  4. Zigbee Adapter findet Stick nicht
    6.0k
65 Beiträge 8 Kommentatoren 15.2k Aufrufe 4 Beobachtet
  • R rettroo
    leider erkennt mein Zigbee-Adapter meinen Stick nicht mehr. Ich hatte das vorab schon öfters , da half ein Reboot. Nun hilft aber auch das nicht mehr.
    zigbee.0
    2021-11-02 14:19:20.074	error	Error herdsman start
    zigbee.0
    2021-11-02 14:19:20.074	error	Failed to start Zigbee
    zigbee.0
    2021-11-02 14:19:20.074	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2021-11-02 14:19:20.014	info	Installed Version: iobroker.zigbee@1.5.6
    zigbee.0
    2021-11-02 14:19:20.006	info	Starting Zigbee npm ...
    zigbee.0
    2021-11-02 14:19:20.005	info	Try to reconnect. 1 attempts left
    zigbee.0
    2021-11-02 14:19:10.004	error	Error herdsman start
    zigbee.0
    2021-11-02 14:19:10.004	error	Failed to start Zigbee
    zigbee.0
    2021-11-02 14:19:10.004	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2021-11-02 14:19:10.003	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2021-11-02 14:19:10.003	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2021-11-02 14:19:10.003	error	Please update configuration to prevent further issues.
    zigbee.0
    2021-11-02 14:19:10.003	error	- Channel List: configured=26, adapter=26
    zigbee.0
    2021-11-02 14:19:10.003	error	- Network Key: configured=01030507090b0d0f00020406080a0c0a, adapter=01030507090b0d0f00020406080a0c0a
    zigbee.0
    2021-11-02 14:19:10.002	error	- Extended PAN ID: configured=dadddddddddddddd, adapter=00124b00060d9d28
    zigbee.0
    2021-11-02 14:19:10.002	error	- PAN ID: configured=6754, adapter=6754
    zigbee.0
    2021-11-02 14:19:10.002	error	Configuration is not consistent with adapter state/backup!
    @rettroo sagte in Zigbee Adapter findet Stick nicht:
    Das muss aber übereinstimmen.
    Bring die Extended PAN ID im Adapter übereinander.
    Dann würde ich prüfen, ob zwei Instanzen vom zigbee-Adapter benötigt werden. Und in deren Einstellungen den by-id-DeviceLink setzen, nicht /dev/ttyUSBx
    R 1 Antwort Letzte Antwort
      rettroo
      @thomas-braun said in Zigbee Adapter findet Stick nicht:
      00124b00060d9d28
      hach, das wars... danke. Obwohl ich keine Ahnung habe wie diese ID zustande kam: 00124b00060d9d28...
      Zweite Instanz hatte ich nur zu Testzwecke installiert..
      • R rettroo
        00124b00060d9d28
        rettroo
        @rettroo
        es funktioniert jetzt zwar aber ich habe noch folgendes im Log:
        zigbee.0
        2021-11-04 13:31:43.970	warn	Extended PAN ID is reversed (expected=289d0d06004b1200, actual=00124b00060d9d28)
        was will er mir sagen?
        • R rettroo
          @rettroo
          zigbee.0
          @rettroo
          Das du die byte order im Adapter anpassen musst. Schau welcher Wert da im Moment in den Einstellungen drin ist und setze den anderen dafür ein.
          Das ist zwar der gleiche Wert, aber einmal als 'big endian' und einmal als 'little endian' geschrieben.
          • MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            hier das gleiche Problem!
            Aber alles Probiert, es geht hier nicht.
            IObroker auf dem NUC als VM.
            AsgothianA Thomas BraunT 2 Antworten Letzte Antwort
            • MathiasJM MathiasJ
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @mathiasj sagte in Zigbee Adapter findet Stick nicht:
              Welches der oben genannten Probleme hast du denn ?
              • Der Stick wird nicht gefunden ?
              • Die PAN ID ist "reversed" ?
              • Die PAN ID ist nicht so vie konfiguriert ?
              Schreib doch mal bitte:
              • welche Hardware ?
              • welche Version (NodeJS, Zigbee Adapter, Firmware auf dem Coordinator)
              • was kommt an "warn" oder "error" Meldungen bei Dir im Log.
              A.
              p.s. Bitte alles als Text posten, keine Screenshots - sonst (von mir) keine Hilfe.
              p.p.s: Die Aussage Den Fehler hab ich auch ist fast immer falsch, und immer unvollständig, insbesondere wenn der Fehler nicht klar ist.
                @mathiasj
                Soso...
                Das ist schade.
                • MathiasJM Offline
                  MathiasJM Offline
                  MathiasJ
                  Wie bekomme ich die FW Version des dongles, ob der PAN reserviert ist, heraus?
                  Der Stick wurde fertig geflasht gekauft.
                    @mathiasj
                    Steht alles in deinem LogFile. Oder sollen wir jetzt, (weil es ja das gleiche Problem ist...) das von deinen Vorpostern nehmen?
