  4. ioBroker lässt sich nicht upgraden
    1.0k
45 Beiträge 7 Kommentatoren 3.9k Aufrufe 5 Beobachtet
  • A Accu
    @thomas-braun habe jetzt mal folgendes gemacht und er rödelt noch rum:
    pi@Raspi:~ $ sudo dpkg --configure -a
    Setting up lighttpd (1.4.53-4+deb10u1) ...
    Configuration file '/etc/lighttpd/lighttpd.conf'
     ==> Modified (by you or by a script) since installation.
     ==> Package distributor has shipped an updated version.
       What would you like to do about it ?  Your options are:
        Y or I  : install the package maintainer's version
        N or O  : keep your currently-installed version
          D     : show the differences between the versions
          Z     : start a shell to examine the situation
     The default action is to keep your current version.
    *** lighttpd.conf (Y/I/N/O/D/Z) [default=N] ? Y
    Installing new version of config file /etc/lighttpd/lighttpd.conf ...
    Setting up libgs9-common (9.27~dfsg-2+deb10u4) ...
    Setting up x11proto-dev (2018.4-4) ...
    Setting up bubblewrap (0.3.1-4) ...
    Setting up libpipeline1:armhf (1.5.1-2) ...
    Setting up libcairo-script-interpreter2:armhf (1.16.0-4+rpt1) ...
    Setting up libxdot4 (2.40.1-6+deb10u1) ...
    Setting up liblmdb0:armhf (0.9.22-1) ...
    Setting up libtext-iconv-perl (1.7-5+b10) ...
    Setting up libnih1 (1.0.3-10+b11) ...
    Setting up proftpd-doc (1.3.6-4+deb10u6) ...
    Setting up idn2 (2.0.5-1+deb10u1) ...
    Setting up pigpio-tools (1.79-1+rpt1) ...
    Setting up libcwidget3v5:armhf (0.5.17-11) ...
    Setting up libglibmm-2.4-1v5:armhf (2.58.0-2) ...
    Setting up libtext-charwidth-perl (0.04-7.1+b1) ...
    Setting up runit-helper (2.8.6) ...
    Setting up libxapian30:armhf (1.4.11-1) ...
    Setting up gtk-update-icon-cache (3.24.5-1+rpt2) ...
    Setting up dhcpcd5 (1:8.1.2-1+rpt1) ...
    Configuration file '/etc/dhcpcd.conf'
    *** dhcpcd.conf (Y/I/N/O/D/Z) [default=N] ? Y
    Installing new version of config file /etc/dhcpcd.conf ...
    Setting up mysql-common (5.8+1.0.5) ...
    update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
    Setting up iio-sensor-proxy (2.4-2) ...
    iio-sensor-proxy.service is a disabled or a static unit, not starting it.
    Setting up cups-ppdc (2.2.10-6+deb10u4) ...
    Setting up systemd-sysv (241-7~deb10u8+rpi1) ...
    Setting up imagemagick-6-common (8:6.9.10.23+dfsg-2.1+deb10u1) ...
    Installing new version of config file /etc/ImageMagick-6/coder.xml ...
    Installing new version of config file /etc/ImageMagick-6/delegates.xml ...
    Installing new version of config file /etc/ImageMagick-6/log.xml ...
    Installing new version of config file /etc/ImageMagick-6/mime.xml ...
    Installing new version of config file /etc/ImageMagick-6/policy.xml ...
    Installing new version of config file /etc/ImageMagick-6/quantization-table.xml ...
    Installing new version of config file /etc/ImageMagick-6/thresholds.xml ...
    Installing new version of config file /etc/ImageMagick-6/type-apple.xml ...
    Installing new version of config file /etc/ImageMagick-6/type-dejavu.xml ...
    Installing new version of config file /etc/ImageMagick-6/type-ghostscript.xml ...
    Installing new version of config file /etc/ImageMagick-6/type-windows.xml ...
    Installing new version of config file /etc/ImageMagick-6/type.xml ...
    Setting up libpython3.7-stdlib:armhf (3.7.3-2+deb10u3) ...
    Setting up libraw1394-11:armhf (2.1.2-1+b1) ...
    Setting up gnupg2 (2.2.12-1+rpi1+deb10u1) ...
    Setting up libxft2:armhf (2.3.2-2) ...
    Setting up libip6tc0:armhf (1.8.2-4) ...
    Setting up libvte-common (1:0.28.2-6) ...
    Setting up libpsl5:armhf (0.20.2-2) ...
    Setting up libgnutls-openssl27:armhf (3.6.7-4+deb10u7) ...
    Setting up fonts-lato (2.0-2) ...
    Setting up libsodium23:armhf (1.0.17-1) ...
    Setting up apt-utils (1.8.2.3) ...
    Setting up chromium-codecs-ffmpeg-extra (92.0.4515.98~buster-rpt2) ...
    Setting up liblouisutdml-data (2.7.0-5) ...
    Setting up libpangoxft-1.0-0:armhf (1.42.4-8~deb10u1) ...
    Setting up libip4tc0:armhf (1.8.2-4) ...
    Setting up e2fslibs:armhf (1.44.5-1+deb10u3) ...
    Setting up whois (5.4.3) ...
    Setting up apt-transport-https (1.8.2.3) ...
    Setting up libvte-2.91-common (0.54.2-2) ...
    Setting up cups-server-common (2.2.10-6+deb10u4) ...
    Setting up libgslcblas0:armhf (2.5+dfsg-6) ...
    Setting up libfontembed1:armhf (1.21.6-5+rpt1) ...
    Setting up libpython3.7:armhf (3.7.3-2+deb10u3) ...
    Setting up libgspell-1-common (1.6.1-2) ...
    Setting up e2fsprogs-l10n (1.44.5-1+deb10u3) ...
    Setting up gcc-4.9-base:armhf (4.9.4-2+rpi1+b19) ...
    Setting up libx264-155:armhf (2:0.155.2917+git0a84d98-2+rpi1) ...
    Setting up libgssdp-1.0-3:armhf (1.0.5-0+deb10u1) ...
    Setting up evince-common (3.30.2-3+deb10u1) ...
    Setting up gawk (1:4.2.1+dfsg-1) ...
    Setting up psmisc (23.2-1+deb10u1) ...
    Setting up libgutenprint-common (5.3.1-7) ...
    Setting up libx265-165:armhf (2.9-4) ...
    Setting up libgc1c2:armhf (1:7.6.4-0.4) ...
    Setting up libyaml-0-2:armhf (0.2.1-1) ...
    Setting up libilmbase23:armhf (2.2.1-2) ...
    Setting up libaspell15:armhf (0.60.7~20110707-6+deb10u1) ...
    Setting up distro-info-data (0.41+deb10u4) ...
    Setting up manpages (4.16-2) ...
    Setting up libglvnd0:armhf (1.3.0-7~bpo10+1) ...
    Setting up libvte9 (1:0.28.2-6) ...
    Setting up libi2c0:armhf (4.1-1) ...
    Setting up libsnmp-base (5.7.3+dfsg-5+deb10u2) ...
    Setting up x11proto-randr-dev (2018.4-4) ...
    Setting up libtdb1:armhf (1.3.16-2+b1) ...
    Setting up rpi.gpio-common:armhf (0.7.0-0.1~bpo10+4) ...
    Setting up libtirpc-common (1.1.4-0.4) ...
    Setting up xmms2-core (0.8+dfsg-18.2) ...
    Setting up libgusb2:armhf (0.3.0-1) ...
    Setting up libasan1:armhf (4.9.4-2+rpi1+b19) ...
    Setting up libfribidi-dev:armhf (1.0.5-3.1+deb10u1) ...
    Setting up gpicview (0.2.5-2+rpt1) ...
    update-alternatives: using /usr/bin/gpicview to provide /usr/bin/display (display) in auto mode
    Setting up libprocps7:armhf (2:3.3.15-2) ...
    Setting up libfltk1.3:armhf (1.3.4-9) ...
    Setting up libwebpdemux2:armhf (0.6.1-2+deb10u1) ...
    Setting up libdbusmenu-glib4:armhf (18.10.20180917~bzr490+repack1-1) ...
    Setting up libutf8proc2:armhf (2.3.0-1) ...
    Setting up libaom0:armhf (1.0.0-3) ...
    Setting up libbrotli1:armhf (1.0.7-2+deb10u1) ...
    Setting up libfstrm0:armhf (0.4.0-1) ...
    Setting up libkyotocabinet16v5:armhf (1.2.76-4.2+rpi1) ...
    Setting up libsrtp2-1:armhf (2.2.0-1) ...
    Setting up cron (3.0pl1-134+deb10u1) ...
    Installing new version of config file /etc/crontab ...
    Installing new version of config file /etc/init.d/cron ...
    Setting up libheif1:armhf (1.3.2-2~deb10u1) ...
    Setting up liblab-gamut1 (2.40.1-6+deb10u1) ...
    Setting up libcodec2-0.8.1:armhf (0.8.1-2) ...
    Setting up libnorm1:armhf (1.5.8+dfsg2-1) ...
    Setting up rsyslog (8.1901.0-1) ...
    Installing new version of config file /etc/init.d/rsyslog ...
    Installing new version of config file /etc/logrotate.d/rsyslog ...
    Installing new version of config file /etc/rsyslog.conf ...
    Setting up pango1.0-tools (1.42.4-8~deb10u1) ...
    Setting up binutils-common:armhf (2.31.1-16+rpi2) ...
    Setting up libdjvulibre21:armhf (3.5.27.1-10) ...
