  • simatecS simatec
    @noah3112
    Ich glaube wir reden aneinander vorbei.
    Jetzt mache mal folgendes…
    Öffne das Fenster warte dann mal etwas länger als eine Minute und schließe es wieder.
    Und genau diesen Log von beiden Aktionen bitte posten
    #3853
    @simatec
    2021-11-09 20:41:06.837 - debug: shuttercontrol.0 (1386) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: true
    2021-11-09 20:41:06.846 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter conversion is:false
    2021-11-09 20:41:06.893 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger drive-up is:35
    2021-11-09 20:41:06.894 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger change is:upDown
    2021-11-09 20:41:06.895 - debug: shuttercontrol.0 (1386) #1 save trigger height: 0% for device Wohnzimmer Klein
    2021-11-09 20:41:06.895 - debug: shuttercontrol.0 (1386) #1 save trigger action: Manu_Mode for device Wohnzimmer Klein
    2021-11-09 20:41:06.896 - info: shuttercontrol.0 (1386) #1 Set ID: Wohnzimmer Klein value: 35%
    2021-11-09 20:41:06.951 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - window is still open -> driving now to :35
    2021-11-09 20:41:07.010 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein Old value = 35. New value = 35. automatic is active
    2021-11-09 20:41:07.012 - debug: shuttercontrol.0 (1386) Shutter state changed: Wohnzimmer Klein old value = 35 new value = 0
    2021-11-09 20:41:07.013 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein drived manually to 0. Old value = 35. New value = 0
    2021-11-09 20:41:07.014 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein Updated trigger action to Manu_Mode to prevent moving after window close
    2021-11-09 20:41:07.979 - debug: shuttercontrol.0 (1386) save current height after State Check: 0% from Wohnzimmer Klein
    2021-11-09 20:41:07.980 - debug: shuttercontrol.0 (1386) Shutter Wohnzimmer Klein was moved manually to: 0% while window was open - prevent trigger from driving back
    2021-11-09 20:41:42.350 - debug: shuttercontrol.0 (1386) insidetemperature changed: zigbee.0.00158d0001e548d4.temperature Value: 18.89
    2021-11-09 20:42:18.127 - debug: shuttercontrol.0 (1386) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: false
    2021-11-09 20:42:18.141 - debug: shuttercontrol.0 (1386) TriggerID changed: zigbee.0.00158d0002370a0c.opened Value: false
    2021-11-09 20:42:18.150 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter conversion is:false
    2021-11-09 20:42:18.152 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter conversion is:false
    2021-11-09 20:42:18.206 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter current state.val is:35
    2021-11-09 20:42:18.208 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter current Height is:0
    2021-11-09 20:42:18.209 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger Height is:0
    2021-11-09 20:42:18.211 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger Action is:Manu_Mode
    2021-11-09 20:42:18.212 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger Change is:upDown
    2021-11-09 20:42:18.216 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter current state.val is:35
    2021-11-09 20:42:18.217 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter current Height is:0
    2021-11-09 20:42:18.218 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger Height is:0
    2021-11-09 20:42:18.219 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger Action is:Manu_Mode
    2021-11-09 20:42:18.219 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein - shutter trigger Change is:upDown
    2021-11-09 20:42:45.203 - debug: shuttercontrol.0 (1386) Shutter state changed: Wohnzimmer Klein old value = 35 new value = 0
    2021-11-09 20:42:45.204 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein Old value = 35. New value = 0. automatic is active
    2021-11-09 20:42:45.352 - debug: shuttercontrol.0 (1386) Shutter state changed: Wohnzimmer Klein old value = 35 new value = 0
    2021-11-09 20:42:45.352 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein Old value = 35. New value = 0. automatic is active
    2021-11-09 20:42:45.353 - debug: shuttercontrol.0 (1386) Shutter state changed: Wohnzimmer Klein old value = 35 new value = 0
    2021-11-09 20:42:45.353 - debug: shuttercontrol.0 (1386) Wohnzimmer Klein Old value = 35. New value = 0. automatic is active
      @simatec muss er erst wieder auf "alles Auto" stellen?
