  4. BackItUp für InfluxDB
    1.0k
backitup influxdb
273 Beiträge 32 Kommentatoren 77.6k Aufrufe 28 Beobachtet
  • MassiveAttackM MassiveAttack
    @simatec said in BackItUp für InfluxDB:
    @massiveattack
    Was geben folgenden Konsolenbefehle bei dir aus?
     curl -k -H "Authorization: Bearer deinAPIKey" http://deineIP:3000/api/search
    [{"id":6,"uid":"H0MPaYZRz","title":"ENERGY","uri":"db/energy","url":"/d/H0MPaYZRz/energy","slug":"","type":"dash-db","tags":[],"isStarred":false,"sortMeta":0},{"id":4,"uid":"92wFUskRz","title":"HEATPUMP","uri":"db/heatpump","url":"/d/92wFUskRz/heatpump","slug":"","type":"dash-db","tags":[],"isStarred":false,"sortMeta":0},{"id":5,"uid":"bJgHQszRk","title":"WEATHER","uri":"db/weather","url":"/d/bJgHQszRk/weather","slug":"","type":"dash-db","tags":[],"isStarred":false,"sortMeta":0}]
     curl -s "http://deineIP:3000/api/datasources" -u admin:deinPasswort
    [{"id":1,"uid":"21vzeokgz","orgId":1,"name":"ioBroker","type":"influxdb","typeName":"InfluxDB","typeLogoUrl":"public/app/plugins/datasource/influxdb/img/influxdb_logo.svg","access":"proxy","url":"http://192.168.0.80:8086","password":"","user":"root","database":"iobroker","basicAuth":false,"isDefault":true,"jsonData":{},"readOnly":false},{"id":2,"uid":"KeyuCGRRz","orgId":1,"name":"MetaQueries","type":"goshposh-metaqueries-datasource","typeName":"goshposh-metaqueries-datasource","typeLogoUrl":"public/img/icn-datasource.svg","access":"proxy","url":"","password":"","user":"","database":"","basicAuth":false,"isDefault":false,"jsonData":{},"readOnly":false}]
    MassiveAttackM Offline
    MassiveAttack
    #141
    curl -H "Authorization: Bearer eyJrIjoiU3Zmd0p0N2h5VVhGZW1OSDk2MmJJSjhreWJpNDgyNloiLCJuIjoiYWRtaW4iLCJpZCI6MX0=" http://192.168.0.10
    :3000/api/dashboards/home
    {"meta":{"isHome":true,"canSave":false,"canEdit":true,"canAdmin":false,"canStar":false,"slug":"","url":"","expires":"0001-01-01T00:00:00Z","created":"0001-01-01T00:00:00Z","updated":"0001-01-01T00:00:00Z","updatedBy":"","createdBy":"","version":0,"hasAcl":false,"isFolder":false,"folderId":0,"folderUid":"","folderTitle":"General","folderUrl":"","provisioned":false,"provisionedExternalId":""},"dashboard":{"links":[],"panels":[{"datasource":null,"gridPos":{"h":3,"w":24,"x":0,"y":0},"id":1,"title":"","transparent":false,"type":"welcome"},{"datasource":null,"folderId":0,"gridPos":{"h":15,"w":12,"x":0,"y":4},"headings":true,"id":3,"limit":30,"links":[],"options":{},"query":"","recent":true,"search":false,"starred":true,"tags":[],"title":"Dashboards","type":"dashlist"},{"datasource":null,"gridPos":{"h":15,"w":12,"x":12,"y":4},"id":4,"links":[],"options":{"feedUrl":"https://grafana.com/blog/news.xml"},"title":"Latest from the blog","type":"news"},{"gridPos":{"h":9,"w":24,"x":0,"y":3},"id":123123,"type":"gettingstarted"}],"schemaVersion":22,"tags":[],"templating":{"list":[]},"time":{"from":"now-6h","to":"now"},"timepicker":{"hidden":true,"refresh_intervals":["5s","10s","30s","1m","5m","15m","30m","1h","2h","1d"],"time_options":["5m","15m","1h","6h","12h","24h","2d","7d","30d"],"type":"timepicker"},"timezone":"browser","title":"Home"}}
      @massiveattack
      simatecS Offline
      simatecS Offline
      simatec
      #142
      @massiveattack sagte in BackItUp für InfluxDB:
      energy
      Was gibt folgender Befehl aus?
      curl -k -H "Authorization: Bearer deinAPIKEY" http://deineIP/api/dashboards/db/energy
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      MassiveAttackM 1 Antwort Letzte Antwort
      • simatecS simatec
        energy
        MassiveAttack
        #143
        @simatec
        {"message":"Not found"}
          @simatec
          simatecS Offline
          simatecS Offline
          simatec
          #144
          @massiveattack
          sorry Port vergessen
          curl -k -H "Authorization: Bearer deinAPIKEY" http://deineIP:3000/api/dashboards/db/energy
          • simatecS simatec
            @massiveattack
            MassiveAttack
            #145
            @simatec
            ich habe es eh richtig abgefragt mit port, er findet nix
              @simatec
              simatecS Offline
              simatecS Offline
              simatec
              #146
              @massiveattack
              Dann liegt dein Problem in Grafana selber.