    Setting up firmware-misc-nonfree (1:20190114-2+rpt3) ...
    update-initramfs: deferring update (trigger activated)
    Setting up libsensors-config (1:3.5.0-3) ...
    Installing new version of config file /etc/sensors3.conf ...
    Setting up x11proto-kb-dev (2018.4-4) ...
    Setting up libsepol1-dev:armhf (2.8-1) ...
    Setting up fonts-roboto-slab (1.100263+20170512-1) ...
    Setting up libxmmsclient6 (0.8+dfsg-18.2) ...
    Setting up fonts-freefont-ttf (20120503-9) ...
    Setting up libnfs12:armhf (3.0.0-2) ...
    Setting up gnome-themes-extra-data (3.28-1) ...
    Setting up libcdio18:armhf (2.0.0-2) ...
    Setting up libpackagekit-glib2-18:armhf (1.1.12-5) ...
    Setting up libnss-systemd:armhf (241-7~deb10u8+rpi1) ...
    First installation detected...
    Checking NSS setup...
    Setting up libcolorhug2:armhf (1.4.3-4) ...
    Setting up libnftnl11:armhf (1.1.7-1~bpo10+1~0) ...
    Setting up libopenexr23:armhf (2.2.1-4.1) ...
    Setting up libmysofa0:armhf (0.6~dfsg0-3+deb10u1) ...
    Setting up libnss3:armhf (2:3.42.1-1+deb10u3) ...
    Setting up libharfbuzz-gobject0:armhf (2.3.1-1) ...
    Setting up obsession (20140608-2) ...
    Setting up gtk2-engines-pixflat:armhf (0.3) ...
    Setting up libgomp1:armhf (8.3.0-6+rpi1) ...
    Setting up libfuse2:armhf (2.9.9-1+deb10u1) ...
    Setting up libffi-dev:armhf (3.2.1-9) ...
    Setting up locales (2.28-10+rpt2+rpi1) ...
    Installing new version of config file /etc/locale.alias ...
    Generating locales (this might take a while)...
      de_DE.UTF-8... done
      en_GB.UTF-8... done
    Generation complete.
    Setting up libunwind8:armhf (1.2.1-10~deb10u1) ...
    Setting up libjs-modernizr (2.6.2+ds1-3) ...
    Setting up xmms2-plugin-vorbis (0.8+dfsg-18.2) ...
    Setting up libncurses5:armhf (6.1+20181013-2+deb10u2) ...
    Setting up libdjvulibre-dev:armhf (3.5.27.1-10) ...
    Setting up libprotobuf-c1:armhf (1.3.1-1+b1) ...
    Setting up libgpgme11:armhf (1.12.0-6) ...
    Setting up x11proto-xinerama-dev (2018.4-4) ...
    Setting up libpcre2-16-0:armhf (10.32-5) ...
    Setting up libicu63:armhf (63.1-6+deb10u1) ...
    Setting up gtk2-engines-clearlookspix:armhf (1:2.20.8) ...
    Setting up colord-data (1.4.3-4) ...
    Setting up libcupsimage2:armhf (2.2.10-6+deb10u4) ...
    Setting up libjansson4:armhf (2.12-1) ...
    Setting up libc6-dbg:armhf (2.28-10+rpt2+rpi1) ...
    Setting up libnl-route-3-200:armhf (3.4.0-1) ...
    Setting up lxinput (0.3.5-1+rpi9) ...
    Setting up libpython2.7-stdlib:armhf (2.7.16-2+deb10u1) ...
    Setting up libqpdf21:armhf (8.4.0-2) ...
    Setting up libcairomm-1.0-1v5:armhf (1.12.2-4) ...
    Setting up libdconf1:armhf (0.30.1-2) ...
    Setting up mariadb-common (1:10.3.31-0+deb10u1) ...
    update-alternatives: /etc/mysql/mariadb.cnf wird verwendet, um /etc/mysql/my.cnf (my.cnf) im automatischen Modus bereitzustellen
    Setting up libxdo3:armhf (1:3.20160805.1-4) ...
    Setting up libasound2-data (1.1.8-1+rpt1) ...
    Setting up libftdi1-2:armhf (1.4-1+b2) ...
    Setting up busybox (1:1.30.1-4) ...
    Setting up libasan5:armhf (8.3.0-6+rpi1) ...
    Setting up fonts-quicksand (0.2016-2) ...
    Setting up libpigpiod-if1 (1.79-1+rpt1) ...
    Setting up php7.3-common (7.3.29-1~deb10u1) ...
    Creating config file /etc/php/7.3/mods-available/calendar.ini with new version
    Creating config file /etc/php/7.3/mods-available/ctype.ini with new version
    Creating config file /etc/php/7.3/mods-available/exif.ini with new version
    Creating config file /etc/php/7.3/mods-available/fileinfo.ini with new version
    Creating config file /etc/php/7.3/mods-available/ftp.ini with new version
    Creating config file /etc/php/7.3/mods-available/gettext.ini with new version
    Creating config file /etc/php/7.3/mods-available/iconv.ini with new version
    Creating config file /etc/php/7.3/mods-available/pdo.ini with new version
    Creating config file /etc/php/7.3/mods-available/phar.ini with new version
    Creating config file /etc/php/7.3/mods-available/posix.ini with new version
    Creating config file /etc/php/7.3/mods-available/shmop.ini with new version
    Creating config file /etc/php/7.3/mods-available/sockets.ini with new version
    Creating config file /etc/php/7.3/mods-available/sysvmsg.ini with new version
    Creating config file /etc/php/7.3/mods-available/sysvsem.ini with new version
    Creating config file /etc/php/7.3/mods-available/sysvshm.ini with new version
    Creating config file /etc/php/7.3/mods-available/tokenizer.ini with new version
    Setting up gdb (8.2.1-2) ...
    Setting up x11proto-damage-dev (1:2018.4-4) ...
    Setting up gnome-accessibility-themes (3.28-1) ...
    Setting up vim-common (2:8.1.0875-5) ...
    Installing new version of config file /etc/vim/vimrc ...
    Setting up libgles2:armhf (1.3.0-7~bpo10+1) ...
    Setting up libass9:armhf (1:0.14.0-2) ...
    Setting up liblouis-data (3.8.0-2) ...
    Setting up x11proto-composite-dev (1:2018.4-4) ...
    Setting up emacsen-common (3.0.4) ...
    Removing obsolete conffile /etc/emacs/site-start.d/00debian-vars.el ...
    Removing obsolete conffile /etc/emacs/site-start.el ...
    Setting up libslang2:armhf (2.3.2-2) ...
    Setting up libva2:armhf (2.4.0-1) ...
    Setting up gcc-7-base:armhf (7.3.0-19) ...
    Setting up libblockdev-utils2:armhf (2.20-7+deb10u1+b1) ...
    Setting up make (4.2.1-1.2) ...
    Setting up libntlm0:armhf (1.5-1+deb10u1) ...
    Setting up dialog (1.3-20190211-1) ...
    Setting up xmms2-plugin-id3v2 (0.8+dfsg-18.2) ...
    Setting up libgsl23:armhf (2.5+dfsg-6) ...
    Setting up aptitude-common (0.8.11-7) ...
    Setting up x11proto-core-dev (2018.4-4) ...
    Setting up libiptc0:armhf (1.8.2-4) ...
    Setting up libpathplan4 (2.40.1-6+deb10u1) ...
    Setting up libncurses6:armhf (6.1+20181013-2+deb10u2) ...
    Setting up strace (4.26-0.2) ...
    Setting up wamerican (2018.04.16-1) ...
    Setting up libdbus-1-3:armhf (1.12.20-0+deb10u1) ...
    Setting up dbus (1.12.20-0+deb10u1) ...
    A reboot is required to replace the running dbus-daemon.
    Please reboot the system when convenient.
    Setting up xz-utils (5.2.4-1) ...
    Setting up pi-greeter (0.14) ...
    Installing new version of config file /etc/lightdm/pi-greeter.conf ...
    Setting up debconf-utils (1.5.71+deb10u1) ...
    Setting up libexif12:armhf (0.6.21-5.1+deb10u5) ...
    Setting up rfkill (2.33.1-0.1) ...
    Setting up libimagequant0:armhf (2.12.2-1.1) ...
    Setting up libgd3:armhf (2.2.5-5.2) ...
    Setting up libluajit-5.1-common (2.1.0~beta3+dfsg-5.1) ...
    Setting up gtk2-engines-pixbuf:armhf (2.24.32-3+rpt1) ...
    Setting up libssl-dev:armhf (1.1.1d-0+deb10u7) ...
    Setting up libmpc3:armhf (1.1.0-1) ...
    Setting up gcc-6-base:armhf (6.5.0-1+rpi1+b1) ...
    Setting up libatomic1:armhf (8.3.0-6+rpi1) ...
    Setting up udev (241-7~deb10u8+rpi1) ...
    Installing new version of config file /etc/init.d/udev ...
    Installing new version of config file /etc/udev/udev.conf ...
    insserv: FATAL: service udev has to be enabled to use service plymouth
    insserv: FATAL: service udev has to be enabled to use service raspi-config
    Removing obsolete conffile /etc/init/udev.conf ...
    Removing obsolete conffile /etc/init/udevmonitor.conf ...
    Removing obsolete conffile /etc/init/udevtrigger.conf ...
    Setting up x11proto-input-dev (2018.4-4) ...
    Setting up patch (2.7.6-3+deb10u1) ...
