  4. Admin :8081 Ladezeit: (fast) unendlich!
70 Beiträge 6 Kommentatoren 7.7k Aufrufe 4 Beobachtet
    @rotamint
    Und dann schleifst du da auch noch einen kompletten Desktop mit.
    Ausknipsen, den Quark.
    Und wo kommt der ganze Java-Kram her?
    rotamint
    Danke Homoran, der Admin hat nun geladen :)
    Platform: linux
    os: linux
    Architecture: arm
    CPUs: 4
    Speed: 1500 MHz
    Model: ARMv7 Processor rev 3 (v7l)
    RAM: 1.8 GB
    System uptime: 00:15:33
    Node.js: v14.17.0
    NPM: 6.14.13
    Disk size: 55.9 GiB
    Disk free: 45.4 GiB
    adapters count: 345
    Uptime: 00:15:22
    Active instances: 11
    iobroker status:
    pi@ioBroker:~ $ iobroker staus
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-con        troller
      iobroker stop                                                stops the js-cont        roller
      iobroker restart                                             Restarts js-contr        oller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
      iobroker info                                                Shows the host in        fo
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter
      iobroker install <adapter>                                   Installs a specif        ied adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specif        ied adapter
      iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter fr        om system
      iobroker del <adapter>.<instance>                            Remove adapter in        stance
      iobroker update [<repositoryUrl>]                            Update repository        and list adapters
      iobroker upgrade                                             Upgrade managemen        t
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
      iobroker list <type> [<filter>]                              List all entries,        like objects
      iobroker chmod <mode> <file>                                 Change file right        s
      iobroker chown <user> <group> <file>                         Change file owner        ship
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given        hostname
      iobroker set <adapter>.<instance>                            Change settings o        f adapter config
      iobroker license <license.file or license.text>              Update license by        given file
      iobroker cert                                                Certificate manag        ement
      iobroker clean <yes>                                         Clears all object        s and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specifi        ed backup
      iobroker validate <backup name or path>                      Validate a specif        ied backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance
      iobroker repo [<name>]                                       Show repo informa        tion
      iobroker uuid                                                Show uuid of the        installation
      iobroker unsetup                                             Reset license, in        stallation secret and language
      iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost managem        ent
      iobroker compact                                             compact group man        agement
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    pi@ioBroker:~ $
    iobroker list intances:
    pi@ioBroker:~ $ iobroker list instances
    + system.adapter.admin.0                  : admin                 : ioBroker        -  enabled, port: 8081, bind: 192.168.1.9, run as:        admin
    + system.adapter.backitup.0               : backitup              : ioBroker        -  enabled
      system.adapter.ble.0                    : ble                   : ioBroker        - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker        - disabled
    + system.adapter.discovery.0              : discovery             : ioBroker        -  enabled
      system.adapter.echarts.0                : echarts               : ioBroker        - disabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker        - disabled
      system.adapter.ecovacs-deebot.1         : ecovacs-deebot        : ioBroker        - disabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker        - disabled
      system.adapter.feiertage.0              : feiertage             : ioBroker        - disabled
      system.adapter.fritzdect.0              : fritzdect             : ioBroker        - disabled
      system.adapter.growatt.0                : growatt               : ioBroker        - disabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker        - disabled
      system.adapter.history.0                : history               : ioBroker        - disabled
    + system.adapter.hm-rega.0                : hm-rega               : ioBroker        -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker        -  enabled, port: 12001
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker        - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker        - disabled
    + system.adapter.javascript.0             : javascript            : ioBroker        -  enabled
      system.adapter.linkeddevices.0          : linkeddevices         : ioBroker        - disabled
      system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker        - disabled
      system.adapter.milight-smart-light.1    : milight-smart-light   : ioBroker        - disabled
      system.adapter.ping.0                   : ping                  : ioBroker        - disabled
      system.adapter.sayit.0                  : sayit                 : ioBroker        - disabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker        -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBroker        -  enabled, port: 8087, bind: 0.0.0.0, run as: admi        n
      system.adapter.smartcontrol.0           : smartcontrol          : ioBroker        - disabled
    + system.adapter.sonoff.0                 : sonoff                : ioBroker        -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker        - disabled
      system.adapter.tr-064.0                 : tr-064                : ioBroker        - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker        - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker        - disabled
      system.adapter.vis.0                    : vis                   : ioBroker        -  enabled
    + system.adapter.web.0                    : web                   : ioBroker        -  enabled, port: 8082, bind: 192.168.1.9, run as:        admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker        - disabled
      system.adapter.wled.0                   : wled                  : ioBroker        - disabled
    + system.adapter.zigbee.0                 : zigbee                : ioBroker        -  enabled, port: /dev/ttyACM0
    + instance is alive
    pi@ioBroker:~ $
    OK, VNC hab ich deaktiviert ;-)
    Danke!
