  4. Adapter "smartmeter"
    1.0k
3.6k Beiträge 281 Kommentatoren 3.1m Aufrufe 162 Beobachtet
  • M-A HuebM M-A Hueb
    habe iobroker unter Windows am laufen. nach einem Update des js.controllers startet mein smartmeter -Adapter nicht mehr.
    Folgendes steht im Log:
    host.Server(SmartHome)	2021-10-27 12:06:11.367	info	Restart adapter system.adapter.smartmeter.0 because enabled
    host.Server(SmartHome)	2021-10-27 12:06:11.367	error	instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.Server(SmartHome)	2021-10-27 12:06:11.367	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.Server(SmartHome)	2021-10-27 12:06:11.367	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Object.<anonymous> (C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\lib\win32.js:1:36)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at bindings (C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\node_modules\bindings\bindings.js:112:48)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: \\?\C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\build\Release\bindings.node
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: Error: \\?\C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\build\Release\bindings.node ist keine zulässige Win32-Anwendung.
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: ^
    host.Server(SmartHome)	2021-10-27 12:06:11.366	error	Caught by controller[0]: throw e;
    host.Server(SmartHome)	2021-10-27 12:06:11.365	error	Caught by controller[0]: C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings\node_modules\bindings\bindings.js:121
    host.Server(SmartHome)	2021-10-27 12:06:09.208	info	instance system.adapter.smartmeter.0 started with pid 9080
    Was muss ich machen das es wieder läuft?
    M-A HuebM Offline
    M-A HuebM Offline
    M-A Hueb
    #2186
    @m-a-hueb erledigt. Windows reboot hilft
    iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
    • apollon77A apollon77
      @rossi73 ist der Port anderweitig belegt? Vllt von deinem cat an der Kommandozeile? Ansonsten Konfig ricjtig?
      rossi73
      schrieb am zuletzt editiert von rossi73
      #2187
      @apollon77
      Servus, sorry, jetzt kommen DAU-Fragen:
      Wie/Wo finde ich raus ob der Port anderweitig belegt ist?
      Den Befehl cat kannte ich nicht und hab ihn denke ich noch nie benutzt. Den Raspberry hab ich auch schon mal des öfteren ge-rebootet.
      Konfig:
      Danke!
      HomoranH R 2 Antworten Letzte Antwort
      • R rossi73
        @apollon77
        Konfig:
        Danke!
        HomoranH Offline
        HomoranH Offline
        #2188
        @rossi73 sagte in Adapter "smartmeter":
        in der Console kann ich DAten vom Lesekopf empfangen (1b 1b 1b 1b...).
        wie kommst du denn da an den Kopf?
        (ohne seinen Port zu nutzen)
        R 1 Antwort Letzte Antwort
          rossi73
          #2189
          Hallo, Über Minicom
          sudo apt-get install minicom
          sudo minicom -D /dev/ttyUSB0 -b 9600 --displayhex --wrap
          aber den Befehl beende ich dann ja wieder...
          • R rossi73
            Hallo, Über Minicom
            HomoranH Offline
            HomoranH Offline
            #2190
            und wie gibst du danach den Port weider frei?
              rossi73
              #2191
              wahrscheinlich gar nicht wenn du so frägst ;) wie mach ich das?
              • R rossi73
                #2192
                @rossi73 Reboot ist ne gute idee :-)
                • R rossi73
                  @apollon77
                  Konfig:
                  Danke!
                  rossi73
                  #2193
                  @apollon77
                  Das ist immer meine erste Option... :D
                    rossi73
                    #2194
                    @homoran @apollon77
                    Kann es daran liegen das ich ioBroker im docker Container laufen lasse? Grüße
                    • R rossi73
                      @homoran @apollon77
                      HomoranH Offline
                      HomoranH Offline
                      #2195
                      solche Informationen gehören immer in die erste Anfrage sonst sucht man sich dumm und dämlich 😡
                      Möglich ist das natürlich, da der Docker so seine Spezialitäten hat.
                      und genau deshalb nutze ich ihn nicht und kann da nicht mehr helfen.
                      Aber ioBroker im Docker auf RasPi????
                      und von wo hast du sudo minicom -D /dev/ttyUSB0 -b 9600 --displayhex --wrap aufgerufen?
                        rossi73
                        #2196
                        Sorry! 😖
                        Das Problem war das ich den iobroker ohne docker container gar nicht zum Laufen brachte... werde es dann nachher aber nochmal probieren.