    Setting up mailutils-common (1:3.5-4) ...
    Setting up gnupg-agent (2.2.12-1+rpi1+deb10u1) ...
    Setting up libtcl8.6:armhf (8.6.9+dfsg-2) ...
    Setting up usb.ids (2019.07.27-0+deb10u1) ...
    Setting up icu-devtools (63.1-6+deb10u1) ...
    Setting up sudo (1.8.27-1+deb10u3) ...
    Installing new version of config file /etc/init.d/sudo ...
    Setting up libmariadb3:armhf (1:10.3.31-0+deb10u1) ...
    Setting up libudev-dev:armhf (241-7~deb10u8+rpi1) ...
    Setting up libboost-iostreams1.67.0:armhf (1.67.0-13+deb10u1) ...
    Setting up libfl2:armhf (2.6.4-6.2) ...
    Setting up libwnck22:armhf (2.30.7-6) ...
    Setting up libsensors5:armhf (1:3.5.0-3) ...
    Setting up libpcre2-8-0:armhf (10.32-5) ...
    Setting up libaacs0:armhf (0.9.0-2) ...
    Setting up aspell (0.60.7~20110707-6+deb10u1) ...
    Setting up libxtables12:armhf (1.8.2-4) ...
    Setting up libqt5core5a:armhf (5.11.3+dfsg1-1+rpi1+deb10u4) ...
    Setting up libofa0:armhf (0.9.3-19) ...
    Setting up libpangomm-1.4-1v5:armhf (2.42.0-2) ...
    Setting up libjim0.77:armhf (0.77+dfsg0-3) ...
    Setting up libfm4:armhf (1.3.1-1+rpt18) ...
    Setting up libglapi-mesa:armhf (19.3.2-1~bpo10+1~rpt4) ...
    Setting up libkpathsea6:armhf (2018.20181218.49446-1) ...
    Setting up libevent-core-2.1-6:armhf (2.1.8-stable-4) ...
    Setting up libgfortran5:armhf (8.3.0-6+rpi1) ...
    Setting up php7.3-intl (7.3.29-1~deb10u1) ...
    Creating config file /etc/php/7.3/mods-available/intl.ini with new version
    Setting up libvulkan1:armhf (1.1.97-2) ...
    Setting up libevent-2.1-6:armhf (2.1.8-stable-4) ...
    Setting up pi-printer-support (1.1) ...
    Setting up libcrack2:armhf (2.9.6-2) ...
    Setting up sysuser-helper (1.3.3) ...
    Setting up libcloog-isl4:armhf (0.18.4-2) ...
    Setting up libisc-export1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
    Setting up libplymouth4:armhf (0.9.4-1.1+rpt2) ...
    Setting up libnotify-bin (0.7.7-4) ...
    Setting up libutempter0:armhf (1.1.6-3) ...
    Setting up libubsan1:armhf (8.3.0-6+rpi1) ...
    Setting up nano (3.2-3) ...
    Installing new version of config file /etc/nanorc ...
    update-alternatives: Warnung: Alternative /usr/bin/emacs24 (Teil der Link-Gruppe editor) existiert nicht;
    sie wird aus der Liste der Alternativen entfernt
    Setting up libgail18:armhf (2.24.32-3+rpt1) ...
    Setting up libpci3:armhf (1:3.5.2-1) ...
    Setting up xdg-dbus-proxy (0.1.1-1) ...
    Setting up libbdplus0:armhf (0.1.2-3) ...
    Setting up libnuma1:armhf (2.0.12-1) ...
    Setting up libvidstab1.1:armhf (1.1.0-2) ...
    Setting up libisl19:armhf (0.20-2) ...
    Setting up x11proto-xext-dev (2018.4-4) ...
    Setting up rtmpdump (2.4+20151223.gitfa8646d.1-2) ...
    Setting up keyutils (1.6-6) ...
    Setting up libmad0:armhf (0.15.1b-10) ...
    Setting up libpython3.5-minimal:armhf (3.5.4-4) ...
    Setting up elpa-let-alist (1.0.5-3) ...
    Setting up mount (2.33.1-0.1) ...
    Setting up sound-theme-freedesktop (0.8-2) ...
    Setting up libcomerr2:armhf (1.44.5-1+deb10u3) ...
    Setting up exim4-config (4.92-8+deb10u6) ...
    Adding system-user for exim (v4)
    Setting up libexif-doc (0.6.21-5.1+deb10u5) ...
    Setting up libxshmfence1:armhf (1.3-1) ...
    Setting up libmm-glib0:armhf (1.10.0-1) ...
    Setting up libgtk2.0-bin (2.24.32-3+rpt1) ...
    Setting up pigz (2.4-1) ...
    Setting up libgdk-pixbuf2.0-bin (2.38.1+dfsg-1) ...
    Setting up dbus-x11 (1.12.20-0+deb10u1) ...
    Setting up libqt5dbus5:armhf (5.11.3+dfsg1-1+rpi1+deb10u4) ...
    Setting up libavahi-common-dev:armhf (0.7-4+deb10u1) ...
    Setting up lighttpd-modules-ldap (1.4.53-4+deb10u1) ...
    Setting up libpigpiod-if2-1 (1.79-1+rpt1) ...
    Setting up libuchardet0:armhf (0.0.6-3) ...
    Setting up libubsan0:armhf (7.3.0-19) ...
    Setting up procps (2:3.3.15-2) ...
    Installing new version of config file /etc/init.d/procps ...
    Installing new version of config file /etc/sysctl.conf ...
    Setting up php7.3-opcache (7.3.29-1~deb10u1) ...
    Creating config file /etc/php/7.3/mods-available/opcache.ini with new version
    Setting up libgtksourceview-3.0-common (3.24.9-2) ...
    Setting up libasound2:armhf (1.1.8-1+rpt1) ...
    Setting up libv4lconvert0:armhf (1.16.3-3) ...
    Setting up lxsession-edit (0.5.4-1+rpt1) ...
    Setting up libuser1 (1:0.62~dfsg-0.1) ...
    Setting up libboost-python1.67.0 (1.67.0-13+deb10u1) ...
    Setting up x11proto-render-dev (2:2018.4-4) ...
    Setting up gdbserver (8.2.1-2) ...
    Setting up pypy-lib:armhf (7.0.0+dfsg-3) ...
    Setting up libpam-systemd:armhf (241-7~deb10u8+rpi1) ...
    Setting up libv4l2rds0:armhf (1.16.3-3) ...
    Setting up flashrom (1.0-1) ...
    Setting up git-man (1:2.20.1-2+deb10u3) ...
    Setting up libopenal-data (1:1.19.1-1) ...
    Installing new version of config file /etc/openal/alsoft.conf ...
    Setting up libgirepository-1.0-1:armhf (1.58.3-2) ...
    Setting up lxpanel-data (0.10.0-2+rpt15) ...
    Setting up libssh2-1:armhf (1.8.0-2.1) ...
    Setting up libboost-atomic1.67.0:armhf (1.67.0-13+deb10u1) ...
    Setting up libcairo-gobject2:armhf (1.16.0-4+rpt1) ...
    Setting up libcdt5 (2.40.1-6+deb10u1) ...
    Setting up libcgraph6 (2.40.1-6+deb10u1) ...
    Setting up pixflat-icons (0.3) ...
    gtk-update-icon-cache: Cache file created successfully.
    Setting up apache2-data (2.4.38-3+deb10u6) ...
    Setting up libwayland-egl1:armhf (1.16.0-1) ...
    Setting up usb-modeswitch (2.5.2+repack0-2) ...
    Installing new version of config file /etc/usb_modeswitch.conf ...
    Removing obsolete conffile /etc/init/usb-modeswitch-upstart.conf ...
    Setting up libvolume-key1 (0.3.12-2+b1) ...
    Setting up libstemmer0d:armhf (0+svn585-1) ...
    Setting up libmagickcore-6-headers (8:6.9.10.23+dfsg-2.1+deb10u1) ...
    Setting up libgphoto2-port12:armhf (2.5.22-3) ...
    Setting up lighttpd-modules-mysql (1.4.53-4+deb10u1) ...
    Setting up libatkmm-1.6-1v5:armhf (2.28.0-2) ...
    Setting up libhunspell-1.7-0:armhf (1.7.0-2) ...
    Setting up libboost-system1.67.0:armhf (1.67.0-13+deb10u1) ...
    Setting up glib-networking-common (2.58.0-2+deb10u2) ...
    Setting up libgutenprint9 (5.3.1-7) ...
    Setting up libsane-common (1.0.27-3.2) ...
    Setting up libbinutils:armhf (2.31.1-16+rpi2) ...
    Setting up cpp-8 (8.3.0-6+rpi1) ...
    Setting up libqt5sensors5:armhf (5.11.3-2) ...
    Setting up libgck-1-0:armhf (3.28.1-1) ...
    Setting up libieee1284-3:armhf (0.2.11-13) ...
    Setting up emacs-common (1:26.1+1-3.2+deb10u2) ...
    Setting up libaio1:armhf (0.3.112-3) ...
    Setting up x11proto-fixes-dev (1:2018.4-4) ...
    Setting up initramfs-tools-core (0.133+deb10u1) ...
    Installing new version of config file /etc/initramfs-tools/initramfs.conf ...
    Setting up libc-dev-bin (2.28-10+rpt2+rpi1) ...
    Setting up lxtask (0.1.9-1) ...
    Setting up libpigpio1 (1.79-1+rpt1) ...
