  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.8k Aufrufe 82 Beobachtet
    Megawaldi
    #295
    Hab noch falsche Datentypen gefunden:
    mihome-vacuum.0
    	2021-08-09 17:14:10.059	info	State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    mihome-vacuum.0
    	2021-08-09 17:14:09.590	info	create states for water box
    GitHub Issue wurde schon erstellt 😉
    • S saeft_2003
      @Meistertr
      ich habe seit heute mit der 3.2.2 wieder Adapter crashs. Davor gab es mit der 3.2.1 keinerlei Probleme.
      mihome-vacuum.0
      	2021-08-07 21:05:00.612	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      mihome-vacuum.0
      	2021-08-07 21:05:00.612	error	Socket Close
      mihome-vacuum.0
      	2021-08-07 21:05:00.547	error	undefined
      mihome-vacuum.0
      	2021-08-07 21:05:00.547	error	unhandled promise rejection: undefined
      mihome-vacuum.0
      	2021-08-07 21:05:00.544	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      mihome-vacuum.0
      	2021-08-07 13:40:08.943	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      mihome-vacuum.0
      	2021-08-07 13:40:08.942	error	Socket Close
      mihome-vacuum.0
      	2021-08-07 13:40:08.901	error	undefined
      mihome-vacuum.0
      	2021-08-07 13:40:08.901	error	unhandled promise rejection: undefined
      mihome-vacuum.0
      	2021-08-07 13:40:08.899	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Was habe ich gemacht?
      mihome-vacuum Adapter update von 3.2.1 auf 3.2.2
      admin update auf 5.x
      Wann passiert der crash?
      Immer beim starten einer Raumreinigung. Danach wird der Adapter neugestartet/crasht und man kann die Raumreinigung erneut starten.
      saeft_2003
      #296
      @saeft_2003 sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
      @Meistertr
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      @Meistertr
      Seit dem downgrade auf 3.2.1 sind die crashs wieder verschwunden. Soll ich ein issues auf git aufmachen?
      MeistertrM 1 Antwort Letzte Antwort
      • S saeft_2003
        @Meistertr
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        mihome-vacuum.0
        @Meistertr
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        #297
        @saeft_2003 bitte
        • MeistertrM Meistertr
          @saeft_2003 bitte
          saeft_2003
          #298
          @meistertr
          erledigt.
          https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/373
          • bahnuhrB Offline
            bahnuhrB Offline
            bahnuhr
            #299
            bei mir wurde die map nicht angezeigt (funktionierte aber eigentlich schon lange).
            Instanz und Adapter deinstalliert.
            Und alles neu wie in #1 beschrieben.
            Dann habe ich den neuen DP wie früher per binding in ein basic-html widget eingefügt:
            In run wird mir angezeigt:
            Hat sich die Vorgehensweise geändert ?
            Oder wie bekomme ich die Karte wieder angezeigt ?
            mfg
            Dieter
            Danke.
            • bahnuhrB bahnuhr
              mfg
              Dieter
              haselchenH Offline
              haselchenH Offline
              haselchen
              #300
              @bahnuhr
              <img src="{mihome-vacuum.0.cleanmap.map64}"/>
              und basic HTML nutze ich dafür.
              Klappt wunderbar.
              • haselchenH haselchen
                @bahnuhr
                Klappt wunderbar.
                bahnuhrB Offline
                bahnuhrB Offline
                bahnuhr
                #301
                @haselchen sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                <img src="
                Dies war früher nicht drin.
                Egal, jetzt läuft es.
                Danke schön.
                mfg
                Dieter
                Danke.
                • bahnuhrB Offline
                  bahnuhrB Offline
                  bahnuhr
                  #302
                  Nachtrag:
                  Ich bekomme im log folgendes angezeigt:
                  mihome-vacuum.0
                  2021-09-10 09:47:59.128	warn	Get Error when receiving map url: Error: connect ETIMEDOUT 124.251.58.87:443
                  mihome-vacuum.0
                  2021-09-10 09:28:48.411	warn	Get Error when receiving map url: Error: connect ETIMEDOUT 124.251.58.87:443
                  mihome-vacuum.0
                  2021-09-10 08:56:05.404	warn	Get Error when receiving map url: Error: connect ETIMEDOUT 183.84.6.21:443
                  Und die map wird nicht aktualisiert.
                  Habt ihr das auch ?
