  • B bishop
    @foxro
    ich habe etwas ähnliches! Das hat alles mal funktioniert.
    hier mal ein Log:
    2021-06-08 06:00:00.075 - info: shuttercontrol.0 (31678) #21 Set ID: Kim value: 100%
    2021-06-08 06:00:00.076 - debug: shuttercontrol.0 (31678) shutterUpSleep #1 Kim old height: 0% new height: 100%
    2021-06-08 06:00:00.086 - debug: shuttercontrol.0 (31678) Shutter state changed: Kim old value = 0 new value = 100
    2021-06-08 06:00:00.086 - debug: shuttercontrol.0 (31678) Kim Old value = 0. New value = 100. automatic is active
    2021-06-08 06:00:00.260 - debug: shuttercontrol.0 (31678) outsidetemperature changed: alias.0.Temperaturen.Hochbeet Value: 15.6
    2021-06-08 06:00:05.035 - info: shuttercontrol.0 (31678) #21 Set ID: Schlafzimmer value: 100%
    2021-06-08 06:00:05.036 - debug: shuttercontrol.0 (31678) shutterUpSleep #1 Schlafzimmer old height: 0% new height: 100%
    2021-06-08 06:00:05.044 - debug: shuttercontrol.0 (31678) Shutter state changed: Schlafzimmer old value = 0 new value = 100
    2021-06-08 06:00:05.044 - debug: shuttercontrol.0 (31678) Schlafzimmer Old value = 0. New value = 100. automatic is active
    2021-06-08 06:00:05.083 - info: javascript.0 (1038) script.js.common.Kinder_Licht: Licht von Kim ausgeschalten
    2021-06-08 06:00:10.029 - info: shuttercontrol.0 (31678) #21 Set ID: Jan value: 100%
    2021-06-08 06:00:10.029 - debug: shuttercontrol.0 (31678) shutterUpSleep #1 Jan old height: 0% new height: 100%
    2021-06-08 06:00:10.036 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 100
    2021-06-08 06:00:10.036 - debug: shuttercontrol.0 (31678) Jan Old value = 0. New value = 100. automatic is active
    2021-06-08 06:00:11.086 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 1
    2021-06-08 06:00:11.086 - debug: shuttercontrol.0 (31678) Jan drived manually to 1. Old value = 0. New value = 1
    2021-06-08 06:00:11.086 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:13.083 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 2
    2021-06-08 06:00:13.083 - debug: shuttercontrol.0 (31678) Jan drived manually to 2. Old value = 0. New value = 2
    2021-06-08 06:00:13.083 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:14.028 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 3
    2021-06-08 06:00:14.028 - debug: shuttercontrol.0 (31678) Jan drived manually to 3. Old value = 0. New value = 3
    2021-06-08 06:00:14.028 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:15.030 - info: shuttercontrol.0 (31678) #21 Set ID: Balkon value: 100%
    2021-06-08 06:00:15.030 - debug: shuttercontrol.0 (31678) shutterUpSleep #1 Balkon old height: 0% new height: 100%
    2021-06-08 06:00:15.036 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 100
    2021-06-08 06:00:15.036 - debug: shuttercontrol.0 (31678) Balkon Old value = 0. New value = 100. automatic is active
    2021-06-08 06:00:15.072 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 4
    2021-06-08 06:00:15.072 - debug: shuttercontrol.0 (31678) Jan drived manually to 4. Old value = 0. New value = 4
    2021-06-08 06:00:15.072 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:15.753 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 1
    2021-06-08 06:00:15.753 - debug: shuttercontrol.0 (31678) Balkon drived manually to 1. Old value = 0. New value = 1
    2021-06-08 06:00:15.754 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:16.012 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 5
    2021-06-08 06:00:16.012 - debug: shuttercontrol.0 (31678) Jan drived manually to 5. Old value = 0. New value = 5
    2021-06-08 06:00:16.012 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:16.763 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 5
    2021-06-08 06:00:16.763 - debug: shuttercontrol.0 (31678) Balkon drived manually to 5. Old value = 0. New value = 5
    2021-06-08 06:00:16.764 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:17.062 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 8
    2021-06-08 06:00:17.062 - debug: shuttercontrol.0 (31678) Jan drived manually to 8. Old value = 0. New value = 8
    2021-06-08 06:00:17.062 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:17.762 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 8
    2021-06-08 06:00:17.762 - debug: shuttercontrol.0 (31678) Balkon drived manually to 8. Old value = 0. New value = 8
    2021-06-08 06:00:17.763 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:18.126 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 15
    2021-06-08 06:00:18.126 - debug: shuttercontrol.0 (31678) Jan drived manually to 15. Old value = 0. New value = 15
    2021-06-08 06:00:18.126 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:18.763 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 11
    2021-06-08 06:00:18.763 - debug: shuttercontrol.0 (31678) Balkon drived manually to 11. Old value = 0. New value = 11
    2021-06-08 06:00:18.763 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:19.047 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 21
    2021-06-08 06:00:19.047 - debug: shuttercontrol.0 (31678) Jan drived manually to 21. Old value = 0. New value = 21
    2021-06-08 06:00:19.047 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:19.765 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 14
    2021-06-08 06:00:19.765 - debug: shuttercontrol.0 (31678) Balkon drived manually to 14. Old value = 0. New value = 14
    2021-06-08 06:00:19.765 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:20.188 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 28
    2021-06-08 06:00:20.188 - debug: shuttercontrol.0 (31678) Jan drived manually to 28. Old value = 0. New value = 28
    2021-06-08 06:00:20.189 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:20.239 - debug: shuttercontrol.0 (31678) outsidetemperature changed: alias.0.Temperaturen.Hochbeet Value: 15.8
    2021-06-08 06:00:20.767 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 17
    2021-06-08 06:00:20.767 - debug: shuttercontrol.0 (31678) Balkon drived manually to 17. Old value = 0. New value = 17
    2021-06-08 06:00:20.767 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:21.043 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 34
    2021-06-08 06:00:21.043 - debug: shuttercontrol.0 (31678) Jan drived manually to 34. Old value = 0. New value = 34
    2021-06-08 06:00:21.043 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:21.761 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 20
    2021-06-08 06:00:21.762 - debug: shuttercontrol.0 (31678) Balkon drived manually to 20. Old value = 0. New value = 20
    2021-06-08 06:00:21.762 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:22.095 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 41
    2021-06-08 06:00:22.095 - debug: shuttercontrol.0 (31678) Jan drived manually to 41. Old value = 0. New value = 41
    2021-06-08 06:00:22.096 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:22.767 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 24
    2021-06-08 06:00:22.767 - debug: shuttercontrol.0 (31678) Balkon drived manually to 24. Old value = 0. New value = 24
    2021-06-08 06:00:22.767 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:23.074 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 47
    2021-06-08 06:00:23.075 - debug: shuttercontrol.0 (31678) Jan drived manually to 47. Old value = 0. New value = 47
    2021-06-08 06:00:23.075 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:23.768 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 27
    2021-06-08 06:00:23.768 - debug: shuttercontrol.0 (31678) Balkon drived manually to 27. Old value = 0. New value = 27
    2021-06-08 06:00:23.768 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:24.141 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 54
    2021-06-08 06:00:24.141 - debug: shuttercontrol.0 (31678) Jan drived manually to 54. Old value = 0. New value = 54
    2021-06-08 06:00:24.141 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:24.769 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 30
    2021-06-08 06:00:24.770 - debug: shuttercontrol.0 (31678) Balkon drived manually to 30. Old value = 0. New value = 30
    2021-06-08 06:00:24.770 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:25.029 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 60
