  4. Test Adapter fb-checkpresence v1.1.x
    1.0k
    6.1k
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 381.8k Aufrufe 78 Beobachtet
  • J jukus100
    @afuerhoff krieg immer noch ne ähnliche Fehlermeldung auch mit 1.1.5.
    fb-checkpresence.0	2021-06-10 15:30:10.867	error	(14313) onMessage: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
    fb-checkpresence.0	2021-06-10 15:30:10.673	debug	(14313) loop family ends after 6,157389090 s
    fb-checkpresence.0	2021-06-10 15:30:08.822	debug	(14313) system.adapter.admin.0: logging true
    fb-checkpresence.0	2021-06-10 15:30:03.652	info	(14313) state fb-checkpresence.0.reconnect changed: false (ack = true)
    fb-checkpresence.0	2021-06-10 15:30:03.610	info	(14313) state fb-checkpresence.0.reboot changed: false (ack = true)
    fb-checkpresence.0	2021-06-10 15:30:03.515	info	(14313) loop successfully started
    fb-checkpresence.0	2021-06-10 15:30:03.512	info	(14313) states successfully subscribed
    fb-checkpresence.0	2021-06-10 15:30:03.509	warn	(14313) infoNoFamilyMembers: no family members defined! Objects are not created!
    fb-checkpresence.0	2021-06-10 15:30:03.500	info	(14313) createGlobalObjects finished successfully
    fb-checkpresence.0	2021-06-10 15:30:02.720	warn	(14313) The state "devices" will not longer exist in a future version. Please use "fb-devices.count" instead!
    fb-checkpresence.0	2021-06-10 15:30:02.719	warn	(14313) The state "activeDevices" will not longer exist in a future version. Please use "fb-devices.active" instead!
    fb-checkpresence.0	2021-06-10 15:30:02.719	warn	(14313) The state "blacklist" will not longer exist in a future version. Please use "blacklist.presence" instead!
    fb-checkpresence.0	2021-06-10 15:30:02.718	warn	(14313) The state "guest" will not longer exist in a future version. Please use "guest.presence" instead!
    fb-checkpresence.0	2021-06-10 15:30:02.714	warn	(14313) You should then manually delete the old states!
    fb-checkpresence.0	2021-06-10 15:30:02.713	warn	(14313) In an future version some states are not more existent. Please use compatibility = false to switch to the new handling of the states!
    fb-checkpresence.0	2021-06-10 15:30:02.694	info	(14313) Layer3Forwarding1-GetDefaultConnectionService is supported
    fb-checkpresence.0	2021-06-10 15:30:02.693	info	(14313) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
    fb-checkpresence.0	2021-06-10 15:30:02.692	info	(14313) WANPPPConnection1-ForceTermination is supported
    fb-checkpresence.0	2021-06-10 15:30:02.690	info	(14313) DeviceConfig1-Reboot is supported
    fb-checkpresence.0	2021-06-10 15:30:02.689	info	(14313) DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2021-06-10 15:30:02.688	info	(14313) WLANConfiguration3-GetSecurityKeys is supported
    fb-checkpresence.0	2021-06-10 15:30:02.687	info	(14313) WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0	2021-06-10 15:30:02.686	info	(14313) WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0	2021-06-10 15:30:02.685	info	(14313) WANIPConnection1-GetInfo is supported
    fb-checkpresence.0	2021-06-10 15:30:02.683	info	(14313) WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2021-06-10 15:30:02.682	info	(14313) WANCommonInterfaceConfig1-GetCommonLinkProperties is supported
    fb-checkpresence.0	2021-06-10 15:30:02.681	info	(14313) DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2021-06-10 15:30:02.680	info	(14313) Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2021-06-10 15:30:02.679	info	(14313) Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2021-06-10 15:30:02.678	info	(14313) Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0	2021-06-10 15:30:02.676	info	(14313) Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2021-06-10 15:30:02.675	info	(14313) configuration default connection: 1.WANIPConnection.1
