<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zigbee Adapter findet Stick nicht]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">leider erkennt mein Zigbee-Adapter meinen Stick nicht mehr. Ich hatte das vorab schon öfters , da half ein Reboot. Nun hilft aber auch das nicht mehr.</p>
<p dir="auto"><img src="/assets/uploads/files/1635859062461-6d7caa95-b66c-4a87-99e3-db7371a73d32-image.png" alt="6d7caa95-b66c-4a87-99e3-db7371a73d32-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1635859101678-bb40a93c-d8de-4b4f-a012-020ffb2999cc-image.png" alt="bb40a93c-d8de-4b4f-a012-020ffb2999cc-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1635859133729-381bfbe1-62ca-42bf-9738-c5bb66ab2d44-image.png" alt="381bfbe1-62ca-42bf-9738-c5bb66ab2d44-image.png" class=" img-fluid img-markdown" /></p>
<pre><code>
zigbee.0
2021-11-02 14:19:20.074	error	Error herdsman start
zigbee.0
2021-11-02 14:19:20.074	error	Failed to start Zigbee
zigbee.0
2021-11-02 14:19:20.074	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
zigbee.0
2021-11-02 14:19:20.014	info	Installed Version: iobroker.zigbee@1.5.6
zigbee.0
2021-11-02 14:19:20.006	info	Starting Zigbee npm ...
zigbee.0
2021-11-02 14:19:20.005	info	Try to reconnect. 1 attempts left
zigbee.0
2021-11-02 14:19:10.004	error	Error herdsman start
zigbee.0
2021-11-02 14:19:10.004	error	Failed to start Zigbee
zigbee.0
2021-11-02 14:19:10.004	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
zigbee.0
2021-11-02 14:19:10.003	error	Re-commissioning your network will require re-pairing of all devices!
zigbee.0
2021-11-02 14:19:10.003	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
zigbee.0
2021-11-02 14:19:10.003	error	Please update configuration to prevent further issues.
zigbee.0
2021-11-02 14:19:10.003	error	- Channel List: configured=26, adapter=26
zigbee.0
2021-11-02 14:19:10.003	error	- Network Key: configured=01030507090b0d0f00020406080a0c0a, adapter=01030507090b0d0f00020406080a0c0a
zigbee.0
2021-11-02 14:19:10.002	error	- Extended PAN ID: configured=dadddddddddddddd, adapter=00124b00060d9d28
zigbee.0
2021-11-02 14:19:10.002	error	- PAN ID: configured=6754, adapter=6754
zigbee.0
2021-11-02 14:19:10.002	error	Configuration is not consistent with adapter state/backup!
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/49012/zigbee-adapter-findet-stick-nicht</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Mar 2026 17:09:33 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/49012.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Nov 2021 13:20:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Tue, 01 Mar 2022 08:02:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a> sagte in <a href="/post/770194">Zigbee Adapter findet Stick nicht</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Gibt es eine Möglichkeit die Pan ID und anderen Keys im Adapter zu ändern bzw. auf dem Stick?<br />
Denn wenn diese nur im Adapter neu hinterlegt werden, werden diese am Stick nicht angepasst/überschrieben und keine Verbindung zum Gerät mehr aufgebaut.</p>
</blockquote>
<p dir="auto">Die Parameter müssen nicht nur auf den Stick übertragen sondern auch an die Geräte weitergegeben werden, da diese in die Verschlüsselung der Kommunikation eingehen. Diese muss aber mit den alten Parametern laufen.</p>
<p dir="auto">Da nicht alle Geräte ständig aufnahmebereit sind ist ein Umstellen der Verschlüsselung im laufenden Betrieb so ohne weiteres nicht realisierbar.</p>
<p dir="auto">Selbst das umstellen des Funkkanals (was keine Anpassung der Verschlüsselung bedeutet und daher eine Grössenordnung einfacher zu realisieren ist) ist durch die Batteriebetriebenen Geräte die dieses im Zweifelsfall nicht mit bekommen nicht mal eben so zu realisieren.</p>
<p dir="auto">A.<br />
Nachtrag:<br />
Hue erlaubt es über einen Zeitraum von X (ich erinnere nicht wie lange der ist) den Funkkanal (halbautomatisch) umzustellen. Dieses funktioniert meines Wissens aber nur bei Geräten die sich an bestimmte (optionale) Teile der Zigbee Spezifikation halten. Insbesondere bei TuYa und Aqara ist eine Unterstützung dieser Methoden fraglich.</p>
]]></description><link>https://forum.iobroker.net/post/770461</link><guid isPermaLink="true">https://forum.iobroker.net/post/770461</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Tue, 01 Mar 2022 08:02:25 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Mon, 28 Feb 2022 18:39:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a></p>
<p dir="auto">Das weiß ich nicht.</p>
]]></description><link>https://forum.iobroker.net/post/770200</link><guid isPermaLink="true">https://forum.iobroker.net/post/770200</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 28 Feb 2022 18:39:10 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Mon, 28 Feb 2022 18:38:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Was im LogFile steht ist soweit klar und das kann dann auch übernommen werden, das ist soweit klar und funktioniert auch.<br />
