  4. Adapter WM-Bus / Kampstrup Multical 21
    apollon77A
153 Beiträge 12 Kommentatoren 37.2k Aufrufe 13 Beobachtet
  • W WolfgangFB
    @matze-dev
    pi@raspberrypi:~ $ wmbusmeters --debug auto:t1 MyTapWater auto 57813696 E4E7EAF6FD17EAFB9587BC2996783C63
    (wmbusmeters) version: _
    (config) number of meters: 1
    (main) device /dev/ttyAMA0 not currently used, detect contents...
    (serial) EVENT thread interrupted
    (serial) before config: /dev/ttyAMA0 speed(B38400) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serial) after config:  /dev/ttyAMA0 speed(B9600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serialtty) opened /dev/ttyAMA0 fd 3 (detect amb8465)
    (serial) received binary ""
    (serial /dev/ttyAMA0) sent "FF0A02008077"
    (serialtty) closed /dev/ttyAMA0 (detect amb8465)
    (amb8465) are you there? no.
    (serial) before config: /dev/ttyAMA0 speed(B9600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serial) after config:  /dev/ttyAMA0 speed(B57600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serialtty) opened /dev/ttyAMA0 fd 3 (detect im871a)
    (serial /dev/ttyAMA0) sent "A5010F00"
    (im871a/im170a) are you there? no.
    (serialtty) closed /dev/ttyAMA0 (detect im871a)
    (serial) before config: /dev/ttyAMA0 speed(B57600) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serial) after config:  /dev/ttyAMA0 speed(B19200) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serialtty) opened /dev/ttyAMA0 fd 3 (detect rc1180)
    (serial /dev/ttyAMA0) sent "00"
    (serial /dev/ttyAMA0) sent "30"
    (serialtty) closed /dev/ttyAMA0 (detect rc1180)
    (rc1180) are you there? no.
    (serial) before config: /dev/ttyAMA0 speed(B19200) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serial) after config:  /dev/ttyAMA0 speed(B38400) input() output() control(CLOCAL|CREAD|CSIZE) local() special_chars() modem(DTR|RTS|CTS)
    (serialtty) opened /dev/ttyAMA0 fd 3 (detect cul)
    (serial /dev/ttyAMA0) sent "560A0D"
    (cul) probe response ""
    (serialtty) closed /dev/ttyAMA0 (detect cul)
    (cul) are you there? no
    (main) ignoring /dev/ttyAMA0, it does not respond as any of the supported wmbus devices.
    (main) device /dev/ttyUSB0 not currently used, detect contents...
    (main) ignoring /dev/ttyUSB0, it does not respond as any of the supported wmbus devices.
    No wmbus device detected, waiting for a device to be plugged in.
    (shell) exec (capture output) "/bin/pidof"
    (shell) arg "wmbusmetersd"
    (shell) return code 1
    (shell) 1824 exited
    (shell) arg "wmbusmeters"
    (shell) return code 0
    (shell) 1825 exited
    Notice! Other wmbusmeters (pid 673) is running and it might hog any wmbus devices.
    (serial) registered regular callback HOT_PLUG_DETECTOR(0) every 2 seconds
    (serial) waiting for stop
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #76
    @wolfgangfb
    W 1 Antwort Letzte Antwort
      @wolfgangfb
      W
      W
      WolfgangFB
      #77
      In wmbusmeters.log steht nichts.
      Ich frage mich allerdings, wie ich den "Other wmbusmeters" in den Griff bekommen kann. Da start ständig eine neue Instanz.
      pi@raspberrypi:/var/log/wmbusmeters/meter_readings $ sudo systemctl stop wmbusmeters
      pi@raspberrypi:/var/log/wmbusmeters/meter_readings $ ps -aux | grep wmbus
      root     16817  0.2  0.0   1468   392 ?        Ss   21:28   0:00 /snap/wmbusmeters/596/bin/sh /snap/wmbusmeters/596/launcher.sh
      root     16841  0.2  0.0  23032  1448 ?        Sl   21:28   0:00 /snap/wmbusmeters/596/usr/bin/wmbusmeters --useconfig=/var/snap/wmbusmeters/common
      pi       17054  0.0  0.0   7360   492 pts/0    S+   21:29   0:00 grep --color=auto wmbus
      pi@raspberrypi:/var/log/wmbusmeters/meter_readings $ sudo kill -9 16817
      root     17125  2.6  0.0   1468   388 ?        Ss   21:29   0:00 /snap/wmbusmeters/596/bin/sh /snap/wmbusmeters/596/launcher.sh
      root     17154  0.5  0.0  22008  1464 ?        Sl   21:29   0:00 /snap/wmbusmeters/596/usr/bin/wmbusmeters --useconfig=/var/snap/wmbusmeters/common
      pi       17170  0.0  0.0   7360   496 pts/0    S+   21:29   0:00 grep --color=auto wmbus
      pi@raspberrypi:/var/log/wmbusmeters/meter_readings $ wmbusmeters --debug auto:t1 MyTapWater auto 57813696 E4E7EAF6FD17EAFB9587BC2996783C63
      (serial) received binary "0984488448844884"
      (im871a) checkIM871AFrame "0984488448844884"
      (im871a) frame does not start with a5 "0984488448844884"
      (im871a) no a5 found at all, drop frame packet.
