  4. Bei meinem ioBroker sind plötzlich Adapter-Instanzen rot
    6.5k
91 Beiträge 7 Kommentatoren 10.0k Aufrufe 5 Beobachtet
    @tramisch
    iobroker list instances
    Tramisch
    Bei iobroker list instances kommt bei mir
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.daikin.0                 : daikin                : raspberrypi                              - disabled
      system.adapter.daikin.1                 : daikin                : raspberrypi                              - disabled
      system.adapter.daikin.2                 : daikin                : raspberrypi                              - disabled
      system.adapter.deconz.0                 : deconz                : raspberrypi                              - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.email.0                  : email                 : raspberrypi                              - disabled
      system.adapter.enigma2.0                : enigma2               : raspberrypi                              - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
      system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
      system.adapter.hue.0                    : hue                   : raspberrypi                              - disabled, port: 80
      system.adapter.info.0                   : info                  : raspberrypi                              - disabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.kodi.0                   : kodi                  : raspberrypi                              - disabled, port: 9090
      system.adapter.material.0               : material              : raspberrypi                              - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
      system.adapter.mihome.0                 : mihome                : raspberrypi                              - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      system.adapter.netatmo.0                : netatmo               : raspberrypi                              - disabled
      system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 192.168.178.50
      system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              - disabled
      system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 192.168.178.50, run as: admin
      system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
      system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
      system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
      system.adapter.tahoma.0                 : tahoma                : raspberrypi                              -  enabled
      system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 192.168.178.50, run as: admin
      system.adapter.windows-control.0        : windows-control       : raspberrypi                              - disabled
    + instance is alive
    Die Adapter, welche als "disabled" angezeigt werden, sind von mir auch tatsächlich derzeit auf disabled (also grau). Nur die mit enabled sind die, welche rot angezeigt werden.
    • T Tramisch
      + instance is alive
      @tramisch sagte in Bei meinem ioBroker sind plötzlich Adapter-Instanzen rot:
      sind alle Adapter-Instanzen auf rot.
      Also sind alle zwei Instanzen?
      was steht denn im log wenn du diese restartest?
        Tramisch
        schrieb am zuletzt editiert von Tramisch
        2 Instanzen? Ups, davon weiß ich nichts. Ich hatte mal vor einigen Wochen das Problem, dass ich gar nicht mehr auf den ioBroker draufkam. Daraufhin hatte ich eine neue Instanz erschaffen, um auf "backitup" zugreifen zu können, um dann wieder ein Update zurückladen zu können. Dananch - so dachte ich - habe ich eine Instanz des Admin wieder entfernt. Seit dem lief alles i. O.
        Habe ich nun doch noch immer 2 Instanzen?
        Zur Frage "was steht denn im log wenn du diese restartest?"
        Da gerate ich offen bar in eine Art Dauerschleife
        host.raspberrypi
        2021-08-22 09:12:30.727	info	iobroker npm-install: npm install iobroker.alexa2@3.9.3 --loglevel error --prefix "/opt/iobroker" (System call)
        host.raspberrypi
        2021-08-22 09:12:30.724	info	iobroker npm-install: NPM version: 7.19.1
        host.raspberrypi
        2021-08-22 09:12:27.245	info	iobroker install alexa2@3.9.3 using installedVersion
        host.raspberrypi
        2021-08-22 09:12:27.242	warn	startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 3 attempt