    Thomas BraunT HomoranH 4 Antworten Letzte Antwort
    • R rotamint
      Platform: linux
      os: linux
      Architecture: arm
      CPUs: 4
      Speed: 1500 MHz
      RAM: 1.8 GB
      Node.js: v14.17.0
      NPM: 6.14.13
      Disk size: 55.9 GiB
      Disk free: 45.4 GiB
      adapters count: 345
      Uptime: 00:15:22
      iobroker status:
      iobroker [command]
      Commands:
      Options:
      pi@ioBroker:~ $
      + instance is alive
      pi@ioBroker:~ $
      Danke!
      @rotamint sagte in Admin :8081 Ladezeit: (fast) unendlich!:
      Den Dekstop komplett rauswerfen. Nicht nur den VNC. Auf Servern bewegt man sich ausschließlich per Kommandozeile.
      • R rotamint
        Platform: linux
        os: linux
        Architecture: arm
        CPUs: 4
        Speed: 1500 MHz
        RAM: 1.8 GB
        Node.js: v14.17.0
        NPM: 6.14.13
        Disk size: 55.9 GiB
        Disk free: 45.4 GiB
        adapters count: 345
        Uptime: 00:15:22
        iobroker status:
        iobroker [command]
        Commands:
        Options:
        pi@ioBroker:~ $
        + instance is alive
        pi@ioBroker:~ $
        Danke!
        iobroker staus
        Du hast da zwar irgendwo Staus, das Kommando heißt aber dennoch
        iobroker status
        R 1 Antwort Letzte Antwort
          iobroker staus
          iobroker status
          rotamint
          pi@ioBroker:~ $ iobroker status
          Objects type: file
          States  type: file
          pi@ioBroker:~ $
          • R rotamint
            Objects type: file
            States  type: file
            pi@ioBroker:~ $
            @rotamint
            Okay. Und wo kommt der java-Kram im root-Kontext her? Das sieht mega schief aus.
            • R rotamint
              Platform: linux
              os: linux
              Architecture: arm
              CPUs: 4
              Speed: 1500 MHz
              RAM: 1.8 GB
              Node.js: v14.17.0
              NPM: 6.14.13
              Disk size: 55.9 GiB
              Disk free: 45.4 GiB
              adapters count: 345
              Uptime: 00:15:22
              iobroker status:
              iobroker [command]
              Commands:
              Options:
              pi@ioBroker:~ $
              + instance is alive
              pi@ioBroker:~ $
              Danke!
              bei/nach welcher Aktion?
              da dein Raspi nur 2GB RAM hat solltwst du wirklich nur das allernötigste drauf laufen lassen.
              Desktop und gar vnc gehören da nicht zu.
              kann es sein, dass irgendetwas noch den port 8081 nutzt?
              Instanzen laufen nicht allzuviele. die sollten keinen Stau verursachen.
                rotamint
                @homoran said in Admin :8081 Ladezeit: (fast) unendlich!:
                Fast 20 Minuten warten...
                OK, 4 GB besser?
                Weiß ich nicht, wie kann ich das raus finden?
                Lief in der Vergangenheit auch deutlich schneller. Ist mir jetzt halt aufgefallen dass es eeewig dauert...
                • R rotamint
                  OK, 4 GB besser?
                  OK, 4 GB besser?
                  Nee, lt. htop hast du 2GB.
                  Und auch mit 4GB lässt man auf einem Server keine GUI laufen. Und auch nicht mit 8, 16, 32, 64 GB RAM.
                  free -ht --mega
                  sagt?
                  • R rotamint
                    OK, 4 GB besser?
                    OK, 4 GB besser?
                    nein!
                    wenn er erst nach
                    erreichbar ist, istwas anderes faul.
                    meiner hat auch nur 2GB, und bei deinen wenigen Instanzen ist 2GB vollkommen ausreichend.
                    da bremst eich irgenwas anderes aus
                      OK, 4 GB besser?
                      free -ht --mega
                      sagt?
                      rotamint
                      @thomas-braun said in Admin :8081 Ladezeit: (fast) unendlich!:
                      OK, 4 GB besser?
                      free -ht --mega
                      sagt?
                      pi@ioBroker:~ $ free -ht --mega
                      Mem:           1,9G        523M        836M         33M        505M        1,3G
                      Swap:           99M          0B         99M
                      Total:         2,0G        523M        936M
                      pi@ioBroker:~ $
                        OK, 4 GB besser?
