  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.7k
812 Beiträge 97 Kommentatoren 456.4k Aufrufe 83 Beobachtet
  • C Cino
    Ich habe auch Probleme mit dem Update und Zigbee. Bin schon die ganzen Befehle hier im Thread durchgegangen.
    host.iobroker
    2021-11-19 05:56:44.411	info	Rebuild for adapter system.adapter.zigbee.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.iobroker
    2021-11-19 05:56:44.411	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker
    2021-11-19 05:56:44.411	error	Caught by controller[0]: }
    host.iobroker
    2021-11-19 05:56:44.410	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.iobroker
    2021-11-19 05:56:44.410	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32) {
    host.iobroker
    2021-11-19 05:56:44.410	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
    host.iobroker
    2021-11-19 05:56:44.409	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1101:14)
    host.iobroker
    2021-11-19 05:56:44.409	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.iobroker
    2021-11-19 05:56:44.409	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
    host.iobroker
    2021-11-19 05:56:44.408	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.iobroker
    2021-11-19 05:56:44.408	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    host.iobroker
    2021-11-19 05:56:44.408	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    host.iobroker
    2021-11-19 05:56:44.407	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
    host.iobroker
    2021-11-19 05:56:44.407	error	Caught by controller[0]: at Object.Module._extensions..node (node:internal/modules/cjs/loader:1183:18)
    host.iobroker
    2021-11-19 05:56:44.407	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.iobroker
    2021-11-19 05:56:44.406	error	Caught by controller[0]: NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
    host.iobroker
    2021-11-19 05:56:44.406	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    host.iobroker
    2021-11-19 05:56:44.406	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.iobroker
    2021-11-19 05:56:44.405	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node'
    host.iobroker
    2021-11-19 05:56:44.405	error	Caught by controller[0]: ^
    host.iobroker
    2021-11-19 05:56:44.405	error	Caught by controller[0]: throw e;
    host.iobroker
    2021-11-19 05:56:44.404	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
    crunchipC Offline
    crunchipC Offline
    #134
    @cino sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
    Dann zeig auch mal das Ergebnis der Eingaben
    • C Offline
      Cino
      schrieb am zuletzt editiert von Cino
      #135
      Sorry, ich mach das nochmal neu. Das ist alles durcheinander gekommen.
      pi@iobroker:/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/                                               bindings/build/Release $ npm install --loglevel error --production
      > @serialport/bindings@9.2.5 install
      > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@seri                                               alport/bindings/build“ wird betreten
        CXX(target) Release/obj.target/bindings/src/serialport.o
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_ME                                               THOD_ARGS_TYPE)’:
      ../src/serialport.cpp:78:51: warning: cast between incompatible function types f                                               rom ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {a                                               ka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_                                               AfterOpen);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_                                               METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:135:53: warning: cast between incompatible function types                                                from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {                                               aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EI                                               O_AfterUpdate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_M                                               ETHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:175:52: warning: cast between incompatible function types                                                from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {                                               aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO                                               _AfterClose);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_M                                               ETHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:215:52: warning: cast between incompatible function types                                                from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {                                               aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO                                               _AfterFlush);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_MET                                               HOD_ARGS_TYPE)’:
      ../src/serialport.cpp:271:50: warning: cast between incompatible function types                                                from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {                                               aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_A                                               fterSet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_MET                                               HOD_ARGS_TYPE)’:
      ../src/serialport.cpp:316:50: warning: cast between incompatible function types                                                from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {                                               aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_A                                               fterGet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan:                                               :NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:366:58: warning: cast between incompatible function types                                                from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {                                               aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_                                               cb)EIO_AfterGetBaudRate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_M                                               ETHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:412:52: warning: cast between incompatible function types                                                from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {                                               aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO                                               _AfterDrain);
