ioBroker Synology Adapter
Den Eintrag habe ich gemacht -> https://github.com/instalator/ioBroker.synology/issues/66
Hier die Logdatei, ich persönlich kann dies nicht lesen :(
2021-07-20 15:25:31.339 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}} 2021-07-20 15:25:31.340 - [34mdebug[39m: synology.0 (7079) * Packet SS non installed, skipped 2021-07-20 15:25:31.340 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:31.340 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}} 2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) * Packet DL non installed, skipped 2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}} 2021-07-20 15:25:31.341 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: FS method: listSharings params: {} 2021-07-20 15:25:31.489 - [34mdebug[39m: synology.0 (7079) * The response is received, parse: 2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) parseListSharings - Response: {"links":[],"offset":0,"total":0} 2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) >>>>>>>>>>>>>>> Read all data, save received data. 2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) setStates 2021-07-20 15:25:31.490 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.time" 2021-07-20 15:25:31.491 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.uptime" 2021-07-20 15:25:31.491 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.cpu_load" 2021-07-20 15:25:31.591 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:31.592 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}} 2021-07-20 15:25:31.592 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {} 2021-07-20 15:25:32.670 - [34mdebug[39m: synology.0 (7079) * The response is received, parse: 2021-07-20 15:25:32.671 - [34mdebug[39m: synology.0 (7079) SystemUtilization - Response: {"cpu":{"15min_load":56,"1min_load":60,"5min_load":53,"device":"System","other_load":3,"system_load":8,"user_load":15},"disk":{"disk":[{"device":"sda","display_name":"Drive 1","read_access":0,"read_byte":0,"type":"internal","utilization":2,"write_access":2,"write_byte":15974},{"device":"sdb","display_name":"Drive 2","read_access":0,"read_byte":0,"type":"internal","utilization":2,"write_access":2,"write_byte":15974}],"total":{"device":"total","read_access":0,"read_byte":0,"utilization":2,"write_access":4,"write_byte":31948}},"lun":[],"memory":{"avail_real":131836,"avail_swap":2892524,"buffer":76368,"cached":859704,"device":"Memory","memory_size":2097152,"real_usage":42,"si_disk":0,"so_disk":0,"swap_usage":10,"total_real":1871684,"total_swap":3221428},"network":[{"device":"total","rx":1693923,"tx":46163},{"device":"eth0","rx":1693923,"tx":46163}],"nfs":[{"device":"nfs","read_OPS":0,"read_max_latency":0,"total_OPS":0,"total_max_latency":0,"write_OPS":0,"write_max_latency":0}],"space":{"total":{"device":"total","read_access":0,"read_byte":0,"utilization":0,"write_access":2,"write_byte":9011},"volume":[{"device":"dm-1","display_name":"volume1","read_access":0,"read_byte":0,"utilization":0,"write_access":2,"write_byte":9011}]},"time":1626787529} 2021-07-20 15:25:32.671 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:32.672 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}} 2021-07-20 15:25:32.672 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {} 2021-07-20 15:25:32.924 - [34mdebug[39m: synology.0 (7079) * The response is received, parse: 2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false} 2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}} 2021-07-20 15:25:32.925 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getInfo params: {} 2021-07-20 15:25:32.956 - [34mdebug[39m: synology.0 (7079) * The response is received, parse: 2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) TempInfo - Response: {"codepage":"ger","model":"DS218+","ram":2048,"serial":"1870PCN814705","temperature":40,"temperature_warn":false,"time":"Tue Jul 20 15:25:32 2021","uptime":12580,"version":"41890","version_string":"DSM 7.0-41890"} 2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}} 2021-07-20 15:25:32.957 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1} 2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) * The response is received, parse: 2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) InfoSystem - Response: {"hdd_info":[{"capacity":"6001175126016","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"WD60EFAX-68SHWN0","order":1,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":32,"testing_progress":"","testing_type":"idle","volume":"reuse_1"},{"capacity":"6001175126016","diskPath":"/dev/sdb","diskType":"SATA","diskno":"Drive 2","ebox_order":0,"model":"WD60EFAX-68SHWN0","order":2,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":33,"testing_progress":"","testing_type":"idle","volume":"reuse_1"}],"vol_info":[{"desc":"","inode_free":"363593799","inode_total":"365953024","name":"volume_1","status":"normal","total_size":"5901558661120","used_size":"3241873846272","vol_desc":"","volume":"volume_1"}]} 2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:33.151 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}} 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * Packet SS non installed, skipped 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}} 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * Packet SS non installed, skipped 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}} 2021-07-20 15:25:33.152 - [34mdebug[39m: synology.0 (7079) * Packet DL non installed, skipped 2021-07-20 15:25:33.153 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:33.153 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}} 2021-07-20 15:25:33.153 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: FS method: listSharings params: {} 2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) * The response is received, parse: 2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) parseListSharings - Response: {"links":[],"offset":0,"total":0} 2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) >>>>>>>>>>>>>>> Read all data, save received data. 2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) setStates 2021-07-20 15:25:33.278 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.time" 2021-07-20 15:25:33.279 - [34mdebug[39m: synology.0 (7079) setObject "DiskStationManager.info.uptime" 2021-07-20 15:25:33.379 - [34mdebug[39m: synology.0 (7079) ----------------------------------------------------------------------------------------------------- 2021-07-20 15:25:33.379 - [34mdebug[39m: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}} 2021-07-20 15:25:33.379 - [34mdebug[39m: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}@mirotech hab genau das gleiche Problem (gerade erst festgestellt, weil ich 3 Kameras habe, aber nur 1 angezeigt wurde). Habe alle Objekte gelöscht und den Adapter neu gestartet - nun garkeine Cam mehr da...