Aber das sind die Daten, welche bei der allerersten Verbindung übertragen wurden.</p>
<p dir="auto">Wenn hier etwas geändert wird, wird nichts auf den Stick übertragen<br />
<img src="/assets/uploads/files/1646073456038-9a1cb613-6fb8-49d1-9328-e3f12d57753e-image.png" alt="9a1cb613-6fb8-49d1-9328-e3f12d57753e-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/770198</link><guid isPermaLink="true">https://forum.iobroker.net/post/770198</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Mon, 28 Feb 2022 18:38:11 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Mon, 28 Feb 2022 18:32:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a> sagte in <a href="/post/770194">Zigbee Adapter findet Stick nicht</a>:</p>
<blockquote>
<p dir="auto">Gibt es eine Möglichkeit die Pan ID und anderen Keys im Adapter zu ändern</p>
</blockquote>
<p dir="auto">Ja, man kann die natürlich eingeben und 'passend machen'.<br />
Im LogFile steht was genau erwartet wird.</p>
]]></description><link>https://forum.iobroker.net/post/770196</link><guid isPermaLink="true">https://forum.iobroker.net/post/770196</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 28 Feb 2022 18:32:13 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Mon, 28 Feb 2022 18:29:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/770194</link><guid isPermaLink="true">https://forum.iobroker.net/post/770194</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Mon, 28 Feb 2022 18:29:42 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Fri, 25 Feb 2022 05:24:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/asgothian" aria-label="Profile: asgothian">@<bdi>asgothian</bdi></a></p>
<p dir="auto">nein ich bin blind, daher ist das Lesen nicht ganz so einfach.<br />
Aber mittels Sprachsteuerung geht es mittlerweile und man kommt durchs Leben</p>
]]></description><link>https://forum.iobroker.net/post/768282</link><guid isPermaLink="true">https://forum.iobroker.net/post/768282</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Fri, 25 Feb 2022 05:24:35 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 20:57:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a> sagte in <a href="/post/768179">Zigbee Adapter findet Stick nicht</a>:</p>
<blockquote>
<p dir="auto">wusste nicht, dass man die Nr. aus den Adaptern nehmen muss. War der Meinung, dass jeweils freie Nummer verwendet werden können.</p>
</blockquote>
<p dir="auto">Lesen kannst du aber schon ? Da steht doch:</p>
<pre><code>Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
</code></pre>
<p dir="auto">Also auf deutsch: Deine Konfiguration passt nicht. Entweder du passt die Konfiguration an oder du löscht die beiden Dateien und lernst alle Geräte neu an. Genau das ist <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> mit Dir durchgegangen.</p>
<p dir="auto">A.</p>
]]></description><link>https://forum.iobroker.net/post/768244</link><guid isPermaLink="true">https://forum.iobroker.net/post/768244</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Thu, 24 Feb 2022 20:57:36 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 19:36:14 GMT]]></title><description><![CDATA[<p dir="auto">besten Dank...funktioniert nun<br />
]]></description><link>https://forum.iobroker.net/post/768179</link><guid isPermaLink="true">https://forum.iobroker.net/post/768179</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Thu, 24 Feb 2022 19:36:14 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 19:04:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a> sagte in <a href="/post/768159">Zigbee Adapter findet Stick nicht</a>:</p>
<pre><code>2022-02-24 19:51:33.597	error	- Network Key: configured=0103050ab8fb0d0fffb20486080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
2022-02-24 19:51:33.596	error	- Extended PAN ID: configured=5d0dfdeddddcdbda, adapter=00124b0024c0ac4a
2022-02-24 19:51:33.594	error	- PAN ID: configured=6772, adapter=6756
</code></pre>
<p dir="auto">Diese drei Einstellungen müssen sich decken.<br />
Ggf. müssten dann alle Geräte aber neuangelernt werden. Deswegen gibt es den Haken, diese abweichenden Einstellungen einfach zu ignorieren.</p>
<p dir="auto">Ein sauberer Start sähe dann so aus:</p>
<pre><code>2022-02-24 20:02:57.373  - info: host.chet instance system.adapter.zigbee.0 started with pid 57742
2022-02-24 20:03:00.623  - info: zigbee.0 (57742) starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v17.6.0, js-controller: 4.0.15
2022-02-24 20:03:00.734  - info: zigbee.0 (57742) Starting Zigbee  npm ...