        host.raspberrypi
        2021-08-22 09:12:26.240	info	iobroker npm-install: exit 25
        host.raspberrypi
        2021-08-22 09:12:25.213	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.alexa2@3.9.3: 217
        host.raspberrypi
        2021-08-22 09:12:25.189	info	iobroker npm-install: npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-08-22T07_12_25_156Z-debug.log
        host.raspberrypi
        2021-08-22 09:12:25.187	info	iobroker npm-install:
        host.raspberrypi
        2021-08-22 09:12:25.153	info	iobroker npm-install: npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/color-string' -> '/opt/iobroker/node_modules/.color-string-TIiP9v7Y'
        host.raspberrypi
        2021-08-22 09:12:25.150	info	iobroker npm-install: npm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/color-stringnpm ERR! dest /opt/iobroker/node_modules/.color-string-TIiP9v7Ynpm ERR! errno -39
        host.raspberrypi
        2021-08-22 09:12:25.148	info	iobroker npm-install: npm ERR! code ENOTEMPTY
        host.raspberrypi
        2021-08-22 09:12:17.446	info	iobroker npm-install: npm install iobroker.alexa2@3.9.3 --loglevel error --prefix "/opt/iobroker" (System call)
        host.raspberrypi
        2021-08-22 09:12:17.443	info	iobroker npm-install: NPM version: 7.19.1
        host.raspberrypi
        2021-08-22 09:12:14.091	info	iobroker install alexa2@3.9.3 using installedFrom
        host.raspberrypi
        2021-08-22 09:12:14.090	warn	startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 2 attempt
        host.raspberrypi
        2021-08-22 09:12:13.089	info	iobroker npm-install: exit 25
        host.raspberrypi
        2021-08-22 09:12:12.056	error	iobroker npm-install: host.raspberrypi Cannot install iobroker.alexa2@3.9.3: 217
        host.raspberrypi
        2021-08-22 09:12:12.033	info	iobroker npm-install: npm ERR! /home/iobroker/.npm/_logs/2021-08-22T07_12_11_999Z-debug.log
        host.raspberrypi
        2021-08-22 09:12:12.031	info	iobroker npm-install: npm ERR! A complete log of this run can be found in:
        host.raspberrypi
        2021-08-22 09:12:12.029	info	iobroker npm-install:
        host.raspberrypi
        2021-08-22 09:12:11.995	info	iobroker npm-install: npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/color-string' -> '/opt/iobroker/node_modules/.color-string-TIiP9v7Y'
        host.raspberrypi
        2021-08-22 09:12:11.989	info	iobroker npm-install: npm ERR! errno -39
        host.raspberrypi
        2021-08-22 09:12:11.985	info	iobroker npm-install: npm ERR! dest /opt/iobroker/node_modules/.color-string-TIiP9v7Y
        host.raspberrypi
        2021-08-22 09:12:11.982	info	iobroker npm-install: npm ERR! path /opt/iobroker/node_modules/color-string
        host.raspberrypi
        2021-08-22 09:12:11.980	info	iobroker npm-install: npm ERR! syscall rename
        host.raspberrypi
        2021-08-22 09:12:11.977	info	iobroker npm-install: npm ERR! code ENOTEMPTY
        host.raspberrypi
        2021-08-22 09:12:04.440	info	iobroker npm-install: npm install iobroker.alexa2@3.9.3 --loglevel error --prefix "/opt/iobroker" (System call)
        host.raspberrypi
        2021-08-22 09:12:04.435	info	iobroker npm-install: NPM version: 7.19.1
        host.raspberrypi
        2021-08-22 09:12:00.978	info	iobroker install alexa2@3.9.3 using installedFrom
        host.raspberrypi
        2021-08-22 09:12:00.977	warn	startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 1 attempt
        host.raspberrypi
        2021-08-22 09:12:00.828	info	"system.adapter.alexa2.0" enabled
        Was mir gerade auch auffällt ist, wenn ich mit "Discovery.0" (der grün ist) nach neuen Geräten suche, findet er "Chromcast.1". Wenn ich dass dann zulasse, verfüge ich über "Chromcast.0" und "Chromcast.1". Was ja wohl tatsächlich 2 Instanzen sein dürften? ABER beide sind grün, wenn ich sie starte.
        • T Tramisch
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          crunchipC Offline
          crunchipC Offline
          dein Auszug zeigt aber nicht das log wenn du eines deiner Instanzen startest
          das ist eher dein Problem
          das ist normal, bzw sollte eigentlich nicht sein, gab bezüglich discovery mal einen Thread
            Tramisch
            Ich dachte das was im Protokoll steht sei das Log? Wo finde ich denn das Log?
