  4. Slave-Installation - reassign instance falsch [SOLVED]
34 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • Dennis.BD Dennis.B
    @homoran yea i have tried that before but it does not really do anything if you do re-login.... I only grabbed 2 new pi's because i have the same issue with my debian server and that the server might have an issue but it might be something else here.
    @dennis-b OK - dann bitte manuell konfigurieren über iobroker setup custom (kein enable oder discover nutzen)
    Anschließende Neustarts der beiden Hosts
    Dennis.BD 1 Antwort Letzte Antwort
      Dennis.BD Offline
      Dennis.BD Offline
      Dennis.B
      pi@pi:~ $ iobroker setup custom
      Current configuration:
      - Objects database:
        - Type: file
        - Host/Unix Socket: 0.0.0.0
        - Port: 9001
      - States database:
        - Type: file
        - Port: 9000
      - Data Directory: ../../iobroker-data/
      Type of objects DB [(f)ile, (r)edis, ...], default [file]: file
      Host / Unix Socket of objects DB(file), default[0.0.0.0]: 0.0.0.0
      Port of objects DB(file), default[9001]: 9001
      Type of states DB [(f)file, (r)edis, ...], default [file]: file
      Host / Unix Socket of states DB (file), default[0.0.0.0]: 0.0.0.0
      Port of states DB (file), default[9000]: 9000
      Data directory (file), default[../../iobroker-data/]:
      Host name of this machine [pi]: pi
      updating conf/iobroker.json
      pi@pi:~ $ sudo reboot now
      Connection to pi closed by remote host.
      Connection to pi closed.
      pi@rp-surveillance:~ $ iobroker setup custom
      - Objects database:
        - Type: file
        - Host/Unix Socket: 192.168.101.99
        - Port: 9001
      - States database:
        - Type: file
        - Port: 9000
      Host / Unix Socket of objects DB(file), default[192.168.101.99]: 192.168.101.99
      Host / Unix Socket of states DB (file), default[192.168.101.99]: 192.168.101.99
      Host name of this machine [rp-surveillance]: rp-surveillance
      pi@rp-surveillance:~ $ sudo reboot now
      Connection to rp-surveillance closed by remote host.
      Connection to rp-surveillance closed.
      nach neustart beider hosts geht es leider immer noch nicht.
      pi1
      2021-11-24 10:08:37.364  - info: host.pi iobroker.js-controller version 3.3.19 js-controller starting
      2021-11-24 10:08:37.381  - info: host.pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-11-24 10:08:37.383  - info: host.pi hostname: pi, node: v14.18.1
      2021-11-24 10:08:37.385  - info: host.pi ip addresses: fe80::9ca0:7208:2eb7:69f7
      2021-11-24 10:08:38.466  - info: host.pi connected to Objects and States
      2021-11-24 10:08:38.538  - info: host.pi added notifications configuration of host
      2021-11-24 10:08:41.434  - info: host.pi 3 instances found
      2021-11-24 10:08:41.462  - info: host.pi starting 3 instances
      2021-11-24 10:08:41.601  - info: host.pi instance system.adapter.admin.0 started with pid 956
      2021-11-24 10:08:45.573  - info: host.pi instance system.adapter.discovery.0 started with pid 1014
      2021-11-24 10:08:49.559  - info: host.pi instance system.adapter.backitup.0 started with pid 1075
      2021-11-24 10:08:49.922  - info: discovery.0 (1014) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.1, js-controller: 3.3.19
      2021-11-24 10:09:02.964  - info: admin.0 (956) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.1, js-controller: 3.3.19
      2021-11-24 10:09:03.131  - info: admin.0 (956) requesting all states
      2021-11-24 10:09:03.136  - info: admin.0 (956) requesting all objects
      2021-11-24 10:09:04.510  - info: admin.0 (956) received all objects
      2021-11-24 10:09:05.848  - info: admin.0 (956) http server listening on port 8081
      2021-11-24 10:09:05.863  - info: admin.0 (956) Use link "http://localhost:8081" to configure.