      (serial) received binary "540442205404E2"
      (cul) probe response "T<04>B T<04><E2>"
      (shell) output: >>><<<
      (shell) 17248 exited
      (shell) 17249 exited
      Notice! Other wmbusmeters (pid 17154) is running and it might hog any wmbus devices.
      • W WolfgangFB
        M
        M
        matze-dev
        #78
        @wolfgangfb morgen müsste ich die komplette Doku fertig haben - dann kann man das komplette System von Scratch aufsetzen und hat dann alles beisammen. Ich stelle die Anleitung + Skripte dann hier ein.
        • W
          W
          WolfgangFB
          #79
          @matze-dev
          Super, ich hoffe, Du hast das dann auch mal mit einer echt blanken Raspberry Installation getestet.
          • W WolfgangFB
            @matze-dev
            M
            M
            matze-dev
            schrieb am zuletzt editiert von matze-dev
            #80
            @wolfgangfb in der Tat, das wird parallel mit einer neuen Karte aufgesetzt und gleich mitdokumentiert :-)
            • M
              M
              matze-dev
              #81
              @matze-dev Kamstrup/Multical 21 realisiert mit Rasperry Pi, iM871A und iobroker zum Auslesen des Wasserzählers
              Nun ist es soweit.
              Anbei die Doku
              Installationsbeschreibung-ioBroker-Rasp-PI+IMST871A.pdf
              hier sind noch die erforderlichen Skripten -sind in der Doku beschrieben, wie man diese verwendet und einbaut.
              extract_watermeters-values.js: das wird vom MQTT-Broker getriggert und liest die Werte aus, die im Datagramm stehen
              calculate_average_new.js: das läuft einmal die Nacht und berechnet den Jahresgesamtverbrauch
              hier sind noch 2 Hilfsscripten, wenn man die States neu anlegen oder löschen möchte - braucht man fürs erste nicht.
              zum Löschen aller states: delete_states.js
              zum Setzen aller states: create_states.js
              • M matze-dev
                Nun ist es soweit.
                Anbei die Doku
                W
                W
                WolfgangFB
                #82
                @matze-dev
                Hi
                Erstmal vielen Dank für die ausführliche Anleitung.
                Ich kann einen großen Erfolg melden: Ich kann meinen Wasserzähler auslesen!!!
                pi@raspberrypi:/var/log/wmbusmeters/meter_readings $ more MyTapWater_2021-07-21
                {"media":"cold water","meter":"multical21","name":"MyTapWater","id":"57813696","total_m3":0.668,"target_m3":0.668,"max_flow_m3h":0,"f
                low_temperature_c":127,"external_temperature_c":18,"current_status":"DRY","time_dry":"22-31 days","time_reversed":"","time_leaking":"
                ","time_bursting":"","timestamp":"2021-07-21T21:59:54Z","device":"im871a[00100776]","rssi_dbm":0}
                Was es jetzt genau war kann ich noch nicht sage, aber in dieser Anleitung waren ein paar Installationen mehr vorhanden als ich bisher gemacht habe. Ich glaube der Hauptpunkt ist, dass mein Zähler im C1 Mode sendet.
                Was noch nicht klappt ist der mqtt Adapter, der bleibt einfach bei gelb hängen. "Verbunden mit mqtt: falsch"
                Wo kann ich da ansetzen? (Zur Not schreibe ich mir aber selbst ein Skript, dass die täglichen meter_readings auswertet, das würde ich hinbekommen :-) )
                • W WolfgangFB
                  @matze-dev
                  Hi
                  M
                  M
                  matze-dev
                  #83
                  @wolfgangfb Hallo, schön zu hören. Mein MQTT ist auch gelb. Das ist OK. Wenn Du auf den gelben Punkt gehst, dann zeigt er Dir die Zustände an. Die ersten müssten grün sein. Wichtig ist, ob in den Objekten die Variablen angelegt sind und diese ab und zu grün werden, dann läuft alles. Der Broker wacht nur kurz auf, wenn Daten rein kommen, darum denke ich, dass das so Ok ist. Das mit den verschiedenen Versionen des Zählers ist in der Tat etwas tricky. Hast es aber rausgefunden! Viel Glück.