            Was genau meinst Du und Wie korrigiere ich das?
            Mit Windows kenne ich mich sehr gut aus, aber bei linux habe ich mega Verständnisprobleme, praktisch an jeder Ecke und Kante.
            • T Tramisch
              @tramisch
              Erstmal nodeJS sauber installieren, inkl. npm.
              Schau in meiner Signatur danach.
              • T Tramisch
                crunchipC Offline
                crunchipC Offline
                richtig, setzt du nen Filter für den entsprechenden Adapter, siehst du nur den entsprechenden Adapter
                  @tramisch
                  Tramisch
                  Habe ich alles befolgt und dabei gemerkt, dass der rasp immer und immer quälend langsamer wird. Alles ist jetzt total langsam geworden. Irgendwas ist da bei mir total falsch.
                  Jedenfalls sah es bei mir vorher so aus:
                  /usr/bin/nodejs
                  /usr/local/bin/node
                  /usr/local/bin/npm
                  Dann habe ich die entfernt und gefixt. Jetzt aber schaut es so aus, dass auch "nodejs" bei local zu finden ist
                  /usr/local/bin/nodejs
                  /usr/local/bin/node
                  /usr/local/bin/npm
                  Doch das scheint ja falsch zu sind. Bei tail -f /opt/iobroker/log/iobroker.current.log erscheint nach extrem langen vielen Minuten am Ende das hier:
                  2021-08-22 09:56:53.177  - error: fullybrowser.0 (2760) No one IP configured
                  2021-08-22 09:56:53.849  - info: deconz.0 (1974) starting. Version 1.3.19 in /opt/iobroker/node_modules/iobroker.deconz, node: v14.9.0, js-controller: 3.3.15
                  2021-08-22 09:56:54.013  - info: deconz.0 (1974) deConz Version: 2.12.6; API version: 1.16.0
                  2021-08-22 09:56:54.080  - info: deconz.0 (1974) Code 403: Forbidden get all lights: [{"error":{"address":"/lights","description":"unauthorized user","type":1}}]
                  2021-08-22 09:56:54.084  - info: deconz.0 (1974) Code 403: Forbidden get all sensors: [{"error":{"address":"/sensors","description":"unauthorized user","type":1}}]
                  2021-08-22 09:56:54.087  - info: deconz.0 (1974) Code 403: Forbidden get all groups: [{"error":{"address":"/groups","description":"unauthorized user","type":1}}]
                  2021-08-22 10:00:19.729  - info: host.raspberrypi "system.adapter.alexa2.0" disabled
                  2021-08-22 10:00:19.758  - info: host.raspberrypi "system.adapter.alexa2.0" enabled
                  2021-08-22 10:00:19.765  - info: host.raspberrypi "system.adapter.alexa2.0" disabled
                  2021-08-22 10:02:32.175  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2021-08-22 10:05:48.230  - info: host.raspberrypi iobroker npm-install: node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.8.0/canvas-v2.8.0-node-v83-linux-glibc-arm.tar.gz
                  2021-08-22 10:07:31.874  - info: host.raspberrypi iobroker npm-install: ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]   E(ptr - data > imgdOffset, "image data overlaps with another structure");     ~~~~~~~~~~~^~~~~~~~~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg)                         ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]   E(ptr - data + imgdSize > len, "not enough image data");     ~~~~~~~~~~~~~~~~~~~~~~^~~~~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg)                         ^~~~
                  2021-08-22 10:07:39.858  - info: host.raspberrypi iobroker npm-install: In file included from ../../nan/nan.h:2884,                 from ../src/backend/Backend.h:6,                 from ../src/Canvas.h:5,                 from ../src/Canvas.cc:3:../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = unsigned char]’:../src/Canvas.cc:274:65:   required from here../../nan/nan_typedarray_contents.h:34:54: warning: ‘v8::ArrayBuffer::Contents v8::ArrayBuffer::GetContents()’ is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908. [-Wdeprecated-declarations]       data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;                                   ~~~~~~~~~~~~~~~~~~~^~
                  2021-08-22 10:07:39.863  - info: host.raspberrypi iobroker npm-install: In file included from /home/iobroker/.cache/node-gyp/14.9.0/include/node/node.h:67,                 from ../../nan/nan.h:54,                 from ../src/backend/Backend.h:6,                 from ../src/Canvas.h:5,                 from ../src/Canvas.cc:3:/home/iobroker/.cache/node-gyp/14.9.0/include/node/v8.h:5266:12: note: declared here   Contents GetContents();            ^~~~~~~~~~~