                    MathiasJM 1 Antwort Letzte Antwort
                      @mathiasj
                      MathiasJM Offline
                      MathiasJM Offline
                      MathiasJ
                      Nein, ich schaue mir die logfiles an und poste die hier
                      • MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        schrieb am zuletzt editiert von MathiasJ
                        Hier das Logfile:
                        Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C838-if00'"
                        	2021-11-06 11:07:36.699	error	Cannot read property 'getEntries' of null
                        zigbee.0
                        2021-11-06 11:07:36.698	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
                        zigbee.0
                        2021-11-06 11:07:36.696	error	unhandled promise rejection: Cannot read property 'getEntries' of null
                        zigbee.0
                        2021-11-06 11:07:36.696	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        zigbee.0
                        2021-11-06 11:07:36.694	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        zigbee.0
                        2021-11-06 11:07:36.693	info	terminating
                        zigbee.0
                        2021-11-06 11:07:36.692	warn	Failed to stop zigbee during startup
                        zigbee.0
                        2021-11-06 11:07:36.690	info	Zigbee: disabling joining new devices.
                        zigbee.0
                        2021-11-06 11:07:36.685	info	cleaned everything up...
                        zigbee.0
                        2021-11-06 11:07:36.683	info	Got terminate signal TERMINATE_YOURSELF
                        zigbee.0
                        2021-11-06 11:07:16.615	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0
                        2021-11-06 11:07:16.614	debug	List of ports: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyS2"}]
                        zigbee.0
                        2021-11-06 11:07:16.400	debug	sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                        zigbee.0
                        2021-11-06 11:07:16.398	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                          Hier das Logfile:
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          @mathiasj
                          Und auf welchem by-id-Device-Link ist der Adapter eingestellt?
                          Stick in die VM durchgereicht?
                            @mathiasj
                            MathiasJM Offline
                            MathiasJM Offline
                            MathiasJ
                            nein, es ist ein Tinkerboard ud keine VM.
                            ich habe eingegeben:
                            Gruß,
                            Mathias
                              Gruß,
                              Mathias
                              eingegeben
                              Schreit nach Tippfehler. Sowas kopiert man per copy&paste.
                              ls -la /dev/serial/by-id/
                                eingegeben
                                dondaik
                                da mein zigbee auch nicht startet ....
                                die consolenantwort
                                ls -la /dev/serial/by-id/ sagt
                                und das steht auch bei den einstellungen
                                wer Schreibfehler findet darf sie behalten … :-(
                                Ps: Anfänger im Bereich Tinkerboard + IOBROKER !
                                • D dondaik
                                  die consolenantwort
                                  @dondaik
                                  Bitte keine Screenshots von Konsolentext, nicht als root rumhampeln.
                                  Der Adapterstart sieht wie im LogFile aus?
                                    @dondaik
                                    dondaik
                                    schrieb am zuletzt editiert von dondaik
                                    werde ich versuchen
                                    • D dondaik
                                      werde ich versuchen
                                      @dondaik
                                      Hi Don,
                                      bitte ganze Sätze für die Mitlesenden :-)
                                      (du Editeur!)
                                      Was suchst du denn genau?
                                      Adapterstart, ich denke da meint @Thomas-Braun was im log steht, wenn du die Instanz neu startest
                                      und den Consolenfehler bitte auch markieren und in code-Tags (Icon </>) einbetten
                                      und root verbiegt ggf. einieg Rechte im System, da solltest du als normaler User arbeiten - das mit dem root war wahrscheinlich noch als du dein Tinkerboard aufgesetzt hast üblich.
                                      Was mich zu der Frage bringt, ob dein gessamter Unterbau überhaupt aktuell ist (OS,node, npm)
                                        @dondaik
                                        Hi Don,
                                        (du Editeur!)
                                        dondaik
                                        ja iobroker ist akutuell - da aufgrund des fehlers und des neuen admins mehrfach ganz neu aufgesetzt ...
                                        • D dondaik
                                          dondaik
                                          hier was aus dem log
                                          mqtt.0
                                          2021-11-06 12:26:10.835	info	Client [NH-Kombisensor] verbunden mit geheimem 1636197970834_9415
                                          zick-bebee.0
                                          2021-11-06 12:26:10.610	info	Installierte Version: iobroker.zigbee@1.5.6
                                          zick-bebee.0
                                          2021-11-06 12:26:10.597	fehler	Fehler Herdsman Start
                                          zick-bebee.0
                                          2021-11-06 12:26:10.596	fehler	Zigbee konnte nicht gestartet werden
                                          zick-bebee.0
                                          2021-11-06 12:26:10.595	fehler	Start des Zigbee-Herdsman-Problems: "Fehler beim Öffnen des seriellen Ports 'Fehler: Fehler: Keine solche Datei oder verzeichnis, kann /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C838-if00' nicht öffnen"
                                          zick-bebee.0
                                          2021-11-06 12:26:10.577	debuggen	Zigbee-Hirten starten...
                                          MOD-Edit: Code in code-tags gesetzt!