    Setting up libavahi-core7:armhf (0.7-4+deb10u1) ...
    Setting up libimobiledevice6:armhf (1.2.1~git20181030.92c5462-2+deb10u1) ...
    Setting up openssl (1.1.1d-0+deb10u7) ...
    Installing new version of config file /etc/ssl/openssl.cnf ...
    Setting up libwebpmux3:armhf (0.6.1-2+deb10u1) ...
    Setting up libbsd0:armhf (0.9.1-2+deb10u1) ...
    Setting up libgpg-error-l10n (1.35-1) ...
    Setting up binutils-arm-linux-gnueabihf (2.31.1-16+rpi2) ...
    Setting up gvfs-common (1.38.1-5) ...
    Setting up libdrm-common (2.4.100-4+rpi1~bpo10+1) ...
    Setting up libelf1:armhf (0.176-1.1) ...
    Setting up pimixer (0.20190918~133938) ...
    Setting up libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
    Setting up libgcr-base-3-1:armhf (3.28.1-1) ...
    Setting up libxml2:armhf (2.9.4+dfsg1-7+deb10u2) ...
    Setting up libopenmpt0:armhf (0.4.3-1+deb10u1) ...
    Setting up fonts-font-awesome (5.0.10+really4.7.0~dfsg-1) ...
    Setting up sphinx-rtd-theme-common (0.4.3+dfsg-1) ...
    Setting up libcc1-0:armhf (8.3.0-6+rpi1) ...
    Setting up libnih-dbus1 (1.0.3-10+b11) ...
    Setting up info (6.5.0.dfsg.1-4+b1) ...
    Setting up liblocale-gettext-perl (1.07-3+b3) ...
    Setting up sqlite3 (3.27.2-3+deb10u1) ...
    Setting up libpolkit-gobject-1-0:armhf (0.105-25+rpt1) ...
    Setting up guile-2.2-libs:armhf (2.2.4+1-2+deb10u1) ...
    Setting up libzvbi-common (0.2.35-16) ...
    Setting up libmbim-glib4:armhf (1.18.0-1) ...
    Setting up libgstreamer1.0-0:armhf (1.14.4-1) ...
    Setcap worked! gst-ptp-helper is not suid!
    Setting up yelp-xsl (3.31.90-1) ...
    Setting up libmp3lame0:armhf (3.100-2+b1) ...
    Setting up libvpx5:armhf (1.7.0-3+deb10u1) ...
    Setting up libgraphene-1.0-0:armhf (1.8.4-1) ...
    Setting up libilmbase-dev (2.2.1-2) ...
    Setting up libsynctex2:armhf (2018.20181218.49446-1) ...
    Setting up libpython3-stdlib:armhf (3.7.3-1) ...
    Setting up libpgm-5.2-0:armhf (5.2.122~dfsg-3) ...
    Setting up libtiffxx5:armhf (4.1.0+git191117-2~deb10u2) ...
    Setting up libgdbm6:armhf (1.18.1-4) ...
    Setting up libpopt0:armhf (1.16-12) ...
    Setting up libaa1:armhf (1.4p5-46) ...
    Setting up lxhotkey-core (0.1.0-1+b1) ...
    Setting up libhiredis0.14:armhf (0.14.0-3) ...
    Setting up ncurses-term (6.1+20181013-2+deb10u2) ...
    Setting up libaprutil1:armhf (1.6.1-4) ...
    Setting up libpango1.0-0:armhf (1.42.4-8~deb10u1) ...
    Setting up logrotate (3.14.0-4) ...
    Installing new version of config file /etc/cron.daily/logrotate ...
    Installing new version of config file /etc/logrotate.conf ...
    Created symlink /etc/systemd/system/timers.target.wants/logrotate.timer → /lib/systemd/system/logrotate.timer.
    logrotate.service is a disabled or a static unit not running, not starting it.
    Setting up libfm-gtk4:armhf (1.3.1-1+rpt18) ...
    Setting up libxmmsclient-glib1 (0.8+dfsg-18.2) ...
    Setting up libtirpc3:armhf (1.1.4-0.4) ...
    Setting up firmware-ralink (1:20190114-2+rpt3) ...
    Setting up glib-networking-services (2.58.0-2+deb10u2) ...
    Setting up fuse (2.9.9-1+deb10u1) ...
    Setting up lxhotkey-gtk (0.1.0-1+b1) ...
    Setting up libzvbi0:armhf (0.2.35-16) ...
    Setting up libevent-pthreads-2.1-6:armhf (2.1.8-stable-4) ...
    Setting up python3.7 (3.7.3-2+deb10u3) ...
    Setting up libcanberra0:armhf (0.30-7) ...
    Setting up manpages-dev (4.16-2) ...
    Setting up libportaudio2:armhf (19.6.0-1+deb10u1) ...
    Setting up libibverbs1:armhf (22.1-1) ...
    Setting up libdw1:armhf (0.176-1.1) ...
    Setting up libmagickcore-6-arch-config:armhf (8:6.9.10.23+dfsg-2.1+deb10u1) ...
    Setting up libpython2.7:armhf (2.7.16-2+deb10u1) ...
    Setting up libdbusmenu-gtk3-4:armhf (18.10.20180917~bzr490+repack1-1) ...
    Setting up php7.3-sqlite3 (7.3.29-1~deb10u1) ...
    Creating config file /etc/php/7.3/mods-available/sqlite3.ini with new version
    Creating config file /etc/php/7.3/mods-available/pdo_sqlite.ini with new version
    Setting up gettext (0.19.8.1-9) ...
    Setting up libtag1v5-vanilla:armhf (1.11.1+dfsg.1-0.3+deb10u1) ...
    Setting up libboost-regex1.67.0:armhf (1.67.0-13+deb10u1) ...
    Setting up libharfbuzz-icu0:armhf (2.3.1-1) ...
    Setting up libboost-chrono1.67.0:armhf (1.67.0-13+deb10u1) ...
    Setting up libnftables1:armhf (0.9.6-1~bpo10+1~0) ...
    Setting up exim4-base (4.92-8+deb10u6) ...
    exim: DB upgrade, deleting hints-db
    Setting up libblockdev-crypto2:armhf (2.20-7+deb10u1+b1) ...
    Setting up libldb1:armhf (2:1.5.1+really1.4.6-3+deb10u1) ...
    Setting up libasan3:armhf (6.5.0-1+rpi1+b1) ...
    Setting up nftables (0.9.6-1~bpo10+1~0) ...
    Setting up libzmq5:armhf (4.3.1-4+deb10u2) ...
    Setting up usermode (1.109-3) ...
    Setting up initramfs-tools (0.133+deb10u1) ...
    Installing new version of config file /etc/kernel/postinst.d/initramfs-tools ...
    Installing new version of config file /etc/kernel/postrm.d/initramfs-tools ...
    Setting up libblockdev-swap2:armhf (2.20-7+deb10u1+b1) ...
    Setting up libcaca0:armhf (0.99.beta19-2.1) ...
    Setting up libgles2-mesa:armhf (19.3.2-1~bpo10+1~rpt4) ...
    Setting up libgs9:armhf (9.27~dfsg-2+deb10u4) ...
    Setting up wget (1.20.1-1.1) ...
    Setting up libglade2-0:armhf (1:2.6.4-2) ...
    Setting up elpa-graphql (0.1.1-3) ...
    Setting up python2.7 (2.7.16-2+deb10u1) ...
    Setting up libwoff1:armhf (1.0.2-1) ...
    Setting up xdotool (1:3.20160805.1-4) ...
    Setting up libboost-thread1.67.0:armhf (1.67.0-13+deb10u1) ...
    Setting up libfm-modules:armhf (1.3.1-1+rpt18) ...
    Setting up ibverbs-providers:armhf (22.1-1) ...
    Setting up php7.3-json (7.3.29-1~deb10u1) ...
    Creating config file /etc/php/7.3/mods-available/json.ini with new version
    Setting up libpulse0:armhf (12.2-4+deb10u1+rpi3) ...
    Setting up libpython2-stdlib:armhf (2.7.16-1) ...
    Setting up libgail-common:armhf (2.24.32-3+rpt1) ...
    Setting up libarchive13:armhf (3.3.3-4+deb10u1) ...
    Setting up libcdio-cdda2:armhf (10.2+0.94+2-4) ...
    Setting up libselinux1-dev:armhf (2.8-1+b1) ...
    Setting up sntp (1:4.2.8p12+dfsg-4) ...
    Setting up cpp-4.9 (4.9.4-2+rpi1+b19) ...
    Setting up iptables (1.8.2-4) ...
    update-alternatives: /usr/sbin/iptables-legacy wird verwendet, um /usr/sbin/iptables (iptables) im automatischen Modus bereitzustellen
    update-alternatives: /usr/sbin/ip6tables-legacy wird verwendet, um /usr/sbin/ip6tables (ip6tables) im automatischen Modus bereitzustellen
    update-alternatives: /usr/sbin/iptables-nft wird verwendet, um /usr/sbin/iptables (iptables) im automatischen Modus bereitzustellen
    update-alternatives: /usr/sbin/ip6tables-nft wird verwendet, um /usr/sbin/ip6tables (ip6tables) im automatischen Modus bereitzustellen
    update-alternatives: /usr/sbin/arptables-nft wird verwendet, um /usr/sbin/arptables (arptables) im automatischen Modus bereitzustellen
    update-alternatives: /usr/sbin/ebtables-nft wird verwendet, um /usr/sbin/ebtables (ebtables) im automatischen Modus bereitzustellen
    Setting up libmagickwand-6-headers (8:6.9.10.23+dfsg-2.1+deb10u1) ...