                  2021-08-22 10:07:54.462  - info: host.raspberrypi iobroker npm-install: In file included from ../../nan/nan.h:2884,
                  2021-08-22 10:07:54.482  - info: host.raspberrypi iobroker npm-install:                  from ../src/backend/Backend.h:6,                 from ../src/Canvas.h:5,                 from ../src/CanvasRenderingContext2d.h:6,                 from ../src/CanvasRenderingContext2d.cc:3:../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = unsigned char]’:../src/CanvasRenderingContext2d.cc:1038:64:   required from here../../nan/nan_typedarray_contents.h:34:54: warning: ‘v8::ArrayBuffer::Contents v8::ArrayBuffer::GetContents()’ is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908. [-Wdeprecated-declarations]       data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;                                   ~~~~~~~~~~~~~~~~~~~^~In file included from /home/iobroker/.cache/node-gyp/14.9.0/include/node/node.h:67,                 from ../../nan/nan.h:54,                 from ../src/backend/Backend.h:6,                 from ../src/Canvas.h:5,                 from ../src/CanvasRenderingContext2d.h:6,                 from ../src/CanvasRenderingContext2d.cc:3:/home/iobroker/.cache/node-gyp/14.9.0/include/node/v8.h:5266:12: note: declared here   Contents GetContents();            ^~~~~~~~~~~In file included from ../../nan/nan.h:2884,                 from ../src/backend/Backend.h:6,                 from ../src/Canvas.h:5,                 from ../src/CanvasRenderingContext2d.h:6,                 from ../src/CanvasRenderingContext2d.cc:3:../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = double]’:../src/CanvasRenderingContext2d.cc:1763:43:   required from here../../nan/nan_typedarray_contents.h:34:54: warning: ‘v8::ArrayBuffer::Contents v8::ArrayBuffer::GetContents()’ is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908. [-Wdeprecated-declarations]       data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;                                   ~~~~~~~~~~~~~~~~~~~^~In file included from /home/iobroker/.cache/node-gyp/14.9.0/include/node/node.h:67,                 from ../../nan/nan.h:54,                 from ../src/backend/Backend.h:6,                 from ../src/Canvas.h:5,                 from ../src/CanvasRenderingContext2d.h:6,                 from ../src/CanvasRenderingContext2d.cc:3:/home/iobroker/.cache/node-gyp/14.9.0/include/node/v8.h:5266:12: note: declared here   Contents GetContents();            ^~~~~~~~~~~
                  2021-08-22 10:08:13.717  - info: host.raspberrypi iobroker npm-install: In file included from ../../nan/nan.h:2884,                 from ../src/ImageData.h:5,                 from ../src/ImageData.cc:3:../../nan/nan_typedarray_contents.h: In instantiation of ‘Nan::TypedArrayContents<T>::TypedArrayContents(v8::Local<v8::Value>) [with T = unsigned char]’:../src/ImageData.cc:116:53:   required from here../../nan/nan_typedarray_contents.h:34:54: warning: ‘v8::ArrayBuffer::Contents v8::ArrayBuffer::GetContents()’ is deprecated: Use GetBackingStore. See http://crbug.com/v8/9908. [-Wdeprecated-declarations]       data   = static_cast<char*>(buffer->GetContents().Data()) + byte_offset;                                   ~~~~~~~~~~~~~~~~~~~^~In file included from /home/iobroker/.cache/node-gyp/14.9.0/include/node/node.h:67,                 from ../../nan/nan.h:54,                 from ../src/ImageData.h:5,                 from ../src/ImageData.cc:3:/home/iobroker/.cache/node-gyp/14.9.0/include/node/v8.h:5266:12: note: declared here   Contents GetContents();            ^~~~~~~~~~~
                  2021-08-22 10:08:41.721  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter javascript@5.2.8
                  2021-08-22 10:08:43.785  - info: host.raspberrypi iobroker npm-install: upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                  2021-08-22 10:08:44.550  - info: host.raspberrypi iobroker npm-install: upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                  2021-08-22 10:08:45.495  - info: host.raspberrypi iobroker npm-install: upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/javascript/javascript.js vs/basic-languages/javascript/javascript.js application/javascript
                  2021-08-22 10:08:46.224  - info: host.raspberrypi iobroker npm-install: upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.b673e3ef.chunk.js static/js/main.b673e3ef.chunk.js application/javascript
                  2021-08-22 10:09:15.938  - info: host.raspberrypi iobroker npm-install: upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/index_m.html index_m.html text/html