      ../src/serialport.cpp: At global scope:
      ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of                                                ‘ToParityEnum’ [-Wparentheses]
        433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8                                               str)) {
      ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of                                                ‘ToStopBitEnum’ [-Wparentheses]
        452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
      In file included from ../node_modules/nan/nan.h:58,
                       from ../src/./serialport.h:13,
                       from ../src/serialport.cpp:1:
      /home/iobroker/.cache/node-gyp/16.13.0/include/node/node.h:821:7: warning: cast                                                between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_                                               ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_fun                                               c’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-                                               function-type]
        821 |       (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/16.13.0/include/node/node.h:855:3: note: in expan                                               sion of macro ‘NODE_MODULE_X’
        855 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_                                               usage)
      ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
        486 | NODE_MODULE(serialport, init);
        CXX(target) Release/obj.target/bindings/src/serialport_unix.o
      ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
      ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncat                                               ed writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
        179 | rorString, sizeof(data->errorString), "Error %s Cannot open %s", strerro                                               r(errno), data->path);
      ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (ass                                               uming 1043) into a destination of size 1024
        179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Can                                               not open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
      ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncate                                               d writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         89 | rString, sizeof(data->errorString), "Error: %s, cannot open %s", strerro                                               r(errno), data->path);
      ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assu                                               ming 1045) into a destination of size 1024
         89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, c                                               annot open %s", strerror(errno), data->path);
        CXX(target) Release/obj.target/bindings/src/poller.o
        CXX(target) Release/obj.target/bindings/src/serialport_linux.o
        SOLINK_MODULE(target) Release/obj.target/bindings.node
        COPY Release/bindings.node
      make: Verzeichnis „/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@seri                                               alport/bindings/build“ wird verlassen
      added 65 packages, and audited 66 packages in 29s
      8 packages are looking for funding
        run `npm fund` for details
      found 0 vulnerabilities
      host.iobroker
      2021-11-19 06:30:40.587	info	iobroker npm-rebuild: exit 0
      host.iobroker
      2021-11-19 06:30:39.564	info	iobroker npm-rebuild: Rebuild zigbee done
      host.iobroker
      2021-11-19 06:30:39.539	info	iobroker npm-rebuild: npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-11-19T05_30_39_483Z-debug.log
      host.iobroker
      2021-11-19 06:30:39.531	info	iobroker npm-rebuild:
      host.iobroker
      2021-11-19 06:30:39.483	info	iobroker npm-rebuild: npm ERR! Fix the upstream dependency conflict, or retrynpm ERR! this command with --force, or --legacy-peer-depsnpm ERR! to accept an incorrect (and potentially broken) dependency resolution.npm ERR! npm ERR! See /home/iobroker/.npm/eresolve-report.txt for a full report.
      host.iobroker
      2021-11-19 06:30:39.480	info	iobroker npm-rebuild: npm ERR! While resolving: iobroker.zigbee@1.6.6npm ERR! Found: eslint@7.32.0npm ERR! node_modules/eslintnpm ERR! dev eslint@"^7.18.0" from the root projectnpm ERR! npm ERR! Could not resolve dependency:npm ERR! peer eslint@"4.x" from lint-diff@1.2.1npm ERR! node_modules/lint-diffnpm ERR! dev lint-diff@"*" from the root projectnpm ERR!
      host.iobroker
      2021-11-19 06:30:39.462	info	iobroker npm-rebuild: npm ERR!
      host.iobroker
      2021-11-19 06:30:39.461	info	iobroker npm-rebuild: npm ERR! ERESOLVE unable to resolve dependency tree
      host.iobroker
      2021-11-19 06:30:39.441	info	iobroker npm-rebuild: npm ERR! code ERESOLVE
      host.iobroker
      2021-11-19 06:30:38.629	info	instance system.adapter.heatingcontrol.0 started with pid 9210
      host.iobroker
      2021-11-19 06:30:34.124	info	instance system.adapter.lgtv.0 started with pid 9096
      host.iobroker
      2021-11-19 06:30:33.277	info	iobroker npm-rebuild: npm install --loglevel error --production (System call1) in "/opt/iobroker/node_modules/iobroker.zigbee"
      host.iobroker
      2021-11-19 06:30:31.860	info	iobroker rebuild zigbee --install
      IOB@RPI4
      Shelly, Zigbee, ebus
      • C Cino
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        host.iobroker
        #136
        @cino kannst du zigbee vllt aktualisieren? Da scheint bei dir irgendwas rech strange zu sein. Ansonsten lösch das node_modules/iobroker.zigbee Verzeichnuis und starte die Instanz neu, dann sollte es neu installiert weren. Hat mich dem Node.js Update weniger zu tun ...