                  • M matze-dev
                    W
                    W
                    WolfgangFB
                    #84
                    @matze-dev
                    Hi
                    Das Problem ist, dass die Datenpunkte nicht angelegt werden.
                    Wenn ich auf den gelben Punkt klicke sehe ich, dass die Verbindung mit Host Ok ist, Lebenszeichen da ist, aber Verbindung mit MQTT nicht OK ist.
                    Die Frage ist jetzt, ob der mkosquitto richtig läuft oder der Adapter ein Problem hat, wo setze ich da mit der Fehlersuche an?
                    Gruß und Dank
                    Wolfgang
                    • M
                      M
                      matze-dev
                      #85
                      @wolfgangfb also bei mir war es so, dass der mosquitto Server noch lief, dann ist der MQTT aber auf rot gelaufen und es gab einen IP Adresskonflikt, weil die Adresse und Port bereits an den anderen Prozess gebunden sind. Der muss rauskonfiguriert werden, ist in meiner Doku beschrieben. Das sieht man schön im Log auf der linken Seite. Bei Dir ist er aber gelb? Schau mal auf der linken Seite im Log. Wie sind da die Fehlermeldungen? Ggfs. mal den MQTT neu starten. Wichtig ist auch, dass beide Skripte laufen, das eine macht genau die Variablenübernahme.
                      • M matze-dev
                        W
                        W
                        WolfgangFB
                        #86
                        @matze-dev
                        Sieg!!!!!
                        Was es jetzt im Endeffekt war, kann ich auch nicht sagen, ich habe die letzten Installationsschritte nochmal durchgeführt und dann festgestellt, dass mein IO-Broker einige Einstellungen einfach nicht gespeichert hat (ich habe die die definitiv beim ersten mal 1:1 aus Deinen Vorgaben übernommen. Plötzlich und unerwartet waren dann auf einmal die Datenpunkte da.
                        Zur Info: Die Wasseruhr liegt auf meinem Schreibtisch und meldet deshalb "dry".
                        Was mich noch etwas irritiert sind die Temperaturen. Auf meinem Schreibtisch sollten eigentlich um die 25° sein.
                        Kleiner Hinweis noch zur ansonsten tollen Anleitung (ohne die hätte ich wahrscheinlich aufgeben müssen): Für Leute, die wirklich kurz vor dem Verzweifeln sind und wirklich alles 1:1 nachmachen wollen wäre der Hinweis ganz gut, dass die Anzeige des IO-Brokers bei unterschiedlichen Browsern unterschiedlich aussehe kann (bei einem Browser klappt bei mir z.B. das Adapter Fenster einfach nicht, auf dem nächsten dagegen problemlos.
                        Also: Vielen vielen vielen Dank!
                        PS. Gibt es so eine tolle Anleitung auch für den Modbus-RTU
                        PPS (Weil ich hier ja schon die Linux Experten habe, gehört sonst nicht hierher) Wie kann ich in dem ssh Fenster die Farben so einstellen, dass man das dunkelblau vor schwarzem Hintergrund lesen kann? (Wenn ich mit der Maus den Text markiere wird daraus gelb auf weiß was genauso schlecht zu lesen ist)?
                        Schönes Wochenende und einen trockenen Keller wünscht
                        Wolfgang
                        Thomas BraunT M 2 Antworten Letzte Antwort
                        • W WolfgangFB
                          @matze-dev
                          Sieg!!!!!
                          Wolfgang
                          Thomas BraunT
                          Thomas BraunT
                          #87
                          @wolfgangfb sagte in Adapter WM-Bus / Kampstrup Multical 21:
                          Das kann man in der config-Datei zu der verwendeten Shell einstellen.
                          Für die bash z.B. in der bashrc
                          Btw: Mit CodeTags statt der eh verpönten Screenshots wäre das nicht passiert. Verwende CodeTags!
                            W
                            W
                            WolfgangFB
                            #88
                            Dank, ich habe es gefunden. Das mit dem Screenshot war Absicht, ich weiß, dass Code-Tags besser lesbar sind, ich wollte aber gerade zeigen, wie unleserlich das ganze in meiner Shell aussieht.
                            • W WolfgangFB
                              @matze-dev
                              Sieg!!!!!
                              Wolfgang
                              M
                              M
                              matze-dev
                              #89
                              @wolfgangfb Hallo, schön dass es geklappt hat! 😊
                              Leider kann ich mit dem Modbus-RTU nicht weiterhelfen, habe nur den Wasserzähler eingebaut bekommen.
