  4. ioBroker Synology Adapter
615 Beiträge 62 Kommentatoren 240.1k Aufrufe 54 Beobachtet
  • M mirotech
    @glasfaser
    Den Eintrag habe ich gemacht -> https://github.com/instalator/ioBroker.synology/issues/66
    Hier die Logdatei, ich persönlich kann dies nicht lesen :(
    2021-07-20 15:25:31.339  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    2021-07-20 15:25:31.340  - debug: synology.0 (7079) * Packet SS non installed, skipped
    2021-07-20 15:25:31.340  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:31.340  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    2021-07-20 15:25:31.341  - debug: synology.0 (7079) * Packet DL non installed, skipped
    2021-07-20 15:25:31.341  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:31.341  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    2021-07-20 15:25:31.341  - debug: synology.0 (7079) * Get info from (fastPoll) api: FS method: listSharings params: {}
    2021-07-20 15:25:31.489  - debug: synology.0 (7079) * The response is received, parse:
    2021-07-20 15:25:31.490  - debug: synology.0 (7079) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    2021-07-20 15:25:31.490  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:31.490  - debug: synology.0 (7079) >>>>>>>>>>>>>>> Read all data, save received data.
    2021-07-20 15:25:31.490  - debug: synology.0 (7079) setStates
    2021-07-20 15:25:31.490  - debug: synology.0 (7079) setObject "DiskStationManager.info.time"
    2021-07-20 15:25:31.491  - debug: synology.0 (7079) setObject "DiskStationManager.info.uptime"
    2021-07-20 15:25:31.491  - debug: synology.0 (7079) setObject "DiskStationManager.info.cpu_load"
    2021-07-20 15:25:31.591  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:31.592  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    2021-07-20 15:25:31.592  - debug: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    2021-07-20 15:25:32.670  - debug: synology.0 (7079) * The response is received, parse:
    2021-07-20 15:25:32.671  - debug: synology.0 (7079) SystemUtilization - Response: {"cpu":{"15min_load":56,"1min_load":60,"5min_load":53,"device":"System","other_load":3,"system_load":8,"user_load":15},"disk":{"disk":[{"device":"sda","display_name":"Drive 1","read_access":0,"read_byte":0,"type":"internal","utilization":2,"write_access":2,"write_byte":15974},{"device":"sdb","display_name":"Drive 2","read_access":0,"read_byte":0,"type":"internal","utilization":2,"write_access":2,"write_byte":15974}],"total":{"device":"total","read_access":0,"read_byte":0,"utilization":2,"write_access":4,"write_byte":31948}},"lun":[],"memory":{"avail_real":131836,"avail_swap":2892524,"buffer":76368,"cached":859704,"device":"Memory","memory_size":2097152,"real_usage":42,"si_disk":0,"so_disk":0,"swap_usage":10,"total_real":1871684,"total_swap":3221428},"network":[{"device":"total","rx":1693923,"tx":46163},{"device":"eth0","rx":1693923,"tx":46163}],"nfs":[{"device":"nfs","read_OPS":0,"read_max_latency":0,"total_OPS":0,"total_max_latency":0,"write_OPS":0,"write_max_latency":0}],"space":{"total":{"device":"total","read_access":0,"read_byte":0,"utilization":0,"write_access":2,"write_byte":9011},"volume":[{"device":"dm-1","display_name":"volume1","read_access":0,"read_byte":0,"utilization":0,"write_access":2,"write_byte":9011}]},"time":1626787529}
    2021-07-20 15:25:32.671  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:32.672  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
    2021-07-20 15:25:32.672  - debug: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
    2021-07-20 15:25:32.924  - debug: synology.0 (7079) * The response is received, parse:
    2021-07-20 15:25:32.925  - debug: synology.0 (7079) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
    2021-07-20 15:25:32.925  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:32.925  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
    2021-07-20 15:25:32.925  - debug: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getInfo params: {}
    2021-07-20 15:25:32.956  - debug: synology.0 (7079) * The response is received, parse:
    2021-07-20 15:25:32.957  - debug: synology.0 (7079) TempInfo - Response: {"codepage":"ger","model":"DS218+","ram":2048,"serial":"1870PCN814705","temperature":40,"temperature_warn":false,"time":"Tue Jul 20 15:25:32 2021","uptime":12580,"version":"41890","version_string":"DSM 7.0-41890"}
    2021-07-20 15:25:32.957  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:32.957  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
    2021-07-20 15:25:32.957  - debug: synology.0 (7079) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
    2021-07-20 15:25:33.151  - debug: synology.0 (7079) * The response is received, parse:
    2021-07-20 15:25:33.151  - debug: synology.0 (7079) InfoSystem - Response: {"hdd_info":[{"capacity":"6001175126016","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"WD60EFAX-68SHWN0","order":1,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":32,"testing_progress":"","testing_type":"idle","volume":"reuse_1"},{"capacity":"6001175126016","diskPath":"/dev/sdb","diskType":"SATA","diskno":"Drive 2","ebox_order":0,"model":"WD60EFAX-68SHWN0","order":2,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":33,"testing_progress":"","testing_type":"idle","volume":"reuse_1"}],"vol_info":[{"desc":"","inode_free":"363593799","inode_total":"365953024","name":"volume_1","status":"normal","total_size":"5901558661120","used_size":"3241873846272","vol_desc":"","volume":"volume_1"}]}
    2021-07-20 15:25:33.151  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:33.151  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = function | poll = undefined
    2021-07-20 15:25:33.152  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:33.152  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
    2021-07-20 15:25:33.152  - debug: synology.0 (7079) * Packet SS non installed, skipped
    2021-07-20 15:25:33.152  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
    2021-07-20 15:25:33.152  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 7 | typeof poll = object | poll = {"api":"dl","method":"getConfigSchedule","params":{}}
    2021-07-20 15:25:33.152  - debug: synology.0 (7079) * Packet DL non installed, skipped
    2021-07-20 15:25:33.153  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:33.153  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 8 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
    2021-07-20 15:25:33.153  - debug: synology.0 (7079) * Get info from (fastPoll) api: FS method: listSharings params: {}
    2021-07-20 15:25:33.278  - debug: synology.0 (7079) * The response is received, parse:
    2021-07-20 15:25:33.278  - debug: synology.0 (7079) parseListSharings - Response: {"links":[],"offset":0,"total":0}
    2021-07-20 15:25:33.278  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:33.278  - debug: synology.0 (7079) >>>>>>>>>>>>>>> Read all data, save received data.
    2021-07-20 15:25:33.278  - debug: synology.0 (7079) setStates
    2021-07-20 15:25:33.278  - debug: synology.0 (7079) setObject "DiskStationManager.info.time"
    2021-07-20 15:25:33.279  - debug: synology.0 (7079) setObject "DiskStationManager.info.uptime"
    2021-07-20 15:25:33.379  - debug: synology.0 (7079) -----------------------------------------------------------------------------------------------------
    2021-07-20 15:25:33.379  - debug: synology.0 (7079) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
    2021-07-20 15:25:33.379  - debug: synology.0 (7079) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
    GlasfaserG Offline
    GlasfaserG Offline
    #265
    @mirotech sagte in ioBroker Synology Adapter:
    .........poll = {"api":"ss"
    ..........poll = {"api":"dl"
    Diese Einträge kann schon der Adapterentwickler gebrauchen und das Protokoll hattest du ja schon auf Gihub hochgeladen .
    Was dieses heißt kann ich nicht genau sagen , eventuell mit der API Versionseinstellung zu tun ,bzw es kann nicht ausgelesen werden !?
    • M mirotech
      @glasfaser
      Kueppert
      #266
      @mirotech hab genau das gleiche Problem (gerade erst festgestellt, weil ich 3 Kameras habe, aber nur 1 angezeigt wurde). Habe alle Objekte gelöscht und den Adapter neu gestartet - nun garkeine Cam mehr da...
      Hab auch DSM 7 drauf...wenn der Developer mangels Synology den Adapter nicht weiter entwickeln kann, wars das :(
      • K Kueppert
        #267
        @kueppert @Glasfaser @mirotech
        ja, bei mir jetzt auch, hab die Tage festgestellt, dass die Links der Cameras im Adapter nicht mehr stimmen, dann mal die Datenpunkte gelöscht und jetzt werden keine mehr Angelegt.
        Auch funktionieren Scripts nicht mehr, die auf die API zugreifen, da genau diese mit 7.0.x geändert wurden...
        Schade.. da brauchen wir einen FREIWILLIGEN.. :D
        I 1 Antwort Letzte Antwort
          I Offline
          I Offline
          Idefix01
          #268
          Hallöchen,
          hat jemand den Adapter zum laufen bekommen mit der 2 Faktor Authentifiation? Bei mir bleibt er immer gelb und hat keine Verbindung. Der User ist auch in der Admin Gruppe wie es sein soll, aber es geht trotzdem nicht. Denn die Nummer für die 2 Faktor Authentification ändert sich ja jede Minute
            @skokarl Inzwischen gibt es ein grosses Update vom Synology-Adapter, damit funktioniert jetzt wieder alles und die Streams werden da auch ohne Probleme ausgelesen und als Datenpunkte angelegt. ( und noch viel mehr :-))
            Schaut euch den mal an:
            iobroker Synology Adapter
            GlasfaserG Offline
            GlasfaserG Offline
            #269
            Mhhh 🤔 wo ist der Adapter , auf GitHub ist er weg !?
            Auch hier und in der Repro http://download.iobroker.net/list.html
            • GlasfaserG Glasfaser
              #270
              @glasfaser der Dev. hat ihn auf Git geloescht, schade, denn mit DSM6 lief er ja einwandfrei, nur mit DSM7 nicht mehr richtig...