                  Danke.
                  apollon77A DiginixD 2 Antworten Letzte Antwort
                  • bahnuhrB bahnuhr
                    Nachtrag:
                    mihome-vacuum.0
                    mihome-vacuum.0
                    mihome-vacuum.0
                    Habt ihr das auch ?
                    #303
                    @bahnuhr sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                    ETIMEDOUT
                    sagt das der Adapter keine Antwort bekommt von der genannten IP - das scheint ja irgendwas externes zu sein
                    • bahnuhrB bahnuhr
                      Nachtrag:
                      mihome-vacuum.0
                      mihome-vacuum.0
                      mihome-vacuum.0
                      Habt ihr das auch ?
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #304
                      @bahnuhr Taucht bei mir in keinem Log der letzten 14 Tage auf und in der Zeit wurde der Sauger ca. 24 mal gestartet und in Räume geschickt und nach Beendigung die Karte aus der Xiaomi Cloud per E-Mail an mich gesendet.
                      Karte inkl. gefahrener Route war in der Zeit immer korrekt.
                      Ich nutze ein Xiaomi 1S mit Xiaomi Cloud.
                      ..:: So long! Tom ::..
                      • bahnuhrB Offline
                        bahnuhrB Offline
                        bahnuhr
                        #305
                        Seit heute wird die Instanz nicht mehr grün (bleibt auf gelb).
                        Im debug log kommt:
                        mihome-vacuum.0
                        2021-09-11 12:44:07.794	debug	Helo message Timeout
                        mihome-vacuum.0
                        2021-09-11 12:44:05.791	debug	server started on 0.0.0.0:53421
                        mihome-vacuum.0
                        2021-09-11 12:44:05.788	info	IOT enabled, create state
                        mihome-vacuum.0
                        2021-09-11 12:44:05.784	debug	MIIO: Config: ip:192.168.abc.xxx token: 30374952abcedee
                        mihome-vacuum.0
                        2021-09-11 12:44:05.783	debug	Create State for deviceInfowifi_signal
                        mihome-vacuum.0
                        2021-09-11 12:44:05.782	debug	Create State for deviceInfofw_ver
                        mihome-vacuum.0
                        2021-09-11 12:44:05.781	debug	Create State for deviceInfomodel
                        mihome-vacuum.0
                        2021-09-11 12:44:05.781	debug	Create State for deviceInfomac
                        mihome-vacuum.0
                        2021-09-11 12:44:05.780	debug	Create State for deviceInfo
                        mihome-vacuum.0
                        2021-09-11 12:44:05.739	debug	load Map creator... true
                        mihome-vacuum.0
                        2021-09-11 12:44:05.668	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.3.15
                        jemand eine idee?
                        Danke.
                        • bahnuhrB Offline
                          bahnuhrB Offline
                          bahnuhr
                          #306
                          jetzt ging es wieder.
                          Scheint wohl an China zu legen.
                          Danke.
                          • N Offline
                            N Offline
                            nu_81
                            #307
                            bekomme seit einiger Zeit immer diese Warnungen im Log:
                            Ich nutze einen S50.
                            Wenn ich in der offiziellen App den Reinigungsmodus ändere, werden auch tasächlich kleine Werte (38,60, etc. in den Datenpunkt eingetragen).
                            Der Adapter erwartet hier offenbar Werte größer 102.
                            An meinem S50 habe ich länger keine Firmware Apdates eingespielt, da dieser gerootet ist und so wunderbar funktioniert.
                            Liegt es eventuell daran? Kann ich das irgendwie umgehen?
                            • N nu_81
                              DiginixD Offline
                              DiginixD Offline
                              Diginix
                              #308
                              @nu_81
                              Du kannst den min Wert des Objektes einfach editieren:
                              Danach sollte die Meldung weg sein. Evtl. setzt der Adapter ihn bei einem Neustart wieder zurück. Dann müsste man es im Code des Adapters korrigieren. Wenn es für alle S50 gebraucht würde, wäre ein GIT Issue richtig.
                                mctom
                                #309
                                ich habe seit ein paar Tagen das Problem, dass meine Map nicht mehr angezeigt wird.
                                Bei mir läuft aktuell die Version 3.2.2 ich habe den Datenpunkt (MAP64) schon mal gelöscht und den Adapter neu gestartet.
                                Es tauchen keine Fehlermeldungen im LOG auf. Aber der Datenpunkt bleibt leer.
                                Hat jemand eine Idee woran dies liegen kann oder was noch mal testen könnte.