    2021-06-08 06:00:25.029 - debug: shuttercontrol.0 (31678) Jan drived manually to 60. Old value = 0. New value = 60
    2021-06-08 06:00:25.029 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:25.719 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 33
    2021-06-08 06:00:25.719 - debug: shuttercontrol.0 (31678) Balkon drived manually to 33. Old value = 0. New value = 33
    2021-06-08 06:00:25.719 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:26.067 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 66
    2021-06-08 06:00:26.067 - debug: shuttercontrol.0 (31678) Jan drived manually to 66. Old value = 0. New value = 66
    2021-06-08 06:00:26.067 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:26.726 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 36
    2021-06-08 06:00:26.726 - debug: shuttercontrol.0 (31678) Balkon drived manually to 36. Old value = 0. New value = 36
    2021-06-08 06:00:26.726 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:27.115 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 73
    2021-06-08 06:00:27.115 - debug: shuttercontrol.0 (31678) Jan drived manually to 73. Old value = 0. New value = 73
    2021-06-08 06:00:27.115 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:27.729 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 39
    2021-06-08 06:00:27.729 - debug: shuttercontrol.0 (31678) Balkon drived manually to 39. Old value = 0. New value = 39
    2021-06-08 06:00:27.729 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:28.055 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 79
    2021-06-08 06:00:28.055 - debug: shuttercontrol.0 (31678) Jan drived manually to 79. Old value = 0. New value = 79
    2021-06-08 06:00:28.055 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:28.732 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 43
    2021-06-08 06:00:28.732 - debug: shuttercontrol.0 (31678) Balkon drived manually to 43. Old value = 0. New value = 43
    2021-06-08 06:00:28.732 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:29.099 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 86
    2021-06-08 06:00:29.099 - debug: shuttercontrol.0 (31678) Jan drived manually to 86. Old value = 0. New value = 86
    2021-06-08 06:00:29.099 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:29.727 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 46
    2021-06-08 06:00:29.727 - debug: shuttercontrol.0 (31678) Balkon drived manually to 46. Old value = 0. New value = 46
    2021-06-08 06:00:29.727 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:30.043 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 92
    2021-06-08 06:00:30.043 - debug: shuttercontrol.0 (31678) Jan drived manually to 92. Old value = 0. New value = 92
    2021-06-08 06:00:30.043 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:30.731 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 49
    2021-06-08 06:00:30.731 - debug: shuttercontrol.0 (31678) Balkon drived manually to 49. Old value = 0. New value = 49
    2021-06-08 06:00:30.731 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:31.087 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 99
    2021-06-08 06:00:31.088 - debug: shuttercontrol.0 (31678) Jan drived manually to 99. Old value = 0. New value = 99
    2021-06-08 06:00:31.088 - debug: shuttercontrol.0 (31678) Jan Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:31.314 - debug: shuttercontrol.0 (31678) Shutter state changed: Jan old value = 0 new value = 100
    2021-06-08 06:00:31.314 - debug: shuttercontrol.0 (31678) Jan Old value = 0. New value = 100. automatic is active
    2021-06-08 06:00:31.740 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 52
    2021-06-08 06:00:31.741 - debug: shuttercontrol.0 (31678) Balkon drived manually to 52. Old value = 0. New value = 52
    2021-06-08 06:00:31.741 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:32.732 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 55
    2021-06-08 06:00:32.732 - debug: shuttercontrol.0 (31678) Balkon drived manually to 55. Old value = 0. New value = 55
    2021-06-08 06:00:32.732 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:33.732 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 58
    2021-06-08 06:00:33.732 - debug: shuttercontrol.0 (31678) Balkon drived manually to 58. Old value = 0. New value = 58
    2021-06-08 06:00:33.732 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:34.732 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 62
    2021-06-08 06:00:34.732 - debug: shuttercontrol.0 (31678) Balkon drived manually to 62. Old value = 0. New value = 62
    2021-06-08 06:00:34.732 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:35.732 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 65
    2021-06-08 06:00:35.732 - debug: shuttercontrol.0 (31678) Balkon drived manually to 65. Old value = 0. New value = 65
    2021-06-08 06:00:35.732 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:36.312 - info: javascript.0 (1038) script.js.common.Kinder_Licht: Licht von Jan ausgeschalten
    2021-06-08 06:00:37.042 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 68
    2021-06-08 06:00:37.043 - debug: shuttercontrol.0 (31678) Balkon drived manually to 68. Old value = 0. New value = 68
    2021-06-08 06:00:37.043 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:37.731 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 71
    2021-06-08 06:00:37.732 - debug: shuttercontrol.0 (31678) Balkon drived manually to 71. Old value = 0. New value = 71
    2021-06-08 06:00:37.732 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:38.738 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 74
    2021-06-08 06:00:38.738 - debug: shuttercontrol.0 (31678) Balkon drived manually to 74. Old value = 0. New value = 74
    2021-06-08 06:00:38.739 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:39.569 - info: alexa2.0 (5677) Alexa-Push-Connection established. Disable Polling
    2021-06-08 06:00:39.741 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 77
    2021-06-08 06:00:39.741 - debug: shuttercontrol.0 (31678) Balkon drived manually to 77. Old value = 0. New value = 77
    2021-06-08 06:00:39.741 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:40.748 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 81
    2021-06-08 06:00:40.748 - debug: shuttercontrol.0 (31678) Balkon drived manually to 81. Old value = 0. New value = 81
    2021-06-08 06:00:40.748 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:41.745 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 84
    2021-06-08 06:00:41.745 - debug: shuttercontrol.0 (31678) Balkon drived manually to 84. Old value = 0. New value = 84
    2021-06-08 06:00:41.745 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:42.745 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 87
    2021-06-08 06:00:42.745 - debug: shuttercontrol.0 (31678) Balkon drived manually to 87. Old value = 0. New value = 87
    2021-06-08 06:00:42.746 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:43.747 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 90
    2021-06-08 06:00:43.747 - debug: shuttercontrol.0 (31678) Balkon drived manually to 90. Old value = 0. New value = 90
    2021-06-08 06:00:43.747 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:44.755 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 93
    2021-06-08 06:00:44.755 - debug: shuttercontrol.0 (31678) Balkon drived manually to 93. Old value = 0. New value = 93
    2021-06-08 06:00:44.755 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:45.749 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 97
    2021-06-08 06:00:45.749 - debug: shuttercontrol.0 (31678) Balkon drived manually to 97. Old value = 0. New value = 97
    2021-06-08 06:00:45.749 - debug: shuttercontrol.0 (31678) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
    2021-06-08 06:00:46.803 - debug: shuttercontrol.0 (31678) Shutter state changed: Balkon old value = 0 new value = 100
    2021-06-08 06:00:46.803 - debug: shuttercontrol.0 (31678) Balkon Old value = 0. New value = 100. automatic is active
    Warum funktioniert es beim Rollladen Kim und Schlafzimmer?
    Hatte vermutet das was mit den Aliases nicht stimmt und habe somit direkt verknüpft.
