  4. yr.no Widget
    6.3k
yr.no Widget
52 Beiträge 4 Kommentatoren 8.3k Aufrufe 3 Beobachtet
  • P plc
    so sieh der Log nach dem Löschen aus
    $ iobroker del yr
    Delete adapter "yr"
    host.ioBroker-RasPi Counted 1 instances of yr
    host.ioBroker-RasPi Counted 1 meta of yr
    host.ioBroker-RasPi Counted 1 adapter for yr
    host.ioBroker-RasPi Counted 2 devices of yr
    host.ioBroker-RasPi Counted 89 channels of yr
    host.ioBroker-RasPi Counted 1199 states of yr
    host.ioBroker-RasPi Counted 15 states of system.adapter.yr
    host.ioBroker-RasPi Counted 1199 states (io.yr.*) from states
    host.ioBroker-RasPi Counted 13 states (system.adapter.yr.*) from states
    host.ioBroker-RasPi Counted 1 objects of yr
    host.ioBroker-RasPi file yr.admin deleted
    host.ioBroker-RasPi object yr deleted
    host.ioBroker-RasPi object yr.admin deleted
    host.ioBroker-RasPi Deleting 1309 object(s). Be patient...
    host.ioBroker-RasPi: Only 1200 objects left to be deleted.
    host.ioBroker-RasPi: Only 1000 objects left to be deleted.
    host.ioBroker-RasPi: Only 800 objects left to be deleted.
    host.ioBroker-RasPi: Only 600 objects left to be deleted.
    host.ioBroker-RasPi: Only 400 objects left to be deleted.
    host.ioBroker-RasPi: Only 200 objects left to be deleted.
    host.ioBroker-RasPi Deleting 1212 state(s). Be patient...
    host.ioBroker-RasPi: Only 1200 states left to be deleted.
    host.ioBroker-RasPi: Only 1000 states left to be deleted.
    host.ioBroker-RasPi: Only 800 states left to be deleted.
    host.ioBroker-RasPi: Only 600 states left to be deleted.
    host.ioBroker-RasPi: Only 400 states left to be deleted.
    host.ioBroker-RasPi: Only 200 states left to be deleted.
    npm uninstall iobroker.yr --loglevel error --prefix "/opt/iobroker" (System call)
    Process exited with code 0
    MOD-Edit: Code in code-tags gesetzt!
    @plc ok - wie sieht jetzt die Adapterseite aus?
    ggf. mit STRG-F5 mal den Browsercache löschen!
    @plc sagte in yr.no Widget:
    warum ist die Instanz scheuduled wie bekomme ich diese gestartet
    die ruft nur alle von dir konfigurierte Anzahl Minuten die Daten ab
    P 1 Antwort Letzte Antwort
      plc
      HomoranH P 2 Antworten Letzte Antwort
      • P plc
        • P plc
          plc
          @plc said in yr.no Widget:
          jetzt sieht es richtig aus also nach der Deinstallation kein Adapter vorhanden.
          • P plc
            keine Nacherzählungen - Beweise!
            Konfigs als Screenshots, logs und Code als Text in code-tags
            Auch alle Objekte vollständig weg?
              plc
              • P plc
                plc
                @plc
                nach der Deinstallation unter Objekten
                • P plc
                  @plc
                  @plc schön!
                  Vertrauen ist gut - Kontrolle ist besser:
                  iobroker list adapters
                  iobroker list instances
                  iobroker update -i
                    @plc schön!
                    iobroker update -i
                    plc
                    • P plc
                      @homoran sagte in yr.no Widget:
                        plc
                        wie kann ich aus Putty Konsole Queltex rauskopieren
                        • P plc
                          einfach markieren, dann ist es in der Zwischenablage
                            plc
                            pi@ioBroker-RasPi:~ $ iobroker list adapters
                            system.adapter.admin                   : admin          - v5.1.25
                            system.adapter.alexa2                  : alexa2         - v3.11.2
                            system.adapter.backitup                : backitup       - v2.1.17
                            system.adapter.daswetter               : daswetter      - v3.0.7
                            system.adapter.iot                     : iot            - v1.8.22
                            system.adapter.javascript              : javascript     - v5.2.8
                            system.adapter.knx                     : knx            - v1.0.45
                            system.adapter.rpi2                    : rpi2           - v1.3.1
                            system.adapter.shuttercontrol          : shuttercontrol - v1.2.1
                            system.adapter.vis                     : vis            - v1.4.4
                            system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                            system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                            system.adapter.vis-weather             : vis-weather    - v2.5.3
                            system.adapter.web                     : web            - v3.4.9
                            pi@ioBroker-RasPi:~ $ iobroker list instances
                            + system.adapter.admin.0                  : admin                 : ioBroker-RasPi                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : ioBroker-RasPi                           -  enabled
                            + system.adapter.backitup.0               : backitup              : ioBroker-RasPi                           -  enabled
                              system.adapter.daswetter.0              : daswetter             : ioBroker-RasPi                           -  enabled
                            + system.adapter.iot.0                    : iot                   : ioBroker-RasPi                           -  enabled
                            + system.adapter.javascript.0             : javascript            : ioBroker-RasPi                           -  enabled
                            + system.adapter.knx.0                    : knx                   : ioBroker-RasPi                           -  enabled, bind: 192.168.178.22
                            + system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi                           -  enabled
                            + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-RasPi                           -  enabled
                              system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-RasPi                           -  enabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-RasPi                           -  enabled
                              system.adapter.vis-weather.0            : vis-weather           : ioBroker-RasPi                           -  enabled
                              system.adapter.vis.0                    : vis                   : ioBroker-RasPi                           -  enabled
                            + system.adapter.web.0                    : web                   : ioBroker-RasPi                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            pi@ioBroker-RasPi:~ $ iobroker update -i
                            Used repository: stable
                            hash unchanged, use cached sources
                            update done
                            Adapter    "admin"         : 5.1.25   , installed 5.1.25
                            Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
                            Adapter    "backitup"      : 2.1.17   , installed 2.1.17
                            Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                            Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                            Adapter    "iot"           : 1.8.22   , installed 1.8.22
                            Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                            Controller "js-controller" : 3.3.18   , installed 3.3.18
                            Adapter    "knx"           : 1.0.45   , installed 1.0.45
                            Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
                            Adapter    "shuttercontrol": 1.2.1    , installed 1.2.1
                            Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                            Adapter    "socketio"      : 3.1.4    , installed 3.1.5
                            Adapter    "vis"           : 1.4.4    , installed 1.4.4
                            Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                            Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                            Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
                            Adapter    "web"           : 3.4.9    , installed 3.4.9
                            • P plc
                              + instance is alive
                              update done
                              @plc Danke - das kann ich lesen!
