  4. Slave-Installation - reassign instance falsch [SOLVED]
34 Beiträge 5 Kommentatoren 1.7k Aufrufe 4 Beobachtet
    @dennis-b sagte in Slave-Installation - reassign instance falsch:
    You need to re-login before doing anything else on the console!
    did you do that?
    Dennis.BD Offline
    Dennis.BD Offline
    Dennis.B
    @homoran yea i have tried that before but it does not really do anything if you do re-login.... I only grabbed 2 new pi's because i have the same issue with my debian server and that the server might have an issue but it might be something else here.
    • Dennis.BD Dennis.B
      @dennis-b OK - dann bitte manuell konfigurieren über iobroker setup custom (kein enable oder discover nutzen)
      Anschließende Neustarts der beiden Hosts
      Dennis.BD 1 Antwort Letzte Antwort
        Dennis.BD Offline
        Dennis.BD Offline
        Dennis.B
        pi@pi:~ $ iobroker setup custom
        Current configuration:
        - Objects database:
          - Type: file
          - Host/Unix Socket: 0.0.0.0
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        - Data Directory: ../../iobroker-data/
        Type of objects DB [(f)ile, (r)edis, ...], default [file]: file
        Host / Unix Socket of objects DB(file), default[0.0.0.0]: 0.0.0.0
        Port of objects DB(file), default[9001]: 9001
        Type of states DB [(f)file, (r)edis, ...], default [file]: file
        Host / Unix Socket of states DB (file), default[0.0.0.0]: 0.0.0.0
        Port of states DB (file), default[9000]: 9000
        Data directory (file), default[../../iobroker-data/]:
        Host name of this machine [pi]: pi
        updating conf/iobroker.json
        pi@pi:~ $ sudo reboot now
        Connection to pi closed by remote host.
        Connection to pi closed.
        pi@rp-surveillance:~ $ iobroker setup custom
        - Objects database:
          - Type: file
          - Host/Unix Socket: 192.168.101.99
          - Port: 9001
        - States database:
          - Type: file
          - Port: 9000
        Host / Unix Socket of objects DB(file), default[192.168.101.99]: 192.168.101.99
        Host / Unix Socket of states DB (file), default[192.168.101.99]: 192.168.101.99
        Host name of this machine [rp-surveillance]: rp-surveillance
        pi@rp-surveillance:~ $ sudo reboot now
        Connection to rp-surveillance closed by remote host.
        Connection to rp-surveillance closed.
        nach neustart beider hosts geht es leider immer noch nicht.
        pi1
        2021-11-24 10:08:37.364  - info: host.pi iobroker.js-controller version 3.3.19 js-controller starting
        2021-11-24 10:08:37.381  - info: host.pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-11-24 10:08:37.383  - info: host.pi hostname: pi, node: v14.18.1
        2021-11-24 10:08:37.385  - info: host.pi ip addresses: fe80::9ca0:7208:2eb7:69f7
        2021-11-24 10:08:38.466  - info: host.pi connected to Objects and States
        2021-11-24 10:08:38.538  - info: host.pi added notifications configuration of host
        2021-11-24 10:08:41.434  - info: host.pi 3 instances found
        2021-11-24 10:08:41.462  - info: host.pi starting 3 instances
        2021-11-24 10:08:41.601  - info: host.pi instance system.adapter.admin.0 started with pid 956
        2021-11-24 10:08:45.573  - info: host.pi instance system.adapter.discovery.0 started with pid 1014
        2021-11-24 10:08:49.559  - info: host.pi instance system.adapter.backitup.0 started with pid 1075
        2021-11-24 10:08:49.922  - info: discovery.0 (1014) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.1, js-controller: 3.3.19
        2021-11-24 10:09:02.964  - info: admin.0 (956) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.1, js-controller: 3.3.19
        2021-11-24 10:09:03.131  - info: admin.0 (956) requesting all states
        2021-11-24 10:09:03.136  - info: admin.0 (956) requesting all objects
        2021-11-24 10:09:04.510  - info: admin.0 (956) received all objects
        2021-11-24 10:09:05.848  - info: admin.0 (956) http server listening on port 8081
        2021-11-24 10:09:05.863  - info: admin.0 (956) Use link "http://localhost:8081" to configure.