                  2021-08-22 10:09:16.555  - info: host.raspberrypi iobroker npm-install: upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/de.js google-blockly/own/msg/de.js application/javascript
                  2021-08-22 10:09:17.164  - info: host.raspberrypi iobroker npm-install: upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_sendto.js google-blockly/own/blocks_sendto.js application/javascript
                  2021-08-22 10:09:17.799  - info: host.raspberrypi iobroker npm-install: upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/it.js google-blockly/msg/js/it.js application/javascript
                  2021-08-22 10:09:18.475  - info: host.raspberrypi iobroker npm-install: upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur application/octet-stream
                  2021-08-22 10:09:18.545  - info: host.raspberrypi iobroker npm-install: upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur application/octet-stream
                  2021-08-22 10:09:18.632  - info: host.raspberrypi iobroker npm-install: upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur application/octet-stream
                  2021-08-22 10:09:18.691  - info: host.raspberrypi iobroker npm-install: upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/dropdown-arrow.svg google-blockly/media/dropdown-arrow.svg image/svg+xml
                  2021-08-22 10:09:18.754  - info: host.raspberrypi iobroker npm-install: upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
                  2021-08-22 10:09:18.815  - info: host.raspberrypi iobroker npm-install: upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
                  2021-08-22 10:09:18.876  - info: host.raspberrypi iobroker npm-install: upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
                  2021-08-22 10:09:18.935  - info: host.raspberrypi iobroker npm-install: upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                  2021-08-22 10:09:18.995  - info: host.raspberrypi iobroker npm-install: upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                  2021-08-22 10:09:19.053  - info: host.raspberrypi iobroker npm-install: upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
                  2021-08-22 10:09:19.112  - info: host.raspberrypi iobroker npm-install: upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
                  2021-08-22 10:09:19.170  - info: host.raspberrypi iobroker npm-install: upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
                  2021-08-22 10:09:19.229  - info: host.raspberrypi iobroker npm-install: upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
                  2021-08-22 10:09:19.287  - info: host.raspberrypi iobroker npm-install: upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
                  2021-08-22 10:09:19.346  - info: host.raspberrypi iobroker npm-install: upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
                  2021-08-22 10:09:19.407  - info: host.raspberrypi iobroker npm-install: upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
                  2021-08-22 10:09:19.474  - info: host.raspberrypi iobroker npm-install: upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
                  2021-08-22 10:09:19.566  - info: host.raspberrypi iobroker npm-install: upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE application/octet-stream
                  2021-08-22 10:09:19.632  - info: host.raspberrypi iobroker npm-install: upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/x-icon
                  2021-08-22 10:09:19.699  - info: host.raspberrypi iobroker npm-install: upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
                  2021-08-22 10:09:19.785  - info: host.raspberrypi iobroker npm-install: upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                  2021-08-22 10:09:19.998  - error: host.raspberrypi iobroker npm-install: /opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:56      throw err      ^Error: /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../package.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../package.json'    at Object.openSync (fs.js:465:3)    at Object.readFileSync (fs.js:368:35)    at Object.readFileSync (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/jsonfile/index.js:50:22)    at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:585:47)    at processImmediate (internal/timers.js:463:21) {  errno: -2,  syscall: 'open',  code: 'ENOENT',  path: '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../package.json'}
                  2021-08-22 10:09:20.016  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:21.018  - warn: host.raspberrypi startInstance cannot find adapter "node-red@2.4.0". Try to install it... 1 attempt