    fb-checkpresence.0	2021-06-10 15:30:02.673	debug	(14313) configuration filter delay: 15
    fb-checkpresence.0	2021-06-10 15:30:02.672	debug	(14313) configuration guest info: true
    fb-checkpresence.0	2021-06-10 15:30:02.671	debug	(14313) configuration qr code: false
    fb-checkpresence.0	2021-06-10 15:30:02.670	debug	(14313) configuration ssl: true
    fb-checkpresence.0	2021-06-10 15:30:02.669	debug	(14313) configuration compatibility: true
    fb-checkpresence.0	2021-06-10 15:30:02.667	debug	(14313) configuration whitelist: true
    fb-checkpresence.0	2021-06-10 15:30:02.666	debug	(14313) configuration mesh info: false
    fb-checkpresence.0	2021-06-10 15:30:02.665	debug	(14313) configuration fb-devices false
    fb-checkpresence.0	2021-06-10 15:30:02.664	debug	(14313) configuration familymembers: []
    fb-checkpresence.0	2021-06-10 15:30:02.663	debug	(14313) configuration familymembers count: 0
    fb-checkpresence.0	2021-06-10 15:30:02.662	debug	(14313) configuration dateformat: <yyyy.mm.dd HH:MM:ss>
    fb-checkpresence.0	2021-06-10 15:30:02.660	debug	(14313) configuration history: <>
    fb-checkpresence.0	2021-06-10 15:30:02.659	debug	(14313) configuration user: <jk>
    fb-checkpresence.0	2021-06-10 15:30:02.656	info	(14313) start fb-checkpresence.0: FRITZ!Box 6490 Cable version: 141.07.12 ip-address: "fritz.box" - interval devices: 1 min. - interval members: 60 s
    ecovacs-deebot.0	2021-06-10 15:30:00.096	info	(8471) Start cleaning spot area(s): 1,4,5
    fb-checkpresence.0	2021-06-10 15:29:46.937	info	(14313) service X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Can not find service file! Feature is deactivated
    fb-checkpresence.0	2021-06-10 15:29:46.935	info	(14313) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Can not find service file! Feature is deactivated
    fb-checkpresence.0	2021-06-10 15:29:20.737	debug	(14313) system.adapter.admin.0: logging false
    fb-checkpresence.0	2021-06-10 15:29:16.261	info	(14313) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
    fb-checkpresence.0	2021-06-10 15:29:15.662	debug	(14313) statesDB connected
    fb-checkpresence.0	2021-06-10 15:29:15.660	debug	(14313) States connected to redis: 127.0.0.1:9000
    fb-checkpresence.0	2021-06-10 15:29:15.633	debug	(14313) States create User PubSub Client
    fb-checkpresence.0	2021-06-10 15:29:15.630	debug	(14313) States create System PubSub Client
    fb-checkpresence.0	2021-06-10 15:29:15.606	debug	(14313) Redis States: Use Redis connection: 127.0.0.1:9000
    fb-checkpresence.0	2021-06-10 15:29:15.601	debug	(14313) objectDB connected
    fb-checkpresence.0	2021-06-10 15:29:15.579	debug	(14313) Objects connected to redis: 127.0.0.1:9001
    fb-checkpresence.0	2021-06-10 15:29:15.540	debug	(14313) Objects client initialize lua scripts
    fb-checkpresence.0	2021-06-10 15:29:15.537	debug	(14313) Objects create User PubSub Client
    fb-checkpresence.0	2021-06-10 15:29:15.533	debug	(14313) Objects create System PubSub Client
    fb-checkpresence.0	2021-06-10 15:29:15.518	debug	(14313) Objects client ready ... initialize now
    fb-checkpresence.0	2021-06-10 15:29:15.423	debug	(14313) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.raspberrypi	2021-06-10 15:29:13.109	info	instance system.adapter.fb-checkpresence.0 started with pid 14313
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #586
    @jukus100
    Timeout kann schon mal vorkommen. Wenn ständig, dann Fritzbox neu booten.
    Hat nichts mit der anderen Meldung zu tun.
      SaiBot1981
      #587
      Moin, ich hab da mal einen Frage bezüglich rebooten. Kannst du evtl auch eine Funktion einbauen durch die Man die FritzRepeater rebooten könnte?
