  4. Test Adapter Worx v0.4.x
worxlandroid
198 Beiträge 36 Kommentatoren 41.7k Aufrufe 35 Beobachtet
  • S schmuh
    @bostil
    ja, ist aber ein Standard Basic Widget aus vis.
    [{"tpl":"tplValueListHtml8","data":{"hm_id":12069,"digits":6,"factor":1,"value0":"kein Fehler","value1":"verfangen","value2":"angehoben","style0":"color: green","style1":"color: red","style2":"color: red","comment":"","visibility-cond":"==","visibility-val":1,"count":"17","oid":"worx.0.201930198403012674D0.mower.error","test_list":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"locked":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value3":"Kabel verloren","value4":"außerhalb vom Kabel","value5":"Regen","value6":"zum mähen Tür schließen","value7":"zur Heimfahrt Tür schließen","value8":"Mähwerk blockiert","value9":"Radantrieb blockiert","value10":"Zeitüberschreitung verfangen","value11":"Mäher liegt auf dem Rücken","value12":"Batteriestand niedrig","value13":"Kabel gefunden","value14":"Ladefehler","value30":"","value31":"","value32":"","value33":"","value34":"","value15":"Zeitüberschreitung Home nicht gefunden","value16":"Mäher gesperrt","value17":"Batterietemperatur zu hoch","style3":"color: red","style4":"color: red","style5":"color: yellow","style6":"color: red","style7":"color: red","style8":"color: red","style9":"color: red","style10":"color: red","style11":"color: red","style12":"color: red","style13":"color: green","style14":"color: red","style15":"color: red","style16":"color: red","style17":"color: red"},"style":{"width":"116px","height":"20px","left":"417px","top":"90px","background":"","font":"normal normal normal 16px/normal Arial","text-align":"right","color":"white","padding":"0px","z-index":1,"border-radius":"2px","font-size":"small"},"widgetSet":"basic"}]
    Beste Grüße
    schmuh
    BostilB Offline
    BostilB Offline
    Bostil
    #183
    @schmuh Genial! Hat mir super weitergeholfen. Dieses Widget kannte ich noch nicht, aber dank deiner Vorlage habe ich es nun verstanden und konnte dies auch für den Status-Datenpunkt umschreiben. Kinderleicht! Danke dir nochmal.
    • R romann.k
      @worxweis Also ich muss da nichts pushen. Was mir nur aufgefallen ist, ist dass wenn man versucht die Kalendereinstellungen direkt in die Datenpunkte in den Ordnern der Wochentage zu schreiben, also z.B. monday.startTime und monday.workTime direkt beschreibt, die Verbindung zum Server anscheindend irgendwie zerschossen wird (sorry wenn ich es nicht professioneller ausdrücken kann, aber ich bin Nutzer der Sorte google-copy-paste ;) - vielleicht hat ein Experte ja eine Idee warum das so ist) - dann kann ich z.B. auch mowTimeExtend nicht mehr steuern ohne, dass ich warte oder den worx account zurücksetze. Hast du da vielleicht was eingestellt vorher?
      Wenn ich den die Kalendereinstellungen direkt über den Datenpunkt calJson setze funktioniert alles bestens und die Werte übernehmen sich dann auch direkt in die Worx app und die anderen Datenpunkte vom Kalender.
      Ansonsten könnte man theoretisch den entsprechenden Tag in dem calJson Datenpunkt auf ["00:00",0,0] setzen, dass hätte den selben Effekt wie mowTimeExtend auf -100%.
      W Offline
      W Offline
      worxweis
      #184
      @romann-k Also ich hab jetzt den Datenpunkt calJson direkt beschrieben, jedoch wird nach kurzer Zeit wieder alles mit den Werten von der Landroid App überschrieben. Noch jemand eine Idee, was ich falsch machen könnte?
      hsteinmeH 1 Antwort Letzte Antwort
      • W worxweis
        hsteinmeH Online
        hsteinmeH Online
        hsteinme
        #185
        @worxweis Welche Adapterversion setzt Du ein?
        W 1 Antwort Letzte Antwort
        • hsteinmeH hsteinme
          W Offline
          W Offline
          worxweis
          #186
          @hsteinme wie oben geschrieben 1.3.0
          • W worxweis
            hsteinmeH Online
            hsteinmeH Online
            hsteinme
            #187
            @worxweis Ja, da ist der Fehler noch drin. Siehe https://github.com/iobroker-community-adapters/ioBroker.worx/issues/237
              W Offline
              W Offline
              worxweis
              #188
              @hsteinme Ich bin am Verzweifeln! Ich habe auf die version 1.3.6 upgedatet, aber an dem zustand, dass die eingetragenen Werte nicht erhalten bleiben ändert sich nichts.
              Ich verwende übrigens nur die 1. Kalenderzeiten, nicht die 2.ten.
              Hab jetzt jedoch den Worx adapter auf Debug getsellt und da wurde mir folgendes angezeigt:
              4e8794a1-d277-463d-969a-688074bed630-grafik.png No valid JSON format
              ich erstelle den JsonEintrag folgendermassen:
              Mache ich hier etwas falsch?
              also mein Eintrag sieht jedenfalls genauso aus wie der vom adapter:
              Wobei lokal der selbst generierte ist und Worx, der der im Adapter steht.
