  4. Admin nach JavaScript-Update nicht mehr erreichbar
    6.3k
27 Beiträge 4 Kommentatoren 3.0k Aufrufe 3 Beobachtet
  • YunkieY Yunkie
    vielen Dank für die bisherige Unterstützung!
    Leider lieferte der letzte Befehl folgendes:
    iobroker@iobroker-pi:~ $ iobroker upgrade
    This upgrade of "javascript" will introduce the following changes:
    -> 5.2.13:
    Fixed the loading of Node.js typings
    -> 5.2.12:
    Fixed the font in the editor
    -> 5.2.10:
    Parse variables to floats for mathematical operations
    Names with the dot at the end are not allowed anymore
    The blockly sounds are disabled
    -> 5.2.9:
    Make sure day of weeks is an array (Sentry IOBROKER-JAVASCRIPT-7Y)
    Report to sentry is disabled in GUI if sentry is deactivated
    Fixed many GitHub issues
    Would you like to upgrade javascript from @5.2.8 to @5.2.13 now? [(y)es, (n)o]: y
    Update javascript from @5.2.8 to @5.2.13
    NPM version: 6.14.15
    npm install iobroker.javascript@5.2.13 --loglevel error --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
    ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
       Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
    In file included from ../authenticate_pam.cc:23:
    ../../nan/nan.h:1026:46: note: declared here
       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
    In file included from /home/iobroker/.cache/node-gyp/12.22.7/include/node/v8-internal.h:14,
                     from /home/iobroker/.cache/node-gyp/12.22.7/include/node/v8.h:27,
                     from /home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:67,
                     from ../../nan/nan.h:56,
    /home/iobroker/.cache/node-gyp/12.22.7/include/node/v8.h:3553:51: note: declared here
       V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
    /home/iobroker/.cache/node-gyp/12.22.7/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
    In file included from /home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:67,
    /home/iobroker/.cache/node-gyp/12.22.7/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
       int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    /home/iobroker/.cache/node-gyp/12.22.7/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
    ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
    ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      username->WriteUtf8(m->username, sizeof(m->username) - 1);
    ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      password->WriteUtf8(m->password, sizeof(m->password) - 1);
    ../authenticate_pam.cc: At global scope:
    ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
     void init(Handle<Object> exports) {
    ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
               rand_r
    ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
    In file included from ../../nan/nan.h:56,
    ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
     NODE_MODULE(authenticate_pam, init);
    /home/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.10.63-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v12.22.7
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Update "system.adapter.javascript.0"
    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.fc5df117.chunk.js static/js/main.fc5df117.chunk.js application/javascript
    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    Adapter "javascript" updated
    Auch wenn die letzte Zeile "javascript updated" lautet, ist das Update nicht durchgelaufen.
    @yunkie sagte in Admin nach JavaScript-Update nicht mehr erreichbar:
    woran machst du das fest?
    YunkieY 1 Antwort Letzte Antwort
      YunkieY Offline
      YunkieY Offline
      Yunkie
      Entschuldigt, habe diesmal die "Adapter"-Seite nicht aktualisiert.
      tatsächlich scheint das Update nun durchgelaufen zu sein.
      Vielen Dank!
      • YunkieY Yunkie
        Vielen Dank!
        @yunkie
        Wäre schön wenn du alles hier reinkopieren würdest.
        Hast du zufällig den Adapter 'terminal' installiert?
          @yunkie
          YunkieY Offline
          YunkieY Offline
          Yunkie
          entschuldige, was soll ich hier noch reinkopieren? Die ganze Ausgabe nach dem "upgrade" Befehl steht oben 😕
          Ja ich habe den Adapter Terminal installiert.
          OT: Ich kann den "Ring"-Adapter nicht aktualisieren. Sollte ich dafür einen neuen Thread aufmachen?
          Die Fehlermeldung sieht ähnlich aus wie bei der JavaScript Installation. Ich habe das Gefühl das diese Zeilen dafür interessant sind:
          gyp ERR! not ok
          gyp ERR! UNCAUGHT EXCEPTION
          gyp ERR! stack /opt/iobroker/node_modules/fstream/lib/dir-reader.js:191
          gyp ERR! stack "     'warn'
          gyp ERR! stack ^^^^^^^^^^^^
          gyp ERR! stack
          gyp ERR! stack SyntaxError: Invalid or unexpected token
          gyp ERR! stack     at wrapSafe (internal/modules/cjs/loader.js:915:16)
          gyp ERR! stack     at Module._compile (internal/modules/cjs/loader.js:963:27)
          gyp ERR! stack     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
          gyp ERR! stack     at Module.load (internal/modules/cjs/loader.js:863:32)
          gyp ERR! stack     at Function.Module._load (internal/modules/cjs/loader.js:708:14)
          gyp ERR! stack     at Module.require (internal/modules/cjs/loader.js:887:19)
          gyp ERR! stack     at require (internal/modules/cjs/helpers.js:74:18)
          gyp ERR! stack     at Object.<anonymous> (/opt/iobroker/node_modules/fstream/fstream.js:11:11)
          gyp ERR! stack     at Module._compile (internal/modules/cjs/loader.js:999:30)
          gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          gyp ERR! cwd /opt/iobroker/node_modules/utf-8-validate
          gyp ERR! node-gyp -v v3.8.0
          gyp ERR! This is a bug in `node-gyp`.
          gyp ERR! Try to update node-gyp and file an Issue if it does not help:
          gyp ERR!     <https://github.com/nodejs/node-gyp/issues>
          npm ERR! code ELIFECYCLE
          npm ERR! errno 7
          npm ERR! utf-8-validate@5.0.7 install: `node-gyp-build`
          npm ERR! Exit status 7
          npm ERR!
          npm ERR! Failed at the utf-8-validate@5.0.7 install script.
          npm ERR!     /home/iobroker/.npm/_logs/2021-11-16T20_28_21_503Z-debug.log
          host.iobroker-pi Cannot install iobroker.ring@1.2.8: 7
          • YunkieY Yunkie
            gyp ERR! not ok
            gyp ERR! stack
            npm ERR! errno 7
            npm ERR!