                              Sieht soweit alles gut aus
                              Jetzt bitte nochmal den Adapter yr installieren
                                plc
                                install log
                                $ iobroker add yr --host ioBroker-RasPi
                                NPM version: 6.14.15
                                npm install iobroker.yr@3.0.5 --loglevel error --prefix "/opt/iobroker" (System call)
                                host.ioBroker-RasPi install adapter yr
                                upload [90] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowshowers_polartwilight.svg icons/snowshowers_polartwilight.svg image/svg+xml
                                upload [80] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetshowers_day.svg icons/sleetshowers_day.svg image/svg+xml
                                upload [70] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/rain.svg icons/rain.svg image/svg+xml
                                upload [60] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/lightsnowshowers_polartwilight.svg icons/lightsnowshowers_polartwilight.svg image/svg+xml
                                upload [50] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/lightrainshowersandthunder_polartwilight.svg icons/lightrainshowersandthunder_polartwilight.svg image/svg+xml
                                upload [40] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/heavysnowshowersandthunder_day.svg icons/heavysnowshowersandthunder_day.svg image/svg+xml
                                upload [30] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/heavysleetshowers_night.svg icons/heavysleetshowers_night.svg image/svg+xml
                                upload [20] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/heavyrainandthunder.svg icons/heavyrainandthunder.svg image/svg+xml
                                upload [19] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/heavyrain.svg icons/heavyrain.svg image/svg+xml
                                upload [18] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/fog.svg icons/fog.svg image/svg+xml
                                upload [17] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/fair_polartwilight.svg icons/fair_polartwilight.svg image/svg+xml
                                upload [16] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/fair_night.svg icons/fair_night.svg image/svg+xml
                                upload [15] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/fair_day.svg icons/fair_day.svg image/svg+xml
                                upload [14] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/cloudy.svg icons/cloudy.svg image/svg+xml
                                upload [13] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/clearsky_polartwilight.svg icons/clearsky_polartwilight.svg image/svg+xml
                                upload [12] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/clearsky_night.svg icons/clearsky_night.svg image/svg+xml
                                upload [11] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/clearsky_day.svg icons/clearsky_day.svg image/svg+xml
                                upload [10] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/LICENSE icons/LICENSE null
                                upload [9] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [8] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [7] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [6] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [5] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [4] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [3] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [2] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [1] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [0] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                host.ioBroker-RasPi object system.adapter.yr created/updated
                                host.ioBroker-RasPi create instance yr
                                host.ioBroker-RasPi object system.adapter.yr.0.logLevel created
                                host.ioBroker-RasPi object system.adapter.yr.0.sigKill created
                                host.ioBroker-RasPi object system.adapter.yr.0.eventLoopLag created
                                host.ioBroker-RasPi object system.adapter.yr.0.outputCount created
                                host.ioBroker-RasPi object system.adapter.yr.0.inputCount created
                                host.ioBroker-RasPi object system.adapter.yr.0.uptime created
                                host.ioBroker-RasPi object system.adapter.yr.0.memRss created
                                host.ioBroker-RasPi object system.adapter.yr.0.memHeapTotal created
                                host.ioBroker-RasPi object system.adapter.yr.0.memHeapUsed created
                                host.ioBroker-RasPi object system.adapter.yr.0.cputime created
                                host.ioBroker-RasPi object system.adapter.yr.0.cpu created
                                host.ioBroker-RasPi object system.adapter.yr.0.compactMode created
                                host.ioBroker-RasPi object system.adapter.yr.0.connected created
                                host.ioBroker-RasPi object system.adapter.yr.0.alive created
                                host.ioBroker-RasPi object system.adapter.yr.0 created
                                • P plc
                                  install log
                                  sieht gut aus, auch die ganzen Icons werden hochgeladen
                                    plc
                                    so sieht es unter Objekten aus
                                    • P plc
                                      @plc sieht doch genauso aus wie bei @Glasfaser
                                      GlasfaserG P 2 Antworten Letzte Antwort
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Nur mal zur INFO :
                                        Ich habe geschrieben :
                                        Kenne den Adapter nicht , aber wenn ich mir ein Screenshot dazu anschaue , mußt du ein HTML Widget nehmen inkl. diesem Datenpunkt html
                                        Das war ein Screenshot hier aus dem Forum .....
                                          plc
                                          aber wenn ich richtig verstanden habe muss irgendwo zumindest ein Datenpunkt mit URL geben
                                          GlasfaserG Samson71S 2 Antworten Letzte Antwort