      • S SaiBot1981
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        schrieb am zuletzt editiert von afuerhoff
        #588
        @saibot1981
        Fritz Repeater kann ich nicht rebooten
        • afuerhoffA afuerhoff
          @saibot1981
          bishop
          #589
          @afuerhoff
          passt jetzt nicht zum Adaptername, aber ist es möglich ein Telefon zu sperren damit es nicht klingelt?
          oder wie müsste ich da den Command zusammenstricken!?!
          • B bishop
            @afuerhoff
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #590
            @bishop sagte in Test Adapter fb-checkpresence v1.1.x:
            Du könntest hier mal schauen. Da gibt es auch für DECT ein Dokument
            https://avm.de/service/schnittstellen/
              bishop
              #591
              @afuerhoff
              habe ich mir mal angeschaut die "x_dectSCPD.pdf", habe aber nicht wirklich Ahnung wie ich da ein DECT Telefon sperren soll.
              • B bishop
                @afuerhoff
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #592
                @bishop
                Ich habe in der Doku auch nichts passendes gefunden
                PischleuderP 1 Antwort Letzte Antwort
                  @bishop
                  PischleuderP Offline
                  Pischleuder
                  #593
                  @afuerhoff
                  Danke zunächst für den Adpater, den ich gegen den life360 tauschen möchte.
                  Beim starten erhalte ich folgende Fehlermeldung:
                  fb-checkpresence.0	2021-06-19 14:36:02.630	info	(29822) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  fb-checkpresence.0	2021-06-19 14:36:02.627	info	(29822) terminating
                  fb-checkpresence.0	2021-06-19 14:36:02.129	warn	(29822) State "fb-checkpresence.0.info.connection" has no existing object, this might lead to an error in future versions
                  fb-checkpresence.0	2021-06-19 14:36:02.125	info	(29822) cleaned everything up ...
                  fb-checkpresence.0	2021-06-19 14:36:02.121	info	(29822) Got terminate signal TERMINATE_YOURSELF
                  fb-checkpresence.0	2021-06-19 14:36:02.068	warn	(29822) onReady: Fb init: getSSLPort: DeviceInfo:1 GetSecurityPort timeout of 6000ms exceeded
                  fb-checkpresence.0	2021-06-19 14:36:02.066	warn	(29822) The user could have been blocked from the fritzbox due to authentification problems! Please stop the adapter and reboot the fritzbox. Then start and try again.
                  fb-checkpresence.0	2021-06-19 14:35:55.979	info	(29822) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
                  fb-checkpresence.0	2021-06-19 14:31:06.056	info	(26051) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  fb-checkpresence.0	2021-06-19 14:31:06.055	info	(26051) terminating
                  fb-checkpresence.0	2021-06-19 14:31:05.557	warn	(26051) State "fb-checkpresence.0.info.connection" has no existing object, this might lead to an error in future versions
                  User und Passwort stimmen.
                  Any idea ?
                  Gruss
                  • PischleuderP Pischleuder
                    @afuerhoff
                    Any idea ?
                    Gruss
                    Pischleuder
                    #594
                    @pischleuder
                    Edit: Kommando zurück, nach zweimaligem Neustart der Fritzbox funktioniert es nun.
                    • MichMeinM Offline
                      MichMeinM Offline
                      MichMein
                      #595
                      Hi @afuerhoff,
                      seit einem gestrigen Update meiner 7490 auf 7.27 steht der Adapter auf dem orangenen Warndreieck (keine Verbindung zum Gerät).
