  4. VIS -> keine gültige Lizenz gefunden
    1.0k
    6.1k
errorvisinstanz
223 Beiträge 56 Kommentatoren 70.9k Aufrufe 49 Beobachtet
    MyMeyer
    #206
    Hallo, warum bekomme ich einen Lizenz Fehler angezeigt ?
    (Keine gültige vis Lizenz gefunden! Bitte vis Instanz prüfen)
    vis.0 2021-08-18 21:53:29.420 info (18949) Terminated (NO_ERROR): Without reason
    vis.0 2021-08-18 21:53:28.411 info (18949) vis license is OK.
    vis.0 2021-08-18 21:53:28.207 info (18949) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.vis, node: v12.20.2, js-controller: 3.3.15
    vis.0 2021-08-18 21:53:28.132 debug (18949) statesDB connected
    vis.0 2021-08-18 21:53:28.131 debug (18949) States connected to redis: 127.0.0.1:6379
    vis.0 2021-08-18 21:53:28.128 debug (18949) States create User PubSub Client
    vis.0 2021-08-18 21:53:28.127 debug (18949) States create System PubSub Client
    vis.0 2021-08-18 21:53:28.124 debug (18949) Redis States: Use Redis connection: 127.0.0.1:6379
    vis.0 2021-08-18 21:53:28.123 debug (18949) objectDB connected
    vis.0 2021-08-18 21:53:28.119 debug (18949) Objects connected to redis: 0.0.0.0:9001
    vis.0 2021-08-18 21:53:28.100 debug (18949) Objects client initialize lua scripts
    vis.0 2021-08-18 21:53:28.100 debug (18949) Objects create User PubSub Client
    vis.0 2021-08-18 21:53:28.099 debug (18949) Objects create System PubSub Client
    vis.0 2021-08-18 21:53:28.098 debug (18949) Objects client ready ... initialize now
    vis.0 2021-08-18 21:53:28.035 debug (18949) Redis Objects: Use Redis connection: 0.0.0.0:9001
    vis.0 2021-08-18 21:52:39.056 info (17416) Terminated (NO_ERROR): Without reason
    vis.0 2021-08-18 21:52:37.989 info (17416) vis license is OK.
    vis.0 2021-08-18 21:52:37.771 info (17416) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.vis, node: v12.20.2, js-controller: 3.3.15
    MyMeyer
    >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
    >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
    • M MyMeyer
      MyMeyer
      schrieb am zuletzt editiert von MyMeyer
      #207
      Betrag kann gelöscht werden !
      Gibt es unten den drei Punkten "löschen" nicht mehr ? In der Foren Hilfe steht es so zumindest.
      MyMeyer
      GraveG 1 Antwort Letzte Antwort
      • M MyMeyer
        GraveG Offline
        GraveG Offline
        Grave
        #208
        Ich bin neu was vis angeht und habe mein system neu gemacht. Ich habe das selbe Problem mit der Free Lizenz. Im Editor (über meine lokale IP) blink die vis version 1.4.3 rot. Habe schon alles neu gemacht. Bei ein downgrade zur Version 1.4.2 blinkt sie nicht mehr aber dann kommt immer eine fehlermeldung das er ein css datei nicht erstellen kann. Geh ich dann wieder auf die Version 1.4.3 blinkt sie nicht mehr aber der fehler das die css datei nicht erstellt werden kann kommt dann dort auch.
        • GraveG Grave
          MyMeyer
          #209
          @grave Hi, nachdem ich alle Adapter aktualisiert hatte lief es wieder. (Admin,Web,Vis).
          Wie ist es bei Dir aus ?
          MyMeyer
          • M MyMeyer
            #210
            @mymeyer
            Hast du auch node aktualisiert? Dein
            node: v12.20.2
            ist steinalt. Wie wichtig aktuelle Versionen sind haste ja jetzt gemerkt.
            Holger76H 1 Antwort Letzte Antwort
              @mymeyer
              node: v12.20.2
              Holger76H Offline
              Holger76H Offline
              Holger76
              schrieb am zuletzt editiert von Holger76
              #211
              ich höänge mich mal an den thread an, da ich gerade das gleiche Problem habe. Ich war 10 Tage um Urlaub , komme wieder und die VIS zeigt "keine gültige VIS lizenz gefunden, bitte prüfen" Im Adapter steht unter PRÜFUNG "Service ist momentan nicht erreichbar oder keine Internetverbindung vorhanden. Bitte fersuchen Sie später noch ein mal oder prüfen Sie die Internetverbindung."
              Diese Meldung kann ich mir aber nicht erklären, da sonst alles funktioniert, apt update, upgrade, Adapter installation etc... Also Internet ist vorhanden. Ich hatte auch sonst keine Änderungen gemacht, ich war ja auch gar nicht da. Alle Adapter habe ich nun auch aktuell auf latest, den VIS komplett neu installiert ... keine Änderung.