            "enabled": true,
            "shutterName": "Balkon",
            "name": "sonoff.0.RolladenBalkon.ShutterPosition1",
            "triggerID": "alias.0.Tueren.Balkontuer",
            "typeUp": "sleep",
            "typeDown": "goldenhour",
            "type": "in- & outside temperature and direction",
            "heightDownSun": "30",
            "direction": "245",
            "directionRange": "50",
            "tempInside": "24",
            "tempSensor": "",
            "outsideTempSensor": "alias.0.Temperaturen.Hochbeet",
            "tempOutside": "25",
            "lightSensor": "",
            "valueLight": "15",
            "heightUp": "100",
            "heightDown": "0",
            "triggerState": "0",
            "triggerDrive": "100",
            "triggerChange": "onlyUp",
            "elevation": "8",
            "autoDrive": "off",
            "hysteresisOutside": "10",
            "hysteresisInside": "5",
            "hysteresisLight": "5",
            "currentAction": "",
            "currentHeight": "",
            "oldHeight": "",
            "firstCompleteUp": "",
            "triggerHeight": "",
            "LateDown": false,
            "inSummerNotDown": false,
            "KeepSunProtect": true,
            "triggerAction": "",
            "driveAfterClose": false,
            "useXmasLevel": false,
            "XmasLevel": "",
            "betweenPosition": false,
            "betweenPositionLevel": "",
            "trigDelyUp": "",
            "trigDelyDown": ""
            "enabled": true,
            "shutterName": "Kim",
            "name": "alias.0.Rolllaeden.Kim",
            "triggerID": "alias.0.Fenster.Kim_Zimmer_Fenster",
            "typeUp": "sleep",
            "typeDown": "sleep",
            "type": "outside temperature and direction",
            "heightDownSun": "3",
            "direction": "245",
            "directionRange": "55",
            "tempInside": "",
            "tempSensor": "",
            "lightSensor": "",
            "valueLight": "",
            "heightUp": "100",
            "heightDown": "0",
            "triggerDrive": "10",
            "elevation": "",
            "autoDrive": "upDown",
            "hysteresisInside": "",
            "hysteresisLight": "",
            "oldHeight": "",
            "LateDown": false,
            "XmasLevel": "",
            "trigDelyUp": "",
            "trigDelyDown": ""
    Konfig:
      "native": {
        "livingAutomatic": "livingGoldenHour",
        "W_shutterDownLiving": "20:00",
        "W_shutterUpLivingMin": "06:00",
        "W_shutterUpLivingMax": "07:00",
        "driveDelayUpLiving": "2",
        "WE_shutterDownLiving": "20:00",
        "WE_shutterUpLivingMin": "07:00",
        "WE_shutterUpLivingMax": "08:30",
        "sleepAutomatic": "sleepSunriseSunset",
        "W_shutterDownSleep": "19:00",
        "W_shutterUpSleepMin": "06:00",
        "W_shutterUpSleepMax": "06:00",
        "driveDelayUpSleep": "5",
        "WE_shutterDownSleep": "19:15",
        "WE_shutterUpSleepMin": "08:00",
        "WE_shutterUpSleepMax": "08:00",
        "childrenAutomatic": "childrenSunriseSunset",
        "W_shutterDownChildren": "19:00",
        "W_shutterUpChildrenMin": "06:00",
        "W_shutterUpChildrenMax": "06:30",
        "driveDelayUpChildren": "10",
        "WE_shutterDownChildren": "19:14",
        "WE_shutterUpChildrenMin": "08:00",
        "WE_shutterUpChildrenMax": "08:30",
        "latitude": "49.18669",
        "longitude": "9.23639",
        "sunProtEndElevation": "",
        "astroDelayUp": "0",
        "astroDelayDown": "0",
        "driveDelayUpAstro": "2",
        "SummerStart": "01.03.",
        "SummerEnd": "30.09.",
        "XMasStart": "01.12.",
        "XMasEnd": "06.01.",
        "publicHolidays": true,
        "publicHolInstance": "feiertage.0",
        "HolidayDP": "",
        "lightsensorDown": "250",
        "lightsensorUp": "500",
        "lightsensorUpDown": "alias.0.Helligkeit.hinten",
        "schoolfree": false,
        "schoolfreeInstance": "",
        "schoolfreeChildrenArea": true,
        "schoolfreeSleepArea": false,
        "schoolfreeLivingArea": false,
        "LateAllDown": false,
        "LateAllDownTime": "22:15",
        "betweenPositionTime": "22:00",
        "noGoTime": "0",
        "currentShutterState": true,
        "currentShutterStateTime": "35",
        "triggerAutoSleep": "",
        "triggerAutoLiving": "",
        "triggerAutoChildren": "",
        "direction": "245",
        "actualValueTemp": "alias.0.Temperaturen.Hochbeet",
        "actualValueLight": "",
        "actualValueTempInside": "fritzdect.0.DECT_087610171751.celsius",
        "typeUp": "sleep",
        "triggerStateShutter": "0",
        "triggerChangeShutter": "onlyUp",
        "triggerDriveShutter": "10",
        "autoDriveShutter": "upDown",
        "heightDownShutter": "0",
        "heightUpShutter": "100",
        "triggerID": "alias.0.Fenster.Schlafzimmer_Fenster",
        "LateDown": false,
        "XmasLevel": "",
        "trigDelyUp": "",
        "trigDelyDown": "",
        "events": [
    alias.0.Rolllaeden.Kim = sonoff.0.RolladenKim.ShutterPosition1.
    ShutterPosition1 ändert sich so wie der Rolladen steht, sieht man ja auch in den Logs.
    Mir wurde empfohlen mit der Option "Überprüfen des aktuellen Rollladenstatus" zu experimentieren.
    Habe ich gemacht aber ich sehe keine Änderung, wie man in den Log´s sieht. Haken ist gesetzt und 35sek eingestellt, somit sollte Automatic aktiv sein.
    Ist es aber nicht stehen auf Manu_Mode...
    was kann ich noch tun um das Problem in den Griff zu bekommen!?! Ist da wo ein BUG.
    Das hatte mal funktioniert, kann aber nicht genau sagen welche Version das war.
    simatecS Offline
    simatecS Offline
    simatec
    #3151
    @bishop sagte in Test Adapter shuttercontrol v1.2.x:
    Stelle mal die Zeit zur Prüfung höher ... Eventuell mal auf 60 Sekunden gehen
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      bishop
      schrieb am zuletzt editiert von bishop
      #3152
      @simatec
      hatte ich auch schon drin.
      Werde es nochmal auf 60sek machen, mal schauen wie es morgen aussieht!
      Ein simulieren Button wäre nicht schlecht :)
      • B bishop
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        #3153
        @bishop Welchen Wert haben denn die beiden Objekte "alias.0.Rolllaeden.Kim" "sonoff.0.RolladenKim.ShutterPosition1"?
        • simatecS simatec
          bishop
          #3154
          @simatec
          Alias Kim hat den Wert 100 %.
          ShutterPosition1 hat den Wert 100
          • B bishop
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            #3155
            @bishop Laut deinem Log benötigen die Rollläden Jan und Balkon länger als 35 Sekunden, um auf den Endwert zu kommen.
            Stelle die Überprüfung mal auf 100 oder 120 Sekunden
            B 2 Antworten Letzte Antwort
            • simatecS simatec
              bishop
              #3156
              @simatec
              Ok, danke werde ich umstellen.
              • F FoxRo
                @tolkin said in Test Adapter shuttercontrol v1.2.x:
                TriggerID changed: hm-rpc.1.0007DA49A8BE5F.1.STATE Value: 0
                Sowas habe ich noch nicht gesehen - sorry.
                um 2021-06-07 22:27:13.394 wechselt der Trigger auf Wert "2"
                um 2021-06-07 22:27:13.492 fährt er nach oben los...
                und nur 4Sek. später ändert der Trigger wieder auf Wert "0" obwohl noch keine Endlage erreicht wurde.
                Um 2021-06-07 22:27:18.881 also wieder 5Sek später wird ein Pos-Levelstatus "18" gemeldet, was nicht der Vorgabe 100% entspricht, weshalb er in den Manu_Mode wechselt und die aktuelle Position speichert.
                2 Sek. später kommt ein neuer Pos. Wert 24.
                Danach kommt wieder Fenster geöffnet und nur 4Sek. später wieder geschlossen. Er fährt dann nicht runter, weil die aktuelle Pos. als manuell angefahrene Pos. gespeichert wurde, als wärst Du eben bei offenem Fenster manuell dahin gefahren, was Shuttercontrol als "Vorgabe" nimmt.
                Also wenn nicht Du da ungeduldig das Fenster auf und zu gemacht hast und zwischendurch auch noch manuell gefahren bist, würde ich sagen, da gibt es ein Status Update Problem von der HM Seite. Da muss ich dann aber leider passen, da ich HM komplett nicht kenne. Aber vielleicht kann Dir hier sonst jemand helfen, der auch HM hat?
                Sorry.
                Viel Erfolg
                TolkinT Offline
                TolkinT Offline
                Tolkin
                #3157
                @foxro
                Du hast Recht, ich habe etwas wild rauf/runter geklickt und auch manuell dazwischen gefunkt. Jetzt habe ich es gerade nochmal gemacht. Meine Einstellungen sehen wie folgt aus
                Das Debug.log
                Rollo wurde manuell heruntergefahren und der Griff geöffnet, dass Rollo fuhr hoch. Beim schließen ist nichts passiert.