                              Ich hoffe, wegen der Browser-Fenster sehen Nachahmer hier im Threat nach und sehen Deinen Hinsweis. Die Browserhersteller ändern ja permanent, da weiß ich leider auch nicht, wann und wie sich das Verhalten ändern wird. Darum würde ich es erst einmal draußen lassen. Trotzdem Danke für den Hinweis.
                              • M matze-dev
                                W
                                W
                                WolfgangFB
                                #90
                                @matze-dev
                                Noch ein Hinweis für diejenigen, die das einfach nachbauen möchten.
                                Bei mir ist noch folgendes passiert: Als ich die Skripte (insbesondere "extract_wmbusmeters-values.js") anpassen wollte kam mein Ultraedit (Schriftart Courier) nicht mit den Umlauten zurecht und hat aus einem "ü" ein "ü" gemacht etc. Das Resultat war, dass einige Datenpunkte nicht angelegt worden sind (alle, die entweder einen Umlaut enthalten oder als Einheit das "°" Zeichen. Diese Datenpunkte kann ich auch nicht von Hand neu anlegen, die sind irgendwie gesperrt/blockiert. Abhilfe hat gebracht,die Datenpunkte mit einem neuen Namen zu versehen.
                                Gruß Wolfgang
                                • W WolfgangFB
                                  @matze-dev
                                  Gruß Wolfgang
                                  Thomas BraunT
                                  Thomas BraunT
                                  #91
                                  @wolfgangfb
                                  Stell beim Editor utf-8 ein. Das dürfte das Problem der Codierung beheben.
                                  Aber ja, es ist eine gute Idee Sonderzeichen wie deutsche Umlaute aus Skripten herauszuhalten.
                                    @wolfgangfb
                                    W
                                    W
                                    WolfgangFB
                                    #92
                                    Ich wollte nur darauf hinweisen was passiert, wenn man nicht darauf achtet (dass eben die Datenpunkte überhaupt nicht angelegt werden).
                                    • TbsJahT
                                      TbsJahT
                                      TbsJah
                                      #93
                                      Endlich habe ich von der Gemeinde die KEM inkl. Passwort erhalten und konnte nun auch starten...
                                      @matze-dev
                                      Danke für deine ausführliche Anleitung! Hat bei dem ersten Test auf anhieb funktioniert.
                                      Einfacher war jetzt für das Produktivsystem (für mich) mit git zu arbeiten.
                                      Ebenso reicht es bei mir aus nur den MQTT Client zu installieren um zu puplishen
                                      sudo apt install mosquitto-clients
                                      sudo apt install git
                                      git clone https://github.com/weetmuts/wmbusmeters
                                      ./configure; make; sudo make install
                                      Statt mit vi arbeite ich lieber mit nano. Macht es für mich einfacher
                                      sudo nano /etc/wmbusmeters.conf
                                      Da ich bei mir den Raspi öfters mal reboote habe ich device auf auto gestellt
                                      Da bei jedem Neustart der USB willkürlich gezogen wird
                                      device=auto:c1
                                      Noch einmal danke
                                      • W
                                        W
                                        WolfgangFB
                                        #94
                                        @matze-dev
                                        Hallo Matze
                                        Ich habe gerade versucht, auf einem zweiten Raspberry das ganze nochmal von Grund auf neu nachzuvollziehen. Installation klappt auch, die Werte werden ausgelesen, nur die Übertragung per MQTT in IoBroker klappt nicht. Vermutlich weil ich ja einen zweiten raspi mit genau der gleichen Konfiguration laufen habe.
                                        Frage: Wie stelle ich den Mosquitto so ein, dass er sich nicht mit einem zweiten Mosquitto im gleichen Netz beißt? Ich vermute (bin mir aber nicht sicher), dass ein anderer Port genügen könnte (wo stellt man den ein?)
                                        Gruß Wolfgang
                                        • W WolfgangFB
                                          @matze-dev
                                          Hallo Matze
                                          Gruß Wolfgang
                                          M
                                          M
                                          matze-dev
                                          #95
                                          @wolfgangfb Hallo Wolfgang, das glaube ich eher nicht - der MQTT als Broker wird ja immer dann geweckt, wenn ein neues Datagramm eintrifft. Das klappt m.E. auch mit einer zweiten "Hardwareinstanz" = weiterer Raspi parallel. Siehst Du die Werte im 2. Raspi? Ist die mqtt-Installation korrekt gelaufen etc.? Viel Glück.
                                          84.0k
