  4. [ESPHome] Beta release
591 Beiträge 48 Kommentatoren 238.9k Aufrufe 39 Beobachtet
  • Matthias 4M Offline
    Matthias 4M Offline
    Matthias 4
    #381
    ich habe Probleme bei der Installation des Adapters.
    $ iobroker url https://github.com/esphome/esphome --host raspberrypi --debug
    install esphome/esphome#d536509a63189490f314e5923471828ca28ba26d
    NPM version: 8.1.3
    npm install esphome/esphome#d536509a63189490f314e5923471828ca28ba26d --prefix "/opt/iobroker" (System call)
    npm WARN tarball tarball data for github:esphome/esphome#d536509a63189490f314e5923471828ca28ba26d (null) seems to be corrupted. Trying again.
    npm ERR! code ENOENT
    npm ERR! syscall open
    npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneiTKNLZ/package.jsonnpm ERR! errno -2
    npm ERR! enoent ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneiTKNLZ/package.json'
    npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent
    npm ERR! /home/iobroker/.npm/_logs/2021-11-05T16_12_09_282Z-debug.log
    host.raspberrypi Cannot install esphome/esphome#d536509a63189490f314e5923471828ca28ba26d: 254
    ERROR: Process exited with code 25
    Kann mir jemand Helfen,... :-)
    Vielen Dank
    pi@raspberrypi:~ $ node -v
    v12.22.7
    pi@raspberrypi:~ $ npm -v
    8.1.3
    Adapter "admin" : 5.1.25 , installed 5.1.25
    Adapter "discovery" : 2.7.0 , installed 2.7.0
    Adapter "doorio" : 2.0.3 , installed 2.0.3
    Adapter "info" : 1.9.8 , installed 1.9.8
    Adapter "javascript" : 5.2.8 , installed 5.2.8
    Controller "js-controller" : 3.3.18 , installed 3.3.18
    Adapter "mqtt" : 2.4.0 , installed 2.4.0
    Adapter "simple-api" : 2.6.1 , installed 2.6.1
    Adapter "socketio" : 3.1.4 , installed 3.1.5
    Adapter "vis" : 1.4.4 , installed 1.4.4
    Adapter "web" : 3.4.9 , installed 3.4.9
    E Thomas BraunT 2 Antworten Letzte Antwort
    • Matthias 4M Matthias 4
      NPM version: 8.1.3
      Vielen Dank
      v12.22.7
      8.1.3
      e-s
      #382
      @matthias-4
      Wo hast du npm 8 her? Npm 6 ist derzeit aktuell und 7 ist noch nicht völlig fehlerfrei.
        NPM version: 8.1.3
        Vielen Dank
        v12.22.7
        8.1.3
        #383
        @matthias-4
        npm@6 verwenden und den npm cache mal löschen.
        cd /opt/iobroker
        npm cache clear --force
        Und bitte Konsolentext in CodeTags </> einbetten. Danke.
        Matthias 4M 1 Antwort Letzte Antwort
          @matthias-4
          cd /opt/iobroker
          Matthias 4M Offline
          Matthias 4M Offline
          Matthias 4
          #384
          ich habe das geändert und bin jetzt auf 5.8.
          Die Installation ist mit Code 0 durchgelaufen. Danke
          ESP Home erscheint rechts in dem Menüband. Beim Draufklicken erscheint leider Local Host nicht erreichbar?
          Was mache ich falsch?
          Matthias
          Matthias 4M E DutchmanD 3 Antworten Letzte Antwort
            Matthias
            Matthias 4M Offline
            Matthias 4M Offline
            Matthias 4
            #385
            Danke hat funktioniert :-)
              Matthias
              e-s
              #386
              @matthias-4
              Wieso denn jetzt 5.8, npm6 ist derzeit Standard und sollte genutzt werden.
                Matthias
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                #387
                @matthias-4 sagte in [ESPHome] Beta release:
                Matthias
                Ip adresse bei Adapter Einstellungen eintragen, siehe Doku 😉
                  tloeffel
                  #388
                  Hallo Zusammen,
                  diese Meldung taucht auf. Wie "update" ich dieses unter IOBROKER?
                  Gruß Thomas
                  E 1 Antwort Letzte Antwort
                  • T tloeffel
                    Hallo Zusammen,
                    Gruß Thomas
                    e-s
                    #389
                    @tloeffel
                    Nutzt du das interne esphome vom Adapter, dann ignoriere es einfach.
                      tloeffel
                      #390
                      Hallo Zusammen,
                      ich musste mein Ubuntu auf Version 20-4 bringen. Somit habe ich auch IOBROKER neu installieren müssen. Nun habe ich folgenden Fehler. Ich bekomme "optisch" keine Adapter mehr "online". Im LOG werden sie angezeigt und auch beim Adapter selbst kann ich Ihn sehen. Aber in dieser Anzeige nicht, somit geht auch kein kompilieren und über Wifi updaten mehr. Habt Ihr eine Idee?
