  4. admin Webseite Leer (Keine Anmeldemaske)
    6.7k
81 Beiträge 4 Kommentatoren 9.3k Aufrufe 3 Beobachtet
  • K Kaskadeur111
    @homoran OK, bitte wartet alle kurz, wird sonst zu unübersichtlich.... ich führe jetzt
    iobroker stop
    iobroker del admin.0
    iobroker del admin
    iobroker install admin
    iobroker start
    aus
    Kaskadeur111
    schrieb am zuletzt editiert von Kaskadeur111
    @kaskadeur111 sagte in admin Webseite Leer (Keine Anmeldemaske):
    root@iobroker2:/opt/iobroker# iobroker del admin
    Delete adapter "admin"
    host.iobroker2 object admin deleted
    host.iobroker2 object admin.admin deleted
    npm uninstall iobroker.admin --loglevel error --prefix "/opt/iobroker" (System c
    all)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/pcap
    npm ERR! command failed
    npm ERR! command sh -c node-gyp rebuild
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
    npm ERR!   CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
    npm ERR! ../pcap_binding.cc:2:10: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden
    npm ERR!  #include <pcap/pcap.h>
    npm ERR!           ^~~~~~~~~~~~~
    npm ERR! compilation terminated.
    npm ERR! make: *** [pcap_binding.target.mk:112: Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:262:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    npm ERR! gyp ERR! System Linux 4.4.59+
    npm ERR! gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/pcap
    npm ERR! gyp ERR! node -v v12.22.2
    npm ERR! gyp ERR! node-gyp -v v3.8.0
    npm ERR! gyp ERR! not ok
    npm ERR!     /opt/iobroker/.npm/_logs/2021-07-24T12_59_56_173Z-debug.log
    Error deleting adapter admin from disk: Error: host.iobroker2: Cannot uninstall iobroker.admin: 1
    You might have to delete it yourself!
      @kaskadeur111
      Jetzt muss ein Docker Kundiger helfen.
      Nur noch zur Abklärung
      Was ich bisher versucht habe (laut Hormorans Tip aus dem Forum:
      admin neu installiert
      npm cache clean
      iobroker stop
      npm install iobroker.admin
      iobroker upload admin
      iobroker start
      jscontroller neu installiert:
      npm cache clean
      iobroker stop
      npm install iobroker.js-controller
      iobroker start
      hast du die npm Befehle im Installationsverzeichnis (üblicherweise /opt/iobroker, bei Docker hab ich keine Ahnung!) ausgeführt?
        @kaskadeur111
        npm cache clean
        iobroker stop
        iobroker start
        npm cache clean
        iobroker stop
        iobroker start
        Kaskadeur111
        @homoran OK, Danke Dir trotzdem sehr für die Unterstützung bis hierhin!
        Ja ich habe die Befehle in /opt/iobroker ausgeführt
        Kann mir jemand sagen wie ich den admin adapter manuell deinstallieren kann ("You might have to delete it yourself!")?
        iobroker list adapters sagt mir immer noch dass die 5.1.5 installiert sei, obwohl es im iobroker-data/files Ordner keine admin Ordner mehr gibt (müsste der dort aufgeführt sein?)
        • K Kaskadeur111
          @kaskadeur111
          cd /opt/iobroker
          npm list pcap
          Da schlägt der Bau vom pcap fehl. Wozu auch immer das Modul verwendet wird. Auf meinem System ist es jedenfalls nicht vorhanden
            @kaskadeur111
            cd /opt/iobroker
            npm list pcap
            Kaskadeur111
            root@iobroker2:/opt/iobroker# npm list pcap
            iobroker.inst@1.3.1 /opt/iobroker
            ├─┬ iobroker.amazon-dash@1.1.0
            │ └── pcap@3.1.0
            └── pcap@2.1.0 extraneous
            Das ist der Dash Button Adapter, soll ich den mal runterschmeißen? (Den brauche ich eigentlich ;-))
            • K Kaskadeur111
              nein!