2022-02-24 20:03:01.262  - info: zigbee.0 (57742) Installed Version: iobroker.zigbee@1.6.16
2022-02-24 20:03:12.028  - info: zigbee.0 (57742) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220103}}
2022-02-24 20:03:12.037  - info: zigbee.0 (57742) Unable to disable LED, unsupported function.
2022-02-24 20:03:12.051  - info: zigbee.0 (57742)   --&gt; transmitPower : normal
2022-02-24 20:03:12.271  - info: zigbee.0 (57742) Zigbee started
</code></pre>
]]></description><link>https://forum.iobroker.net/post/768163</link><guid isPermaLink="true">https://forum.iobroker.net/post/768163</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 24 Feb 2022 19:04:32 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 18:54:43 GMT]]></title><description><![CDATA[<p dir="auto">vielleicht kannst mir bei der Fehlersuche helfen ;)<br />
alle anderen Adapter laufen ja einwandfrei<br />
Hab jetzt nochmals den Haken raus genommen, um auf den Fehler zu kommen</p>
<pre><code>2022-02-24 19:51:44.454	error	Error herdsman start
2022-02-24 19:51:44.453	error	Failed to start Zigbee
2022-02-24 19:51:44.449	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
2022-02-24 19:51:44.078	info	Installed Version: iobroker.zigbee@1.6.16
2022-02-24 19:51:44.010	info	Starting Zigbee npm ...
2022-02-24 19:51:44.007	info	Try to reconnect. 1 attempts left
2022-02-24 19:51:34.002	error	Error herdsman start
2022-02-24 19:51:34.001	error	Failed to start Zigbee
2022-02-24 19:51:34.000	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
2022-02-24 19:51:33.600	error	Re-commissioning your network will require re-pairing of all devices!
2022-02-24 19:51:33.600	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
2022-02-24 19:51:33.599	error	Please update configuration to prevent further issues.
2022-02-24 19:51:33.598	error	- Channel List: configured=11, adapter=11
2022-02-24 19:51:33.593	error	Configuration is not consistent with adapter state/backup!
2022-02-24 19:51:33.315	info	Installed Version: iobroker.zigbee@1.6.16
2022-02-24 19:51:32.323	info	Starting Zigbee npm ...
2022-02-24 19:51:32.151	info	starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.3, js-controller: 3.3.22
2022-02-24 19:51:22.802	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2022-02-24 19:51:22.798	info	terminating
2022-02-24 19:51:22.314	info	Zigbee: disabling joining new devices.
2022-02-24 19:51:22.296	info	cleaned everything up...