                      Hier das normale Log,
                      2021-07-10 03:19:23.831 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:19:37.843 - warn: fb-checkpresence.0 (28047) getExtIp:
                      2021-07-10 03:19:43.849 - warn: fb-checkpresence.0 (28047) getGuestWlan WLANConfiguration:3 GetInfo timeout of 6000ms exceeded
                      2021-07-10 03:19:49.853 - warn: fb-checkpresence.0 (28047) checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:24:48.173 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:30:00.508 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:30:14.522 - warn: fb-checkpresence.0 (28047) getExtIp:
                      2021-07-10 03:30:20.529 - warn: fb-checkpresence.0 (28047) getGuestWlan WLANConfiguration:3 GetInfo timeout of 6000ms exceeded
                      2021-07-10 03:30:26.535 - warn: fb-checkpresence.0 (28047) checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:35:24.853 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:40:37.191 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:40:51.203 - warn: fb-checkpresence.0 (28047) getExtIp:
                      2021-07-10 03:40:57.210 - warn: fb-checkpresence.0 (28047) getGuestWlan WLANConfiguration:3 GetInfo timeout of 6000ms exceeded
                      2021-07-10 03:41:03.216 - warn: fb-checkpresence.0 (28047) checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:46:01.539 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:51:13.858 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:51:27.870 - warn: fb-checkpresence.0 (28047) getExtIp:
                      2021-07-10 03:51:33.877 - warn: fb-checkpresence.0 (28047) getGuestWlan WLANConfiguration:3 GetInfo timeout of 6000ms exceeded
                      2021-07-10 03:51:39.884 - warn: fb-checkpresence.0 (28047) checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 03:56:38.202 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 04:01:50.526 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 04:02:04.546 - warn: fb-checkpresence.0 (28047) getExtIp:
                      2021-07-10 04:02:10.550 - warn: fb-checkpresence.0 (28047) getGuestWlan WLANConfiguration:3 GetInfo timeout of 6000ms exceeded
                      2021-07-10 04:02:16.555 - warn: fb-checkpresence.0 (28047) checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 04:07:14.894 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 04:12:27.231 - warn: fb-checkpresence.0 (28047) checkPresence: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      2021-07-10 04:12:41.244 - warn: fb-checkpresence.0 (28047) getExtIp:
                      2021-07-10 04:12:47.249 - warn: fb-checkpresence.0 (28047) getGuestWlan WLANConfiguration:3 GetInfo timeout of 6000ms exceeded
                      2021-07-10 04:12:53.254 - warn: fb-checkpresence.0 (28047) checkDevices: getDeviceList: Hosts:1 X_AVM-DE_GetHostListPath: timeout of 6000ms exceeded
                      Und hier ein Debug-Log nach Adapterrestart,
                      2021-07-10 20:16:41.038 - info: fb-checkpresence.0 (28047) Got terminate signal TERMINATE_YOURSELF
                      2021-07-10 20:16:41.041 - info: fb-checkpresence.0 (28047) cleaned everything up ...
                      2021-07-10 20:16:41.542 - info: fb-checkpresence.0 (28047) terminating
                      2021-07-10 20:16:41.544 - info: fb-checkpresence.0 (28047) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2021-07-10 20:16:45.453 - debug: fb-checkpresence.0 (14943) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2021-07-10 20:16:45.496 - debug: fb-checkpresence.0 (14943) Objects client ready ... initialize now
                      2021-07-10 20:16:45.499 - debug: fb-checkpresence.0 (14943) Objects create System PubSub Client
                      2021-07-10 20:16:45.500 - debug: fb-checkpresence.0 (14943) Objects create User PubSub Client
                      2021-07-10 20:16:45.502 - debug: fb-checkpresence.0 (14943) Objects client initialize lua scripts
                      2021-07-10 20:16:45.524 - debug: fb-checkpresence.0 (14943) Objects connected to redis: 127.0.0.1:9001
                      2021-07-10 20:16:45.534 - debug: fb-checkpresence.0 (14943) objectDB connected
                      2021-07-10 20:16:45.536 - debug: fb-checkpresence.0 (14943) Redis States: Use Redis connection: 127.0.0.1:9000
                      2021-07-10 20:16:45.546 - debug: fb-checkpresence.0 (14943) States create System PubSub Client
                      2021-07-10 20:16:45.548 - debug: fb-checkpresence.0 (14943) States create User PubSub Client
                      2021-07-10 20:16:45.559 - debug: fb-checkpresence.0 (14943) States connected to redis: 127.0.0.1:9000