    Setting up xrdp (0.9.9-1+deb10u1) ...
    Installing new version of config file /etc/init.d/xrdp ...
    Installing new version of config file /etc/pam.d/xrdp-sesman ...
    Installing new version of config file /etc/xrdp/pulse/default.pa ...
    Installing new version of config file /etc/xrdp/sesman.ini ...
    Installing new version of config file /etc/xrdp/startwm.sh ...
    Installing new version of config file /etc/xrdp/xrdp.ini ...
    Installing new version of config file /etc/xrdp/xrdp_keyboard.ini ...
    Setting up iproute2 (4.20.0-2+deb10u1) ...
    Installing new version of config file /etc/iproute2/ematch_map ...
    Installing new version of config file /etc/iproute2/nl_protos ...
    Installing new version of config file /etc/iproute2/rt_protos ...
    Installing new version of config file /etc/iproute2/rt_tables.d/README ...
    Setting up libcdio-paranoia2:armhf (10.2+0.94+2-4) ...
    Setting up cvs (2:1.12.13+real-27) ...
    Verwendung eines zweifelhaften Benutzernamens wird erlaubt.
    addgroup: Die Gruppe »_cvsadmin« existiert bereits als Systemgruppe. Programmende.
    Setting up pigpiod (1.79-1+rpt1) ...
    Setting up libtk8.6:armhf (8.6.9-2) ...
    Setting up libedit2:armhf (3.1-20181209-1) ...
    Setting up libqt5positioning5:armhf (5.11.3+dfsg-2) ...
    Setting up lxmusic (0.4.7-1) ...
    Setting up cpp-6 (6.5.0-1+rpi1+b1) ...
    Setting up libexif-gtk5:armhf (0.4.0-2) ...
    Setting up netcat-openbsd (1.195-2) ...
    Setting up libpolkit-backend-1-0:armhf (0.105-25+rpt1) ...
    Setting up libqt5script5:armhf (5.11.3+dfsg-3) ...
    Setting up libjavascriptcoregtk-4.0-18:armhf (2.32.4-1~deb10u1+rpi1) ...
    Setting up libx11-dev:armhf (2:1.6.7-1+deb10u2) ...
    Setting up libgsasl7 (1.8.0-8+b1) ...
    Setting up libpoppler82:armhf (0.71.0-5) ...
    Setting up libenchant1c2a:armhf (1.6.0-11.1+b2) ...
    Setting up libglib2.0-bin (2.58.3-2+deb10u2) ...
    Setting up isc-dhcp-client (4.4.1-2+deb10u1) ...
    Setting up libpulsedsp:armhf (12.2-4+deb10u1+rpi3) ...
    Setting up libspectre1:armhf (0.2.8-1) ...
    Setting up libblockdev-loop2:armhf (2.20-7+deb10u1+b1) ...
    Setting up screen (4.6.2-3+deb10u1) ...
    Setting up debconf-i18n (1.5.71+deb10u1) ...
    Setting up libgstreamer-plugins-base1.0-0:armhf (1.14.4-2+deb10u1) ...
    Setting up libcurl3-gnutls:armhf (7.64.0-4+deb10u2) ...
    Setting up rpcbind (1.2.5-0.3+deb10u1) ...
    Installing new version of config file /etc/init.d/rpcbind ...
    Removing obsolete conffile /etc/init/portmap-wait.conf ...
    Removing obsolete conffile /etc/init/rpcbind.conf ...
    Removing obsolete conffile /etc/init/rpcbind-boot.conf ...
    insserv: warning: current start runlevel(s) (empty) of script `rpcbind' overrides LSB defaults (S).
    insserv: warning: current stop runlevel(s) (0 1 6 S) of script `rpcbind' overrides LSB defaults (0 1 6).
    Setting up dconf-service (0.30.1-2) ...
    Setting up python3 (3.7.3-1) ...
    running python rtupdate hooks for python3.7...
    running python post-rtupdate hooks for python3.7...
    Setting up geoclue-2.0 (2.5.2-1+deb10u1) ...
    geoclue.service is a disabled or a static unit, not starting it.
    Setting up libblockdev2:armhf (2.20-7+deb10u1+b1) ...
    Setting up binutils (2.31.1-16+rpi2) ...
    Setting up libmbim-proxy (1.18.0-1) ...
    Setting up libm17n-0:armhf (1.8.0-2) ...
    Setting up php-sqlite3 (2:7.3+69) ...
    Setting up libaprutil1-ldap:armhf (1.6.1-4) ...
    Setting up libisc1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
    Setting up vim-tiny (2:8.1.0875-5) ...
    Installing new version of config file /etc/vim/vimrc.tiny ...
    update-alternatives: Alternative /usr/bin/vim.tiny wird aktualisiert, weil Linkgruppe vi geänderte Slave-Links hat
    update-alternatives: Alternative /usr/bin/vim.tiny wird aktualisiert, weil Linkgruppe view geänderte Slave-Links hat
    update-alternatives: Alternative /usr/bin/vim.tiny wird aktualisiert, weil Linkgruppe ex geänderte Slave-Links hat
    Setting up elpa-with-editor (2.8.1-1) ...
    Setting up python3-rpi.gpio (0.7.0-0.1~bpo10+4) ...
    Setting up ghostscript (9.27~dfsg-2+deb10u4) ...
    Setting up raspberrypi-sys-mods (20211005) ...
    Installing new version of config file /etc/profile.d/at-dbus-fix.sh ...
    Installing new version of config file /etc/sysctl.d/98-rpi.conf ...
    Installing new version of config file /etc/udev/rules.d/99-com.rules ...
    Blocking vscode repo...
    Removing obsolete conffile /etc/profile.d/wifi-country.sh ...
    Removing obsolete conffile /etc/modprobe.d/blacklist-rtl8192cu.conf ...
    Setting up dillo (3.0.5-5+rpt1) ...
    Setting up python3-spidev (20200602~200721-1~buster) ...
    Setting up libaprutil1-dbd-sqlite3:armhf (1.6.1-4) ...
    Setting up libappstream4:armhf (0.12.5-1) ...
    Setting up python3-markupsafe (1.1.0-1) ...
    Setting up gnome-themes-extra:armhf (3.28-1) ...
    Setting up python2 (2.7.16-1) ...
    Setting up printer-driver-postscript-hp (3.18.12+dfsg0-2+b2) ...
    Setting up libluajit-5.1-2:armhf (2.1.0~beta3+dfsg-5.1) ...
    Setting up usbutils (1:010-3) ...
    Setting up libwbclient0:armhf (2:4.9.5+dfsg-5+deb10u1+rpi1) ...
    Setting up cups-client (2.2.10-6+deb10u4) ...
    Setting up libqt5network5:armhf (5.11.3+dfsg1-1+rpi1+deb10u4) ...
    Setting up libpython3.5-stdlib:armhf (3.5.4-4) ...
    Setting up gnome-themes-standard (3.28-1) ...
    Setting up libgupnp-1.0-4:armhf (1.0.5-0+deb10u1) ...
    Setting up lxhotkey-plugin-openbox (0.1.0-1+b1) ...
    Setting up libgcc-4.9-dev:armhf (4.9.4-2+rpi1+b19) ...
    Setting up php-intl (2:7.3+69) ...
    Setting up liblouis17:armhf (3.8.0-2) ...
    Setting up librsvg2-2:armhf (2.44.10-2.1+rpi1) ...
    Setting up libglusterfs0:armhf (5.5-3) ...
    Setting up libv4l-0:armhf (1.16.3-3) ...
    Setting up python3-simplejson (3.16.0-1) ...
    Setting up runit (2.1.2-25) ...
    Installing new version of config file /etc/runit/1 ...
    Installing new version of config file /etc/runit/2 ...
    Installing new version of config file /etc/runit/3 ...
    Setting up wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u3) ...
    Setting up gdisk (1.0.3-1.1) ...
    Setting up libatk-bridge2.0-0:armhf (2.30.0-5) ...
    Setting up luajit (2.1.0~beta3+dfsg-5.1) ...
    Setting up python3-pil:armhf (5.4.1-2+deb10u2) ...
    Setting up ca-certificates (20200601~deb10u2) ...
    Updating certificates in /etc/ssl/certs...
    0 added, 0 removed; done.
    Setting up libgstreamer-plugins-bad1.0-0:armhf (1.14.4-1+rvt+deb10u2) ...
    Setting up python3-cups (1.9.73-2+b1) ...
    Setting up alsa-utils (1.1.8-2+rpt1) ...
    Setting up cracklib-runtime (2.9.6-2) ...
    Setting up libpython-stdlib:armhf (2.7.16-1) ...
    Setting up dbus-user-session (1.12.20-0+deb10u1) ...
    Setting up libgupnp-igd-1.0-4:armhf (0.2.5-3) ...
    Setting up libmagickcore-6.q16-6:armhf (8:6.9.10.23+dfsg-2.1+deb10u1) ...
    Setting up bluez (5.50-1.2~deb10u2+rpt1) ...
    Installing new version of config file /etc/bluetooth/input.conf ...
    Installing new version of config file /etc/bluetooth/main.conf ...
    Installing new version of config file /etc/dbus-1/system.d/bluetooth.conf ...
    Setting up libqt5xml5:armhf (5.11.3+dfsg1-1+rpi1+deb10u4) ...