        • crunchipC Offline
          crunchipC Offline
          #137
          @cino gemeint war eher die Ausgabe von node/nodejs/npm
          • DiginixD Offline
            DiginixD Offline
            Diginix
            #138
            @apollon77 Habe heute nodeJS von 12 auf 14 aktualisiert und dabei noch den JS-Controller von 3.3.18 auf 3.3.19.
            Update selbst inkl:
            iobroker fix
            npm rebuild
            Danach verhielten sich dennoch div. Adapter merkwürdig. Der web ist z.T. im loop pro Sek mehrfach abgestürzt mit:
            2021-11-19 12:54:18 - warn: web.0 (2835245) Cannot parse "undefined"
            2021-11-19 12:54:18 - warn: web.0 (2835245) socket.io [use] unknown user
            Außerdem wurden dann mehrere Adapter immer neu gestartet mit Meldung "already running".
            Am Ende habe ich über alle /opt/iobroker/node_modules/iobroker.%adapter% ein
            iobroker rebuild %adapter% --install
            laufen lassen.
            In /opt/iobroker/node_modules gibt es natürlich noch viele Ordner die nicht nicht "iobroker.xxx" heißen. Ob darin nun noch was aus nodeJS 12 Zeiten ist und rebuilded werden müsste, kann ich nicht sagen.
            Nach einem kompletten Reboot läuft nun seit 1h erstmal alles ruhig.
            ..:: So long! Tom ::..
            • B backfisch88
              Hallo
              jedes mal (schon öfter probiert), wenn ich auf nodejs 14 upgrade läuft danach der mihome-vacuum Adapter nicht mehr.
              Es läuft alles Reibungslos, bis es ein Befehl von IOBroker kommt... nach einigen Minuten ist er wieder verbunden (manchmal auch länger) und das Spiel geht von vorne los
              mit node 12.X lief alles normal
              Auszug aus dem Log
              mihome-vacuum.0
              2021-11-18 13:32:51.245	info	Map selected create states...
              mihome-vacuum.0
              2021-11-18 13:32:50.686	info	settest next timer: not available
              mihome-vacuum.0
              2021-11-18 13:32:50.159	info	select standard vacuum protocol....
              mihome-vacuum.0
              2021-11-18 13:32:50.144	warn	No Answer for DeviceModel use model from Config
              mihome-vacuum.0
              2021-11-18 13:32:50.144	warn	No Answer for DeviceModel use old one
              mihome-vacuum.0
              2021-11-18 13:32:50.143	warn	YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
              mihome-vacuum.0
              2021-11-18 13:32:40.089	info	IOT enabled, create state
              mihome-vacuum.0
              2021-11-18 13:32:39.827	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
              host.IOBroker
              2021-11-18 13:32:37.671	info	instance system.adapter.mihome-vacuum.0 started with pid 14078
              host.IOBroker
              2021-11-18 13:32:36.632	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
              host.IOBroker
              2021-11-18 13:32:36.631	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
              host.IOBroker
              2021-11-18 13:32:36.624	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGBUS
              mihome-vacuum.0
              2021-11-18 13:31:26.406	info	trigger cleaning segment 17
              mihome-vacuum.0
              2021-11-18 13:31:16.313	info	create state for carpet_mode
              mihome-vacuum.0
              2021-11-18 13:31:15.114	info	create states for mop
              mihome-vacuum.0
              2021-11-18 13:31:15.103	info	create states for water box
              mihome-vacuum.0
              2021-11-18 13:31:15.087	info	change states from State control.fan_power
              mihome-vacuum.0
              2021-11-18 13:31:15.068	info	Map selected create states...