            @yunkie
            Schmeiß den Terminals-Adapter raus.
              @yunkie
              YunkieY Offline
              YunkieY Offline
              Yunkie
              Alles klar, ist raus. Fiel mir nicht besonders schwer, da ich ihn nicht wirklich gebraucht habe und alles per Putty mache.
              Aber darf ich interessehalber noch fragen warum?
              • YunkieY Yunkie
                @yunkie
                Der sorgt für die ganzen Meldungen zu authenticate_pam.
                iobroker update -i
                sagt?
                  @yunkie
                  iobroker update -i
                  sagt?
                  YunkieY Offline
                  YunkieY Offline
                  Yunkie
                  iobroker@iobroker-pi:~ $ iobroker update -i
                  Used repository: stable
                  hash unchanged, use cached sources
                  update done
                  Adapter    "admin"         : 5.1.25   , installed 5.1.25
                  Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
                  Adapter    "backitup"      : 2.1.17   , installed 2.1.17
                  Adapter    "bring"         : 1.7.8    , installed 1.7.8
                  Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                  Adapter    "discovery"     : 2.7.3    , installed 2.7.3
                  Adapter    "ebus"          : 2.3.2    , installed 2.3.2
                  Adapter    "flot"          : 1.10.7   , installed 1.10.7
                  Adapter    "history"       : 1.9.13   , installed 1.9.13
                  Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                  Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                  Adapter    "info"          : 1.9.8    , installed 1.9.8
                  Adapter    "javascript"    : 5.2.13   , installed 5.2.13
                  Controller "js-controller" : 3.3.18   , installed 3.3.18
                  Adapter    "knx"           : 1.0.45   , installed 1.0.45
                  Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                  Adapter    "octoprint"     : 1.1.1    , installed 1.1.1
                  Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
                  Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                  Adapter    "ring"          : 1.2.8    , installed 1.2.6 [Updateable]
                  Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                  Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                  Adapter    "smartmeter"    : 3.2.1    , installed 3.2.1
                  Adapter    "snmp"          : 0.5.0    , installed 0.5.0
                  Adapter    "socketio"      : 3.1.4    , installed 3.1.5
                  Adapter    "sql"           : 1.15.7   , installed 1.15.7
                  Adapter    "vis"           : 1.4.5    , installed 1.4.5
                  Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                  Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                  Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                  Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
                  Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                  Adapter    "vw-connect"    : 0.0.45   , installed 0.0.45
                  Adapter    "web"           : 3.4.9    , installed 3.4.9
                  • YunkieY Yunkie
                    update done
                    @yunkie
                    iobroker upgrade
                      @yunkie
                      iobroker upgrade
                      YunkieY Offline
                      YunkieY Offline
                      Yunkie
                      liefert leider das:
                      Would you like to upgrade ring from @1.2.6 to @1.2.8 now? [(y)es, (n)o]: y
                      Update ring from @1.2.6 to @1.2.8
                      npm install iobroker.ring@1.2.8 --loglevel error --prefix "/opt/iobroker" (System call)
                      gyp ERR! stack /opt/iobroker/node_modules/fstream/lib/dir-reader.js:192
                      gyp ERR! stack     ].forEach(function!(evi {
                      gyp ERR! stack                       ^
                      gyp ERR! stack
                      gyp ERR! stack SyntaxError: Unexpected token '!'
                      npm ERR! errno 7
                      npm ERR!
                      npm ERR!     /home/iobroker/.npm/_logs/2021-11-16T21_07_26_795Z-debug.log
                      • YunkieY Yunkie
                        liefert leider das:
                        gyp ERR! stack                       ^
                        gyp ERR! stack
                        npm ERR! errno 7
                        npm ERR!
                        @yunkie
                        cd /opt/iobroker
                        npm list utf-8-validate
                          @yunkie
                          cd /opt/iobroker
                          YunkieY Offline
                          YunkieY Offline
                          Yunkie
                          @thomas-braun said in Admin nach JavaScript-Update nicht mehr erreichbar:
                          liefert dies:
                          iobroker@iobroker-pi:/opt/iobroker $ npm list utf-8-validate
                          iobroker.inst@3.0.0 /opt/iobroker
                          └─┬ UNMET DEPENDENCY iobroker.ring@1.2.6
                            └── UNMET DEPENDENCY utf-8-validate@5.0.5
                          npm ERR! missing: iobroker.ring@1.2.6, required by iobroker.inst@3.0.0
                          npm ERR! missing: utf-8-validate@5.0.5, required by iobroker.ring@1.2.6
                          • YunkieY Yunkie
                            liefert dies:
                            @yunkie
                            Fällt mir nichts mehr zu ein.
                              @yunkie
                              YunkieY Offline
                              YunkieY Offline
                              Yunkie
                              Verdammt... Schade! Trotzdem vielen Dank!
                              Ich werde mal versuchen den Adapter komplett neu zu installieren.
                              • YunkieY Yunkie
                                YunkieY Offline
                                YunkieY Offline
                                Yunkie
                                Eine komplette Neuinstallation des Adapters war erfolgreich
                                Wollte nur das Ergebnis mitteilen ;-)