                                Hier noch weitere Details:
                                Adapterversion: 3.2.2
                                Roborock S6
                                Node.js 14.17.16
                                Vielen Dank
                                • bahnuhrB Offline
                                  bahnuhrB Offline
                                  bahnuhr
                                  #310
                                  Mein Robo V1 muss wohl langsam in Rente gehen.
                                  Aus diesem Grund suche ich einen Neuen.
                                  soll können:
                                  • wenn möglich wieder xiaomi
                                  • rooms sollen gehen.
                                  • keine Wischfunktion.
                                  • steuern über den Adapter
                                  Lt. ? gehen wohl diese:
                                  Ist die Tabelle noch aktuell ?
                                  Welchen Robo könnt ihr empfehlen ?
                                  mfg
                                  Dieter
                                  Danke.
                                  • bahnuhrB Offline
                                    bahnuhrB Offline
                                    bahnuhr
                                    #311
                                    So, habe mir nun den roborock S7 gekauft.
                                    habe diesen eingebunden, alles gut soweit.
                                    Beim "Start", "Find", etc. kommt manchmal folgender Fehler:
                                    mihome-vacuum.0
                                    2021-09-26 09:22:20.514	info	starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.3.18
                                    mihome-vacuum.0
                                    2021-09-26 09:21:47.201	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    mihome-vacuum.0
                                    2021-09-26 09:21:47.200	info	terminating
                                    mihome-vacuum.0
                                    2021-09-26 09:21:47.199	error	Socket Close
                                    mihome-vacuum.0
                                    2021-09-26 09:21:47.056	error	undefined
                                    mihome-vacuum.0
                                    2021-09-26 09:21:47.053	error	unhandled promise rejection: undefined
                                    mihome-vacuum.0
                                    2021-09-26 09:21:47.052	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    mihome-vacuum.0
                                    2021-09-26 09:21:47.045	warn	Cant send command please try again "start"
                                    mihome-vacuum.0
                                    2021-09-26 09:21:45.043	info	trigger cleaning all
                                    mihome-vacuum.0
                                    2021-09-26 07:52:04.858	warn	Cant send command please try again "find"
                                    mihome-vacuum.0
                                    2021-09-26 07:49:03.238	warn	Cant send command please try again "find"
                                    mihome-vacuum.0
                                    2021-09-26 07:28:52.303	warn	Cant send command please try again "find"
                                    Nach mehrmaligem Drücken "Start" klappt der Befehl irgendwann.
                                    Danke.
                                    • bahnuhrB bahnuhr
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      bahnuhrB Offline
                                      bahnuhrB Offline
                                      bahnuhr
                                      #312
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      mihome-vacuum.0
                                      Soll ich ein issue aufmachen oder liest man hier mit ?
                                      Danke.
                                      • bahnuhrB Offline
                                        bahnuhrB Offline
                                        bahnuhr
                                        #313
                                        noch einen Punkt zur Karte:
                                        Diese wird bei mir in einem widget "baisc-html" nicht korrekt angezeigt
                                        (beim alten robo "vacuum V1" hat dies noch geklappt.
                                        Jetzt beim roborock S7 sieht das so aus:
                                        Die Karte fängt ziemlich weit unten an. Und dann ist halt nicht alles ersichtlich.
                                        Habt ihr dies auch so ?
                                        Danke.
                                        I 1 Antwort Letzte Antwort
                                        • bahnuhrB Offline
                                          bahnuhrB Offline
                                          bahnuhr
                                          #314
                                          Heute um 08:55 wieder Fehlermeldung beim Versuch den robo zu starten:
                                          host.VM-iobroker
                                          2021-09-27 08:55:09.545	error	instance system.adapter.mihome-vacuum.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          host.VM-iobroker
                                          2021-09-27 08:55:09.544	error	Caught by controller[0]: MESSAGE TIMEOUT
                                          host.VM-iobroker
                                          2021-09-27 08:55:09.543	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                          mihome-vacuum.0
                                          2021-09-27 08:55:08.892	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          mihome-vacuum.0
                                          2021-09-27 08:55:08.889	error	Socket Close
                                          mihome-vacuum.0
                                          2021-09-27 08:55:08.743	error	undefined
                                          mihome-vacuum.0
                                          2021-09-27 08:55:08.742	error	unhandled promise rejection: undefined
                                          mihome-vacuum.0
                                          2021-09-27 08:55:08.741	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          mihome-vacuum.0
                                          2021-09-27 08:55:08.731	warn	Cant send command please try again "start"
                                          Gibts da schon ne Lösung ?
                                          Danke.
                                          C 1 Antwort Letzte Antwort