              der wäre in einem anderen Pfad, hab es gerade nicht im Kopf. irgendwas mit node-modules
              mach erstmal was Thomas sagt
              • K Kaskadeur111
                │ └── pcap@3.1.0
                @kaskadeur111
                Vermutlich eher der extranous pcap.
                cd /opt/iobroker
                npm uninstall pcap@2.1.0
                npm prune
                  @kaskadeur111
                  cd /opt/iobroker
                  npm prune
                  Kaskadeur111
                  uninstall:
                  root@iobroker2:/opt/iobroker# sudo npm uninstall pcap@2.1.0
                  ⸨#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⸩ ⠙ idealTree:socket.io: sill placeDep node_modules/node-red-contrib-polymer socket.io@1.7.4 OK for: node-red-contrib-polymer@0.0.22 w
                  ⸨#######⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⸩ ⠴ idealTree:validate-npm-package-license: sill placeDep ROOT validate-npm-package-license@3.0.4 OK for: normalize-package-data@2.5.0 w
                  ⸨#######⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⸩ ⠦ idealTree:validate-npm-package-license: sill placeDep ROOT validate-npm-package-license@3.0.4 OK for: normalize-package-data@2.5.0 w
                  npm ERR! code 128
                  npm ERR! An unknown git error occurred
                  npm ERR! command git --no-replace-objects ls-remote ssh://git@github.com/ioBroker/ioBroker.cul.git
                  npm ERR! Warning: Permanently added the RSA host key for IP address '140.82.121.4' to the list of known hosts.
                  npm ERR! git@github.com: Permission denied (publickey).
                  npm ERR! fatal: Konnte nicht vom Remote-Repository lesen.
                  npm ERR!
                  npm ERR! Bitte stellen Sie sicher, dass die korrekten Zugriffsberechtigungen bestehen
                  npm ERR! und das Repository existiert.
                  npm ERR!     /root/.npm/_logs/2021-07-24T13_53_38_001Z-debug.log
                  • K Kaskadeur111
                    uninstall:
                    npm ERR! code 128
                    npm ERR!
                    @kaskadeur111 Nix sudo!
                    Hab ich das irgendwo geschrieben?
                      Kaskadeur111
                      @thomas-braun ich habe die befehle erst ohne sudo ausgeführt
                      • K Kaskadeur111
                        @kaskadeur111
                        Du bist doch schon (vermutlich eh Grundlos) root.
                        Und auch deine Fehlversuche möchten wir sehen damit man sieht was da genau eingegeben wurde.
                        Mit git kenn ich mich nicht aus, keine Ahnung warum da jetzt die beiden Dinger aufgerufen werden.
                          @kaskadeur111
                          Kaskadeur111
                          @thomas-braun OK, hier nochmal ohne sudo
                          npm WARN deprecated node-pre-gyp@0.12.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package wi
                          ll recieve updates in the future
                          npm WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package wi
                          npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                          ⸨################⠂⠂⸩ ⠴ reify:bcryptjs: http fetch GET 200 https://codeload.github.com/ioBroker/ioBroker.cul/tar.gz/8ccc0070f9d80e2ffa457a50830c964ab5783a46 928ms (c
                          npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
                          npm WARN core-js@2.6.12: core-js@<3.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detectio
                          n in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Please, upgrade your dependencies to the actual version of core-js.
                          ⸨##################⸩ ⠧ reify:core-js: WARN deprecated core-js@2.6.12: core-js@<3.3 is no longer maintained and not recommended for usage due to the number of issues.