Hab auch DSM 7 drauf...wenn der Developer mangels Synology den Adapter nicht weiter entwickeln kann, wars das :( -
Hab auch DSM 7 drauf...wenn der Developer mangels Synology den Adapter nicht weiter entwickeln kann, wars das :(@kueppert @Glasfaser @mirotech
ja, bei mir jetzt auch, hab die Tage festgestellt, dass die Links der Cameras im Adapter nicht mehr stimmen, dann mal die Datenpunkte gelöscht und jetzt werden keine mehr Angelegt.
Auch funktionieren Scripts nicht mehr, die auf die API zugreifen, da genau diese mit 7.0.x geändert wurden...
Schade.. da brauchen wir einen FREIWILLIGEN.. :D
Hallöchen,
hat jemand den Adapter zum laufen bekommen mit der 2 Faktor Authentifiation? Bei mir bleibt er immer gelb und hat keine Verbindung. Der User ist auch in der Admin Gruppe wie es sein soll, aber es geht trotzdem nicht. Denn die Nummer für die 2 Faktor Authentification ändert sich ja jede Minute
@skokarl Inzwischen gibt es ein grosses Update vom Synology-Adapter, damit funktioniert jetzt wieder alles und die Streams werden da auch ohne Probleme ausgelesen und als Datenpunkte angelegt. ( und noch viel mehr :-))
Schaut euch den mal an:
iobroker Synology AdapterMhhh
wo ist der Adapter , auf GitHub ist er weg !?Auch hier und in der Repro http://download.iobroker.net/list.html
Mhhh
@glasfaser der Dev. hat ihn auf Git geloescht, schade, denn mit DSM6 lief er ja einwandfrei, nur mit DSM7 nicht mehr richtig...
@ilovegym sagte in ioBroker Synology Adapter:
Dann bleibt erstmal die alte Variante aus der Schublade wieder holen :
Aus dem Grund habe ich DSM7 bisher nicht installiert. Ich bleibe erst mal bei DSM6.
der Adapter ist bald wieder da. wir haben ihn in die community geholt. auf git ist schon die 1.1.0 habe ihn heute fit für DSM7 gemacht. Auf den ersten blick sieht alles gut aus, aber gerne testen. dauert noch ein paar Tage bis er wieder offiziell gelistet ist aber über git könnt ihr ihn schon installieren
https://github.com/iobroker-community-adapters/ioBroker.synology -
https://github.com/iobroker-community-adapters/ioBroker.synology@meistertr ahh .. und ich dachte schon... super!! Ihr seit ja alle so Klasse hier.. :-)
https://github.com/iobroker-community-adapters/ioBroker.synology@meistertr gestern 2. NAS auf DSM7 upgedatet. gerade 1.1.0 über git draufgejubelt. beim ersten drüberschauen in den objekten alles im grünen bereich.
allerdings waren die beiden instanzen auch mit 1.0.0 grün und die objekte waren da. -
Geil, hab auch gerade einfach drüber installiert. Die Links zur SurveillanceStation sind nun auch wieder da und funktionieren :) Top Job @Meistertr
@da_woody grün ja und auch waren sie noch befüllt, wurden jedoch nciht mehr geupdatet weil der adapter sie nciht mehr erkannt hat
Adapter habe ich gerade frisch installiert. Läuft gut, Werte werden angezeigt & aktualisiert und livestreams zweier Cameras in VIS dargestellt.
Probleme habe ich mit den snapshots beider cameras unter:synology.0.SurveillanceStation.cameras.FDT.linkSnapshotWenn ich den link davon im Browser eintrage erhalte ich:
{"error":{"code":105},"success":false}Im Link ist auch kein token enthalten, der Link sieht so aus:
http://IP:port/webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&method=GetSnapshot&version=7&cameraId=%202&_sid=undefinedEdit.: kennt ihr wahrscheinlich schon:
synology.0 2021-08-08 20:09:53.234 info State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number" -
Habe gerade den Synology Adapter installiert, leider bleibt dieser bei mir gelb.
Verbunden mit Host ist grün
Lebenszeichen ist grün
Verbunden mit Gerät oder Dienst ist rotIm LOG sind keine Fehler.
Welche API-Version muss ich im Adapter einstellen, wenn man eine NAS DS218+ und DSM-Version 7.0-41890 hat ?
@arnod sagte in ioBroker Synology Adapter:
Stell mal auf Debug , damit kannst du mehr sehen was los ist .
@glasfaser
Ok, habe jetzt mal auf Debug gestellt und es wird dieser Text laufend wiederholt:----------------------------------------------------------------------------------------------------- Error: Reconnection after 10s *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: ECONNREFUSED message: connect ECONNREFUSED * No response, read next. * Get info from (firstPoll) api: DSM method: getPollingData params: {} * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}} ----------------------------------------------------------------------------------------------------- -
@glasfaser
@glasfaser
Was mich noch in deiner Ausgabe wundert , die IP und der Port fehlt !?
hier mal eine Ausgabe aus einem anderen Thread :
*** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EHOSTUNREACH message: connect EHOSTUNREACH 192.168.10.2:5000@glasfaser
Ist richtig ich habe die IP weggelassen.
Port ist 5001 für https.
und nein habe nicht Pi Hole