                      2021-07-10 20:16:45.560 - debug: fb-checkpresence.0 (14943) statesDB connected
                      2021-07-10 20:16:45.880 - info: fb-checkpresence.0 (14943) starting. Version 1.1.7 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.2, js-controller: 3.3.14
                      2021-07-10 20:16:52.290 - info: fb-checkpresence.0 (14943) start fb-checkpresence.0: FRITZ!Box 7490 version: 113.07.27 ip-address: "192.168.178.1" - interval devices: 10 min. - interval members: 300 s
                      2021-07-10 20:16:52.291 - debug: fb-checkpresence.0 (14943) configuration user:
                      2021-07-10 20:16:52.292 - debug: fb-checkpresence.0 (14943) configuration history:
                      2021-07-10 20:16:52.292 - debug: fb-checkpresence.0 (14943) configuration dateformat:
                      2021-07-10 20:16:52.293 - debug: fb-checkpresence.0 (14943) configuration familymembers count: 2
                      2021-07-10 20:16:52.294 - debug: fb-checkpresence.0 (14943) configuration familymembers: [{"familymember":"Michaels-iPhone","macaddress":"DA:5A:91:12:CF:B0","ipaddress":"192.168.178.75","useip":true,"comment":"Michaels-iPhone","enabled":true,"usefilter":false,"group":"","usage":"IP","devicename":""},{"familymember":"Yvonnes-iPhone","macaddress":"26:66:D0:15:4A:2F","ipaddress":"192.168.178.74","useip":true,"comment":"Yvonnes-iPhone","enabled":true,"usefilter":false,"group":"","usage":"IP","devicename":""}]
                      2021-07-10 20:16:52.294 - debug: fb-checkpresence.0 (14943) configuration fb-devices true
                      2021-07-10 20:16:52.295 - debug: fb-checkpresence.0 (14943) configuration mesh info: true
                      2021-07-10 20:16:52.295 - debug: fb-checkpresence.0 (14943) configuration whitelist: true
                      2021-07-10 20:16:52.296 - debug: fb-checkpresence.0 (14943) configuration compatibility: true
                      2021-07-10 20:16:52.297 - debug: fb-checkpresence.0 (14943) configuration ssl: true
                      2021-07-10 20:16:52.297 - debug: fb-checkpresence.0 (14943) configuration qr code: false
                      2021-07-10 20:16:52.297 - debug: fb-checkpresence.0 (14943) configuration guest info: true
                      2021-07-10 20:16:52.298 - debug: fb-checkpresence.0 (14943) configuration filter delay: 15
                      2021-07-10 20:16:52.298 - info: fb-checkpresence.0 (14943) configuration default connection: -
                      2021-07-10 20:16:52.298 - warn: fb-checkpresence.0 (14943) Hosts1-X_AVM-DE_GetHostListPath is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.299 - warn: fb-checkpresence.0 (14943) Hosts1-X_AVM-DE_GetMeshListPath is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.299 - info: fb-checkpresence.0 (14943) Hosts1-GetSpecificHostEntry is supported
                      2021-07-10 20:16:52.299 - warn: fb-checkpresence.0 (14943) Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.300 - info: fb-checkpresence.0 (14943) DeviceInfo1-GetSecurityPort is supported
                      2021-07-10 20:16:52.300 - warn: fb-checkpresence.0 (14943) WANCommonInterfaceConfig1-GetCommonLinkProperties is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.300 - warn: fb-checkpresence.0 (14943) WANPPPConnection1-GetInfo is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.301 - warn: fb-checkpresence.0 (14943) WANIPConnection1-GetInfo is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.301 - warn: fb-checkpresence.0 (14943) WLANConfiguration3-SetEnable is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.301 - warn: fb-checkpresence.0 (14943) WLANConfiguration3-GetInfo is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.301 - warn: fb-checkpresence.0 (14943) WLANConfiguration3-GetSecurityKeys is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.302 - warn: fb-checkpresence.0 (14943) DeviceInfo1-GetInfo is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.302 - warn: fb-checkpresence.0 (14943) X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.302 - warn: fb-checkpresence.0 (14943) X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.303 - warn: fb-checkpresence.0 (14943) DeviceConfig1-Reboot is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.303 - warn: fb-checkpresence.0 (14943) WANPPPConnection1-ForceTermination is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.303 - warn: fb-checkpresence.0 (14943) LANConfigSecurity1-X_AVM-DE_GetCurrentUser is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.304 - warn: fb-checkpresence.0 (14943) Layer3Forwarding1-GetDefaultConnectionService is not supported! Feature is deactivated!