      #3854
      @homoran Ich habe dir doch meine derzeitige Einstellung geschickt. Was meinst du mit auf Automatik stellen?
        #3855
        @noah3112 sagte in Test Adapter shuttercontrol v1.3.x:
        das ist unerheblich. darum geht es ja niccht.
        Wie eben erklärt hast du die Automatik (bis morgen Früh) an dem Fenster deaktiviert.
        um diese wieder zu aktivieren müsstest du auf diesen Button klicken: shuttercontrol.0.control.autoAll
        (ich glaube in der neuen Version gibt es das auch für jedes Fenster einzeln)
          #3856
          @homoran Okay
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            #3857
            @noah3112
            Wie erwartet arbeiten deine Shellys nicht korrekt.
            Aktiviere in den Extraeinstellungen die Statusabfrage und stelle die Abfragezeit auf einen Wert, der höher deiner Rollladenfahrtzeit liegt.
            Dein shelly meldet unmittelbar nach dem setzen der 35%, dass er auf 0% steht. Dementsprechend denkt shuttercontrol, dass dein Rollladen geschlossen ist.
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
              hier wird das zurückrollen unterbunden.
              Du hast keine Zeit eingestellt, nach der der Status überprüft werden soll?
              Hier wird das Fenster geschlossen:
              2021-11-09 16:25:32.817 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - shutter conversion is:false
              und hier der Status überprüft:
              2021-11-09 16:25:32.918 - debug: shuttercontrol.0 (12762) Wohnzimmer Klein - window is still open -> driving now to :35
              gerade mal 100msec. dazwischen.
              Was hast du für Aktoren?
              Kann es sein, dass da etwas später erst die Endposition erreicht wird, was dann als manuelle Veränderung interpretiert wird?
              @homoran Ups ich sehe gerade das ich den Log falsch adressiert habe.
              neee, ist schon gut so. @simatec muss sich das ansehen
              #3858
              @simatec sagte in Test Adapter shuttercontrol v1.3.x:
              @noah3112
              @homoran sagte in Test Adapter shuttercontrol v1.3.x:
              • C Offline
                Cino
                #3859
                Könnte man einen globalen DP erstellen für den Sonnenschutz? Im Winter brauche ich das mit dem halbgeschlossenen Fenstern nicht.
                IOB@RPI4
                Shelly, Zigbee, ebus
                • C Cino
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #3860
                  @cino Was nutzt du für den Sonenschutz? Auch die Außentemperatur?
                  C 1 Antwort Letzte Antwort
                  • simatecS simatec
                    @noah3112
                    #3861
                    @simatec Ich werde mir das heute Nachmittag mal anschauen und gegebenenfalls ändern. Trotzdem bleibt die Frage warum das Ganze in der Version 1.2.1 funktioniert hat!? Danke das ihr euch die Zeit für die Fehleranalyse genommen habt 👍
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #3862
                      @noah3112 Wahrscheinlich war es am Ende ein Bug in 1.2.1, der bei dir einen positiven Effekt hatte
                      • BostilB Bostil
                        Möchte es nicht mal bug nennen, hatte aber folgendes Problem: für das Herunterfahren per Lichtsensor bei Unterschreiten eines Schwellenwertes hatte ich schon länger einen Sensor definiert, der keine Daten mehr lieferte (disconnected). Jedes Mal wenn ich "auto_all" anwählte fuhren alle Rolladen herunter. Habe nun den Sensor entfernt und hoffe, dass dies die Problemlösung ist.