                        nein!
                        wenn er erst nach
                        rotamint
                        OK, 4 GB besser?
                        nein!
                        wenn er erst nach
                        Hat ja auch in der Vergangenheit tadellos gelaufen. Habe da nie gemerkt, an Grenzen zu kommen... Hast Du eine Idee, wie ich dem Übeltäter auf die Spur kommen kann? :8082 läuft wie geschmiert...
                        • R rotamint
                          OK, 4 GB besser?
                          nein!
                          wenn er erst nach
                          @rotamint
                          sudo ss -tunlp
                            @rotamint
                            sudo ss -tunlp
                            rotamint
                            @rotamint
                            sudo ss -tunlp
                            pi@ioBroker:~ $ sudo ss -tunlp
                            Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port
                            udp     UNCONN   0        0                0.0.0.0:48121          0.0.0.0:*        users:(("avahi-daemon",pid=355,fd=14))
                            udp     UNCONN   0        0                0.0.0.0:68             0.0.0.0:*        users:(("dhclient",pid=521,fd=7))
                            udp     UNCONN   0        0                0.0.0.0:631            0.0.0.0:*        users:(("cups-browsed",pid=427,fd=7))
                            udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*        users:(("avahi-daemon",pid=355,fd=12))
                            udp     UNCONN   0        0                      *:32848                *:*        users:(("avahi-daemon",pid=355,fd=15))
                            udp     UNCONN   0        0                      *:5353                 *:*        users:(("avahi-daemon",pid=355,fd=13))
                            tcp     LISTEN   0        511          192.168.1.9:12001          0.0.0.0:*        users:(("io.hm-rpc.0",pid=2095,fd=27))
                            tcp     LISTEN   0        511            127.0.0.1:9000           0.0.0.0:*        users:(("iobroker.js-con",pid=654,fd=24))
                            tcp     LISTEN   0        511            127.0.0.1:9001           0.0.0.0:*        users:(("iobroker.js-con",pid=654,fd=19))
                            tcp     LISTEN   0        5                0.0.0.0:5900           0.0.0.0:*        users:(("vncserver-x11-c",pid=670,fd=12))
                            tcp     LISTEN   0        511          192.168.1.9:8081           0.0.0.0:*        users:(("io.admin.0",pid=928,fd=27))
                            tcp     LISTEN   0        128              0.0.0.0:22             0.0.0.0:*        users:(("sshd",pid=676,fd=3))
                            tcp     LISTEN   0        5              127.0.0.1:631            0.0.0.0:*        users:(("cupsd",pid=327,fd=7))
                            tcp     LISTEN   0        5                   [::]:5900              [::]:*        users:(("vncserver-x11-c",pid=670,fd=11))
                            tcp     LISTEN   0        128                 [::]:22                [::]:*        users:(("sshd",pid=676,fd=4))
                            tcp     LISTEN   0        5                  [::1]:631               [::]:*        users:(("cupsd",pid=327,fd=6))
                            pi@ioBroker:~ $
                            • R rotamint
                              OK, 4 GB besser?
                              nein!
                              wenn er erst nach
                              was hast du denn im moment alles deaktiviert?
                              du kannst den Übeltäter ja nicht finden, wenn er sich jetzt versteckt.
                              und die Antwort zu der Frage von @Thomas-Braun bezüglich JAVA (nicht javascript!!) habe ich auch nicht gefunden.
                                rotamint
                                @homoran Alles außer den Admin…
                                • R rotamint
                                  Platform: linux
                                  os: linux
                                  Architecture: arm
                                  CPUs: 4
                                  Speed: 1500 MHz
                                  RAM: 1.8 GB
                                  Node.js: v14.17.0
                                  NPM: 6.14.13
                                  Disk size: 55.9 GiB
                                  Disk free: 45.4 GiB
                                  adapters count: 345
                                  Uptime: 00:15:22
                                  iobroker status:
                                  iobroker [command]
                                  Commands:
                                  Options:
                                  pi@ioBroker:~ $
                                  + instance is alive
                                  pi@ioBroker:~ $
                                  Danke!
                                  so was meine ich
                                  und wieviele Instanzen laufen üblicherweise?
                                  mehr als bei dem list instances aktiv waren?
                                    so was meine ich
                                    @homoran @rotamint
                                    Da läuft immer noch ein X.
                                    Acker mal den
                                    durch. Insbesondere den Punkt 'Runlevel 5 / graphische Oberfläche'.