              Hat jemand eine Idee, wieso die Meldung kommt ? Natürlich habe ich von der offline-Lizenz gehört und ich denke, dass es das "Problem" beheben sollte, jedoch sehe ich momentan für mich nicht die Notwendigkeit. Falls dies kein Bug ist, wo könnte der Fehler liegen ?
              nodejs 12.22.5
              admin 5.1.25
              vis 1.4.3
              Grüße, Holger
              NUC12i7 -> Proxmox VM [ioBroker.Pro]+[InfluxDB/Grafana]+[AdGuard]+[ OpenCCU ]+[Conbee3] +[Graylog]+[Octopi]+[OpenClaw]
              NUC6CAYH (16GB) [Proxmox Backup Server]+[OMV]
              F 1 Antwort Letzte Antwort
              • Holger76H Holger76
                nodejs 12.22.5
                admin 5.1.25
                vis 1.4.3
                Grüße, Holger
                F Online
                F Online
                fastfoot
                #212
                @holger76 logge auf https://iobroker.net/www/account/licenses ein und kopiere deinen free-key. dann in der Instanz eingeben und speichern
                • F fastfoot
                  Holger76H Offline
                  Holger76H Offline
                  Holger76
                  #213
                  @fastfoot
                  ok, danke.. hat funktioniert ! Da hat sich also was geändert, da der Key nun anders ist. Die Meldung "Service nicht erreichbar" ist da natürlich irreführend. Dass der key sich ändert, ist auch irgendwie an mir vorüber gegangen...
                    @fastfoot
                    F Online
                    F Online
                    fastfoot
                    #214
                    @holger76 sagte in VIS -> keine gültige Lizenz gefunden:
                    @fastfoot
                    ich habe es auch nur zufällig mitbekommen, schön dass es funktioniert hat :-)
                    • F fastfoot
                      @fastfoot
                      fraeggle
                      #215
                      Na super Hatte Stromausfall. Also Kein I-Net. Nachdem Stom wieder kam, war natürlich der IOBroker schneller als die Fritzbox, folglich hätte eigentlich VIS im Offline Modus laufen müssen......
                      Es kam aber die Meldung KEINE Gültige Lizenz....
                      Erst ein kompletter Neustart nach wiederherstellung des INet ließ die VIS wieder laufen.
                      Wat läuft da falsch?
                      • F fraeggle
                        #216
                        @fraeggle sagte in VIS -> keine gültige Lizenz gefunden:
                        nix!
                        Bei Neustart der vis muss eine Internetverbindung da sein um deine Lizenz prüfen zu können
                          nix!
                          fraeggle
                          schrieb am zuletzt editiert von fraeggle
                          #217
                          Für was hab ich dann die Offline Lizenz?
                          Hätt ich vlt dazuschreiben sollen, dass ich die hab...
                          F HomoranH 2 Antworten Letzte Antwort
                          • F fraeggle
                            F Online
                            F Online
                            fastfoot
                            #218
                            Also hier funktioniert die Offlinelizenz, gerade getestet. Schau mal im LOG, evtl musst du die erneuern, wie steht dann im LOG
                            • F Offline
                              fraeggle
                              #219
                              @fastfoot
                              Einziger Eintrag den ich zu VIS in der Zeit finde:
                              vis.0 2021-10-13 15:31:23.815 error (994) Cannot check license: Error: getaddrinfo EAI_AGAIN iobroker.net
                              Aber wie gesagt verwende ich die Offline Lizenz.
                              Hab jetzt auch zur Sicherheit nochmal die UUID die in VIS steht mit der UUID der Lizenz verglichen.
                              echt komisch kann jetzt auch grad nicht so einfach des INet wegnehmen zum testen...
                              • F fraeggle
                                @fastfoot
                                F Online
                                F Online
                                fastfoot
                                #220
                                @fraeggle evtl. bei Gelegenheit den iobroker von der Konsole aus stoppen und neustarten. Dann das LOG mit tail -f log/*curr* beobachten. Die Meldung kommt nur beim Start des iobroker. Ob die zur Erneuerung anstehende Offlinelizenz dadurch zur Onlinelizenz wird kann ich dir allerdings nicht sagen, aber sonst fällt mir dazu nichts ein. Ich weiss auch nicht weshalb meine Lizenz überhaupt erneuert werden musste, der Austausch war dann aber sehr einfach. Dabei hat sich dann auch die UUID verändert
                                • F fraeggle
                                  #221
                                  Jepp!
                                  Damit müsste es natürlich auch ohne I-net klappen
                                  • F fastfoot
                                    #222
                                    @fastfoot Vis version ist auch die aktuellste die das unterstützt?
                                    • apollon77A apollon77
                                      F Online
                                      F Online
                                      fastfoot
                                      #223
                                      @apollon77 sagte in VIS -> keine gültige Lizenz gefunden:
                                      ähem, ich habe das Problem ja nicht, habe nur auf eine evtl. mögliche Ursache hingewiesen