                  2021-08-22 10:09:21.019  - info: host.raspberrypi iobroker install node-red@2.4.0 using installedFrom
                  2021-08-22 10:09:21.234  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:21.246  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:22.247  - warn: host.raspberrypi startInstance cannot find adapter "tahoma@0.4.3". Try to install it... 1 attempt
                  2021-08-22 10:09:22.248  - info: host.raspberrypi iobroker install tahoma@0.4.3 using installedFrom
                  2021-08-22 10:09:22.506  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:22.511  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:23.512  - warn: host.raspberrypi startInstance cannot find adapter "broadlink2@2.0.3". Try to install it... 1 attempt
                  2021-08-22 10:09:23.513  - info: host.raspberrypi iobroker install broadlink2@2.0.3 using installedFrom
                  2021-08-22 10:09:23.744  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:23.752  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:24.754  - warn: host.raspberrypi startInstance cannot find adapter "iot@1.8.13". Try to install it... 1 attempt
                  2021-08-22 10:09:24.754  - info: host.raspberrypi iobroker install iot@1.8.13 using installedFrom
                  2021-08-22 10:09:24.969  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:24.983  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:25.984  - warn: host.raspberrypi startInstance cannot find adapter "net-tools@0.1.5". Try to install it... 1 attempt
                  2021-08-22 10:09:25.985  - info: host.raspberrypi iobroker install net-tools@0.1.5 using installedFrom
                  2021-08-22 10:09:26.187  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:26.193  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:27.194  - warn: host.raspberrypi startInstance cannot find adapter "simple-api@2.5.3". Try to install it... 1 attempt
                  2021-08-22 10:09:27.195  - info: host.raspberrypi iobroker install simple-api@2.5.3 using installedFrom
                  2021-08-22 10:09:27.477  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:27.485  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:28.486  - warn: host.raspberrypi startInstance cannot find adapter "sony-bravia@1.0.1". Try to install it... 1 attempt
                  2021-08-22 10:09:28.487  - info: host.raspberrypi iobroker install sony-bravia@1.0.1 using installedFrom
                  2021-08-22 10:09:28.700  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:28.705  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:29.707  - warn: host.raspberrypi startInstance cannot find adapter "synology@0.1.18". Try to install it... 1 attempt
                  2021-08-22 10:09:29.707  - info: host.raspberrypi iobroker install synology@0.1.18 using installedFrom
                  2021-08-22 10:09:29.919  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:29.926  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:30.929  - warn: host.raspberrypi startInstance cannot find adapter "upnp@1.0.19". Try to install it... 1 attempt
                  2021-08-22 10:09:30.929  - info: host.raspberrypi iobroker install upnp@1.0.19 using installedFrom
                  2021-08-22 10:09:31.135  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:31.140  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:32.140  - warn: host.raspberrypi startInstance cannot find adapter "web@3.4.7". Try to install it... 1 attempt
                  2021-08-22 10:09:32.141  - info: host.raspberrypi iobroker install web@3.4.7 using installedFrom
                  2021-08-22 10:09:32.388  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:32.396  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:33.397  - warn: host.raspberrypi startInstance cannot find adapter "windows-control@0.1.5". Try to install it... 1 attempt
                  2021-08-22 10:09:33.398  - info: host.raspberrypi iobroker install windows-control@0.1.5 using installedFrom
                  2021-08-22 10:09:33.668  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:33.672  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:34.674  - warn: host.raspberrypi startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 1 attempt
                  2021-08-22 10:09:34.675  - info: host.raspberrypi iobroker install alexa2@3.9.3 using installedFrom
                  2021-08-22 10:09:34.908  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:34.913  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:34.914  - info: host.raspberrypi startInstance system.adapter.alexa2.0: instance is disabled but should be started, re-enabling it