                                      @rotamint
                                      rotamint
                                      Was meinst Du damit?
                                      Danke! Stefan.
                                      • R rotamint
                                        Danke! Stefan.
                                        @rotamint
                                        Damit meine ich, dass da ohne Grund ein VNC-Server (und damit auch ein X-Server) läuft. Den knipst man aus, indem man den kompletten GUI/Desktop-Kram auf Eis legt. Wie es für einen Server angesagt ist.
                                          @homoran @rotamint
                                          Acker mal den
                                          rotamint
                                          schrieb am zuletzt editiert von rotamint
                                          Habe den "kleinen Werkzeugkasten" durchgemacht, alle Instanzen wieder gestartet, so wie "es sein soll"
                                          + system.adapter.ble.0                    : ble                   : ioBroker                                 -  enabled
                                            system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
                                          + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                                          + system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
                                          + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker                                 -  enabled
                                          + system.adapter.milight-smart-light.1    : milight-smart-light   : ioBroker                                 -  enabled
                                          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                                          + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 192.168.1.9, run as: admin
                                          + instance is alive
                                          pi@ioBroker:~ $ who -r
                                                   Runlevel 3   2021-06-02 23:30
                                          pi@ioBroker:~ $
                                          Trotzdem sehe ich noch den vnc-Server:
                                          udp         UNCONN       0             0                          0.0.0.0:39357                    0.0.0.0:*           users:(("io.milight-smar",pid=3408,fd=26))
                                          udp         UNCONN       0             0                          0.0.0.0:68                       0.0.0.0:*           users:(("dhclient",pid=507,fd=7))
                                          udp         UNCONN       0             0                          0.0.0.0:631                      0.0.0.0:*           users:(("cups-browsed",pid=415,fd=7))
                                          udp         UNCONN       0             0                          0.0.0.0:5353                     0.0.0.0:*           users:(("avahi-daemon",pid=327,fd=12))
                                          udp         UNCONN       0             0                          0.0.0.0:37139                    0.0.0.0:*           users:(("avahi-daemon",pid=327,fd=14))
                                          udp         UNCONN       0             0                          0.0.0.0:44377                    0.0.0.0:*           users:(("io.milight-smar",pid=3418,fd=26))
                                          udp         UNCONN       0             0                                *:37998                          *:*           users:(("avahi-daemon",pid=327,fd=15))
                                          udp         UNCONN       0             0                                *:5353                           *:*           users:(("avahi-daemon",pid=327,fd=13))
                                          tcp         LISTEN       0             511                    192.168.1.9:12001                    0.0.0.0:*           users:(("io.hm-rpc.0",pid=2910,fd=27))
                                          tcp         LISTEN       0             511                      127.0.0.1:9000                     0.0.0.0:*           users:(("iobroker.js-con",pid=2784,fd=24))
                                          tcp         LISTEN       0             511                      127.0.0.1:9001                     0.0.0.0:*           users:(("iobroker.js-con",pid=2784,fd=19))
                                          tcp         LISTEN       0             5                          0.0.0.0:5900                     0.0.0.0:*           users:(("vncserver-x11-c",pid=624,fd=12))
                                          tcp         LISTEN       0             511                    192.168.1.9:8081                     0.0.0.0:*           users:(("io.admin.0",pid=2802,fd=27))
                                          tcp         LISTEN       0             128                        0.0.0.0:22                       0.0.0.0:*           users:(("sshd",pid=635,fd=3))
                                          tcp         LISTEN       0             5                        127.0.0.1:631                      0.0.0.0:*           users:(("cupsd",pid=350,fd=7))
                                          tcp         LISTEN       0             511                        0.0.0.0:1883                     0.0.0.0:*           users:(("io.sonoff.0",pid=2966,fd=26))
                                          tcp         LISTEN       0             5                             [::]:5900                        [::]:*           users:(("vncserver-x11-c",pid=624,fd=11))
                                          tcp         LISTEN       0             511                              *:4400                           *:*           users:(("io.milight-smar",pid=3418,fd=28))
                                          tcp         LISTEN       0             128                           [::]:22                          [::]:*           users:(("sshd",pid=635,fd=4))
                                          tcp         LISTEN       0             511                              *:8087                           *:*           users:(("io.simple-api.0",pid=2951,fd=26))
                                          tcp         LISTEN       0             5                            [::1]:631                         [::]:*           users:(("cupsd",pid=350,fd=6))
                                          pi@ioBroker:~ $
                                          Der Admin ist auch immer noch träge...
                                          Danke für Eure Hilfe!!!
                                          Thomas BraunT 3 Antworten Letzte Antwort