                2021-06-08 21:44:17.179 - debug: shuttercontrol.0 (6284) TriggerID changed: hm-rpc.1.0007DA49A8BE5F.1.STATE Value: 2
                2021-06-08 21:44:17.181 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - shutter conversion is:false
                2021-06-08 21:44:17.226 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - shutter trigger drive-up is:100
                2021-06-08 21:44:17.226 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - shutter trigger change is:upDown
                2021-06-08 21:44:17.226 - debug: shuttercontrol.0 (6284) #1 save trigger height: 0% for device Rollade Esszimmer
                2021-06-08 21:44:17.226 - debug: shuttercontrol.0 (6284) #1 save trigger action: Manu_Mode for device Rollade Esszimmer
                2021-06-08 21:44:17.226 - info: shuttercontrol.0 (6284) #1 Set ID: Rollade Esszimmer value: 100%
                2021-06-08 21:44:17.270 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - window is still open -> driving now to :100
                2021-06-08 21:44:17.278 - debug: shuttercontrol.0 (6284) Shutter state changed: Rollade Esszimmer old value = 0 new value = 100
                2021-06-08 21:44:17.278 - debug: shuttercontrol.0 (6284) Rollade Esszimmer Old value = 0. New value = 100. automatic is active
                2021-06-08 21:44:46.891 - debug: shuttercontrol.0 (6284) Shutter state changed: Rollade Esszimmer old value = 0 new value = 100
                2021-06-08 21:44:46.891 - debug: shuttercontrol.0 (6284) Rollade Esszimmer Old value = 0. New value = 100. automatic is active
                2021-06-08 21:44:51.593 - debug: shuttercontrol.0 (6284) TriggerID changed: hm-rpc.1.0007DA49A8BE5F.1.STATE Value: 0
                2021-06-08 21:44:51.594 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - shutter conversion is:false
                2021-06-08 21:44:51.638 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - shutter current state.val is:100
                2021-06-08 21:44:51.638 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - shutter trigger drive-up is:100
                2021-06-08 21:44:51.638 - debug: shuttercontrol.0 (6284) Rollade Esszimmer - shutter trigger change is:upDown
                2021-06-08 21:44:51.638 - debug: shuttercontrol.0 (6284) #2 save trigger height: 100% for device: Rollade Esszimmer
                2021-06-08 21:44:51.638 - debug: shuttercontrol.0 (6284) #2 save trigger action: triggered for device: Rollade Esszimmer
                2021-06-08 21:45:00.005 - debug: shuttercontrol.0 (6284) calculate astrodata ...
                2021-06-08 21:45:00.009 - debug: shuttercontrol.0 (6284) Sun Azimut: 309°
                2021-06-08 21:45:00.009 - debug: shuttercontrol.0 (6284) Sun Elevation: -0.4°
                F 1 Antwort Letzte Antwort
                • simatecS simatec
                  bishop
                  #3158
                  @simatec
                  hier mal das Log von heute!
                  2021-06-09 06:00:00.030 - info: shuttercontrol.0 (32073) #21 Set ID: Kim value: 100%
                  2021-06-09 06:00:00.030 - debug: shuttercontrol.0 (32073) shutterUpSleep #1 Kim old height: 10% new height: 100%
                  2021-06-09 06:00:00.079 - debug: shuttercontrol.0 (32073) Shutter state changed: Kim old value = 10 new value = 100
                  2021-06-09 06:00:00.079 - debug: shuttercontrol.0 (32073) Kim Old value = 10. New value = 100. automatic is active
                  2021-06-09 06:00:05.031 - info: shuttercontrol.0 (32073) #21 Set ID: Schlafzimmer value: 100%
                  2021-06-09 06:00:05.031 - debug: shuttercontrol.0 (32073) shutterUpSleep #1 Schlafzimmer old height: 10% new height: 100%
                  2021-06-09 06:00:05.035 - info: javascript.0 (1038) script.js.common.Kinder_Licht: Licht von Kim ausgeschalten
                  2021-06-09 06:00:05.040 - debug: shuttercontrol.0 (32073) Shutter state changed: Schlafzimmer old value = 10 new value = 100
                  2021-06-09 06:00:05.040 - debug: shuttercontrol.0 (32073) Schlafzimmer Old value = 10. New value = 100. automatic is active
                  2021-06-09 06:00:10.029 - info: shuttercontrol.0 (32073) #21 Set ID: Jan value: 100%
                  2021-06-09 06:00:10.029 - debug: shuttercontrol.0 (32073) shutterUpSleep #1 Jan old height: 10% new height: 100%
                  2021-06-09 06:00:10.043 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 100
                  2021-06-09 06:00:10.043 - debug: shuttercontrol.0 (32073) Jan Old value = 10. New value = 100. automatic is active
                  2021-06-09 06:00:10.858 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 14
                  2021-06-09 06:00:10.859 - debug: shuttercontrol.0 (32073) Jan drived manually to 14. Old value = 10. New value = 14
                  2021-06-09 06:00:10.859 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:11.798 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 19
                  2021-06-09 06:00:11.798 - debug: shuttercontrol.0 (32073) Jan drived manually to 19. Old value = 10. New value = 19
                  2021-06-09 06:00:11.798 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:12.848 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 26
                  2021-06-09 06:00:12.848 - debug: shuttercontrol.0 (32073) Jan drived manually to 26. Old value = 10. New value = 26
                  2021-06-09 06:00:12.848 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:13.798 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 32
                  2021-06-09 06:00:13.798 - debug: shuttercontrol.0 (32073) Jan drived manually to 32. Old value = 10. New value = 32
                  2021-06-09 06:00:13.798 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:14.836 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 39
                  2021-06-09 06:00:14.836 - debug: shuttercontrol.0 (32073) Jan drived manually to 39. Old value = 10. New value = 39
                  2021-06-09 06:00:14.836 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:15.027 - info: shuttercontrol.0 (32073) #21 Set ID: Balkon value: 100%
                  2021-06-09 06:00:15.027 - debug: shuttercontrol.0 (32073) shutterUpSleep #1 Balkon old height: 0% new height: 100%
                  2021-06-09 06:00:15.031 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 100
                  2021-06-09 06:00:15.031 - debug: shuttercontrol.0 (32073) Balkon Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:00:15.888 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 46
                  2021-06-09 06:00:15.888 - debug: shuttercontrol.0 (32073) Jan drived manually to 46. Old value = 10. New value = 46
                  2021-06-09 06:00:15.888 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:16.089 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 3
                  2021-06-09 06:00:16.089 - debug: shuttercontrol.0 (32073) Balkon drived manually to 3. Old value = 0. New value = 3
                  2021-06-09 06:00:16.089 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:16.829 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 52
                  2021-06-09 06:00:16.829 - debug: shuttercontrol.0 (32073) Jan drived manually to 52. Old value = 10. New value = 52
                  2021-06-09 06:00:16.829 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:17.093 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 6
                  2021-06-09 06:00:17.093 - debug: shuttercontrol.0 (32073) Balkon drived manually to 6. Old value = 0. New value = 6
                  2021-06-09 06:00:17.093 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:17.912 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 59
                  2021-06-09 06:00:17.912 - debug: shuttercontrol.0 (32073) Jan drived manually to 59. Old value = 10. New value = 59
                  2021-06-09 06:00:17.913 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:18.095 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 9
                  2021-06-09 06:00:18.095 - debug: shuttercontrol.0 (32073) Balkon drived manually to 9. Old value = 0. New value = 9
                  2021-06-09 06:00:18.095 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:18.891 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 65
                  2021-06-09 06:00:18.891 - debug: shuttercontrol.0 (32073) Jan drived manually to 65. Old value = 10. New value = 65
                  2021-06-09 06:00:18.891 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:19.090 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 12
                  2021-06-09 06:00:19.090 - debug: shuttercontrol.0 (32073) Balkon drived manually to 12. Old value = 0. New value = 12
                  2021-06-09 06:00:19.091 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:19.907 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 72
                  2021-06-09 06:00:19.907 - debug: shuttercontrol.0 (32073) Jan drived manually to 72. Old value = 10. New value = 72
                  2021-06-09 06:00:19.907 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:20.095 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 16
                  2021-06-09 06:00:20.096 - debug: shuttercontrol.0 (32073) Balkon drived manually to 16. Old value = 0. New value = 16
                  2021-06-09 06:00:20.096 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:20.811 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 78
                  2021-06-09 06:00:20.811 - debug: shuttercontrol.0 (32073) Jan drived manually to 78. Old value = 10. New value = 78
                  2021-06-09 06:00:20.811 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:21.159 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 19
                  2021-06-09 06:00:21.159 - debug: shuttercontrol.0 (32073) Balkon drived manually to 19. Old value = 0. New value = 19
                  2021-06-09 06:00:21.159 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:21.852 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 84
                  2021-06-09 06:00:21.852 - debug: shuttercontrol.0 (32073) Jan drived manually to 84. Old value = 10. New value = 84
                  2021-06-09 06:00:21.852 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:22.101 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 22
                  2021-06-09 06:00:22.101 - debug: shuttercontrol.0 (32073) Balkon drived manually to 22. Old value = 0. New value = 22
                  2021-06-09 06:00:22.101 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:22.904 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 90
                  2021-06-09 06:00:22.904 - debug: shuttercontrol.0 (32073) Jan drived manually to 90. Old value = 10. New value = 90
                  2021-06-09 06:00:22.904 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:23.098 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 25
                  2021-06-09 06:00:23.098 - debug: shuttercontrol.0 (32073) Balkon drived manually to 25. Old value = 0. New value = 25
                  2021-06-09 06:00:23.098 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:23.848 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 97
                  2021-06-09 06:00:23.848 - debug: shuttercontrol.0 (32073) Jan drived manually to 97. Old value = 10. New value = 97
                  2021-06-09 06:00:23.848 - debug: shuttercontrol.0 (32073) Jan Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:24.104 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 28
                  2021-06-09 06:00:24.104 - debug: shuttercontrol.0 (32073) Balkon drived manually to 28. Old value = 0. New value = 28
                  2021-06-09 06:00:24.104 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:24.281 - debug: shuttercontrol.0 (32073) Shutter state changed: Jan old value = 10 new value = 100