                        aufgerufen habe ich es so:
                        pi@raspi001:~ $ cd /opt/iobroker
                        pi@raspi001:/opt/iobroker $ sudo minicom -D /dev/ttyUSB0 -b 9600 --displayhex --        wrap
                        Willkommen zu minicom 2.7.1
                        Optionen: I18n
                        Übersetzt am Aug 13 2017, 15:25:34.
                        Port /dev/ttyUSB0, 17:02:42
                        Drücken Sie CTRL-A  Z für Hilfe zu speziellen Tasten
                        1b 1b 1b 1b 01 01 01 01 76 05 0f 2c 61 07 62 00 62 00 72 63 01 01 76 01 01 05 05
                         0e cb 03 0b 06 49 53 4b 01 0e 1f 58 6e 76 01 01 63 61 27 00 76 05 0f 2c 61 08 6
                        2 00 62 00 72 63 07 01 77 01 0b 06 49 53 4b 01 0e 1f 58 6e 76 07 01 00 62 0a ff
                        ff 72 62 01 65 09 04 94 fd 77 77 07 81 81 c7 82 03 ff 01 01 01 01 04 49 53 4b 01
                         77 07 01 00 00 00 09 ff 01 01 01 01 0b 06 49 53 4b 01 0e 1f 58 6e 76 01 77 07 0
                        1 00 01 08 00 ff 65 00 00 01 82 01 62 1e 52 ff 59 00 00 00 00 07 84 7c 40 01 77
                        07 01 00 01 08 01 ff 01 01 62 1e 52 ff 59 00 00 00 00 07 84 7c 40 01 77 07 01 00
                         01 08 02 ff 01 01 62 1e 52 ff 59 00 00 00 00 00 00 00 00 01 77 07 01 00 10 07 0
                        0 ff 01 01 62 1b 52 00 55 00 00 00 2a 01 77 07 81 81 c7 82 05 ff 01 01 01 01 83
                        02 46 de 79 95 02 b5 79 d0 5e ba 80 e1 5a 0c 7c f3 6c e7 83 69 dc bd 92 8d e3 74
                         49 c6 ac 85 9d 9f 03 9a 5a 0a 7c 6f 7e 48 ef 0f c4 5a cd e2 9e e2 01 01 01 63 a
                        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                        • R rossi73
                          Sorry! 😖
                          Optionen: I18n
                          #2197
                          Auf 'nem Raspberry?!?
                          • R rossi73
                            Sorry! 😖
                            Optionen: I18n
                            HomoranH Offline
                            HomoranH Offline
                            #2198
                            dann ist zu befürchten, dass da jetzt auch der Wurm drin ist.
                            Auf dem Raspi ist es ein Befehl und ioBroker läuft
                            • R rossi73
                              Sorry! 😖
                              Optionen: I18n
                              HomoranH Offline
                              HomoranH Offline
                              #2199
                              aus der Konsole des ioBroker-Verzeichnisses im Docker???
                              @homoran sagte in Adapter "smartmeter":
                              von wo hast du...
                              wenn das von da klappt sollte es auch vom Adapter aus klappen
                                von wo hast du...
                                rossi73
                                #2200
                                ja, Raspberry Pi 4
                                @Homoran
                                sind zwei verschiedene SD-Karten...
                                und ja, hätte ich auch vermutet aber smartmeter will nicht mit mir kooperieren, egal was ich da in den Einstellungen mache... Zig Kombinationen durchprobiert.
                                Ein Befehl und es läuft? Schaun ma mal...
                                • R rossi73
                                  ja, Raspberry Pi 4
                                  @Homoran
                                  #2201
                                  ja, Raspberry Pi 4
                                  Da würde ich ja noch mehr als sonst von einem Docker-Container abraten.
                                    ja, Raspberry Pi 4
                                    rossi73
                                    #2202
                                    Da ich diesbezüglich ein blutiger Anfänger bin könntest du mir das evtl ein wenig erklären?
                                    • R rossi73
                                      #2203
                                      @rossi73
                                      Was? Wie man RaspberryOS und anschließend ioBroker nativ installiert?
                                        ja, Raspberry Pi 4
                                        rossi73
                                        #2204
                                        @thomas-braun sagte in Adapter "smartmeter":
                                        Davon hätte ich gern mehr erfahren.
                                        • R rossi73
                                          #2205
                                          @rossi73
                                          Ich halte einen Container nicht für einen guten Einstieg in den Umgang mit 'Linux'. Zu viele Eigenheiten, mit denen man zusätzlich auch noch klar kommen muss. Und auf einem Raspberry läuft 'Linux' halt wunderbar ohne Container direkt auf der Hardware.