    Setting up libblas3:armhf (3.8.0-2) ...
    update-alternatives: /usr/lib/arm-linux-gnueabihf/blas/libblas.so.3 wird verwendet, um /usr/lib/arm-linux-gnueabihf/libblas.so.3 (libblas.so.3-arm-linux-gnueabihf) im automatischen Modus bereitzustellen
    Setting up libwebp-dev:armhf (0.6.1-2+deb10u1) ...
    Setting up elpa-treepy (0.1.1-1) ...
    Setting up libopenexr-dev (2.2.1-4.1) ...
    Setting up libpigpiod-if-dev (1.79-1+rpt1) ...
    Setting up libunbound8:armhf (1.9.0-2+deb10u2) ...
    Setting up elpa-dash (2.14.1+dfsg-1) ...
    Setting up gstreamer1.0-plugins-base:armhf (1.14.4-2+deb10u1) ...
    Setting up libpwquality1:armhf (1.4.0-3) ...
    Setting up libnice10:armhf (0.1.14-1) ...
    Setting up libpcre2-posix0:armhf (10.32-5) ...
    Setting up pypy (7.0.0+dfsg-3) ...
    running pypy rtupdate hooks for 7.0
    running pypy post-rtupdate hooks for 7.0
    Setting up python3-certifi (2018.8.24-1) ...
    Setting up libdbus-1-dev:armhf (1.12.20-0+deb10u1) ...
    Setting up python-sense-emu-doc (1.2-1) ...
    Setting up libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
    Setting up libqt5qml5:armhf (5.11.3-4) ...
    Setting up gcc-4.9 (4.9.4-2+rpi1+b19) ...
    Setting up ifupdown (0.8.35) ...
    Installing new version of config file /etc/default/networking ...
    Installing new version of config file /etc/init.d/networking ...
    Removing obsolete conffile /etc/init/networking.conf ...
    Removing obsolete conffile /etc/init/network-interface-container.conf ...
    Removing obsolete conffile /etc/init/network-interface-security.conf ...
    Removing obsolete conffile /etc/init/network-interface.conf ...
    Removing obsolete conffile /etc/network/if-up.d/upstart ...
    Removing obsolete conffile /etc/network/if-down.d/upstart ...
    Setting up libpulse-mainloop-glib0:armhf (12.2-4+deb10u1+rpi3) ...
    Setting up ntp (1:4.2.8p12+dfsg-4) ...
    Installing new version of config file /etc/apparmor.d/usr.sbin.ntpd ...
    Installing new version of config file /etc/cron.daily/ntp ...
    Installing new version of config file /etc/init.d/ntp ...
    Installing new version of config file /etc/ntp.conf ...
    Created symlink /etc/systemd/system/multi-user.target.wants/ntp.service → /lib/systemd/system/ntp.service.
    Setting up pulseaudio-utils (12.2-4+deb10u1+rpi3) ...
    Setting up liblwres161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
    Setting up libhdf5-103:armhf (1.10.4+repack-10) ...
    Setting up libportmidi0:armhf (1:217-6) ...
    Setting up python3-reportlab-accel:armhf (3.5.13-1+deb10u1) ...
    Setting up libunique-1.0-0 (1.1.6-6) ...
    Setting up libsdl1.2debian:armhf (1.2.15+dfsg2-4+rpt2) ...
    Setting up libmatio4:armhf (1.5.13-3) ...
    Setting up python3.5-minimal (3.5.4-4) ...
    Setting up cups-daemon (2.2.10-6+deb10u4) ...
    Created symlink /etc/systemd/system/multi-user.target.wants/cups.path → /lib/systemd/system/cups.path.
    Created symlink /etc/systemd/system/printer.target.wants/cups.service → /lib/systemd/system/cups.service.
    Created symlink /etc/systemd/system/sockets.target.wants/cups.socket → /lib/systemd/system/cups.socket.
    Setting up proftpd-basic (1.3.6-4+deb10u6) ...
    Installing new version of config file /etc/default/proftpd ...
    Installing new version of config file /etc/init.d/proftpd ...
    usermod: Keine Änderungen
    Setting up libgvc6 (2.40.1-6+deb10u1) ...
    Setting up libobt2v5 (3.6.1-8+rpt5) ...
    Setting up gvfs-libs:armhf (1.38.1-5) ...
    Setting up libgdbm-compat4:armhf (1.18.1-4) ...
    Setting up libpigpio-dev (1.79-1+rpt1) ...
    Setting up emacs-el (1:26.1+1-3.2+deb10u2) ...
    Setting up libqt5webchannel5:armhf (5.11.3-2) ...
    Setting up gir1.2-glib-2.0:armhf (1.58.3-2) ...
    Setting up xmms2-plugin-alsa (0.8+dfsg-18.2) ...
    Setting up librsvg2-common:armhf (2.44.10-2.1+rpi1) ...
    Setting up pciutils (1:3.5.2-1) ...
    Setting up libgcc-8-dev:armhf (8.3.0-6+rpi1) ...
    Setting up libperl5.28:armhf (5.28.1-6) ...
    Setting up python3-urllib3 (1.24.1-1) ...
    Setting up aptitude (0.8.11-7) ...
    Setting up python3-reportlab (3.5.13-1+deb10u1) ...
    Setting up libsndio7.0:armhf (1.5.0-3) ...
    Setting up libgvc6-plugins-gtk (2.40.1-6+deb10u1) ...
    Setting up libgvpr2 (2.40.1-6+deb10u1) ...
    Setting up xmms2-plugin-mad (0.8+dfsg-18.2) ...
    Setting up libdrm2:armhf (2.4.100-4+rpi1~bpo10+1) ...
    Setting up dwz (0.12-3) ...
    Setting up libtag1v5:armhf (1.11.1+dfsg.1-0.3+deb10u1) ...
    Setting up libva-drm2:armhf (2.4.0-1) ...
    Setting up groff-base (1.22.4-3+deb10u1) ...
    Setting up cpp (4:8.3.0-1+rpi2) ...
    Setting up libxslt1.1:armhf (1.1.32-2.2~deb10u1) ...
    Setting up cups-pk-helper (0.2.6-1+rpi1) ...
    Setting up libgcc-6-dev:armhf (6.5.0-1+rpi1+b1) ...
    Setting up libcurl4:armhf (7.64.0-4+deb10u2) ...
    Setting up emacs-bin-common (1:26.1+1-3.2+deb10u2) ...
    update-alternatives: /usr/bin/ctags.emacs wird verwendet, um /usr/bin/ctags (ctags) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/ebrowse.emacs wird verwendet, um /usr/bin/ebrowse (ebrowse) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/emacsclient.emacs wird verwendet, um /usr/bin/emacsclient (emacsclient) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/etags.emacs wird verwendet, um /usr/bin/etags (etags) im automatischen Modus bereitzustellen
    Setting up libisccc161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
    Setting up libpolkit-agent-1-0:armhf (0.105-25+rpt1) ...
    Setting up libc6-dev:armhf (2.28-10+rpt2+rpi1) ...
    Setting up libmagickwand-6.q16-6:armhf (8:6.9.10.23+dfsg-2.1+deb10u1) ...
    Setting up python3-crypto (2.6.1-9+b1) ...
    Setting up rpi-eeprom (12.14-1) ...
    Created symlink /etc/systemd/system/multi-user.target.wants/rpi-eeprom-update.service → /lib/systemd/system/rpi-eeprom-update.service.
    Setting up libgxps2:armhf (0.3.1-1) ...
    Setting up python3-cookies (2.2.1-2) ...
    Setting up python-pip-whl (18.1-5+rpt1) ...
    Setting up curl (7.64.0-4+deb10u2) ...
    Setting up poppler-utils (0.71.0-5) ...
    Setting up libsdl-ttf2.0-0:armhf (2.0.11-6) ...
    Setting up glib-networking:armhf (2.58.0-2+deb10u2) ...
    Setting up libobrender32v5 (3.6.1-8+rpt5) ...
    Setting up libboost-random1.67.0:armhf (1.67.0-13+deb10u1) ...
    Setting up hardlink (0.3.2) ...
    Setting up libbluray2:armhf (1:1.1.0-1) ...
    Setting up libsvn1:armhf (1.10.4-1+deb10u2) ...
    Setting up libsdl2-2.0-0:armhf (2.0.9+dfsg1-1+rpt1) ...
    Setting up libva-x11-2:armhf (2.4.0-1) ...
    Setting up python3-smbus:armhf (4.1-1) ...
    Setting up python3-lib2to3 (3.7.3-1) ...
    Setting up libtorrent-rasterbar9 (1.1.11-2) ...
    Setting up python (2.7.16-1) ...
    Setting up libicu-dev:armhf (63.1-6+deb10u1) ...
    Setting up python3-asn1crypto (0.24.0-1) ...
    Setting up policykit-1 (0.105-25+rpt1) ...
    Removing obsolete conffile /etc/dbus-1/system.d/org.freedesktop.PolicyKit1.conf ...
    Setting up elpa-git-commit (2.90.1-2) ...
    tsort: -: Eingabe enthält eine Schleife:
    tsort: elpa-dash
    tsort: emacsen-common
    tsort: elpa-with-editor
    Setting up python-incremental (16.10.1-3) ...
    Setting up libllvm9:armhf (1:9.0.1-6+rpi1~bpo10+1) ...
    Setting up python-constantly (15.1.0-1) ...
    Setting up rsync (3.1.3-6) ...
    Installing new version of config file /etc/init.d/rsync ...
    Setting up python-hyperlink (17.3.1-2) ...