              mihome-vacuum.0
              2021-11-18 13:31:14.463	info	settest next timer: not available
              mihome-vacuum.0
              2021-11-18 13:31:13.932	info	select standard vacuum protocol....
              mihome-vacuum.0
              2021-11-18 13:31:13.815	info	IOT enabled, create state
              mihome-vacuum.0
              2021-11-18 13:31:13.539	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
              mihome-vacuum.0 | 2021-11-18 12:49:49.814 | info | Map selected create states...
              mihome-vacuum.0 | 2021-11-18 12:49:49.125 | info | settest next timer: not available
              mihome-vacuum.0 | 2021-11-18 12:49:48.595 | info | select standard vacuum protocol....
              mihome-vacuum.0 | 2021-11-18 12:49:48.569 | warn | No Answer for DeviceModel use model from Config
              mihome-vacuum.0 | 2021-11-18 12:49:48.568 | warn | No Answer for DeviceModel use old one
              mihome-vacuum.0 | 2021-11-18 12:49:48.567 | warn | YOUR DEVICE IS CONNECTED BUT DID NOT ANSWER YET - CONNECTION CAN TAKE UP TO 10 MINUTES - PLEASE BE PATIENT AND DO NOT TURN THE ADAPTER OFF
              mihome-vacuum.0 | 2021-11-18 12:49:38.508 | info | IOT enabled, create state
              mihome-vacuum.0 | 2021-11-18 12:49:38.255 | info | starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
              host.IOBroker | 2021-11-18 12:49:36.130 | info | instance system.adapter.mihome-vacuum.0 started with pid 6957
              host.IOBroker | 2021-11-18 12:49:35.072 | info | Restart adapter system.adapter.mihome-vacuum.0 because enabled
              host.IOBroker | 2021-11-18 12:49:35.071 | info | instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
              host.IOBroker | 2021-11-18 12:49:35.070 | warn | instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
              host.IOBroker | 2021-11-18 12:49:35.063 | error | Caught by controller[0]: free(): invalid pointer
              mihome-vacuum.0 | 2021-11-18 12:49:15.488 | info | trigger cleaning segment 17
              mihome-vacuum.0 | 2021-11-18 12:49:00.086 | info | create state for carpet_mode
              mihome-vacuum.0 | 2021-11-18 12:48:58.907 | info | create states for mop
              mihome-vacuum.0 | 2021-11-18 12:48:58.904 | info | create states for water box
              mihome-vacuum.0 | 2021-11-18 12:48:58.872 | info | change states from State control.fan_power
              mihome-vacuum.0 | 2021-11-18 12:48:58.839 | info | Map selected create states..
              jemand eine Idee?
              updated über
              curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
              sudo apt-get install -y nodejs
              iobroker fix
              zusätzlich:
              iobroker rebuild ioBroker.mihome-vacuum
              iobroker rebuild ioBroker.mihome-vacuum --install
              und ein rebuild in: opt/iobroker/
              und iobroker stop && sudo apt update && sudo apt upgrade -y && iobroker start
              und in github ein issue aufgemacht, wo ich hierhin verwiesen wurde :)
              und nochmal im DEBUG
              mihome-vacuum.0
              2021-11-18 13:39:10.415	debug	load Map creator... true
              mihome-vacuum.0
              2021-11-18 13:39:10.257	debug	Schedule restart: 0 0,1 * * *
              mihome-vacuum.0
              2021-11-18 13:39:10.172	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.1, js-controller: 3.3.19
              mihome-vacuum.0
              2021-11-18 13:39:09.903	debug	Plugin sentry Initialize Plugin (enabled=true)
              mihome-vacuum.0
              2021-11-18 13:39:06.008	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              mihome-vacuum.0
              2021-11-18 13:39:06.007	debug	Plugin sentry destroyed
              mihome-vacuum.0
              2021-11-18 13:39:06.006	info	terminating
              mihome-vacuum.0
              2021-11-18 13:39:06.005	error	Socket Close
              mihome-vacuum.0