2022-02-24 19:51:22.291	info	Got terminate signal TERMINATE_YOURSELF
</code></pre>
]]></description><link>https://forum.iobroker.net/post/768159</link><guid isPermaLink="true">https://forum.iobroker.net/post/768159</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Thu, 24 Feb 2022 18:54:43 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 18:37:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a> sagte in <a href="/post/768150">Zigbee Adapter findet Stick nicht</a>:</p>
<blockquote>
<p dir="auto">es ist alles richtig installiert<br />
hab nun den Haken bei den Einstellungen gesetzt...und siehe da, läuft nun</p>
</blockquote>
<p dir="auto">Naja, wenn man den Haken da setzen muss, dann ist nicht alles richtig.<br />
Der Haken ignoriert einfach nur die angemeckerten Einstellungen. Ich würde die wenn möglich gerade einstellen.</p>
]]></description><link>https://forum.iobroker.net/post/768151</link><guid isPermaLink="true">https://forum.iobroker.net/post/768151</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 24 Feb 2022 18:37:44 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 18:36:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto"><img src="/assets/uploads/files/1645727756140-a1a74bc8-ba2a-48eb-9cc9-00610bef634b-image.png" alt="a1a74bc8-ba2a-48eb-9cc9-00610bef634b-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/768150</link><guid isPermaLink="true">https://forum.iobroker.net/post/768150</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Thu, 24 Feb 2022 18:36:11 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 18:26:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a><br />
Das bedeutet, dass dein Log zu kurz ist. Der Fehler steht weiter vorne.</p>
]]></description><link>https://forum.iobroker.net/post/768147</link><guid isPermaLink="true">https://forum.iobroker.net/post/768147</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 24 Feb 2022 18:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 18:25:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/asgothian" aria-label="Profile: asgothian">@<bdi>asgothian</bdi></a><br />
kann dir nicht folgen was du meinst.</p>
]]></description><link>https://forum.iobroker.net/post/768145</link><guid isPermaLink="true">https://forum.iobroker.net/post/768145</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Thu, 24 Feb 2022 18:25:26 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 18:14:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/speedyblade" aria-label="Profile: speedyblade">@<bdi>speedyblade</bdi></a></p>
<p dir="auto">Klar.. die haben alle.</p>
<p dir="auto">(die Probleme damit haben das der Zigbee Adapter nicht läuft und die einfach die 3 Startversuche durchlaufen lassen)</p>
<p dir="auto">Dein echtes Problem befindet sich im Log weiter oben.</p>
]]></description><link>https://forum.iobroker.net/post/768139</link><guid isPermaLink="true">https://forum.iobroker.net/post/768139</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Thu, 24 Feb 2022 18:14:16 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Thu, 24 Feb 2022 15:54:45 GMT]]></title><description><![CDATA[<pre><code>	2022-02-24 16:52:30.473	error	Error herdsman start
zigbee.0
	2022-02-24 16:52:30.472	error	Failed to start Zigbee
zigbee.0
	2022-02-24 16:52:30.471	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
</code></pre>
<p dir="auto">sind diese Probleme bekannt?</p>
]]></description><link>https://forum.iobroker.net/post/768094</link><guid isPermaLink="true">https://forum.iobroker.net/post/768094</guid><dc:creator><![CDATA[SpeedyBlade]]></dc:creator><pubDate>Thu, 24 Feb 2022 15:54:45 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Fri, 12 Nov 2021 06:41:16 GMT]]></title><description><![CDATA[<p dir="auto">Update:</p>
<p dir="auto">Es hat tatsächlich am Stick gelegen.<br />
Ich habe den neuen Stick (Conbee2) installiert, die Config im Adapter geändert, dann sprang er sofort auf grün um.<br />
Anlernen mußte ich auch nichts mehr. In der Netzkarte waren sofort alle Geräte da.</p>
]]></description><link>https://forum.iobroker.net/post/702106</link><guid isPermaLink="true">https://forum.iobroker.net/post/702106</guid><dc:creator><![CDATA[MathiasJ]]></dc:creator><pubDate>Fri, 12 Nov 2021 06:41:16 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Tue, 09 Nov 2021 15:31:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a></p>