                  2021-08-22 10:09:34.930  - info: host.raspberrypi instance "system.adapter.alexa2.0" enabled via .alive
                  2021-08-22 10:09:34.981  - info: host.raspberrypi "system.adapter.alexa2.0" enabled
                  2021-08-22 10:09:35.915  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.3". Try to install it... 1 attempt
                  2021-08-22 10:09:35.916  - info: host.raspberrypi iobroker install vis@1.4.3 using installedFrom
                  2021-08-22 10:09:36.152  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:36.157  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:37.164  - warn: host.raspberrypi startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 1 attempt
                  2021-08-22 10:09:37.165  - info: host.raspberrypi iobroker install alexa2@3.9.3 using installedFrom
                  2021-08-22 10:09:37.383  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:37.406  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:38.412  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.3". Try to install it... 2 attempt
                  2021-08-22 10:09:38.412  - info: host.raspberrypi iobroker install vis@1.4.3 using installedFrom
                  2021-08-22 10:09:38.651  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:38.659  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:39.663  - warn: host.raspberrypi startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 2 attempt
                  2021-08-22 10:09:39.664  - info: host.raspberrypi iobroker install alexa2@3.9.3 using installedFrom
                  2021-08-22 10:09:39.863  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:39.868  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:40.871  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.3". Try to install it... 3 attempt
                  2021-08-22 10:09:40.873  - info: host.raspberrypi iobroker install vis@1.4.3 using installedVersion
                  2021-08-22 10:09:41.099  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:41.104  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:42.114  - warn: host.raspberrypi startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 3 attempt
                  2021-08-22 10:09:42.115  - info: host.raspberrypi iobroker install alexa2@3.9.3 using installedVersion
                  2021-08-22 10:09:42.320  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:42.325  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:43.328  - warn: host.raspberrypi startInstance cannot find adapter "vis@1.4.3". Try to install it... 4 attempt
                  2021-08-22 10:09:43.328  - info: host.raspberrypi iobroker install vis@1.4.3 using installedVersion
                  2021-08-22 10:09:43.564  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:43.572  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:44.575  - warn: host.raspberrypi startInstance cannot find adapter "alexa2@3.9.3". Try to install it... 4 attempt
                  2021-08-22 10:09:44.576  - info: host.raspberrypi iobroker install alexa2@3.9.3 using installedVersion
                  2021-08-22 10:09:44.791  - error: host.raspberrypi iobroker npm-install: internal/modules/cjs/loader.js:895  throw err;  ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:892:15)    at Function.Module._load (internal/modules/cjs/loader.js:742:27)    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)    at internal/main/run_main_module.js:17:47 {  code: 'MODULE_NOT_FOUND',  requireStack: []}
                  2021-08-22 10:09:44.806  - info: host.raspberrypi iobroker npm-install: exit 1
                  2021-08-22 10:09:45.811  - error: host.raspberrypi Cannot download and install adapter "vis@1.4.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                  2021-08-22 10:09:46.313  - error: host.raspberrypi Cannot download and install adapter "alexa2@3.9.3". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
                  Soll ich vielleicht noch einmal mein letztes Backup zurücklesen?
                  • T Tramisch
                    /usr/bin/nodejs
                    /usr/local/bin/node
                    /usr/local/bin/npm
                    /usr/local/bin/node
                    /usr/local/bin/npm
                    Ja, ist komplett falsch.
                      Tramisch
                      Was mich auch wundert, hier steht etwas von 355 Adapter? Soll das bedeuten, bei mir laufen aktuell 355 Adapter? Wenn ja, ist das wohl der Grund der Langsamkeit.