        2021-11-24 10:09:07.848  - info: backitup.0 (1075) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 3.3.19
        2021-11-24 10:09:08.046  - info: backitup.0 (1075) [iobroker] backup was activated at 02:40 every 1 day(s)
        2021-11-24 10:10:11.726  - info: host.pi stopInstance system.adapter.admin.0 (force=false, process=true)
        2021-11-24 10:10:11.765  - info: admin.0 (956) Got terminate signal TERMINATE_YOURSELF
        2021-11-24 10:10:11.769  - info: admin.0 (956) terminating http server on port 8081
        2021-11-24 10:10:11.772  - info: admin.0 (956) terminating
        2021-11-24 10:10:11.775  - info: admin.0 (956) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-11-24 10:10:11.800  - info: host.pi stopInstance system.adapter.admin.0 send kill signal
        2021-11-24 10:10:11.812  - info: host.pi stopInstance system.adapter.discovery.0 (force=false, process=true)
        2021-11-24 10:10:11.835  - info: discovery.0 (1014) Got terminate signal TERMINATE_YOURSELF
        2021-11-24 10:10:11.839  - info: discovery.0 (1014) terminating
        2021-11-24 10:10:11.842  - info: discovery.0 (1014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-11-24 10:10:11.886  - info: host.pi stopInstance system.adapter.backitup.0 (force=false, process=true)
        2021-11-24 10:10:11.894  - info: host.pi stopInstance system.adapter.discovery.0 send kill signal
        2021-11-24 10:10:11.903  - info: backitup.0 (1075) Got terminate signal TERMINATE_YOURSELF
        2021-11-24 10:10:11.907  - info: host.pi stopInstance system.adapter.backitup.0 send kill signal
        2021-11-24 10:10:11.907  - info: backitup.0 (1075) cleaned everything up...
        2021-11-24 10:10:11.909  - info: backitup.0 (1075) terminating
        2021-11-24 10:10:11.912  - info: backitup.0 (1075) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-11-24 10:10:12.369  - error: host.pi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2021-11-24 10:10:12.370  - info: host.pi Do not restart adapter system.adapter.admin.0 because desired by instance
        2021-11-24 10:10:12.440  - error: host.pi instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2021-11-24 10:10:12.442  - info: host.pi Do not restart adapter system.adapter.discovery.0 because desired by instance
        2021-11-24 10:10:12.508  - error: host.pi instance system.adapter.backitup.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2021-11-24 10:10:12.509  - info: host.pi Do not restart adapter system.adapter.backitup.0 because desired by instance
        pi2
        2021-11-24 10:09:54.486  - info: host.rp-surveillance iobroker.js-controller version 3.3.19 js-controller starting
        2021-11-24 10:09:54.495  - info: host.rp-surveillance Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        2021-11-24 10:09:54.496  - info: host.rp-surveillance hostname: rp-surveillance, node: v14.18.1
        2021-11-24 10:09:54.497  - info: host.rp-surveillance ip addresses: 192.168.102.188 fe80::865:3498:6aae:1eb7
        2021-11-24 10:09:54.794  - info: host.rp-surveillance connected to Objects and States
        2021-11-24 10:09:54.891  - info: host.rp-surveillance added notifications configuration of host
        2021-11-24 10:09:55.528  - info: host.rp-surveillance Reassign instance admin.0 from pi to rp-surveillance
        2021-11-24 10:09:55.616  - info: host.rp-surveillance Reassign instance discovery.0 from pi to rp-surveillance
        2021-11-24 10:09:55.695  - info: host.rp-surveillance Reassign instance backitup.0 from pi to rp-surveillance
        2021-11-24 10:09:55.762  - info: host.rp-surveillance Delete host system.host.pi
        2021-11-24 10:09:55.803  - info: host.rp-surveillance Delete state "system.host.pi.notifications.system"
        2021-11-24 10:09:55.826  - info: host.rp-surveillance Delete state "system.host.pi.plugins.sentry.enabled"
        2021-11-24 10:09:55.892  - info: host.rp-surveillance Delete state "system.host.pi.compactModeEnabled"
        2021-11-24 10:09:55.912  - info: host.rp-surveillance Delete state "system.host.pi.compactgroupProcesses"
        2021-11-24 10:09:55.931  - info: host.rp-surveillance Delete state "system.host.pi.instancesAsProcess"
        2021-11-24 10:09:55.954  - info: host.rp-surveillance Delete state "system.host.pi.instancesAsCompact"
        2021-11-24 10:09:56.025  - info: host.rp-surveillance Delete state "system.host.pi.cpu"
        2021-11-24 10:09:56.047  - info: host.rp-surveillance Delete state "system.host.pi.cputime"
        2021-11-24 10:09:56.114  - info: host.rp-surveillance Delete state "system.host.pi.mem"
        2021-11-24 10:09:56.143  - info: host.rp-surveillance Delete state "system.host.pi.memHeapUsed"
        2021-11-24 10:09:56.179  - info: host.rp-surveillance Delete state "system.host.pi.memAvailable"
        2021-11-24 10:09:56.264  - info: host.rp-surveillance Delete state "system.host.pi.memHeapTotal"
        2021-11-24 10:09:56.306  - info: host.rp-surveillance Delete state "system.host.pi.memRss"
        2021-11-24 10:09:56.384  - info: host.rp-surveillance Delete state "system.host.pi.uptime"
        2021-11-24 10:09:56.404  - info: host.rp-surveillance Delete state "system.host.pi.load"
        2021-11-24 10:09:56.419  - info: host.rp-surveillance Delete state "system.host.pi.alive"
        2021-11-24 10:09:56.481  - info: host.rp-surveillance Delete state "system.host.pi.freemem"
        2021-11-24 10:09:56.496  - info: host.rp-surveillance Delete state "system.host.pi.inputCount"
        2021-11-24 10:09:56.511  - info: host.rp-surveillance Delete state "system.host.pi.outputCount"
        2021-11-24 10:09:56.526  - info: host.rp-surveillance Delete state "system.host.pi.eventLoopLag"