                  2021-06-09 06:00:24.281 - debug: shuttercontrol.0 (32073) Jan Old value = 10. New value = 100. automatic is active
                  2021-06-09 06:00:25.100 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 32
                  2021-06-09 06:00:25.100 - debug: shuttercontrol.0 (32073) Balkon drived manually to 32. Old value = 0. New value = 32
                  2021-06-09 06:00:25.100 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:26.098 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 35
                  2021-06-09 06:00:26.098 - debug: shuttercontrol.0 (32073) Balkon drived manually to 35. Old value = 0. New value = 35
                  2021-06-09 06:00:26.099 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:27.190 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 38
                  2021-06-09 06:00:27.191 - debug: shuttercontrol.0 (32073) Balkon drived manually to 38. Old value = 0. New value = 38
                  2021-06-09 06:00:27.191 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:28.101 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 41
                  2021-06-09 06:00:28.101 - debug: shuttercontrol.0 (32073) Balkon drived manually to 41. Old value = 0. New value = 41
                  2021-06-09 06:00:28.102 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:29.103 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 44
                  2021-06-09 06:00:29.103 - debug: shuttercontrol.0 (32073) Balkon drived manually to 44. Old value = 0. New value = 44
                  2021-06-09 06:00:29.103 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:29.280 - info: javascript.0 (1038) script.js.common.Kinder_Licht: Licht von Jan ausgeschalten
                  2021-06-09 06:00:30.104 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 47
                  2021-06-09 06:00:30.104 - debug: shuttercontrol.0 (32073) Balkon drived manually to 47. Old value = 0. New value = 47
                  2021-06-09 06:00:30.104 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:31.099 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 51
                  2021-06-09 06:00:31.099 - debug: shuttercontrol.0 (32073) Balkon drived manually to 51. Old value = 0. New value = 51
                  2021-06-09 06:00:31.099 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:32.106 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 54
                  2021-06-09 06:00:32.106 - debug: shuttercontrol.0 (32073) Balkon drived manually to 54. Old value = 0. New value = 54
                  2021-06-09 06:00:32.106 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:33.065 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 57
                  2021-06-09 06:00:33.065 - debug: shuttercontrol.0 (32073) Balkon drived manually to 57. Old value = 0. New value = 57
                  2021-06-09 06:00:33.065 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:33.598 - info: alexa2.0 (12669) Alexa-Push-Connection established. Disable Polling
                  2021-06-09 06:00:34.108 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 60
                  2021-06-09 06:00:34.108 - debug: shuttercontrol.0 (32073) Balkon drived manually to 60. Old value = 0. New value = 60
                  2021-06-09 06:00:34.108 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:35.067 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 63
                  2021-06-09 06:00:35.067 - debug: shuttercontrol.0 (32073) Balkon drived manually to 63. Old value = 0. New value = 63
                  2021-06-09 06:00:35.067 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:36.151 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 67
                  2021-06-09 06:00:36.151 - debug: shuttercontrol.0 (32073) Balkon drived manually to 67. Old value = 0. New value = 67
                  2021-06-09 06:00:36.151 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:37.065 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 70
                  2021-06-09 06:00:37.065 - debug: shuttercontrol.0 (32073) Balkon drived manually to 70. Old value = 0. New value = 70
                  2021-06-09 06:00:37.065 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:38.105 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 73
                  2021-06-09 06:00:38.105 - debug: shuttercontrol.0 (32073) Balkon drived manually to 73. Old value = 0. New value = 73
                  2021-06-09 06:00:38.105 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:39.080 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 76
                  2021-06-09 06:00:39.080 - debug: shuttercontrol.0 (32073) Balkon drived manually to 76. Old value = 0. New value = 76
                  2021-06-09 06:00:39.080 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:40.112 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 79
                  2021-06-09 06:00:40.112 - debug: shuttercontrol.0 (32073) Balkon drived manually to 79. Old value = 0. New value = 79
                  2021-06-09 06:00:40.112 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:41.072 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 82
                  2021-06-09 06:00:41.072 - debug: shuttercontrol.0 (32073) Balkon drived manually to 82. Old value = 0. New value = 82
                  2021-06-09 06:00:41.072 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:42.110 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 86
                  2021-06-09 06:00:42.111 - debug: shuttercontrol.0 (32073) Balkon drived manually to 86. Old value = 0. New value = 86
                  2021-06-09 06:00:42.111 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:43.077 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 89
                  2021-06-09 06:00:43.077 - debug: shuttercontrol.0 (32073) Balkon drived manually to 89. Old value = 0. New value = 89
                  2021-06-09 06:00:43.077 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:44.067 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 92
                  2021-06-09 06:00:44.067 - debug: shuttercontrol.0 (32073) Balkon drived manually to 92. Old value = 0. New value = 92
                  2021-06-09 06:00:44.067 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:45.075 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 95
                  2021-06-09 06:00:45.075 - debug: shuttercontrol.0 (32073) Balkon drived manually to 95. Old value = 0. New value = 95
                  2021-06-09 06:00:45.075 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:46.069 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 98
                  2021-06-09 06:00:46.069 - debug: shuttercontrol.0 (32073) Balkon drived manually to 98. Old value = 0. New value = 98
                  2021-06-09 06:00:46.069 - debug: shuttercontrol.0 (32073) Balkon Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:00:47.196 - debug: shuttercontrol.0 (32073) Shutter state changed: Balkon old value = 0 new value = 100
                  2021-06-09 06:00:47.196 - debug: shuttercontrol.0 (32073) Balkon Old value = 0. New value = 100. automatic is active
                  Balkon steht wieder auf Manu_Mode, somit wird es natürlich keinen Sonnenschutz geben :(
                  2021-06-09 06:09:00.033 - info: shuttercontrol.0 (32073) #13 Set ID: Esszimmer value: 100%
                  2021-06-09 06:09:00.033 - debug: shuttercontrol.0 (32073) shutterUpLiving #1 Esszimmer old height: 0% new height: 100%
                  2021-06-09 06:09:00.042 - debug: shuttercontrol.0 (32073) Shutter state changed: Esszimmer old value = 0 new value = 100
                  2021-06-09 06:09:00.042 - debug: shuttercontrol.0 (32073) Esszimmer Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:09:02.026 - info: shuttercontrol.0 (32073) #13 Set ID: Wohnzimmer value: 100%
                  2021-06-09 06:09:02.026 - debug: shuttercontrol.0 (32073) shutterUpLiving #1 Wohnzimmer old height: 0% new height: 100%
                  2021-06-09 06:09:02.030 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 100
                  2021-06-09 06:09:02.030 - debug: shuttercontrol.0 (32073) Wohnzimmer Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:09:03.302 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 1
                  2021-06-09 06:09:03.302 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 1. Old value = 0. New value = 1
                  2021-06-09 06:09:03.302 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:04.025 - info: shuttercontrol.0 (32073) #13 Set ID: Küche value: 100%
                  2021-06-09 06:09:04.026 - debug: shuttercontrol.0 (32073) shutterUpLiving #1 Küche old height: 0% new height: 100%
                  2021-06-09 06:09:04.030 - debug: shuttercontrol.0 (32073) Shutter state changed: Küche old value = 0 new value = 100
                  2021-06-09 06:09:04.030 - debug: shuttercontrol.0 (32073) Küche Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:09:04.286 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 2
                  2021-06-09 06:09:04.286 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 2. Old value = 0. New value = 2
                  2021-06-09 06:09:04.286 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:05.267 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 3
                  2021-06-09 06:09:05.267 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 3. Old value = 0. New value = 3
                  2021-06-09 06:09:05.267 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:06.025 - info: shuttercontrol.0 (32073) #13 Set ID: Bad value: 100%
                  2021-06-09 06:09:06.025 - debug: shuttercontrol.0 (32073) shutterUpLiving #1 Bad old height: 0% new height: 100%
                  2021-06-09 06:09:06.030 - debug: shuttercontrol.0 (32073) Shutter state changed: Bad old value = 0 new value = 100
                  2021-06-09 06:09:06.030 - debug: shuttercontrol.0 (32073) Bad Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:09:07.280 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 4
                  2021-06-09 06:09:07.280 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 4. Old value = 0. New value = 4
                  2021-06-09 06:09:07.280 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:08.026 - info: shuttercontrol.0 (32073) #13 Set ID: Terrasse value: 100%
                  2021-06-09 06:09:08.026 - debug: shuttercontrol.0 (32073) shutterUpLiving #1 Terrasse old height: 0% new height: 100%
                  2021-06-09 06:09:08.079 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 100
                  2021-06-09 06:09:08.081 - debug: shuttercontrol.0 (32073) Terrasse Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:09:08.807 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 5
                  2021-06-09 06:09:08.807 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 5. Old value = 0. New value = 5
                  2021-06-09 06:09:08.807 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:08.969 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 2
                  2021-06-09 06:09:08.969 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 2. Old value = 0. New value = 2
                  2021-06-09 06:09:08.970 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:09.309 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 11
                  2021-06-09 06:09:09.309 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 11. Old value = 0. New value = 11
                  2021-06-09 06:09:09.310 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:09.630 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 5
                  2021-06-09 06:09:09.630 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 5. Old value = 0. New value = 5
                  2021-06-09 06:09:09.630 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:10.331 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 17
                  2021-06-09 06:09:10.331 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 17. Old value = 0. New value = 17