    Setting up libmailutils5:armhf (1:3.5-4) ...
    Setting up python3-cffi-backend (1.12.2-1) ...
    Setting up libgfxdr0:armhf (5.5-3) ...
    Setting up libstdc++-8-dev:armhf (8.3.0-6+rpi1) ...
    Setting up apache2-utils (2.4.38-3+deb10u6) ...
    Setting up python3-ptyprocess (0.6.0-1) ...
    Setting up libdrm-amdgpu1:armhf (2.4.100-4+rpi1~bpo10+1) ...
    Setting up python3-pyxattr (0.6.1-1) ...
    Setting up elpa-ghub (3.2.0-1) ...
    Setting up python3-pkg-resources (40.8.0-1) ...
    Setting up python3-entrypoints (0.3-1) ...
    Setting up python3-distutils (3.7.3-1) ...
    Setting up libpoppler-dev:armhf (0.71.0-5) ...
    Setting up libdns1104:armhf (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
    Setting up tk8.6 (8.6.9-2) ...
    Setting up libglib2.0-dev-bin (2.58.3-2+deb10u2) ...
    Setting up librdmacm1:armhf (22.1-1) ...
    Setting up youtube-dl (2019.01.17-1.1) ...
    Setting up mesa-vdpau-drivers:armhf (19.3.2-1~bpo10+1~rpt4) ...
    Setting up cups-browsed (1.21.6-5+rpt1) ...
    Created symlink /etc/systemd/system/multi-user.target.wants/cups-browsed.service → /lib/systemd/system/cups-browsed.service.
    Setting up python-urllib3 (1.24.1-1) ...
    Setting up libgnutls-dane0:armhf (3.6.7-4+deb10u7) ...
    Setting up librados2:armhf (12.2.11+dfsg1-2.1+rpi1) ...
    Setting up python3-dbus (1.2.8-3) ...
    Setting up libexif-dev:armhf (0.6.21-5.1+deb10u5) ...
    Setting up mailutils (1:3.5-4) ...
    update-alternatives: /usr/bin/frm.mailutils wird verwendet, um /usr/bin/frm (frm) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/from.mailutils wird verwendet, um /usr/bin/from (from) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/messages.mailutils wird verwendet, um /usr/bin/messages (messages) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/movemail.mailutils wird verwendet, um /usr/bin/movemail (movemail) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/readmsg.mailutils wird verwendet, um /usr/bin/readmsg (readmsg) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/dotlock.mailutils wird verwendet, um /usr/bin/dotlock (dotlock) im automatischen Modus bereitzustellen
    update-alternatives: /usr/bin/mail.mailutils wird verwendet, um /usr/bin/mailx (mailx) im automatischen Modus bereitzustellen
    Setting up liblapack3:armhf (3.8.0-2) ...
    update-alternatives: /usr/lib/arm-linux-gnueabihf/lapack/liblapack.so.3 wird verwendet, um /usr/lib/arm-linux-gnueabihf/liblapack.so.3 (liblapack.so.3-arm-linux-gnueabihf) im automatischen Modus bereitzustellen
    Setting up libsdl-image1.2:armhf (1.2.12-10+deb10u1) ...
    Setting up gir1.2-freedesktop:armhf (1.58.3-2) ...
    Setting up libfluidsynth1:armhf (1.1.11-1+deb10u1) ...
    Setting up gstreamer1.0-x:armhf (1.14.4-2+deb10u1) ...
    Setting up gcc-8 (8.3.0-6+rpi1) ...
    Setting up gstreamer1.0-alsa:armhf (1.14.4-2+deb10u1) ...
    Setting up python3-cairo:armhf (1.16.2-1+b1) ...
    Setting up libpoppler-glib8:armhf (0.71.0-5) ...
    Setting up python3-renderpm:armhf (3.5.13-1+deb10u1) ...
    Setting up python3-setuptools (40.8.0-1) ...
    Setting up python3-distro (1.3.0-1) ...
    Setting up dconf-gsettings-backend:armhf (0.30.1-2) ...
    Setting up gir1.2-gdkpixbuf-2.0:armhf (2.38.1+dfsg-1) ...
    Setting up libmagickcore-6.q16-6-extra:armhf (8:6.9.10.23+dfsg-2.1+deb10u1) ...
    Setting up python-numpy (1:1.16.2-1) ...
    Setting up libgbm1:armhf (19.3.2-1~bpo10+1~rpt4) ...
    Setting up python3.5 (3.5.4-4) ...
    Setting up gir1.2-atk-1.0:armhf (2.30.0-2) ...
    Setting up plymouth (0.9.4-1.1+rpt2) ...
    Configuration file '/etc/plymouth/plymouthd.conf'
    *** plymouthd.conf (Y/I/N/O/D/Z) [default=N] ? N
    update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
    Setting up php7.3-readline (7.3.29-1~deb10u1) ...
    Creating config file /etc/php/7.3/mods-available/readline.ini with new version
    Setting up libgtk-3-0:armhf (3.24.5-1+rpt2) ...
    Setting up openssh-client (1:7.9p1-10+deb10u2+rpt1) ...
    Installing new version of config file /etc/ssh/ssh_config ...
    Setting up python-wicd (1.7.4+tb2-6) ...
    Setting up pi-bluetooth (0.1.18) ...
    Setting up gstreamer1.0-plugins-good:armhf (1.14.4-1+rpt1+deb10u1) ...
    Setting up python-gobject-2 (2.28.6-13) ...
    Setting up python3-olefile (0.46-1) ...
    Setting up lxpanel (0.10.0-2+rpt15) ...
    Setting up libgl1-mesa-dri:armhf (19.3.2-1~bpo10+1~rpt4) ...
    Removing obsolete conffile /etc/drirc ...
    Setting up lxplug-ptbatt (0.14) ...
    Setting up libhdf5-cpp-103:armhf (1.10.4+repack-10) ...
    Setting up lxplug-volume (0.25) ...
    Setting up hplip-data (3.18.12+dfsg0-2) ...
    Setting up libpython3.5:armhf (3.5.4-4) ...
    Setting up printer-driver-escpr (1.7.8-1~bpo10+1) ...
    Setting up samba-libs:armhf (2:4.9.5+dfsg-5+deb10u1+rpi1) ...
    Setting up python-apt (1.8.4.3) ...
    Setting up libcfitsio7:armhf (3.450-3) ...
    Setting up python3-tk:armhf (3.7.3-1) ...
    Setting up libgtk-3-bin (3.24.5-1+rpt2) ...
    Setting up libqmi-glib5:armhf (1.22.0-1.2) ...
    Setting up python-pil:armhf (5.4.1-2+deb10u2) ...
    Setting up libopenal1:armhf (1:1.19.1-1) ...
    Setting up python-asn1crypto (0.24.0-1) ...
    Setting up python-all (2.7.16-1) ...
    Setting up v4l-utils (1.16.3-3) ...
    Setting up libvte-2.91-0:armhf (0.54.2-2) ...
    Setting up libayatana-ido3-0.4-0:armhf (0.4.4-1) ...
    Setting up x11-xserver-utils (7.7+8+rpi1) ...
    Setting up python-attr (18.2.0-1) ...
    Setting up nodejs (12.22.7-1nodesource1) ...
    Setting up man-db (2.8.5-2) ...
    Installing new version of config file /etc/cron.daily/man-db ...
    Installing new version of config file /etc/cron.weekly/man-db ...
    Updating database of manual pages ...
    @accu
    Da ist aber auch das große Geschirr inkl. vollem Desktop aufgefahren.
    Wenn das durch ist auf jedenfall neubooten:
    sudo reboot
      Accu
      oh man, hätte ich nur die Finger davon gelassen. Ich komme jetzt nicht mehr per ssh drauf.
      % ssh pi@192.168.1.13
      ssh: connect to host 192.168.1.13 port 22: Operation timed out
      accu@iMac ~ %
      Ich sollte dazu sagen, dass der PI bei mir am Keller nur am Netzwerk hängt und ich ausschließlich via Terminal verbinde.
      Noch irgendwelche ideen wie ich das jetzt noch retten kann?
      • A Accu
        accu@iMac ~ %
        @accu sagte in ioBroker lässt sich nicht upgraden:
        Und warum schleppst du dann einen ganzen Desktop mit?
        Abwarten, ob der (ssh)-Server wieder auf die Beine kommt. Wenn nicht würde ich da ein Display anklemmen und schauen bis wo gebootet wird.
          Accu
          @thomas-braun bin Anfänger. Wußte nicht, dass man den Desktop ausklammern kann.
          Warte jetzt schon 5min. Die IP timed auch aus.
          • A Accu
            Man installiert den erst gar nicht. Deswegen gibt es ja die Raspberry OS lite - Version, von vorneherein ohne Desktop-Balast.
            Dann musst du mal nachschauen gehen.
              Accu
              @thomas-braun hatte den Pi damals mit Jessi aufgesetzt und bin dann auf Stretch und jetzt auf Buster. Ist quasi alles mit umgezogen.
              Ich habe den PI jetzt mal an den Monitor gehangen und musste mich da jetzt meinem Pi user einloggen. Keine ahung wie ich das ding jetzt wieder zum laufen bringe. Ping 192.168.1.13 findet er jedenfalls nicht mehr. Kann es sein, dass die komplette config überschrieben wurde?