                      Gruß Thomas
                      • T tloeffel
                        Hallo Zusammen,
                        Gruß Thomas
                        DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        #391
                        @tloeffel sagte in [ESPHome] Beta release:
                        Hallo Zusammen,
                        Gruß Thomas
                        Bei der Installation wird immer die aktuellste ESPHome Dashboard Version genommen daarin bevinden sich leider gerade ein bug (außerhalb ioBroker)
                        • DutchmanD Dutchman
                          Hallo Zusammen,
                          Gruß Thomas
                          tloeffel
                          schrieb am zuletzt editiert von tloeffel
                          #392
                          @dutchman
                          Danke für die schnelle Antwort :-). Gehst Du dem BUG nach?
                          "Open" geht übrigens. Auch das Update über Wifi geht trotz roter "offline" Anzeige.
                          Gruß Thomas
                          • T tloeffel
                            @dutchman
                            Gruß Thomas
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            #393
                            eh nein, ich entwickle nicht ESPHome ;) ist aber bei denen bekannt
                              marsmännchen
                              #394
                              Wäre es eigentlich möglich auf einem Multihost am Slave den Adapter zu installieren.
                              Ich meine installiert habe ich ihn bereits auf Master und Slave.
                              Jetzt wollte ich auf den Slave umziehen aber beim erstellen einer Instanz kommt :
                              2021-11-19 18:07:20.599 - error: host.achbotslave startInstance system.adapter.esphome.1: required adapter "admin" not found!
                              Raspberry Pi 4 8GB, Debian 11, js-controller: 5.0.12, Nodejs: v18.18.2, NPM: 9.8.1 (Multihost),
                              Wago PFC200 mit Dali Lichtsteuerung.
                              • M marsmännchen
                                FeuersturmF Offline
                                FeuersturmF Offline
                                Feuersturm
                                #395
                                @marsmännchen Das klingt danach, dass du keine Admin auf dem Slave hast (was nach meinem Wissensstand auch nicht notwendig ist).
                                • FeuersturmF Feuersturm
                                  marsmännchen
                                  schrieb am zuletzt editiert von marsmännchen
                                  #396
                                  Das hab ich mir aufgrund der Fehlermeldung auch gedacht.
                                  Habe dann gestern nachgesehen, aber da ist ein Admin Adapter am Slave.
                                  Dachte ich!!
                                  Hab mich wohl geirrt.
                                  Gerade nochmal nachgesehen, nein am Slave ist kein Admin.
                                  Spricht etwas dagegen auf einem Slave einen Admin Adapter zu installieren um ESPHome zu nutzen?
                                  MfG
                                  Patrick
                                  Edit:
                                  Habe auch von ähnlichem Problem bei einem anderen Adapter gelesen: https://forum.iobroker.net/topic/47840/adapter-worx-funktioniert-nicht-mehr-nach-update
                                  Ich denke es geht nicht anders als einen Admin Adapter anzulegen, außer der Adapterersteller ändert etwas an den "globalDependencies"!?
                                  • M marsmännchen
                                    Dachte ich!!
                                    MfG
                                    Patrick
                                    Edit:
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #397
                                    @marsmännchen sagte in [ESPHome] Beta release:
                                    Dachte ich!!
                                    MfG
                                    Patrick
                                    Edit:
                                    Werde es diese Woche fixen
                                      arne007
                                      #398
                                      hallo zusammen, kann mir jemand sagen, warum ich ESPHome nicht installiert bekomme:
                                      0 info it worked if it ends with ok
                                      1 verbose cli [
                                      1 verbose cli '/usr/local/bin/node',
                                      1 verbose cli '/usr/local/bin/npm',
                                      1 verbose cli 'install',
                                      1 verbose cli 'esphome/esphome#1424091ee51a31d75558f8e4a029ea80edb4d415',
                                      1 verbose cli '--prefix',
                                      1 verbose cli '/opt/iobroker'
                                      1 verbose cli ]
                                      2 info using npm@6.14.11
                                      3 info using node@v14.15.4
                                      4 verbose npm-session 03dd482e48963b72
                                      5 silly install loadCurrentTree
                                      6 silly install readLocalPackageData
                                      7 silly fetchPackageMetaData error for github:esphome/esphome#1424091ee51a31d75558f8e4a029ea80edb4d415 premature close
                                      8 timing stage:rollbackFailedOptional Completed in 2ms
                                      9 timing stage:runTopLevelLifecycles Completed in 8223ms
                                      10 verbose stack Error: premature close
                                      10 verbose stack at PassThrough.onclose (/usr/local/lib/node_modules/npm/node_modules/end-of-stream/index.js:47:67)
                                      10 verbose stack at PassThrough.emit (events.js:327:22)
                                      10 verbose stack at emitCloseNT (internal/streams/destroy.js:87:10)
                                      10 verbose stack at processTicksAndRejections (internal/process/task_queues.js:79:21)
                                      11 verbose cwd /opt/iobroker
                                      12 verbose Linux 5.10.63-v7l+
                                      13 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "esphome/esphome#1424091ee51a31d75558f8e4a029ea80edb4d415" "--prefix" "/opt/iobroker"
                                      14 verbose node v14.15.4
                                      15 verbose npm v6.14.11
                                      16 error premature close
                                      17 verbose exit [ 1, true ]
                                      • A arne007
                                        1 verbose cli [
                                        1 verbose cli ]
                                        #399
                                        @arne007 sagte in [ESPHome] Beta release:
                                        NodeJS ist falsch installiert.
                                          arne007
                                          #400
                                          @thomas-braun falsche Version installiert? Wenn ja, welche sollte ich nehmen?