                  2021-06-09 06:09:10.331 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:10.621 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 9
                  2021-06-09 06:09:10.621 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 9. Old value = 0. New value = 9
                  2021-06-09 06:09:10.622 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:11.276 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 24
                  2021-06-09 06:09:11.277 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 24. Old value = 0. New value = 24
                  2021-06-09 06:09:11.277 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:11.659 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 13
                  2021-06-09 06:09:11.659 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 13. Old value = 0. New value = 13
                  2021-06-09 06:09:11.659 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:12.306 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 30
                  2021-06-09 06:09:12.307 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 30. Old value = 0. New value = 30
                  2021-06-09 06:09:12.307 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:12.658 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 16
                  2021-06-09 06:09:12.658 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 16. Old value = 0. New value = 16
                  2021-06-09 06:09:12.658 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:13.286 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 37
                  2021-06-09 06:09:13.286 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 37. Old value = 0. New value = 37
                  2021-06-09 06:09:13.286 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:13.648 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 20
                  2021-06-09 06:09:13.648 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 20. Old value = 0. New value = 20
                  2021-06-09 06:09:13.648 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:14.271 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 43
                  2021-06-09 06:09:14.271 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 43. Old value = 0. New value = 43
                  2021-06-09 06:09:14.271 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:14.636 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 23
                  2021-06-09 06:09:14.636 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 23. Old value = 0. New value = 23
                  2021-06-09 06:09:14.636 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:15.310 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 50
                  2021-06-09 06:09:15.310 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 50. Old value = 0. New value = 50
                  2021-06-09 06:09:15.310 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:15.628 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 27
                  2021-06-09 06:09:15.629 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 27. Old value = 0. New value = 27
                  2021-06-09 06:09:15.629 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:16.291 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 56
                  2021-06-09 06:09:16.291 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 56. Old value = 0. New value = 56
                  2021-06-09 06:09:16.291 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:16.641 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 30
                  2021-06-09 06:09:16.641 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 30. Old value = 0. New value = 30
                  2021-06-09 06:09:16.641 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:17.277 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 62
                  2021-06-09 06:09:17.278 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 62. Old value = 0. New value = 62
                  2021-06-09 06:09:17.278 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:17.635 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 34
                  2021-06-09 06:09:17.635 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 34. Old value = 0. New value = 34
                  2021-06-09 06:09:17.635 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:18.309 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 69
                  2021-06-09 06:09:18.309 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 69. Old value = 0. New value = 69
                  2021-06-09 06:09:18.309 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:18.621 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 38
                  2021-06-09 06:09:18.621 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 38. Old value = 0. New value = 38
                  2021-06-09 06:09:18.621 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:19.293 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 75
                  2021-06-09 06:09:19.293 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 75. Old value = 0. New value = 75
                  2021-06-09 06:09:19.293 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:19.614 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 41
                  2021-06-09 06:09:19.614 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 41. Old value = 0. New value = 41
                  2021-06-09 06:09:19.614 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:20.276 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 82
                  2021-06-09 06:09:20.276 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 82. Old value = 0. New value = 82
                  2021-06-09 06:09:20.276 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:20.737 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 45
                  2021-06-09 06:09:20.737 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 45. Old value = 0. New value = 45
                  2021-06-09 06:09:20.737 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:21.322 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 88
                  2021-06-09 06:09:21.323 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 88. Old value = 0. New value = 88
                  2021-06-09 06:09:21.323 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:21.651 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 48
                  2021-06-09 06:09:21.652 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 48. Old value = 0. New value = 48
                  2021-06-09 06:09:21.652 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:22.298 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 95
                  2021-06-09 06:09:22.298 - debug: shuttercontrol.0 (32073) Wohnzimmer drived manually to 95. Old value = 0. New value = 95
                  2021-06-09 06:09:22.298 - debug: shuttercontrol.0 (32073) Wohnzimmer Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:22.653 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 52
                  2021-06-09 06:09:22.653 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 52. Old value = 0. New value = 52
                  2021-06-09 06:09:22.653 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:23.188 - debug: shuttercontrol.0 (32073) Shutter state changed: Wohnzimmer old value = 0 new value = 100
                  2021-06-09 06:09:23.188 - debug: shuttercontrol.0 (32073) Wohnzimmer Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:09:23.643 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 55
                  2021-06-09 06:09:23.643 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 55. Old value = 0. New value = 55
                  2021-06-09 06:09:23.643 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:24.633 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 59
                  2021-06-09 06:09:24.633 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 59. Old value = 0. New value = 59
                  2021-06-09 06:09:24.634 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:25.629 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 63
                  2021-06-09 06:09:25.630 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 63. Old value = 0. New value = 63
                  2021-06-09 06:09:25.630 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:26.619 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 66
                  2021-06-09 06:09:26.619 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 66. Old value = 0. New value = 66
                  2021-06-09 06:09:26.619 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:27.664 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 70
                  2021-06-09 06:09:27.665 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 70. Old value = 0. New value = 70
                  2021-06-09 06:09:27.665 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:28.747 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 73
                  2021-06-09 06:09:28.747 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 73. Old value = 0. New value = 73
                  2021-06-09 06:09:28.747 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:29.655 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 77
                  2021-06-09 06:09:29.655 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 77. Old value = 0. New value = 77
                  2021-06-09 06:09:29.656 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:30.735 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 81
                  2021-06-09 06:09:30.736 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 81. Old value = 0. New value = 81
                  2021-06-09 06:09:30.736 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:31.653 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 84
                  2021-06-09 06:09:31.653 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 84. Old value = 0. New value = 84
                  2021-06-09 06:09:31.654 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:32.658 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 88
                  2021-06-09 06:09:32.658 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 88. Old value = 0. New value = 88
                  2021-06-09 06:09:32.659 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:33.640 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 91
                  2021-06-09 06:09:33.640 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 91. Old value = 0. New value = 91
                  2021-06-09 06:09:33.640 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:34.640 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 95
                  2021-06-09 06:09:34.641 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 95. Old value = 0. New value = 95
                  2021-06-09 06:09:34.641 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:35.630 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 98
                  2021-06-09 06:09:35.630 - debug: shuttercontrol.0 (32073) Terrasse drived manually to 98. Old value = 0. New value = 98
                  2021-06-09 06:09:35.630 - debug: shuttercontrol.0 (32073) Terrasse Updated trigger action to Manu_Mode to prevent moving after window close
                  2021-06-09 06:09:36.815 - debug: shuttercontrol.0 (32073) Shutter state changed: Terrasse old value = 0 new value = 100
                  2021-06-09 06:09:36.815 - debug: shuttercontrol.0 (32073) Terrasse Old value = 0. New value = 100. automatic is active
                  2021-06-09 06:09:46.186 - info: javascript.0 (1038) script.js.common.Licht_aus_wenn_Rollladen_hochfährt: Rollladenstand nach ablauf Zeit: 100
                  2021-06-09 06:10:00.002 - debug: shuttercontrol.0 (32073) calculate astrodata ...