                          npm ERR! code 1
                          npm ERR! gyp info it worked if it ends with ok
                          npm ERR! gyp info using node-gyp@3.8.0
                          npm ERR! gyp info using node@14.17.3 | linux | x64
                          npm ERR! gyp info spawn /usr/bin/python2
                          npm ERR! gyp info spawn args [
                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                          npm ERR! gyp info spawn args   'binding.gyp',
                          npm ERR! gyp info spawn args   '-f',
                          npm ERR! gyp info spawn args   'make',
                          npm ERR! gyp info spawn args   '-I',
                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/pcap/build/config.gypi',
                          npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                          npm ERR! gyp info spawn args   '/opt/iobroker/.node-gyp/14.17.3/include/node/common.gypi',
                          npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
                          npm ERR! gyp info spawn args   '-Dvisibility=default',
                          npm ERR! gyp info spawn args   '-Dnode_root_dir=/opt/iobroker/.node-gyp/14.17.3',
                          npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                          npm ERR! gyp info spawn args   '-Dnode_lib_file=/opt/iobroker/.node-gyp/14.17.3/<(target_arch)/node.lib',
                          npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/pcap',
                          npm ERR! gyp info spawn args   '-Dnode_engine=v8',
                          npm ERR! gyp info spawn args   '--depth=.',
                          npm ERR! gyp info spawn args   '--no-parallel',
                          npm ERR! gyp info spawn args   '--generator-output',
                          npm ERR! gyp info spawn args   'build',
                          npm ERR! gyp info spawn args   '-Goutput_dir=.'
                          npm ERR! gyp info spawn args ]
                          npm ERR! gyp info spawn make
                          npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                          npm ERR! gyp ERR! stack     at ChildProcess.emit (events.js:375:28)
                          npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
                          npm ERR! gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                          npm ERR! gyp ERR! node -v v14.17.3
                          npm ERR!     /opt/iobroker/.npm/_logs/2021-07-24T13_58_16_080Z-debug.log
                          • K Kaskadeur111
                            npm ERR! code 1
                            @kaskadeur111
                            Deine nodeJS-Installation ist 100% krumm.
                            Schau in meiner Signatur wir man die gerade zieht.
                            K 2 Antworten Letzte Antwort
                              @kaskadeur111
                              Kaskadeur111
                              @thomas-braun mach ich
                                @kaskadeur111
                                Kaskadeur111
                                #66
                                Frage: Deine einleitende Worte stimmen mich nachdenklich, denn ich habe einen Docker Container auf einer Synology, und ich bin root@ .... was bedeutet jetzt das "Nicht machen!" ???
                                "Vorwort:
                                Bis auf Ausnahmefälle (z. B. bei Docker auf einer Synology) wird ein auf Debian basierendes System seit Jahren NICHT mehr per direktem root-login administriert, sondern als normaler user mittels 'sudo'. Solche login prompts sind also unnötig und 'gefährlich':
                                root@raspberrypi:~#
                                Nicht machen!"
                                OK, wahrscheinlich bedeutet es nichts, denn ich habe ja so einen Ausnahmefall.
                                • K Kaskadeur111
                                  "Vorwort:
                                  root@raspberrypi:~#
                                  Nicht machen!"
                                  #67
                                  @kaskadeur111 Das heißt, das man den root-Account nicht benutzt sondern einen User der entsprechende Rechte erhalten kann.
                                  Auf der Synology geht das aber nicht, weil das dortige System extremst abgespeckt ist und es keine User-Verwaltung im klassischen Sinne gibt.
                                  Aus meiner Sicht ist das ganze auch keine gescheite Basis um dort im Docker den ioBroker laufen zu lassen. Aber das ist ein anderes Thema.
                                    Kaskadeur111
                                    #68
                                    @thomas-braun Hmm Naja, wenn du als Basis die Software meinst, kann sein, da kenne ich mich zu wenig aus.
                                    Bei mir Läuft ein Xpenology auf einem i5 Selbstbau NAS mit 32GB RAM und NVME SSDs. Hardwaretechnisch stimmt die Basis auf jedenfall mal
                                    • K Kaskadeur111
                                      #69
                                      ein Xpenology
                                      das klingt aber nach einem seltsamen OS.
                                        ein Xpenology
                                        Kaskadeur111
                                        #70
                                        @homoran Ist halt eine vollwertige Synology die auf eigener Hardware installiert ist. Aber egal, back to Topic, gibt Gründe für das System wie es ist 🐕
                                        • K Kaskadeur111
                                          #71
                                          @kaskadeur111
                                          Klar rede ich vom OS.
                                          Ich würde auch auf eigener Hardware nicht so'n Krampf wie DSM installieren. Da gibt's vernünftigere NAS-Systeme