                        BostilB Offline
                        BostilB Offline
                        Bostil
                        schrieb am zuletzt editiert von Bostil
                        #3863
                        @bostil sagte in Test Adapter shuttercontrol v1.3.x:
                        Oh Nein, es ist immernoch so: Wenn ich die Automatik aktiviere über "auto_all", dann schließen alle Rolläden. @simatec Hast du eine Idee, was bei mir in der Config nicht stimmt? Habe je Rollade den Sonnenschutz eingestellt auf Innen-/Außentemo/Licht und Himmelsrichtung, wobei der Lichtsensor noch eingestellt ist, aber keine Werte mehr liefert.
                        Neben den o. g. Problem noch eine weitere Fragen:
                        • wenn ich nur noch Innen-/Aupentemp und Himmelsrichtung als Parameter verwenden möchte, gibt es hierfür eine Einstellung / Empfehlung bei der Auswahl?
                        Danke @simatec und @FoxRo für diesen genialen Adapter und die Verbesserungen !!!
                        • F FoxRo
                          @bostil said in Test Adapter shuttercontrol v1.3.x:
                          Würde gerne den Frost-Alarm verwenden.
                          Wie würdet ihr vorgehen? Man benötigt ja noch einen manuell angelegten Datenpunkt, den man auf true oder false schaltet, falls eine gewisste Außentemperatur erreicht wurde, oder ?
                          Je nachdem was Deine Wetterstation her gibt oder was für ein Wetterdienst du nutzt. Wenn lediglich einen Aussentemp Fühler nutzt, dann musst einen logik DP erstellen und da mittels Skript auf Grund der Aussentemp ein True/False setzen. Diesen DP trägtst dann bei Shuttercontrol beim AlarmDP ein.
                          Viel Erfolg!
                          BostilB Offline
                          BostilB Offline
                          Bostil
                          #3864
                          @foxro Wurde es mit einem der letzten Updates eingerichtet, dass man den zusätzlichen Datenpunkt nicht mehr benötigt, sondern die Temp für den Frostschutz direkt im Adapter einstellen kann? DANKE.
                          F 1 Antwort Letzte Antwort
                          • simatecS simatec
                            Cino
                            #3865
                            @simatec said in Test Adapter shuttercontrol v1.3.x:
                            ja
                            IOB@RPI4
                            • C Cino
                              ja
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #3866
                              @cino Nein nutzt du nicht ... das ist der Grund warum dir die Rollläden immer in den Sonnenschutz fahren.
                              Stelle die "Art der Sonnenschutzsteuerung" auf "Außentemperatur/Lichtsensor & Himmelsrichtung
                              • C Offline
                                Cino
                                #3867
                                Auuuu jetzt sehe ich es. Mein Gott lauter Bäume und kein Wald in Sicht.
                                IOB@RPI4
                                • simatecS simatec
                                  #3868
                                  @simatec Hurra hat funktioniert...Vielen Dank!!! Jetzt bitte den Bug aus der Version 1.2.1 entfernen ;-) ...
                                  • simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #3869
                                    @noah3112 Mit der Delayzeit kannst du noch etwas spielen. Nimm sie soweit wie möglich runter
                                    Beobachte einfach mal beim öffnen oder schließen das Objekt im shelly, bis er den tatsächlichen Wert fest hat
                                    Glaube da kann man aber an den shellys auch etws konfigurieren ... Hab die leider nicht hier
                                    • simatecS simatec
                                      #3870
                                      @simatec Alles klar ich teste das mal. Danke das du dir Zeit genommen hast bzw die Geduld ;-)
                                        @homoran Bin gerade nochmal zurück auf Version 1.2.1 und es funzt wieder alles. Ist mir echt zu hoch...
                                        #3871
                                        Ich denke das gilt jetzt wohl nicht mehr und du hast jetzt mehr Durchblick?
                                          #3872
                                          @homoran So langsam steige ich dahinter...aber nur ganz langsam ;-) Zumindest weiß ich jetzt wie ich nach Fehlern suchen kann. Es war einfach nur die Tatsache das es ja funktioniert die etwas verwirrend war. Muss bei dir auch bedanken...