        2021-11-24 10:09:56.543  - info: host.rp-surveillance Delete state "system.host.pi.logLevel"
        2021-11-24 10:09:56.601  - info: host.rp-surveillance Delete state "system.host.pi.diskSize"
        2021-11-24 10:09:56.620  - info: host.rp-surveillance Delete state "system.host.pi.diskFree"
        2021-11-24 10:09:56.637  - info: host.rp-surveillance Delete state "system.host.pi.diskWarning"
        2021-11-24 10:09:56.686  - info: host.rp-surveillance 3 instances found
        2021-11-24 10:09:56.706  - info: host.rp-surveillance starting 3 instances
        2021-11-24 10:09:56.824  - info: host.rp-surveillance instance system.adapter.admin.0 started with pid 1111
        2021-11-24 10:10:00.815  - info: host.rp-surveillance instance system.adapter.discovery.0 started with pid 1693
        2021-11-24 10:10:01.942  - info: admin.0 (1111) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.1, js-controller: 3.3.19
        2021-11-24 10:10:02.138  - info: admin.0 (1111) requesting all states
        2021-11-24 10:10:02.139  - info: admin.0 (1111) requesting all objects
        2021-11-24 10:10:02.835  - info: admin.0 (1111) received all objects
        2021-11-24 10:10:03.350  - info: admin.0 (1111) http server listening on port 8081
        2021-11-24 10:10:03.351  - info: admin.0 (1111) Use link "http://localhost:8081" to configure.
        2021-11-24 10:10:19.816  - info: discovery.0 (1693) starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v14.18.1, js-controller: 3.3.19
        2021-11-24 10:10:20.874  - info: host.rp-surveillance instance system.adapter.backitup.0 started with pid 1762
        2021-11-24 10:10:23.378  - info: backitup.0 (1762) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.1, js-controller: 3.3.19
        2021-11-24 10:10:23.485  - info: backitup.0 (1762) [iobroker] backup was activated at 02:40 every 1 day(s)
          - Objects database:
            - Type: file
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          - Objects database:
            - Type: file
            - Port: 9001
          - States database:
            - Type: file
            - Port: 9000
          pi1
          pi2
          ist das der Master?
          und das der slave?
          Beim Master kein IPv4?
            - Objects database:
              - Type: file
              - Port: 9001
            - States database:
              - Type: file
              - Port: 9000
            - Objects database:
              - Type: file
              - Port: 9001
            - States database:
              - Type: file
              - Port: 9000
            pi1
            pi2
            @dennis-b
            Die Kisten der und in unterschiedlichen Netzen? Wird UDP da geroutet?
              ist das der Master?
              und das der slave?
              Dennis.BD Offline
              Dennis.BD Offline
              Dennis.B
              beide gurkern haben ipv4 und sind im selben netz. Habe nur range 192.168.100.x bis 192.168.103.x
              pi1
              eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
                      ether b8:27:eb:5a:93:30  txqueuelen 1000  (Ethernet)
                      RX packets 0  bytes 0 (0.0 B)
                      RX errors 0  dropped 0  overruns 0  frame 0
                      TX packets 0  bytes 0 (0.0 B)
                      TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
              lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                      inet 127.0.0.1  netmask 255.0.0.0
                      inet6 ::1  prefixlen 128  scopeid 0x10<host>
                      loop  txqueuelen 1000  (Local Loopback)
                      RX packets 7431  bytes 6954458 (6.6 MiB)
                      TX packets 7431  bytes 6954458 (6.6 MiB)
              wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                      inet 192.168.101.99  netmask 255.255.252.0  broadcast 192.168.103.255
                      inet6 fe80::9ca0:7208:2eb7:69f7  prefixlen 64  scopeid 0x20<link>
                      ether b8:27:eb:0f:c6:65  txqueuelen 1000  (Ethernet)
                      RX packets 24241  bytes 14846082 (14.1 MiB)
                      RX errors 0  dropped 1  overruns 0  frame 0
                      TX packets 22505  bytes 20633425 (19.6 MiB)
              pi2
              eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                      inet 192.168.102.188  netmask 255.255.252.0  broadcast 192.168.103.255
                      inet6 fe80::865:3498:6aae:1eb7  prefixlen 64  scopeid 0x20<link>
                      ether e4:5f:01:05:49:07  txqueuelen 1000  (Ethernet)
                      RX packets 759645  bytes 717546600 (684.3 MiB)
                      RX errors 0  dropped 3  overruns 0  frame 0
                      TX packets 446798  bytes 35770471 (34.1 MiB)
                      RX packets 193  bytes 10190 (9.9 KiB)
                      TX packets 193  bytes 10190 (9.9 KiB)
                pi1
                pi2
                LAN hat keine IPv4 Adresse - nur im WLAN
                  Dennis.BD Offline
                  Dennis.BD Offline
                  Dennis.B
                  LAN ist nicht verbunden
                    pi1
                    pi2
                    passt
                    im log wird versucht mit @dennis-b sagte in Slave-Installation - reassign instance falsch:
                    zu verbinden, das ist die WLAN-Adresse. Aber IPv6
                      passt
                      Dennis.BD Offline
                      Dennis.BD Offline
                      Dennis.B
                      ich habe ipv6 jetzt auf beiden deaktiviert und neu gestartet, leider immer noch das Problem.