              2021-11-18 13:39:05.799	error	undefined
              mihome-vacuum.0
              2021-11-18 13:39:05.798	error	unhandled promise rejection: undefined
              mihome-vacuum.0
              2021-11-18 13:39:05.798	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              mihome-vacuum.0
              2021-11-18 13:39:05.796	debug	MIIO Receive Timeout for "app_segment_clean" <<<
              mihome-vacuum.0
              2021-11-18 13:39:04.078	debug	Message= {"id":17,"method":"get_multi_maps_list"}
              mihome-vacuum.0
              2021-11-18 13:39:04.077	debug	ERROR at setGetSoundVolume: MESSAGE TIMEOUT
              mihome-vacuum.0
              2021-11-18 13:39:04.076	debug	MIIO Receive Timeout for "get_sound_volume" <<<
              mihome-vacuum.0
              2021-11-18 13:39:03.794	debug	Message= {"id":16,"method":"app_segment_clean","params":[17]}
              mihome-vacuum.0
              2021-11-18 13:39:03.793	info	trigger cleaning segment 17
              mihome-vacuum.0
              2021-11-18 13:39:03.792	debug	start Cleaning: 18 MObj: {"command":"cleanSegments","message":"17","from":"system.adapter.mihome-vacuum.0","_id":62189570,"segments":[17],"channels":["mihome-vacuum.0.rooms.73001006380"]}
              mihome-vacuum.0
              2021-11-18 13:39:03.791	debug	We are in onMessage:{"command":"cleanSegments","message":{"segments":[17],"channels":["mihome-vacuum.0.rooms.73001006380"]},"from":"system.adapter.mihome-vacuum.0","_id":62189570}
              mihome-vacuum.0
              2021-11-18 13:39:03.784	debug	sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
              mihome-vacuum.0
              2021-11-18 13:39:03.779	debug	command: roomClean parent: 73001006380
              DiginixD Offline
              DiginixD Offline
              Diginix
              #139
              @backfisch88 sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
              Hallo
              Wie du ein Post weiter oben lesen kannst, habe ich heute auch ein Rundumschlag mit Updates gemacht.
              Ich nutze mihome-vacuum in Ver. 3.3.1 mit einem Xiaomi M1S. Der Adapter funktionierte nach dem dem nodeJS Update sofort, nur Canvas musste für die Karte neu gebaut werden. Seit dem hat der Sauger auch schon 3 Räume mit immer aktueller Karte gesaugt.
              • C Offline
                Cino
                #140
                Heute morgen aufgewacht und der Zigbee Adapter lief. Keine Ahnung warum.
                IOB@RPI4
                • C Cino
                  #141
                  Vermutlich, weil der rebuild zwischenzeitlich durchgelaufen ist.
                  C 1 Antwort Letzte Antwort
                  • apollon77A apollon77
                    @backfisch88 Ich glaube der Fehler hier sieht jetzt eher aus wie https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/428
                    backfisch88
                    #142
                    @apollon77 habe wieder auf 12.X Downgraded.
                    egal was man macht... nach einem Befehl ist der Adapter auf rot... Staubsauger reagiert in der App, aber im Adapter eben nicht... auch nach neustart des Adapters manchmal nicht... Reconnect Zeit zwischen 2 Minuten und X Stunden
                    • DiginixD Diginix
                      Hallo
                      backfisch88
                      #143
                      @diginix saugen tut er... aber eben nur ein mal... dann geht der Adapter sofort auf Rot
                      • B backfisch88
                        #144
                        @backfisch88
                        Dann mach beim Adapter ein Issue auf, damit der Maintainer sich das ggf. anschauen kann. Wobei sich das sehr nach einem Individual-Problem anhört.
                          Cino
                          #145
                          @thomas-braun said in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
                          Ja aber in den Logs stand doch von wegen 3 mal versucht und der Adapter wird deaktiviert.