      2021-11-24 10:09:07.848  - info: backitup.0 (1075) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 3.3.19
      2021-11-24 10:09:08.046  - info: backitup.0 (1075) [iobroker] backup was activated at 02:40 every 1 day(s)
      2021-11-24 10:10:11.726  - info: host.pi stopInstance system.adapter.admin.0 (force=false, process=true)
      2021-11-24 10:10:11.765  - info: admin.0 (956) Got terminate signal TERMINATE_YOURSELF
      2021-11-24 10:10:11.769  - info: admin.0 (956) terminating http server on port 8081
      2021-11-24 10:10:11.772  - info: admin.0 (956) terminating
      2021-11-24 10:10:11.775  - info: admin.0 (956) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-24 10:10:11.800  - info: host.pi stopInstance system.adapter.admin.0 send kill signal
      2021-11-24 10:10:11.812  - info: host.pi stopInstance system.adapter.discovery.0 (force=false, process=true)
      2021-11-24 10:10:11.835  - info: discovery.0 (1014) Got terminate signal TERMINATE_YOURSELF
      2021-11-24 10:10:11.839  - info: discovery.0 (1014) terminating
      2021-11-24 10:10:11.842  - info: discovery.0 (1014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-24 10:10:11.886  - info: host.pi stopInstance system.adapter.backitup.0 (force=false, process=true)
      2021-11-24 10:10:11.894  - info: host.pi stopInstance system.adapter.discovery.0 send kill signal
      2021-11-24 10:10:11.903  - info: backitup.0 (1075) Got terminate signal TERMINATE_YOURSELF
      2021-11-24 10:10:11.907  - info: host.pi stopInstance system.adapter.backitup.0 send kill signal
      2021-11-24 10:10:11.907  - info: backitup.0 (1075) cleaned everything up...
      2021-11-24 10:10:11.909  - info: backitup.0 (1075) terminating
      2021-11-24 10:10:11.912  - info: backitup.0 (1075) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-24 10:10:12.369  - error: host.pi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2021-11-24 10:10:12.370  - info: host.pi Do not restart adapter system.adapter.admin.0 because desired by instance
      2021-11-24 10:10:12.440  - error: host.pi instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2021-11-24 10:10:12.442  - info: host.pi Do not restart adapter system.adapter.discovery.0 because desired by instance
      2021-11-24 10:10:12.508  - error: host.pi instance system.adapter.backitup.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2021-11-24 10:10:12.509  - info: host.pi Do not restart adapter system.adapter.backitup.0 because desired by instance
      pi2
      2021-11-24 10:09:54.486  - info: host.rp-surveillance iobroker.js-controller version 3.3.19 js-controller starting
      2021-11-24 10:09:54.495  - info: host.rp-surveillance Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2021-11-24 10:09:54.496  - info: host.rp-surveillance hostname: rp-surveillance, node: v14.18.1
      2021-11-24 10:09:54.497  - info: host.rp-surveillance ip addresses: 192.168.102.188 fe80::865:3498:6aae:1eb7
      2021-11-24 10:09:54.794  - info: host.rp-surveillance connected to Objects and States
      2021-11-24 10:09:54.891  - info: host.rp-surveillance added notifications configuration of host
      2021-11-24 10:09:55.528  - info: host.rp-surveillance Reassign instance admin.0 from pi to rp-surveillance
      2021-11-24 10:09:55.616  - info: host.rp-surveillance Reassign instance discovery.0 from pi to rp-surveillance
      2021-11-24 10:09:55.695  - info: host.rp-surveillance Reassign instance backitup.0 from pi to rp-surveillance
      2021-11-24 10:09:55.762  - info: host.rp-surveillance Delete host system.host.pi
      2021-11-24 10:09:55.803  - info: host.rp-surveillance Delete state "system.host.pi.notifications.system"
      2021-11-24 10:09:55.826  - info: host.rp-surveillance Delete state "system.host.pi.plugins.sentry.enabled"
      2021-11-24 10:09:55.892  - info: host.rp-surveillance Delete state "system.host.pi.compactModeEnabled"
      2021-11-24 10:09:55.912  - info: host.rp-surveillance Delete state "system.host.pi.compactgroupProcesses"
      2021-11-24 10:09:55.931  - info: host.rp-surveillance Delete state "system.host.pi.instancesAsProcess"
      2021-11-24 10:09:55.954  - info: host.rp-surveillance Delete state "system.host.pi.instancesAsCompact"
      2021-11-24 10:09:56.025  - info: host.rp-surveillance Delete state "system.host.pi.cpu"
      2021-11-24 10:09:56.047  - info: host.rp-surveillance Delete state "system.host.pi.cputime"
      2021-11-24 10:09:56.114  - info: host.rp-surveillance Delete state "system.host.pi.mem"
      2021-11-24 10:09:56.143  - info: host.rp-surveillance Delete state "system.host.pi.memHeapUsed"
      2021-11-24 10:09:56.179  - info: host.rp-surveillance Delete state "system.host.pi.memAvailable"
      2021-11-24 10:09:56.264  - info: host.rp-surveillance Delete state "system.host.pi.memHeapTotal"
      2021-11-24 10:09:56.306  - info: host.rp-surveillance Delete state "system.host.pi.memRss"
      2021-11-24 10:09:56.384  - info: host.rp-surveillance Delete state "system.host.pi.uptime"
      2021-11-24 10:09:56.404  - info: host.rp-surveillance Delete state "system.host.pi.load"
      2021-11-24 10:09:56.419  - info: host.rp-surveillance Delete state "system.host.pi.alive"
      2021-11-24 10:09:56.481  - info: host.rp-surveillance Delete state "system.host.pi.freemem"
      2021-11-24 10:09:56.496  - info: host.rp-surveillance Delete state "system.host.pi.inputCount"
      2021-11-24 10:09:56.511  - info: host.rp-surveillance Delete state "system.host.pi.outputCount"