                      2021-07-10 20:16:52.337 - warn: fb-checkpresence.0 (14943) In an future version some states are not more existent. Please use compatibility = false to switch to the new handling of the states!
                      2021-07-10 20:16:52.337 - warn: fb-checkpresence.0 (14943) You should then manually delete the old states!
                      2021-07-10 20:16:52.346 - warn: fb-checkpresence.0 (14943) The state "guest" will not longer exist in a future version. Please use "guest.presence" instead!
                      2021-07-10 20:16:52.347 - warn: fb-checkpresence.0 (14943) The state "blacklist" will not longer exist in a future version. Please use "blacklist.presence" instead!
                      2021-07-10 20:16:52.348 - warn: fb-checkpresence.0 (14943) The state "activeDevices" will not longer exist in a future version. Please use "fb-devices.active" instead!
                      2021-07-10 20:16:52.348 - warn: fb-checkpresence.0 (14943) The state "devices" will not longer exist in a future version. Please use "fb-devices.count" instead!
                      2021-07-10 20:16:52.899 - info: fb-checkpresence.0 (14943) createGlobalObjects finished successfully
                      2021-07-10 20:16:53.117 - warn: fb-checkpresence.0 (14943) The state "fb-checkpresence.0.Michaels-iPhone" will not longer exist in a future version. Please use "fb-checkpresence.0.Michaels-iPhone.presence" instead!
                      2021-07-10 20:16:53.259 - debug: fb-checkpresence.0 (14943) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                      2021-07-10 20:16:53.274 - warn: fb-checkpresence.0 (14943) The state "fb-checkpresence.0.Yvonnes-iPhone" will not longer exist in a future version. Please use "fb-checkpresence.0.Yvonnes-iPhone.presence" instead!
                      2021-07-10 20:16:53.438 - debug: fb-checkpresence.0 (14943) sendTo "getEnabledDPs" to system.adapter.influxdb.0 from system.adapter.fb-checkpresence.0
                      2021-07-10 20:16:53.449 - info: fb-checkpresence.0 (14943) createMemberObjects finished successfully
                      2021-07-10 20:16:53.450 - info: fb-checkpresence.0 (14943) states successfully subscribed
                      2021-07-10 20:16:53.451 - info: fb-checkpresence.0 (14943) loop successfully started
                      2021-07-10 20:17:00.464 - debug: fb-checkpresence.0 (14943) loop family ends after 6,13882628 s
                      2021-07-10 20:17:14.481 - warn: fb-checkpresence.0 (14943) getExtIp:
                      2021-07-10 20:17:14.483 - debug: fb-checkpresence.0 (14943) loop main ends after 12,17266068 s
                      Ich hoffe du kannst helfen, vielen Dank.
                      Gruß Michael
                      Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
                      WalW 1 Antwort Letzte Antwort
                      • MichMeinM MichMein
                        Hi @afuerhoff,
                        WalW Offline
                        WalW Offline
                        Wal
                        #596
                        @michmein ,
                        habe die 7.27 auf einer 6490 und den Adaptern tr-64, fb-checkpresence und Fritzdect ohne Probleme am Laufen.
                        Walter
                        DoorIO-Adapter
                        MichMeinM 1 Antwort Letzte Antwort
                        • WalW Wal
                          @michmein ,
                          MichMeinM Offline
                          MichMeinM Offline
                          MichMein
                          schrieb am zuletzt editiert von MichMein
                          #597
                          @wal danke für die Rückmeldung, hilft mir persönlich aber leider nicht wenn es bei dir läuft 😉
                          Ich versuche mal nen Neustart der Fritzbox.