                          IOB@RPI4
                          G 1 Antwort Letzte Antwort
                          • C Cino
                            guergen
                            #146
                            Nach dem Update von nodejs auf v14.18.1 kommt beim maxcul-Adapter folgender Fehler:
                            maxcul.0
                            	2021-11-19 19:32:59.319	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                            maxcul.0
                            	2021-11-19 19:32:59.319	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18) at Module.load (internal/modules/cjs/loader.js:950:32) at Function.Module._load (internal/modules/cjs/loader.js:790:12) at Module.require (internal/modules/cjs/loader.js:974:19) at require (internal/modules/cjs/helpers.js:93:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (internal/modules/cjs/loader.js:1085:14) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10) at Module.load (internal/modules/cjs/loader.js:950:32) at Function.Module._load (internal/modules/cjs/loader.js:790:12) at Module.require (internal/modules/cjs/loader.js:974:19) at require (internal/modules/cjs/helpers.js:93:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (internal/modules/cjs/loader.js:1085:14) at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                            maxcul.0
                            	2021-11-19 19:32:59.317	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
                            Werde aus den ganzen "Lösungen" nicht ganz schlau....
                            npm rebuild hat nichts gebracht
                            NPM v6.14.15
                            js-controller 3.3.19
                            Beim Slave hat alles geklappt
                            Bin jetzt auf dem Host auf 12 zurück, ohne Heizung geht es grade nicht ;-)
                            Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                            • G guergen
                              maxcul.0
                              maxcul.0
                              maxcul.0
                              NPM v6.14.15
                              #147
                              @guergen
                              maxcul deinstallieren und nochmal neu installieren.
                              • G guergen
                                maxcul.0
                                maxcul.0
                                maxcul.0
                                NPM v6.14.15
                                #148
                                @guergen sagte in [How-to] Node.js für ioBroker richtig updaten - 2021 Edition:
                                Mal in das Verzeichnis wechseln und dort ein "npm install --production" machen
                                  Marty56
                                  #149
                                  @apollon77 Ich habe node v12.22.7. Ist das richtig, dass ich noch ca. 2 Jahre mit dem Update warten kann?
                                  HW:NUC (16 GB Ram)
                                  OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                  J Thomas BraunT apollon77A 3 Antworten Letzte Antwort
                                  • M Marty56
                                    Jan1
                                    #150
                                    @marty56
                                    Theoretisch ja nur praktisch nicht sinnvoll. Ich bin schon lange auf 14 und null Probleme ;)
                                    • J Jan1
                                      @marty56
                                      Marty56
                                      #151
                                      @jan1 Warum meinst Du, dass es nur theoretisch sinnvoll ist?
                                      Wenn ich mir den Thread ansehe, dann brauche ich die ganzen Probleme erstmal nicht.
                                      HW:NUC (16 GB Ram)
                                      • M Marty56
                                        Jan1
                                        #152
                                        @marty56
                                        Ich habe nicht alles gelesen und das meiste was ich gelesen habe, sind wohl (mal wieder) mitgeschleppte Probleme, die versteckt die ganze Zeit schon da waren und nun eben erst deutlich zu sehen sind. Was wiederum nicht wirklich was mit Node 14 zu tun hat, sondern ehr mit zerfledderten Systemen, die jetzt eben mal ein Update oder gleich mehrere erhalten haben.
                                        Ergo, bleib aktuell und habe keine Problem ;)
                                        Es gibt so gut wie kein Grund auf 12 zu bleiben.
                                        Probier es einfach aus und schau obs läuft, zurück geht genau so schnell wie hoch.
                                        Hatte ne Zeitlang produktiv 16 nmit NPM 7 laufen und keine Probleme, dann mit NPM 6 und weil ich eben gerne bastle, wieder zurück auf 14 und alles ohne Ärger.
                                        • M Marty56
                                          #153
                                          @marty56
                                          RELEASE	STATUS	INITIAL RELEASE	ACTIVE LTS START	MAINTENANCE LTS START	END-OF-LIFE
                                          v12		2019-04-23	2019-10-21	        2020-11-30	        2022-04-30
                                          https://nodejs.org/en/about/releases/
                                          Für nodeJS12 also ist im April 22 Schicht. Also kannst du auch jetzt wechseln. Die Erfahrung zeigt: Je länger gewartet wird, umso mehr Probleme gibt es