              Mit dem Befehl solltest du die json deines energy Dashboard als Ausgabe bekommen
              • simatecS simatec
                @massiveattack
                MassiveAttack
                #147
                @simatec
                ja, aber was genau ist der fehler? ist es ein berechtigungsproblem? kann er die db nicht finde? wo müsste das liegen?
                  @simatec
                  MassiveAttack
                  #148
                  @massiveattack
                  sollte eigentlich richtig in var/lib/grafana/ liegen. braucht das file spezielle zugriffsrechte?
                    @massiveattack
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #149
                    @massiveattack Ich habe mir die API von Grafana 8 mal angeschaut.
                    Da wurde etwas geändert, so dass ein Zugriff auf die Dashboards nur noch per "uid" möglich ist.
                    Die Backitup Version 2.1.13 ist darauf angepasst und kommt gerade ins latest.
                    • simatecS simatec
                      MassiveAttack
                      #150
                      @simatec
                      ahh vielen dank :)
                      werde ich testen sobald verfügbar
                      • MassiveAttackM Offline
                        MassiveAttack
                        #151
                        @massiveattack
                        test erfolgreich :)
                        danke nochmals
                          @massiveattack
                          test erfolgreich :)
                          danke nochmals
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #152
                          @massiveattack Kein Problem ;-)
                          • simatecS simatec
                            Mike Hellracer
                            #153
                            der Standard Backup der influxdb funktioniert bei mir ohne Probleme.
                            Da ich jedoch mehrere DB und der influxdb Instanz sichern wollte habe ich die versucht die Option 'mehrere Systeme' zu verwenden. Leider habe ich es scheinbar nicht geschafft den Pfad richtig anzugeben.
                            Mein Pfad zu den DB auf dem lokalen System ist: /var/lib/influxdb/data/<nane der db>
                            Was muss ich unter "vollständiger Pfad" angeben damit das geht?
                            • M Mike Hellracer
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #154
                              @mike-hellracer
                              Den Pfad kannst du normalerweise freilassen. Der ist nur dafür gedacht, falls deine influxd nicht in /usr/bin installiert ist. Also Standard ist einfach leer lassen. Das hat nichts mit einem Pfad zur DB zu tun
                              M G 2 Antworten Letzte Antwort
                              • simatecS simatec
                                @mike-hellracer
                                Mike Hellracer
                                #155
                                @simatec
                                Ja, soweit funktioniert es ja auch.
                                Aber ich habe 2 Datenbanken, welche ich sichern will.
                                Was muss ich nach dem aktivieren von 'mehrere Systeme' unter Pfad angeben?
                                • M Mike Hellracer
                                  @simatec
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #156
                                  @mike-hellracer
                                  Wie schon im letzten Post geschrieben musst du nichts eintragen. Das ist optional. Nur den DB Namen musst du eintragen und wenn Remote Backup, dann noch IP und Port
                                  • simatecS simatec
                                    @mike-hellracer
                                    Mike Hellracer
                                    #157
                                    @simatec
                                    Danke jetzt geht es.
                                    Habe noch ein Problem.
                                    Seit dem letzten Update habe ich kein Register mehr für Javascript.
                                    • M Mike Hellracer
                                      @simatec
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #158
                                      @mike-hellracer Für das Backup deiner Scripte werde keine Einstellungen oder Spiegelungen mehr benötigt.
                                      Backitup löst das alleine
                                      • FreunderNachtF Offline
                                        FreunderNacht
                                        #159
                                        ich stehe gerade vor dem Upgrade der InfluxDB von 1.7 auf 2.3.
                                        Ich habe vor die alte (1.7) zu löschen und die neue (2.3) zu installieren.
                                        Kann ich die Daten, die ich mit Backitup von der 1.7 gesichert habe, dann wieder in der Version 2.3 wieder herstellen?
                                        Ich habe gelesen, daß ein direktes Backup der 1.7 DB sich nicht in die 2.3 importieren lässt.
                                        Hat das schon einer mal versucht?
                                        Wie kann ich nur ein Backup der InfluxDB wieder herstellen?
                                        Freund der Nacht
                                        Intel NUC mit Proxmox
                                        IO Broker (Homematic IP / CCU3 / Shelly / Tasmota / Zigbee)
                                        Influx DB
                                        Grafana
                                        PiHole
                                        PiVPN
                                        • FreunderNachtF FreunderNacht
                                          Freund der Nacht
                                          #160
                                          @freundernacht
                                          Die offizielle Doku kennst du?
                                          https://docs.influxdata.com/influxdb/v2.3/upgrade/v1-to-v2/
                                          FreunderNachtF 1 Antwort Letzte Antwort