      2021-11-24 10:09:56.526  - info: host.rp-surveillance Delete state "system.host.pi.eventLoopLag"
      2021-11-24 10:09:56.543  - info: host.rp-surveillance Delete state "system.host.pi.logLevel"
      2021-11-24 10:09:56.601  - info: host.rp-surveillance Delete state "system.host.pi.diskSize"
      2021-11-24 10:09:56.620  - info: host.rp-surveillance Delete state "system.host.pi.diskFree"
      2021-11-24 10:09:56.637  - info: host.rp-surveillance Delete state "system.host.pi.diskWarning"
      2021-11-24 10:09:56.686  - info: host.rp-surveillance 3 instances found
      2021-11-24 10:09:56.706  - info: host.rp-surveillance starting 3 instances
      2021-11-24 10:09:56.824  - info: host.rp-surveillance instance system.adapter.admin.0 started with pid 1111
      2021-11-24 10:10:00.815  - info: host.rp-surveillance instance system.adapter.discovery.0 started with pid 1693
      2021-11-24 10:10:01.942  - info: admin.0 (1111) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.1, js-controller: 3.3.19
      2021-11-24 10:10:02.138  - info: admin.0 (1111) requesting all states
      2021-11-24 10:10:02.139  - info: admin.0 (1111) requesting all objects
      2021-11-24 10:10:02.835  - info: admin.0 (1111) received all objects
      2021-11-24 10:10:03.350  - info: admin.0 (1111) http server listening on port 8081
      2021-11-24 10:10:03.351  - info: admin.0 (1111) Use link "http://localhost:8081" to configure.
      2021-11-24 10:10:19.816  - info: discovery.0 (1693) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.1, js-controller: 3.3.19
      2021-11-24 10:10:20.874  - info: host.rp-surveillance instance system.adapter.backitup.0 started with pid 1762
      2021-11-24 10:10:23.378  - info: backitup.0 (1762) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 3.3.19
      2021-11-24 10:10:23.485  - info: backitup.0 (1762) [iobroker] backup was activated at 02:40 every 1 day(s)
        - Objects database:
          - Type: file
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        - Objects database:
          - Type: file
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        pi1
        pi2
        @dennis-b sagte in Slave-Installation - reassign instance falsch:
        ist das der Master?
        und das der slave?
        Beim Master kein IPv4?
          - Objects database:
            - Type: file
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          - Objects database:
            - Type: file
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          pi1
          pi2
          @dennis-b
          Die Kisten der und in unterschiedlichen Netzen? Wird UDP da geroutet?
            ist das der Master?
            und das der slave?
            Dennis.BD Offline
            Dennis.BD Offline
            Dennis.B
            beide gurkern haben ipv4 und sind im selben netz. Habe nur range 192.168.100.x bis 192.168.103.x
            pi1
            eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
                    ether b8:27:eb:5a:93:30  txqueuelen 1000  (Ethernet)
                    RX packets 0  bytes 0 (0.0 B)
                    RX errors 0  dropped 0  overruns 0  frame 0
                    TX packets 0  bytes 0 (0.0 B)
                    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
            lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                    inet 127.0.0.1  netmask 255.0.0.0
                    inet6 ::1  prefixlen 128  scopeid 0x10<host>
                    loop  txqueuelen 1000  (Local Loopback)
                    RX packets 7431  bytes 6954458 (6.6 MiB)
                    TX packets 7431  bytes 6954458 (6.6 MiB)
            wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                    inet 192.168.101.99  netmask 255.255.252.0  broadcast 192.168.103.255
                    inet6 fe80::9ca0:7208:2eb7:69f7  prefixlen 64  scopeid 0x20<link>
                    ether b8:27:eb:0f:c6:65  txqueuelen 1000  (Ethernet)
                    RX packets 24241  bytes 14846082 (14.1 MiB)
                    RX errors 0  dropped 1  overruns 0  frame 0
                    TX packets 22505  bytes 20633425 (19.6 MiB)
            pi2
            eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                    inet 192.168.102.188  netmask 255.255.252.0  broadcast 192.168.103.255
                    inet6 fe80::865:3498:6aae:1eb7  prefixlen 64  scopeid 0x20<link>
                    ether e4:5f:01:05:49:07  txqueuelen 1000  (Ethernet)
                    RX packets 759645  bytes 717546600 (684.3 MiB)
                    RX errors 0  dropped 3  overruns 0  frame 0
                    TX packets 446798  bytes 35770471 (34.1 MiB)
                    RX packets 193  bytes 10190 (9.9 KiB)
                    TX packets 193  bytes 10190 (9.9 KiB)
              pi1
              pi2
              LAN hat keine IPv4 Adresse - nur im WLAN
                Dennis.BD Offline
                Dennis.BD Offline
                Dennis.B
                LAN ist nicht verbunden
                  pi1
                  pi2
                  passt
                  im log wird versucht mit @dennis-b sagte in Slave-Installation - reassign instance falsch:
                  zu verbinden, das ist die WLAN-Adresse. Aber IPv6
                    passt
                    Dennis.BD Offline
                    Dennis.BD Offline
                    Dennis.B
                    ich habe ipv6 jetzt auf beiden deaktiviert und neu gestartet, leider immer noch das Problem.