<p dir="auto">Möglich das das in neuen Versionen (Firmware Conbee, Adapter, wat weiß ich...) jetzt drin ist. Hab die Hardware von Dresden Electronics nicht mehr selber im Einsatz.</p>
]]></description><link>https://forum.iobroker.net/post/700729</link><guid isPermaLink="true">https://forum.iobroker.net/post/700729</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 09 Nov 2021 15:31:47 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Tue, 09 Nov 2021 15:27:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Inzwischen finde ich das nicht mehr - früher war es so, dass die Netzkarte mit dem conbee2 nie ein Ergebnis brachte - inzwischen läuft aber auch das zufriedenstellend. (zumindest bei meiner kleinen Umgebung)</p>
]]></description><link>https://forum.iobroker.net/post/700721</link><guid isPermaLink="true">https://forum.iobroker.net/post/700721</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Tue, 09 Nov 2021 15:27:07 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Tue, 09 Nov 2021 15:04:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dondaik" aria-label="Profile: dondaik">@<bdi>dondaik</bdi></a> sagte in <a href="/post/700695">Zigbee Adapter findet Stick nicht</a>:</p>
<blockquote>
<p dir="auto">nur die netzkarte ist der meinung das verbindungslinien unnötig sind .... ggf gibt sich das ja mal.</p>
</blockquote>
<p dir="auto">Das ist so bei Hardware von Dresden Electronic und dem zigbee-Adapter.</p>
]]></description><link>https://forum.iobroker.net/post/700697</link><guid isPermaLink="true">https://forum.iobroker.net/post/700697</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Tue, 09 Nov 2021 15:04:40 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Tue, 09 Nov 2021 15:04:59 GMT]]></title><description><![CDATA[<p dir="auto">dann kann ich meinen teil hier beenden - conbee 2 steckt und nun kann man wenigstens wieder schalten<br />
man dank!</p>
]]></description><link>https://forum.iobroker.net/post/700695</link><guid isPermaLink="true">https://forum.iobroker.net/post/700695</guid><dc:creator><![CDATA[dondaik]]></dc:creator><pubDate>Tue, 09 Nov 2021 15:04:59 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Sat, 06 Nov 2021 18:20:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a>  gemacht als norbert</p>
<pre><code>tinkerboard:~:% iobroker start
tinkerboard:~:% ls -l /dev/serial/by-id/
total 0
lrwxrwxrwx 1 root root 13 Nov  6 15:34 usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001949C838-if00 -&gt; ../../ttyACM0
tinkerboard:~:%
total 0
tinkerboard:~:%
</code></pre>
<pre><code>bleibt ... im  warndreick 2x grün dann:nicht verbunden mit dienst oder gerät
und nun geht es zu schießen... danke, bis morgen</code></pre>
]]></description><link>https://forum.iobroker.net/post/699279</link><guid isPermaLink="true">https://forum.iobroker.net/post/699279</guid><dc:creator><![CDATA[dondaik]]></dc:creator><pubDate>Sat, 06 Nov 2021 18:20:58 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Sat, 06 Nov 2021 17:27:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dondaik" aria-label="Profile: dondaik">@<bdi>dondaik</bdi></a> sagte in <a href="/post/699243">Zigbee Adapter findet Stick nicht</a>:</p>
<blockquote>
<p dir="auto">egal ob user root oder norbert die antwort ist wie angegeben  .....</p>
</blockquote>
<p dir="auto">das ist wahrscheinlich sogar korrekt.<br />
Aber iobroker läuft seit geraumer Zeit unter dem User <em>iobroker</em>.<br />
Wenn du da jetzt als root drin arbeitest kann es passieren, dass der user <em>iobroker</em> nicht mehr an die notwendigen Dateien darf.<br />
Deswegen solltest du nur noch mit dem User <em>norbert</em> arbeiten und <strong>notfalls</strong> mit sudo!</p>
<p dir="auto">Wenn du dich jetzt als <em>norbert</em> eingeloggt hast führe bitte aus:</p>
<pre><code>iobroker stop
iobroker fix
iobroker start
</code></pre>
]]></description><link>https://forum.iobroker.net/post/699247</link><guid isPermaLink="true">https://forum.iobroker.net/post/699247</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 06 Nov 2021 17:27:23 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter findet Stick nicht on Sat, 06 Nov 2021 17:26:42 GMT]]></title><description><![CDATA[<p dir="auto">root oder norbert - die antwort ist gleich ....</p>
]]></description><link>https://forum.iobroker.net/post/699246</link><guid isPermaLink="true">https://forum.iobroker.net/post/699246</guid><dc:creator><![CDATA[dondaik]]></dc:creator><pubDate>Sat, 06 Nov 2021 17:26:42 GMT</pubDate></item></channel></rss>