                  Terrasse und Wohnzimmer auch... warum?
                  Meine Frau hat heute morgen das Fenster von Jan geschlossen!
                  2021-06-09 06:05:50.012 - debug: shuttercontrol.0 (32073) TriggerID changed: alias.0.Fenster.Jan_Zimmer Value: 2
                  2021-06-09 06:05:50.013 - debug: shuttercontrol.0 (32073) Jan - shutter conversion is:false
                  2021-06-09 06:05:50.033 - debug: shuttercontrol.0 (32073) Jan - shutter current state.val is:100
                  2021-06-09 06:05:50.033 - debug: shuttercontrol.0 (32073) Jan - shutter trigger drive-up is:10
                  2021-06-09 06:05:50.033 - debug: shuttercontrol.0 (32073) Jan - shutter trigger change is:onlyUp
                  2021-06-09 06:05:50.033 - debug: shuttercontrol.0 (32073) #2 save trigger height: 100% for device: Jan
                  2021-06-09 06:05:50.033 - debug: shuttercontrol.0 (32073) #2 save trigger action: Manu_Mode for device: Jan
                  2021-06-09 06:05:51.125 - debug: shuttercontrol.0 (32073) TriggerID changed: alias.0.Fenster.Jan_Zimmer Value: 0
                  2021-06-09 06:05:51.167 - debug: shuttercontrol.0 (32073) Jan - shutter conversion is:false
                  2021-06-09 06:05:58.092 - debug: shuttercontrol.0 (32073) Brightness sensor value: 233
                  Somit ist die Automatik auch wieder deaktiviert, was nicht ganz korrekt ist da ja das System gefahren ist.
                  Kann man den Sonnenschutz unabhängig vom Manu_Mode aktivieren, also seperat an und ausschalten für jedes Fenster.
                  "noGoTime": "0",
                      "currentShutterStateTime": "120",
                  hab ich auf 120sek gehabt.
                  ich verstehe nicht ganz wo es hier konfig unterschiede gibt!
                  bei meiner Tochter ihrm Rollladen, passt alles.
                  • F FoxRo
                    @negalein said in Test Adapter shuttercontrol v1.2.x:
                    @foxro sagte in Test Adapter shuttercontrol v1.2.x:
                    Du schraubst den Wert für "Beenden der Sonnenschutzfunktion mit Sonnenhöhe (Elevation)" in den Astro Einstellungen soweit runter, dass sicher vor dem Erreichen der eingestellten Elevation, die Aussentemp unter Deine Vorgaben fällt. Hiermit erreichst, dass erst geöffnet wird, wenn die Aussentemp genügend abgesunken ist. In heissen Sommernächten kommt dann evtl halt direkt das "down", ohne vorher zu öffnen.
                    Habs jetzt mal so eingestellt. Bin gespannt.
                    Das mit der Elevation hab ich eigentlich nie verwendet. Kann man das komplett deaktivieren?
                    Ausschalten lässt sich die Elevation nicht. Sie ist Grundlage jeglicher Beschattung in Shuttercontrol und damit gibt man vor, ab - und bis welchem Sonnenstand man überhaupt beschatten will. Ansonsten würde ja die Beschattungsfunktion bei einigen Konfigurationen wegen warmer Nächte sogar in der Nacht aktiv sein, wo es aber e nichts bringt.
                    Bin auf Dein Feedback gespannt. :-)
                    Viel Erfolg!
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #3159
                    Hallo
                    Wieder nicht funktioniert.
                    Bei 25° gingen sie zu.
                    Aktuell hats 20,8° und sind noch immer zu.
                    Hilft das? Geht um Wohnzimmer.
                    ° Fixer ---> iob fix
                      tobitobsta
                      #3160
                      find den adapter echt super gut und nutze ihn auch jetzt seit über einem Jahr. Ich habe viel rumgespielt mit sun protect, Himmelsrichtung, Temperatur- und Lichtwerten etc.
                      Nun habe ich ein Problem, dass ich nicht loswerde - trotz dass ich bereits den adapter komplett deinstalliert und neu installiert hab und die Konfig dann auch von neuem gemacht hab (also nicht die alte importiert).
                      Das Problem:
                      • ich habe drei Rollos, die alle über Shelly-Schalter gesteuert werden.
                      • Alle gehen zur selben Hausseite raus - also haben auch alle die selben Winkeleinstellungen für den Sonneschutz über Himmelsrichtung.
                      • Der "auto-sun"-datenpunkt ist für alle true.
                      • Bei einem funktioniert das automatische runter und wieder hochfahren - die andere beiden wollen einfach nicht.
                      • Wenn ich manuell das Level in den Shelly-Datenpunkt "shutter.position" eingebe, bewegen sie sich aber.
                      Ich habe auch schon mal den Adapter im Debug-Protokoll aktiviert - da sieht es so aus, als wenn die besagten Rollos einfach ignoriert werden - sie tauchen gar nicht auf.
                      Bin langsam echt ratlos - fällt einem von euch noch irgendwas ein/auf, wie ich hier weiter testen/debuggen kann oder wo ich hier einen Fehler gemacht hab?
                              "enabled": true,
                              "shutterName": "Schlafzimmer Links",
                              "name": "shelly.0.SHSW-25#68C63AF9D51B#1.Shutter.Position",
                              "triggerID": "",
                              "typeUp": "children",
                              "typeDown": "children",
                              "type": "only direction",
                              "direction": "287",
                              "directionRange": "21",
                              "tempInside": "23",
                              "tempSensor": "",
                              "outsideTempSensor": "",
                              "tempOutside": "23",
                              "lightSensor": "",
                              "valueLight": "15",
                              "heightUp": "100",
                              "heightDown": "0",
                              "triggerState": "true",
                              "triggerChange": "off",
                              "elevation": "8",
                              "autoDrive": "off",
                              "hysteresisOutside": "5",
                              "oldHeight": "",
                              "LateDown": false,
                              "KeepSunProtect": false,
                              "XmasLevel": "0",
                              "betweenPositionLevel": "50",
                              "trigDelyUp": "0",
                              "trigDelyDown": "0"
                              "enabled": true,
                              "shutterName": "Schlafzimmer Rechts",
                              "name": "shelly.0.SHSW-25#68C63AFB887B#1.Shutter.Position",
                              "triggerID": "",
                              "direction": "287",
                              "tempInside": "23",
                              "tempSensor": "",
                              "lightSensor": "",
                              "valueLight": "15",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "8",
                              "autoDrive": "off",
                              "oldHeight": "",
                              "LateDown": false,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "trigDelyDown": "0"
                              "enabled": true,
                              "shutterName": "Kinderzimmer Norden",
                              "name": "shelly.0.SHSW-25#68C63AFA5024#1.Shutter.Position",
                              "triggerID": "",
                              "direction": "287",
                              "tempInside": "23",
                              "tempSensor": "",
                              "lightSensor": "",
                              "valueLight": "15",
                              "heightUp": "100",
                              "heightDown": "0",
                              "elevation": "8",
                              "autoDrive": "off",
                              "oldHeight": "",
                              "LateDown": false,
                              "XmasLevel": "0",
                              "trigDelyUp": "0",
                              "trigDelyDown": "0"
                      • TottoT Offline
                        TottoT Offline
                        Totto
                        schrieb am zuletzt editiert von Totto
                        #3161
                        Ich habe ein riesiges Problem mit dem Shuttercontrol Adapter... Letztes Jahr hat der einwandfrei funktioniert. Dann kamen einige Updates im Januar, seit dem ist er diesen Sommer (ist ja noch nicht so lange) nicht mehr in den Sonnenschutz gefahren. Dann kam das Update auf 1.2.0, der Sonnenschutz wurde immer noch nicht gefahren, jetzt habe ich den Adapter mal komplett de- und dann wieder installiert, und neu eingerichtet. Jetzt fahren nicht mal mehr die Rollos abends runter und morgens hoch! 😭
                        Habe mal Screenshot von einem Rollo gepostet (die sind alle nahezu identisch konfiguriert), wo ist der Fehler?