                          Gruß Michael
                            WalW Offline
                            WalW Offline
                            Wal
                            #598
                            @michmein ,
                            das denke ich mir auch, nur afuerhoff wird da auch nichts machen können. Ich lasse mich aber überraschen.
                            Walter
                            DoorIO-Adapter
                            • WalW Wal
                              @michmein ,
                              MichMeinM Offline
                              MichMeinM Offline
                              MichMein
                              #599
                              @wal @afuerhoff
                              Ein Neustart hat das Problem leider nicht behoben, jedoch aber das neu eintragen des bereits korrekt gesetzten Passwortes. Der Adapter ist wieder grün.
                              Schönes Wochenende noch!
                              Gruß Michael
                                @wal @afuerhoff
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #600
                                @michmein
                                Schön das es wieder läuft. Hab deine Message erst heute morgen gesehen. Ich hätte auch erstmal einen Reboot der Fritzbox vorgeschlagen. Wichtig ist dabei, dass der Adapter vorher gestoppt wird.
                                Das mit dem Passwort kann ich mir nicht erklären.
                                Die Konfiguration und somit das Passwort wurden ja nicht zwischenzeitlich verändert. Könnte evtl. mit ioBroker selbst zusammenhängen.
                                Ich nutze die Passwort Funktionalität von ioBroker.
                                • MichMeinM Offline
                                  MichMeinM Offline
                                  MichMein
                                  #601
                                  Hi @afuerhoff,
                                  meine Aussage dass es klappt nach dem ich das Passwort neu eingegeben habe muss ich leider zurück nehmen.
                                  Folgendes habe ich gemacht nachdem ich gesehen hatte das der Adapter nicht lief,
                                  1. Adapter gestoppt, alle Objekte gelöscht, Adapter auf Debug gestellt, Passwort neu eingetragen, Adapter gestartet. Ergebnis > Adapter bleibt orange
                                  2. Adapter gestoppt, alle Objekte gelöscht, Adapter auf Debug gestellt, Eintrag unter Username gelöscht, Adapter gestartet. Ergebnis > Adapter wird grün aber die Objekte werden nicht aktualisiert
                                  3. Adapter gestoppt, alle Objekte gelöscht, Adapter auf Debug gestellt, neuen User in FritzBox angelegt und die Daten im Adapter neu eingetragen, Adapter gestartet. Ergebnis > Adapter bleibt orange
                                  So, während ich jetzt hier geschrieben habe, habe ich nebenbei noch etwas getestet und siehe da nachdem ich SSL deaktiviert hatte klappt es wieder alles und der Adapter wird grün und auch die Objekte werden erstellt und aktualisiert.
                                  Hast du eine Idee warum das so gewesen sein kann?
                                  SSL war sonst die ganze Zeit aktiv und es hat alles funktioniert bis zum kürzlich durchgeführten Update.
                                  Gruß Michael
                                    Hi @afuerhoff,
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #602
                                    @michmein sagte in Test Adapter fb-checkpresence v1.1.x:
                                    Hilfreich wäre noch die Log Ausgabe gewesen, damit man erkennen kann wo der Adapter hängen bleibt.
                                    Das mit dem SSL ist ein Workaround für einen anderen User gewesen, der auch Probleme hatte. Warum das so ist, kann ich nicht wirklich sagen.
                                      mumurik
                                      #603
                                      @afuerhoff
                                      eine Frage, wäre es möglich mit dem Adapter auch die Ticketliste (unter Fritzbox-Internet-Filter-Zugangsprofile) darzustellen, so dass die Tickets in zB einzelne Datenobjekte geschrieben werden könnten?
                                      • M mumurik
                                        @afuerhoff
                                        afuerhoffA Offline
                                        afuerhoffA Offline
                                        afuerhoff
                                        #604
                                        @mumurik
                                        Die Frage wurde oben weiter schon gestellt und auch die Lösung mit dem TR064 Adapter gefunden.
                                        Post 567
                                          @mumurik
                                          Post 567
                                          mumurik
                                          #605
                                          @afuerhoff
                                          super, danke! Habe ich glatt übersehen...
