  4. Zigbee Adapter findet Stick nicht
    6.0k
65 Beiträge 8 Kommentatoren 15.2k Aufrufe 4 Beobachtet
  • R Offline
    rettroo
    leider erkennt mein Zigbee-Adapter meinen Stick nicht mehr. Ich hatte das vorab schon öfters , da half ein Reboot. Nun hilft aber auch das nicht mehr.
    zigbee.0
    2021-11-02 14:19:20.074	error	Error herdsman start
    zigbee.0
    2021-11-02 14:19:20.074	error	Failed to start Zigbee
    zigbee.0
    2021-11-02 14:19:20.074	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    2021-11-02 14:19:20.014	info	Installed Version: iobroker.zigbee@1.5.6
    zigbee.0
    2021-11-02 14:19:20.006	info	Starting Zigbee npm ...
    zigbee.0
    2021-11-02 14:19:20.005	info	Try to reconnect. 1 attempts left
    zigbee.0
    2021-11-02 14:19:10.004	error	Error herdsman start
    zigbee.0
    2021-11-02 14:19:10.004	error	Failed to start Zigbee
    zigbee.0
    2021-11-02 14:19:10.004	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0
    2021-11-02 14:19:10.003	error	Re-commissioning your network will require re-pairing of all devices!
    zigbee.0
    2021-11-02 14:19:10.003	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0
    2021-11-02 14:19:10.003	error	Please update configuration to prevent further issues.
    zigbee.0
    2021-11-02 14:19:10.003	error	- Channel List: configured=26, adapter=26
    zigbee.0
    2021-11-02 14:19:10.003	error	- Network Key: configured=01030507090b0d0f00020406080a0c0a, adapter=01030507090b0d0f00020406080a0c0a
    zigbee.0
    2021-11-02 14:19:10.002	error	- Extended PAN ID: configured=dadddddddddddddd, adapter=00124b00060d9d28
    zigbee.0
    2021-11-02 14:19:10.002	error	- PAN ID: configured=6754, adapter=6754
    zigbee.0
    2021-11-02 14:19:10.002	error	Configuration is not consistent with adapter state/backup!
    Thomas BraunT mickymM 2 Antworten Letzte Antwort
    • R rettroo
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @rettroo sagte in Zigbee Adapter findet Stick nicht:
      Das muss aber übereinstimmen.
      Bring die Extended PAN ID im Adapter übereinander.
      Dann würde ich prüfen, ob zwei Instanzen vom zigbee-Adapter benötigt werden. Und in deren Einstellungen den by-id-DeviceLink setzen, nicht /dev/ttyUSBx
      R 1 Antwort Letzte Antwort
        rettroo
        @thomas-braun said in Zigbee Adapter findet Stick nicht:
        00124b00060d9d28
        hach, das wars... danke. Obwohl ich keine Ahnung habe wie diese ID zustande kam: 00124b00060d9d28...
        Zweite Instanz hatte ich nur zu Testzwecke installiert..
        • R rettroo
          00124b00060d9d28
          rettroo
          @rettroo
          es funktioniert jetzt zwar aber ich habe noch folgendes im Log:
          zigbee.0
          2021-11-04 13:31:43.970	warn	Extended PAN ID is reversed (expected=289d0d06004b1200, actual=00124b00060d9d28)
          was will er mir sagen?
          • R rettroo
            @rettroo
            zigbee.0
            @rettroo
            Das du die byte order im Adapter anpassen musst. Schau welcher Wert da im Moment in den Einstellungen drin ist und setze den anderen dafür ein.
            Das ist zwar der gleiche Wert, aber einmal als 'big endian' und einmal als 'little endian' geschrieben.
            • MathiasJM Offline
              MathiasJM Offline
              MathiasJ
              hier das gleiche Problem!
              Aber alles Probiert, es geht hier nicht.
              IObroker auf dem NUC als VM.
              AsgothianA Thomas BraunT 2 Antworten Letzte Antwort
              • MathiasJM MathiasJ
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @mathiasj sagte in Zigbee Adapter findet Stick nicht:
                Welches der oben genannten Probleme hast du denn ?
                • Der Stick wird nicht gefunden ?
                • Die PAN ID ist "reversed" ?
                • Die PAN ID ist nicht so vie konfiguriert ?
                Schreib doch mal bitte:
                • welche Hardware ?
                • welche Version (NodeJS, Zigbee Adapter, Firmware auf dem Coordinator)
                • was kommt an "warn" oder "error" Meldungen bei Dir im Log.