              J Thomas BraunT 2 Antworten Letzte Antwort
              • A Accu
                Jan1
                @accu
                Ein Pi ist normal,in 30 Minuten neu eingerichtet und ein IOBroker Backup hast hoffentlich zur Hand. Dann würde ich auch gleich Bullseye nehmen und nicht Buster, da auch schon wieder alt.
                https://www.raspifun.de/viewtopic.php?t=4
                • A Accu
                  Ich weiß ja nicht was du da hast überschreiben lassen und wie dein Netzwerk ausschaut.
                  IP-Vergabe per DHCP?
                  ip a
                    Accu
                    also 2 probleme:
                    1. er loggt sich nicht mehr automatisch als Pi user ein. Wie bekomme ich das wieder hin, dass er nicht jedesmal nach dem nutzer fragt?
                    2. er bekommt die IP nicht mehr. Er müsste eigentlich vom DHCP die statische 192.168.1.13 bekommen. Bei ip a steht nur die MAC aber keine IP mehr.
                    gibts unter Buster nicht mehr das Config Tool wie Rasp-Config?
                    HomoranH Thomas BraunT 3 Antworten Letzte Antwort
                    • A Accu
                      also 2 probleme:
                      Auto Login hab ich noch nie gehabt.
                      Ist ein Sicherheitsmerkmal jedesmal zu fragen.
                      Das passt nicht zusammen, oder meinst du Adressreservierung?
                      Wirklich die MAC oder ist das eine IPv6-Adresse?
                      • A Accu
                        also 2 probleme:
                        Doch, natürlich.
                        sudo raspi-config
                        funktioniert nicht?
                        • A Accu
                          also 2 probleme:
                          Auto-Login macht man eh nicht. Die Dienste starten auch ohne eingeloggten user.
                          1. er bekommt die IP nicht mehr. Er müsste eigentlich vom DHCP die statische 192.168.1.13 bekommen. Bei ip a steht nur die MAC aber keine IP mehr.
                          Wat denn nun? Per DHCP dynamisch vergeben oder statisch im OS fixiert?
                            Accu
                            IPs werden über den DHCP dynamisch vergeben.
                            Ich sprach beim Raspi von statischen DHCP. Heißt er bekomt die IP vom DHCP Server der Fritzbox aber eben immer die selbe 192.168.1.13 (statisch) (Fritzbox = dem Gerät immer die gleiche IP geben).
                            Mit sudo raspi-config konnte ich es jetzt wohl hinbiegen, dass er wieder eine IP bekommt.
                            Dafür habe ich jetzt das nächste Problem ich bekomme keinen zugriff mehr auf dein ioBroker Admin.
                            pi@Raspi:~ $ iobroker status
                             Cannot read system.config: null (OK when migrating or restoring)
                             Cannot find view "system" for search "host"
                            Objects type: file
                            States  type: file
                            pi@Raspi:~ $
                            pi@Raspi:~ $ sudo apt update
                            OK:1 http://archive.raspberrypi.org/debian buster InRelease
                            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                            Alle Pakete sind aktuell.
                            pi@Raspi:~ $
                            pi@Raspi:~ $ sudo apt dist-upgrade
                            Paketaktualisierung (Upgrade) wird berechnet... Fertig
                            Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                              alsa-base emacs24 firmware-misc-nonfree firmware-ralink
                              fontconfig-infinality g++-6 gnupg-agent gstreamer0.10-alsa
                              gstreamer0.10-plugins-base libass5 libavcodec57 libavfilter6 libavformat57
                              libavresample3 libavutil55 libbabeltrace-ctf1 libbind9-140 libblas-common
                              libbluetooth3 libbluray1 libboost-filesystem1.62.0 libboost-iostreams1.62.0
                              libboost-system1.62.0 libcdio-cdda1 libcdio-paranoia1 libcdio13 libcfitsio5
                              libdns-export162 libdns162 libdrm-freedreno1 libebur128-1 libevent-2.0-5
                              libgcr-3-common libgfortran3 libglew2.0 libgraphviz-dev
                              libgstreamer-plugins-base0.10-0 libgstreamer0.10-0 libgvc6-plugins-gtk
                              libgvpr2 libhunspell-1.4-0 libicu57 libilmbase12 libisc-export160 libisc160
                              libisccc140 libisccfg140 libjim0.76 liblab-gamut1 liblockfile-bin
                              liblockfile1 liblwres141 libmagickcore-6.q16-3 libmagickcore-6.q16-3-extra
                              libmagickwand-6.q16-3 libmpfr4 libnfs8 libopencv-calib3d2.4v5
                              libopencv-core2.4v5 libopencv-features2d2.4v5 libopencv-flann2.4v5
                              libopencv-highgui2.4-deb0 libopencv-imgproc2.4v5 libopencv-objdetect2.4v5
                              libopencv-video2.4v5 libopenexr22 libpackage-deprecationmanager-perl
                              libpango1.0-0 libperl5.24 libpoppler64 libpostproc54 libprocps6 libpython3.5
                              libpython3.5-dev libpython3.5-minimal libpython3.5-stdlib libsndio6.1
                              libsodium18 libsrtp0 libssl1.0.2 libstdc++-6-dev libswresample2 libswscale4
                              libtiff5-dev libtxc-dxtn-s2tc0 libunbound2 libunistring0 libva-drm1
                              libva-x11-1 libva1 libvpx4 libvte-common libvte9 libwayland-egl1-mesa
                              libwebpmux2 libx264-148 libx265-95 libxfce4util-bin libxfce4util-common
                              libxfce4util7 libxfconf-0-2 lxplug-volume netsurf-common php7.0-intl
                              php7.0-sqlite3 php7.0-xml pimixer point-rpi python-apt python-apt-common
                              python3-pyasn1 python3.5 python3.5-dev python3.5-minimal rename rsync
                              sgml-base tla tla-doc xfconf xml-core
                            Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            pi@Raspi:~ $
                            • A Accu
                              Objects type: file
                              States  type: file
                              pi@Raspi:~ $
                              pi@Raspi:~ $
                              pi@Raspi:~ $
                              sudo apt autoremove
                              Aber sonst schaut das doch ganz gut aus nun.
                              Und zu dem
                              siehe:
                              https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1634136165861
                                Accu
                                geht wieder. ABER mein ursprüngliches Problem ist immer noch nicht gefixt:
                                pi@Raspi:/opt/iobroker/iobroker-data/backup-objects $ iobroker status
                                Objects type: file
                                States  type: file
                                pi@Raspi:/opt/iobroker/iobroker-data/backup-objects $ iobroker backup
                                host.Raspi 9188 states saved
                                host.Raspi 23741 objects saved
                                /usr/bin/iobroker: Zeile 8:  4155 Getötet                sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                pi@Raspi:/opt/iobroker/iobroker-data/backup-objects $ iob stop
                                pi@Raspi:/opt/iobroker/iobroker-data/backup-objects $ iob update
                                No connection to databases possible ...
                                pi@Raspi:/opt/iobroker/iobroker-data/backup-objects $ iob upgrade self
                                • A Accu
                                  Objects type: file
                                  States  type: file
                                  @accu
                                  Läuft der Desktop da eigentlich permanent mit?
                                  who -r
                                    @accu
                                    who -r
                                    Accu
                                    @thomas-braun ```
                                    pi@Raspi:~ $ who -r
                                    Runlevel 3 2021-10-13 17:18
                                    pi@Raspi:~ $
                                    • A Accu
                                      @thomas-braun ```
                                      pi@Raspi:~ $ who -r
                                      pi@Raspi:~ $
                                      @accu
                                      Lass mal das
                                      iobroker backup
                                      weg. Da klemmt ja offenbar auch schon was. Warum auch immer.
                                      Und stell dich in ein anderes Verzeichnis, wenn du da rummachst.
                                      cd ~
                                      iobroker restart
                                      iobroker update
                                        @accu
                                        Lass mal das
                                        iobroker backup
                                        cd ~
                                        iobroker restart
                                        iobroker update
                                        Accu
                                        die gute Nachricht ist, dass mein iOB wieder läuft. Die schlechte, dass ich immer noch den Fehler "no connection to db" bekomme, wenn ich den Host auf die nächste Version heben will. Habe es gerade mal wieder versucht:
                                        permitted by applicable law.
                                        Last login: Thu Oct 14 04:00:31 2021
                                        pi@Raspi:~ $ cd /opt/iobroker/
                                        pi@Raspi:/opt/iobroker $ sudo iob backup
                                        host.Raspi 9171 states saved
                                        /usr/bin/iob: Zeile 8:  5731 Getötet                sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
                                        pi@Raspi:/opt/iobroker $ sudo iob stop
                                        pi@Raspi:/opt/iobroker $ sudo iob fix
                                        library: loaded
                                        Library version=2021-08-05
                                            Welcome to the ioBroker installation fixer!
                                            Script version: 2021-04-07
                                            Installing prerequisites (1/3)
                                        OK:2 https://deb.nodesource.com/node_12.x buster InRelease
                                        Holen:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                        Es wurden 15,0 kB in 2 s geholt (7.888 B/s).
                                        Installed gcc-c++
                                            Checking ioBroker user and directory permissions (2/3)
                                            Checking autostart (3/3)
                                        Enabling autostart...
                                        Autostart enabled!
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        pi@Raspi:/opt/iobroker $ sudo iob update
                                        pi@Raspi:/opt/iobroker $ sudo iob upgrade self
                                        pi@Raspi:/opt/iobroker $ iob start
                                        • A Accu
                                          library: loaded
                                          Installed gcc-c++
                                          Autostart enabled!
                                          @accu
                                          Nicht mit sudo hantieren!