                      sobald der slave zum master connected kommt das hier:
                        @dennis-b wir hatten letztens erst einen seltsamen Fehler in dieser Art
                        https://forum.iobroker.net/topic/49496/slave-installation-master-unter-slave-adresse-erreichbar/20?_=1637743925119
                        Auch mit "komischer" Netmask
                        Allerdings hatte dort ein iobroker fix geholfen - warum auch immer
                          Dennis.BD Offline
                          Dennis.BD Offline
                          Dennis.B
                          @homoran said in Slave-Installation - reassign instance falsch:
                          iobroker fix
                          Ja das hatte ich auch schon gesehen und ausprobiert, leider ohne Erfolg.
                            auch nochmal mit iobroker setup custom reingesehen?
                              Dennis.BD Offline
                              Dennis.BD Offline
                              Dennis.B
                              jo - sieht auch gut aus
                              - Objects database:
                                - Type: file
                                - Port: 9001
                              - States database:
                                - Type: file
                                - Port: 9000
                              - Host name: pi
                              - Objects database:
                                - Type: file
                                - Port: 9001
                              - States database:
                                - Type: file
                                - Port: 9000
                              - Host name: rp-surveillance
                                - Objects database:
                                  - Type: file
                                  - Port: 9001
                                - States database:
                                  - Type: file
                                  - Port: 9000
                                - Host name: pi
                                - Objects database:
                                  - Type: file
                                  - Port: 9001
                                - States database:
                                  - Type: file
                                  - Port: 9000
                                @dennis-b Dann bin ich am Ende mit meinem Latein.
                                Hast du die Frage von @Thomas-Braun geprüft und beantwortet?
                                W 1 Antwort Letzte Antwort
                                  @dennis-b
                                  Dennis.BD Offline
                                  Dennis.BD Offline
                                  Dennis.B
                                  @Homoran
                                  UDP geht.
                                  pi@pi:~ $ nc -ul 6111
                                  test
                                  test
                                  test
                                  test
                                  ^C
                                  pi@pi:~ $
                                  pi@rp-surveillance:~ $ nc -u pi 6111
                                  test
                                  test
                                  test
                                  test
                                  ^C
                                    @Homoran
                                    UDP geht.
                                    test
                                    test
                                    test
                                    test
                                    ^C
                                    pi@pi:~ $
                                    test
                                    test
                                    test
                                    test
                                    ^C
                                    UDP geht.
                                    steht denn jetzt die IPv4 im log bei Verbindungstversuch (Slave neustart über Admin des Masters?)
                                      W Offline
                                      W Offline
                                      wackl
                                      schrieb am zuletzt editiert von wackl
                                      Ich kämpfe seit 2 Tagen mit dem selben Problem.
                                      Habe schon 2 Raspis aufgesetzt, gleiches verhalten,
                                      dann 2 ct am Proxmox, auch kein Erfolg.
                                      Downgrade vom js-controller auf 3.2.16 -> multihost geht sofort
                                      Ab welcher Version das nicht mehr funktioniert wäre auszutesten...
                                        UDP geht.
                                        Dennis.BD Offline
                                        Dennis.BD Offline
                                        Dennis.B
                                        ja beide zeigen ipv4 im log an.
                                        • Dennis.BD Offline
                                          Dennis.BD Offline
                                          Dennis.B
                                          @wackl said in Slave-Installation - reassign instance falsch:
                                          Kann ich bestaetigen, nach downgrade funktioniert es.