                    sobald der slave zum master connected kommt das hier:
                      @dennis-b wir hatten letztens erst einen seltsamen Fehler in dieser Art
                      https://forum.iobroker.net/topic/49496/slave-installation-master-unter-slave-adresse-erreichbar/20?_=1637743925119
                      Auch mit "komischer" Netmask
                      Allerdings hatte dort ein iobroker fix geholfen - warum auch immer
                        Dennis.BD Offline
                        Dennis.BD Offline
                        Dennis.B
                        @homoran said in Slave-Installation - reassign instance falsch:
                        iobroker fix
                        Ja das hatte ich auch schon gesehen und ausprobiert, leider ohne Erfolg.
                          auch nochmal mit iobroker setup custom reingesehen?
                            Dennis.BD Offline
                            Dennis.BD Offline
                            Dennis.B
                            jo - sieht auch gut aus
                            - Objects database:
                              - Type: file
                              - Port: 9001
                            - States database:
                              - Type: file
                              - Port: 9000
                            - Host name: pi
                            - Objects database:
                              - Type: file
                              - Port: 9001
                            - States database:
                              - Type: file
                              - Port: 9000
                            - Host name: rp-surveillance
                              - Objects database:
                                - Type: file
                                - Port: 9001
                              - States database:
                                - Type: file
                                - Port: 9000
                              - Host name: pi
                              - Objects database:
                                - Type: file
                                - Port: 9001
                              - States database:
                                - Type: file
                                - Port: 9000
                              @dennis-b Dann bin ich am Ende mit meinem Latein.
                              Hast du die Frage von @Thomas-Braun geprüft und beantwortet?
                              W 1 Antwort Letzte Antwort
                                @dennis-b
                                Dennis.BD Offline
                                Dennis.BD Offline
                                Dennis.B
                                @Homoran
                                UDP geht.
                                pi@pi:~ $ nc -ul 6111
                                test
                                test
                                test
                                test
                                ^C
                                pi@pi:~ $
                                pi@rp-surveillance:~ $ nc -u pi 6111
                                test
                                test
                                test
                                test
                                ^C
                                  @Homoran
                                  UDP geht.
                                  test
                                  test
                                  test
                                  test
                                  ^C
                                  pi@pi:~ $
                                  test
                                  test
                                  test
                                  test
                                  ^C
                                  UDP geht.
                                  steht denn jetzt die IPv4 im log bei Verbindungstversuch (Slave neustart über Admin des Masters?)
                                    W Offline
                                    W Offline
                                    wackl
                                    schrieb am zuletzt editiert von wackl
                                    Ich kämpfe seit 2 Tagen mit dem selben Problem.
                                    Habe schon 2 Raspis aufgesetzt, gleiches verhalten,
                                    dann 2 ct am Proxmox, auch kein Erfolg.
                                    Downgrade vom js-controller auf 3.2.16 -> multihost geht sofort
                                    Ab welcher Version das nicht mehr funktioniert wäre auszutesten...
                                      UDP geht.
                                      Dennis.BD Offline
                                      Dennis.BD Offline
                                      Dennis.B
                                      ja beide zeigen ipv4 im log an.
                                      • Dennis.BD Offline
                                        Dennis.BD Offline
                                        Dennis.B
                                        @wackl said in Slave-Installation - reassign instance falsch:
                                        Kann ich bestaetigen, nach downgrade funktioniert es.
                                        • W Offline
                                          W Offline
                                          wackl
                                          Hab jetzt einige durchprobiert. Bis 3.3.18 geht's anscheinend. Bei 3.3.19 nicht mehr.