                      Ich bin total ratlos.
                      raspberrypi
                      Plattform
                      linux
                      Betriebssystem
                      linux
                      Architektur
                      arm
                      CPUs
                      Geschwindigkeit
                      1500 MHz
                      Modell
                      ARMv7 Processor rev 3 (v7l)
                      RAM
                      3.75 GB
                      System-Betriebszeit
                      00:12:32
                      Node.js
                      v14.9.0 (Es gibt eine neuere Version: v14.17.5 - Empfohlene Version v12.22.5)
                      NPM
                      6.14.8
                      Datenträgergröße
                      28.96 GB
                      freier Festplattenspeicher
                      16 GB
                      Anzahl der Adapter
                      355
                      Betriebszeit
                      00:12:34
                      Aktive Instanzen
                      location
                      /opt/iobroker/
                      Hostname
                      raspberrypi
                      Thomas BraunT T 2 Antworten Letzte Antwort
                      • T Tramisch
                        raspberrypi
                        Plattform
                        linux
                        Betriebssystem
                        linux
                        Architektur
                        arm
                        CPUs
                        Geschwindigkeit
                        1500 MHz
                        Modell
                        RAM
                        3.75 GB
                        System-Betriebszeit
                        00:12:32
                        Node.js
                        NPM
                        6.14.8
                        Datenträgergröße
                        28.96 GB
                        16 GB
                        Anzahl der Adapter
                        355
                        Betriebszeit
                        00:12:34
                        Aktive Instanzen
                        location
                        /opt/iobroker/
                        Hostname
                        raspberrypi
                        @tramisch Das ist die Zahl der verfügbaren Adapter, nicht die der installierten.
                        • T Tramisch
                          raspberrypi
                          Plattform
                          linux
                          Betriebssystem
                          linux
                          Architektur
                          arm
                          CPUs
                          Geschwindigkeit
                          1500 MHz
                          Modell
                          RAM
                          3.75 GB
                          System-Betriebszeit
                          00:12:32
                          Node.js
                          NPM
                          6.14.8
                          Datenträgergröße
                          28.96 GB
                          16 GB
                          Anzahl der Adapter
                          355
                          Betriebszeit
                          00:12:34
                          Aktive Instanzen
                          location
                          /opt/iobroker/
                          Hostname
                          raspberrypi
                          Tramisch
                          Ich verstehe ohnehin nicht, weshalb nach Rückspielen des Backups die Welt nicht wieder i. O. war? Kapier ich alles nicht.
                            Tramisch
                            Jetzt komme ich gar nicht mehr auf meinen ioBroker. Dies Seite bleibt weiss. Nichts tut sich. Kann/muss ich da jetzt über die rasperry eine neue (temporäre) Admin-Instanz erzeugen oder was sollte ich tun?
                            ODER kann ich über den rasp ein Backup zurückspielen?
                            • T Tramisch
                              @tramisch
                              Hast du nodeJS jetzt senkrecht im System? Ohne bringt dir auch ein Backup nix.
                                @tramisch
                                Tramisch
                                Da kommt nun
                                  throw err;
                                  requireStack: []
                                • T Tramisch
                                  Da kommt nun
                                    throw err;
                                    requireStack: []
                                  @tramisch
                                  nodeJS...
                                    Tramisch
                                    Was meinst Du mit "nodeJS" bzw. wie könnte ich das beheben?
                                    Soll ich noch mal das hier tun?
                                    curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash
                                    sudo apt install nodejs
                                    ...usw usw...
                                    • T Tramisch
                                      ...usw usw...
                                      @tramisch
                                      Du sollst die Anleitung lesen und umsetzen. Siehe oben.
                                      Und nicht kopflos irgendwas irgendwie rumfrickeln.
                                        Tramisch
                                        Du meinst doch diese, richtig?
                                        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                                        Die befolgte ich, mach es aber jetzt gerne gleich noch einmal.
                                        • T Tramisch
                                          @tramisch Ja, die meinte ich.
                                          Wenn du die richtig umgesetzt hättest wäre der Kram nicht in /usr/local/bin zufinden sein.
                                          Also nochmal...