                A.
                p.s. Bitte alles als Text posten, keine Screenshots - sonst (von mir) keine Hilfe.
                p.p.s: Die Aussage Den Fehler hab ich auch ist fast immer falsch, und immer unvollständig, insbesondere wenn der Fehler nicht klar ist.
                  @mathiasj
                  Soso...
                  Das ist schade.
                  • MathiasJM Offline
                    MathiasJM Offline
                    MathiasJ
                    Wie bekomme ich die FW Version des dongles, ob der PAN reserviert ist, heraus?
                    Der Stick wurde fertig geflasht gekauft.
                      @mathiasj
                      Steht alles in deinem LogFile. Oder sollen wir jetzt, (weil es ja das gleiche Problem ist...) das von deinen Vorpostern nehmen?
                      MathiasJM 1 Antwort Letzte Antwort
                        @mathiasj
                        MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        Nein, ich schaue mir die logfiles an und poste die hier
                        • MathiasJM Offline
                          MathiasJM Offline
                          MathiasJ
                          schrieb am zuletzt editiert von MathiasJ
                          Hier das Logfile:
                          Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C838-if00'"
                          	2021-11-06 11:07:36.699	error	Cannot read property 'getEntries' of null
                          zigbee.0
                          2021-11-06 11:07:36.698	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
                          zigbee.0
                          2021-11-06 11:07:36.696	error	unhandled promise rejection: Cannot read property 'getEntries' of null
                          zigbee.0
                          2021-11-06 11:07:36.696	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          zigbee.0
                          2021-11-06 11:07:36.694	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          zigbee.0
                          2021-11-06 11:07:36.693	info	terminating
                          zigbee.0
                          2021-11-06 11:07:36.692	warn	Failed to stop zigbee during startup
                          zigbee.0
                          2021-11-06 11:07:36.690	info	Zigbee: disabling joining new devices.
                          zigbee.0
                          2021-11-06 11:07:36.685	info	cleaned everything up...
                          zigbee.0
                          2021-11-06 11:07:36.683	info	Got terminate signal TERMINATE_YOURSELF
                          zigbee.0
                          2021-11-06 11:07:16.615	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
                          zigbee.0
                          2021-11-06 11:07:16.614	debug	List of ports: [{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyS2"}]
                          zigbee.0
                          2021-11-06 11:07:16.400	debug	sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
                          zigbee.0
                          2021-11-06 11:07:16.398	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                            Hier das Logfile:
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            zigbee.0
                            @mathiasj
                            Und auf welchem by-id-Device-Link ist der Adapter eingestellt?
                            Stick in die VM durchgereicht?
                              @mathiasj
                              MathiasJM Offline
                              MathiasJM Offline
                              MathiasJ
                              nein, es ist ein Tinkerboard ud keine VM.
                              ich habe eingegeben:
                              Gruß,
                              Mathias
                                Gruß,
                                Mathias
                                eingegeben
                                Schreit nach Tippfehler. Sowas kopiert man per copy&paste.
                                ls -la /dev/serial/by-id/
                                  eingegeben
                                  dondaik
                                  da mein zigbee auch nicht startet ....
                                  die consolenantwort
                                  ls -la /dev/serial/by-id/ sagt
                                  und das steht auch bei den einstellungen
                                  wer Schreibfehler findet darf sie behalten … :-(
                                  Ps: Anfänger im Bereich Tinkerboard + IOBROKER !
                                  • D dondaik
                                    die consolenantwort
                                    @dondaik
                                    Bitte keine Screenshots von Konsolentext, nicht als root rumhampeln.
                                    Der Adapterstart sieht wie im LogFile aus?
                                      @dondaik
                                      dondaik
                                      schrieb am zuletzt editiert von dondaik
                                      werde ich versuchen
                                      • D dondaik
                                        werde ich versuchen
                                        @dondaik
                                        Hi Don,
                                        bitte ganze Sätze für die Mitlesenden :-)
                                        (du Editeur!)
                                        Was suchst du denn genau?
                                        Adapterstart, ich denke da meint @Thomas-Braun was im log steht, wenn du die Instanz neu startest
                                        und den Consolenfehler bitte auch markieren und in code-Tags (Icon </>) einbetten
                                        und root verbiegt ggf. einieg Rechte im System, da solltest du als normaler User arbeiten - das mit dem root war wahrscheinlich noch als du dein Tinkerboard aufgesetzt hast üblich.
                                        Was mich zu der Frage bringt, ob dein gessamter Unterbau überhaupt aktuell ist (OS,node, npm)
                                          @dondaik
                                          Hi Don,
                                          (du Editeur!)
                                          dondaik
                                          ja iobroker ist akutuell - da aufgrund des fehlers und des neuen admins mehrfach ganz neu aufgesetzt ...
