 MiB)
      pi2
      eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 192.168.102.188  netmask 255.255.252.0  broadcast 192.168.103.255
              inet6 fe80::865:3498:6aae:1eb7  prefixlen 64  scopeid 0x20<link>
              ether e4:5f:01:05:49:07  txqueuelen 1000  (Ethernet)
              RX packets 759645  bytes 717546600 (684.3 MiB)
              RX errors 0  dropped 3  overruns 0  frame 0
              TX packets 446798  bytes 35770471 (34.1 MiB)
              RX packets 193  bytes 10190 (9.9 KiB)
              TX packets 193  bytes 10190 (9.9 KiB)
        pi1
        pi2
        LAN hat keine IPv4 Adresse - nur im WLAN
          Dennis.BD Offline
          Dennis.BD Offline
          Dennis.B
          LAN ist nicht verbunden
            pi1
            pi2
            passt
            im log wird versucht mit @dennis-b sagte in Slave-Installation - reassign instance falsch:
            zu verbinden, das ist die WLAN-Adresse. Aber IPv6
              passt
              Dennis.BD Offline
              Dennis.BD Offline
              Dennis.B
              ich habe ipv6 jetzt auf beiden deaktiviert und neu gestartet, leider immer noch das Problem.
              sobald der slave zum master connected kommt das hier:
                @dennis-b wir hatten letztens erst einen seltsamen Fehler in dieser Art
                https://forum.iobroker.net/topic/49496/slave-installation-master-unter-slave-adresse-erreichbar/20?_=1637743925119
                Auch mit "komischer" Netmask
                Allerdings hatte dort ein iobroker fix geholfen - warum auch immer
                  Dennis.BD Offline
                  Dennis.BD Offline
                  Dennis.B
                  @homoran said in Slave-Installation - reassign instance falsch:
                  iobroker fix
                  Ja das hatte ich auch schon gesehen und ausprobiert, leider ohne Erfolg.
                    auch nochmal mit iobroker setup custom reingesehen?
                      Dennis.BD Offline
                      Dennis.BD Offline
                      Dennis.B
                      jo - sieht auch gut aus
                      - Objects database:
                        - Type: file
                        - Port: 9001
                      - States database:
                        - Type: file
                        - Port: 9000
                      - Host name: pi
                      - Objects database:
                        - Type: file
                        - Port: 9001
                      - States database:
                        - Type: file
                        - Port: 9000
                      - Host name: rp-surveillance
                        - Objects database:
                          - Type: file
                          - Port: 9001
                        - States database:
                          - Type: file
                          - Port: 9000
                        - Host name: pi
                        - Objects database:
                          - Type: file
                          - Port: 9001
                        - States database:
                          - Type: file
                          - Port: 9000
                        @dennis-b Dann bin ich am Ende mit meinem Latein.
                        Hast du die Frage von @Thomas-Braun geprüft und beantwortet?
                        W 1 Antwort Letzte Antwort
                          @dennis-b
                          Dennis.BD Offline
                          Dennis.BD Offline
                          Dennis.B
                          @Homoran
                          UDP geht.
                          pi@pi:~ $ nc -ul 6111
                          test
                          test
                          test
                          test
                          ^C
                          pi@pi:~ $
                          pi@rp-surveillance:~ $ nc -u pi 6111
                          test
                          test
                          test
                          test
                          ^C
                            @Homoran
                            UDP geht.
                            test
                            test
                            test
                            test
                            ^C
                            pi@pi:~ $
                            test
                            test
                            test
                            test
                            ^C
                            UDP geht.
                            steht denn jetzt die IPv4 im log bei Verbindungstversuch (Slave neustart über Admin des Masters?)
                              W Offline
                              W Offline
                              wackl
                              schrieb am zuletzt editiert von wackl
                              Ich kämpfe seit 2 Tagen mit dem selben Problem.
                              Habe schon 2 Raspis aufgesetzt, gleiches verhalten,
                              dann 2 ct am Proxmox, auch kein Erfolg.
                              Downgrade vom js-controller auf 3.2.16 -> multihost geht sofort
                              Ab welcher Version das nicht mehr funktioniert wäre auszutesten...
                                UDP geht.
                                Dennis.BD Offline
                                Dennis.BD Offline
                                Dennis.B
                                ja beide zeigen ipv4 im log an.
                                • Dennis.BD Offline
                                  Dennis.BD Offline
                                  Dennis.B
                                  @wackl said in Slave-Installation - reassign instance falsch:
                                  Kann ich bestaetigen, nach downgrade funktioniert es.
                                  • W Offline
                                    W Offline
                                    wackl
                                    Hab jetzt einige durchprobiert. Bis 3.3.18 geht's anscheinend. Bei 3.3.19 nicht mehr.
                                    • W wackl
                                      @wackl
                                      Dann weißt du ja was als Beta-Tester zu tun ist.
                                        @wackl
                                        W Offline
                                        W Offline
                                        wackl
                                        Ich wusste nicht, das ich beim installieren mit dem Befehl
                                        curl -sLf https://iobroker.net/install.sh | bash -
                                        eine Beta-Version bekomme :man-shrugging:
                                        • W wackl
                                          @wackl
                                          js-controller
                                          github:	4.0.0
                                          latest:	3.3.19 for 6 days
                                          stable:	3.3.18 for 73 days