                        P.S. Ich habe gerade diese Zeilen im Log gefunden... Was bedeutet das?
                        shuttercontrol.0	2021-06-09 21:07:02.602	info	(16264) starting. Version 1.2.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.shuttercontrol, node: v12.22.1, js-controller: 3.2.16
                        host.server(SmartHome)	2021-06-09 21:06:59.305	info	instance system.adapter.shuttercontrol.0 started with pid 16264
                        host.server(SmartHome)	2021-06-09 21:06:57.493	info	instance system.adapter.shuttercontrol.0 terminated with code null ()
                        host.server(SmartHome)	2021-06-09 21:06:57.493	warn	instance system.adapter.shuttercontrol.0 terminated due to SIGTERM
                        host.server(SmartHome)	2021-06-09 21:06:57.305	info	stopInstance system.adapter.shuttercontrol.0 killing pid 23816
                        shuttercontrol.0	2021-06-09 21:06:56.243	info	(23816) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        shuttercontrol.0	2021-06-09 21:06:56.243	info	(23816) terminating
                        shuttercontrol.0	2021-06-09 21:06:56.243	info	(23816) cleaned everything up...
                        shuttercontrol.0	2021-06-09 21:06:56.243	info	(23816) Got terminate signal TERMINATE_YOURSELF
                        host.server(SmartHome)	2021-06-09 21:06:56.243	info	stopInstance system.adapter.shuttercontrol.0 send kill signal
                        host.server(SmartHome)	2021-06-09 21:06:56.227	info	stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                        shuttercontrol.0	2021-06-09 21:06:50.946	info	(23816) starting. Version 1.2.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.shuttercontrol, node: v12.22.1, js-controller: 3.2.16
                        host.server(SmartHome)	2021-06-09 21:06:46.759	info	instance system.adapter.shuttercontrol.0 started with pid 23816
                        host.server(SmartHome)	2021-06-09 21:06:44.446	info	instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.server(SmartHome)	2021-06-09 21:06:43.712	info	stopInstance system.adapter.shuttercontrol.0 send kill signal
                        shuttercontrol.0	2021-06-09 21:06:43.727	info	(26140) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        shuttercontrol.0	2021-06-09 21:06:43.727	info	(26140) terminating
                        shuttercontrol.0	2021-06-09 21:06:43.727	info	(26140) cleaned everything up...
                        shuttercontrol.0	2021-06-09 21:06:43.727	info	(26140) Got terminate signal TERMINATE_YOURSELF
                        host.server(SmartHome)	2021-06-09 21:06:43.712	info	stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                        • TottoT Totto
                          tobitobsta
                          #3162
                          @totto mir fällt auf, dass das kleine häkchen bei "aktiv" fehlt
                          da_WoodyD TottoT 2 Antworten Letzte Antwort
                          • T tobitobsta
                            Das Problem:
                                    "enabled": true,
                                    "triggerID": "",
                                    "direction": "287",
                                    "tempInside": "23",
                                    "tempSensor": "",
                                    "lightSensor": "",
                                    "valueLight": "15",
                                    "heightUp": "100",
                                    "heightDown": "0",
                                    "elevation": "8",
                                    "autoDrive": "off",
                                    "oldHeight": "",
                                    "LateDown": false,
                                    "XmasLevel": "0",
                                    "trigDelyUp": "0",
                                    "trigDelyDown": "0"
                                    "enabled": true,
                                    "triggerID": "",
                                    "direction": "287",
                                    "tempInside": "23",
                                    "tempSensor": "",
                                    "lightSensor": "",
                                    "valueLight": "15",
                                    "heightUp": "100",
                                    "heightDown": "0",
                                    "elevation": "8",
                                    "autoDrive": "off",
                                    "oldHeight": "",
                                    "LateDown": false,
                                    "XmasLevel": "0",
                                    "trigDelyUp": "0",
                                    "trigDelyDown": "0"
                                    "enabled": true,
                                    "triggerID": "",
                                    "direction": "287",
                                    "tempInside": "23",
                                    "tempSensor": "",
                                    "lightSensor": "",
                                    "valueLight": "15",
                                    "heightUp": "100",
                                    "heightDown": "0",
                                    "elevation": "8",
                                    "autoDrive": "off",
                                    "oldHeight": "",
                                    "LateDown": false,
                                    "XmasLevel": "0",
                                    "trigDelyUp": "0",
                                    "trigDelyDown": "0"
                            da_WoodyD Online
                            da_WoodyD Online
                            #3163
                            @tobitobsta da war doch erst vor ein paar tagen auch so ein problem...
                            der erste angesprochene reagierte, die anderen nicht.irgendwer meinte, eventuell die werte leicht abstufen, damit nicht alle gleichzeitig angesprochen werden. oder so ähnlich. oder was mit verzögerung...
                            • T tobitobsta
                              da_WoodyD Online
                              da_WoodyD Online
                              #3164
                              @tobitobsta ID für helligkeits sensor ist auch keine da.
                              • TottoT Offline
                                TottoT Offline
                                Totto
                                #3165
                                Er fährt ja noch nicht mal mehr morgens rauf und abends runter... Und dann ständig diese Einträge im Log:
                                shuttercontrol.0	2021-06-09 21:34:20.883	info	(3676) starting. Version 1.2.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.shuttercontrol, node: v12.22.1, js-controller: 3.2.16
                                host.server(SmartHome)	2021-06-09 21:33:17.493	info	instance system.adapter.shuttercontrol.0 started with pid 3676
                                host.server(SmartHome)	2021-06-09 21:33:15.321	info	instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                shuttercontrol.0	2021-06-09 21:33:14.415	info	(31136) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                shuttercontrol.0	2021-06-09 21:33:14.415	info	(31136) terminating
                                shuttercontrol.0	2021-06-09 21:33:14.415	info	(31136) cleaned everything up...
                                host.server(SmartHome)	2021-06-09 21:33:14.415	info	stopInstance system.adapter.shuttercontrol.0 send kill signal
                                shuttercontrol.0	2021-06-09 21:33:14.415	info	(31136) Got terminate signal TERMINATE_YOURSELF
                                host.server(SmartHome)	2021-06-09 21:33:14.415	info	stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
                                T FredFF 2 Antworten Letzte Antwort
                                • da_WoodyD da_Woody
                                  tobitobsta
                                  #3166
                                  @da_woody vielen Dank für die Anregungen! Das mit der leichten Variation der Winkelwerte ist vielleicht ne gute Idee, das probier ich mal aus.
                                  Bzgl der fehlenden ID bei Helligkeitssensor müsste so okay sein. Wollte alle anderen Spielereien erstmal weglassen und nur über Himmelsrichtung gehen. Und so sind dann die Defaultwerte bei einem frischen Adapter, wenn man sich um Helligkeitssensoren gar nicht kümmert.
                                  • TottoT Totto
                                    tobitobsta
                                    #3167
                                    @totto evtl lade mal die config runter und poste sie hier - ich vermute da steht irgendwas wie "enabled": false - bei deinem Screenshot sind alle Rollos NICHT aktiviert - das bedeutet jegliche Steuerung über Shuttercontrol-Adapter findet NICHT statt - meines Erachtens nach.
                                    • TottoT Totto
                                      FredFF Online
                                      FredFF Online
                                      FredF
                                      Most Active Forum Testing
                                      #3168
                                      @totto sagte in Test Adapter shuttercontrol v1.2.x:
                                      Wie auch wenn hier die Rollläden nicht aktiv sind
                                      • HomoranH Offline
                                        HomoranH Offline
                                        #3169
                                        @tobitobsta sagte in Test Adapter shuttercontrol v1.2.x:
                                        warum hast du dann Außentemperatur/Lichtsensor eingestellt?
                                        • T tobitobsta
                                          TottoT Offline
                                          TottoT Offline
                                          Totto
                                          #3170
                                          @tobitobsta Oh man, ich Depp!!! Vielen Dank für den Hinweis!
                                          Okay, das zeitgesteuerte Fahren funktioniert jetzt schon mal wieder! Jetzt Jetzt hoffe ich nur, dass der Sonnenschutz jetzt auch wieder funktioniert...
                                          Weiß jemand zufällig, wann die Dokumentation für die Version 1.2.0 online geht?