              GlasfaserG Samson71S 3 Antworten Letzte Antwort
                GlasfaserG Offline
                GlasfaserG Offline
                #271
                @ilovegym sagte in ioBroker Synology Adapter:
                .... habe ich mir schon irgendwie gedacht , denn laut dem letzen Issues Eintrag hat er geschrieben , das er selber keine Syn hat bzw. noch nicht die API Doku dazu .
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #272
                  Dann bleibt erstmal die alte Variante aus der Schublade wieder holen :
                  Synology NAS-Systemwerte an ioBroker übertragen
                    Samson71S Offline
                    Samson71S Offline
                    Samson71
                    #273
                    Aus dem Grund habe ich DSM7 bisher nicht installiert. Ich bleibe erst mal bei DSM6.
                    Markus
                    Bitte beachten:
                    MeistertrM 1 Antwort Letzte Antwort
                    • Samson71S Samson71
                      MeistertrM Offline
                      MeistertrM Offline
                      Meistertr
                      #274
                      der Adapter ist bald wieder da. wir haben ihn in die community geholt. auf git ist schon die 1.1.0 habe ihn heute fit für DSM7 gemacht. Auf den ersten blick sieht alles gut aus, aber gerne testen. dauert noch ein paar Tage bis er wieder offiziell gelistet ist aber über git könnt ihr ihn schon installieren
                      https://github.com/iobroker-community-adapters/ioBroker.synology
                      ? da_WoodyD 2 Antworten Letzte Antwort
                      • MeistertrM Meistertr
                        #275
                        @meistertr ahh .. und ich dachte schon... super!! Ihr seit ja alle so Klasse hier.. :-)
                          da_WoodyD Offline
                          da_WoodyD Offline
                          #276
                          @meistertr gestern 2. NAS auf DSM7 upgedatet. gerade 1.1.0 über git draufgejubelt. beim ersten drüberschauen in den objekten alles im grünen bereich. 👍
                          allerdings waren die beiden instanzen auch mit 1.0.0 grün und die objekte waren da.
                            Kueppert
                            #277
                            Geil, hab auch gerade einfach drüber installiert. Die Links zur SurveillanceStation sind nun auch wieder da und funktionieren :) Top Job @Meistertr
                            • da_WoodyD da_Woody
                              MeistertrM Offline
                              MeistertrM Offline
                              Meistertr
                              #278
                              @da_woody grün ja und auch waren sie noch befüllt, wurden jedoch nciht mehr geupdatet weil der adapter sie nciht mehr erkannt hat
                                lobomauL Offline
                                lobomauL Offline
                                lobomau
                                schrieb am zuletzt editiert von lobomau
                                #279
                                Adapter habe ich gerade frisch installiert. Läuft gut, Werte werden angezeigt & aktualisiert und livestreams zweier Cameras in VIS dargestellt.
                                Probleme habe ich mit den snapshots beider cameras unter:
                                synology.0.SurveillanceStation.cameras.FDT.linkSnapshot
                                Wenn ich den link davon im Browser eintrage erhalte ich:
                                {"error":{"code":105},"success":false}
                                Im Link ist auch kein token enthalten, der Link sieht so aus:
                                http://IP:port/webapi/entry.cgi?api=SYNO.SurveillanceStation.Camera&method=GetSnapshot&version=7&cameraId=%202&_sid=undefined
                                Edit.: kennt ihr wahrscheinlich schon:
                                synology.0
                                2021-08-08 20:09:53.234	info	State value to set for "synology.0.DiskStationManager.info.uptime" has to be type "string" but received type "number"
                                Host: NUC8i3 mit Proxmox:
                                • Slave: Pi4
                                  ArnoD
                                  #280
                                  Habe gerade den Synology Adapter installiert, leider bleibt dieser bei mir gelb.
                                  Verbunden mit Host ist grün
                                  Lebenszeichen ist grün
                                  Verbunden mit Gerät oder Dienst ist rot
                                  Im LOG sind keine Fehler.
                                  Welche API-Version muss ich im Adapter einstellen, wenn man eine NAS DS218+ und DSM-Version 7.0-41890 hat ?
                                  GlasfaserG J 2 Antworten Letzte Antwort
                                  • A ArnoD
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #281
                                    @arnod sagte in ioBroker Synology Adapter:
                                    Stell mal auf Debug , damit kannst du mehr sehen was los ist .
                                      ArnoD
                                      #282
                                      @glasfaser
                                      Ok, habe jetzt mal auf Debug gestellt und es wird dieser Text laufend wiederholt:
                                      Error: Reconnection after 10s
                                      *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: ECONNREFUSED message: connect ECONNREFUSED
                                      * No response, read next.
                                      * Get info from (firstPoll) api: DSM method: getPollingData params: {}
                                      * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
                                      • A ArnoD
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #283
                                        Dein Syn blockiert oder hast du Pi Hole
                                        • A ArnoD
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #284
                                          @arnod
                                          Was mich noch in deiner Ausgabe wundert , die IP und der Port fehlt !?
                                          hier mal eine Ausgabe aus einem anderen Thread :
                                          *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EHOSTUNREACH message: connect EHOSTUNREACH 192.168.10.2:5000