              Sobald ich den Worx Wert mit dem Lokalen Wert überschreibe, dauert es keine 2 Minuten, und der vorherige Wert ist wieder da.
              R 1 Antwort Letzte Antwort
              • W worxweis
                romann.k
                schrieb am zuletzt editiert von romann.k
                #189
                @worxweis said in Test Adapter Worx v0.4.x:
                Sorry für die späte Antwort... Zwei Sachen könntest du mal probieren:
                Erstmal ist die Abfolge der Wochentage (warum auch immer) von Sonntag-Samstag, nicht Montag-Sonntag - da müsstest du also die Sortierung mal ändern.
                Dann könnte es sein, dass der Adapter bzw. der Server nicht auf die Formatierung deines Wertes von "0:00" klar kommt (bei dem ersten Wert)... probiere mal stattdessen "00:00" als Wert wenn du ["00:00",0,0] setzen willst...
                Im Blockly sieht das bei mir dann so aus:
                Ich gebe bei mir wie gesagt ein Zeitfenster über den Kalender vor und habe die Sollzeit nicht über den Kalender direkt gesteuert. Hier lasse ich über Variablen setzen, ob an dem Tag gemäht werden soll und ob die Kante dran ist.
                Ich habe dann noch eine Variable Sollzeit und lasse einen Timer hochlaufen, wenn der Status auf mowing (7) steht. Vorteil ist, dass ich unabhängig vom Akkuzustand immer dieselbe Nettoarbeitszeit ohne Ladezeiten habe.
                Den timeout habe ich in den Block gesetzt, damit wenn ich mehrere Änderungen an meinem Kalender in Vis vornehme nicht etliche male der Datenpunkt neu beschrieben wird. Er wartet dann erstmal bis ich 10 Sekunden keine Eingabe gemacht habe und schreibt dann erst den weekJson fertig.
                • R romann.k
                  W Offline
                  W Offline
                  worxweis
                  #190
                  @romann-k Vielen Dank für dein Bemühen! Hab jetzt alle 0:00 auf 00:00 geändert. Das wars aber nicht.
                  auch wenn ich nur eine Änderung mache wird immer wieder der Wert durch die App Werte überschrieben.
                  Und die Fehlermeldung kommt auch nach wie vor. 😕
                  • W worxweis
                    W Offline
                    W Offline
                    worxweis
                    #191
                    @romann.k Hallo!
                    Ich hab's! Es ist liegt halt meistens am User! Ich hatte beim letzten Tag ein " zuviel! Jetzt kommt auch keine Fehlermeldung mehr!
                    Trotzdem vielen Dank! Das Problem ist einmal gelöst!
                    • W worxweis
                      @romann.k Hallo!
                      romann.k
                      #192
                      @worxweis stimmt... Das hatte ich auch übersehen. Achte nur noch auf die Reihenfolge der Wochentage, sonst weckt er am Sonntag die Nachbarn 😂
                      Freut mich wenn es klappt jetzt.
                      Bin gespannt in welche Richtung sich der Adapter bzw Worx sich in dieser Saison in Richtung Einbindung ist Fremdsysteme entwickeln.
                      • MeistertrM Meistertr
                        Guten Morgen Leute,
                        habe gestern abend die Version 0.4.0 hochgeladen,
                        Was wurde geädert:
                        • Verbindungsprobleme mit mehreren Mähern wurden behoben ( nun laufen alle Mäher über eine Mqtt Verbindung)
                        • info Logs wurden minimiert
                        • Mäher Online Status wurde gefixed
                        Bitte Testen und Rückmelden.
                        Agria4800A Offline
                        Agria4800A Offline
                        Agria4800
                        schrieb am zuletzt editiert von Agria4800
                        #193
                        @meistertr : Ich benutze die 1.3.6 Version und wollte fragen, ob du in die Calendar Json
                        worx.0.201930198XXXXXXXX.calendar.calJson
                        noch die Wochentage (Mo. Di. ...) mit angeben könntest?
                        Da die Aufzählung mit Sonntag startet, komme ich ab und an durcheinander 😊
                        • Agria4800A Agria4800
                          hsteinmeH Online
                          hsteinmeH Online
                          hsteinme
                          #194
                          @agria4800 calendar.calJson hat 1:1 die Struktur, die der Mäher erwartet. Wird diese Struktur geändert, wird der Mäher sie nicht mehr verstehen. Zudem ist dieser Datenpunkt schon einige Zeit lang verfügbar. Würde jetzt im Nachhinein dessen Struktur geändert werden, werden plötzlich alle die Programme auf die Nase fallen, die den Datenpunkt heute schon nutzen.
                          Also ist Auswendiglernen angesagt: Der 1. Eintrag ist der Sonntag.
                          • lobomauL Offline
                            lobomauL Offline
                            lobomau
                            #195
                            Ich bekomme folgende Info-Meldung. Kam mit 1.3.6. Eben 1.3.7 installiert, hat aber nichts geändert:
                            worx.0	2021-06-08 09:35:28.448	info	(29840) State value to set for "worx.0.xxx.weather.lastUpdate" has to be type "date" but received type "number"
                            worx.0	2021-06-08 09:35:28.446	info	(29840) State value to set for "worx.0.xxxx.weather.humidity" has to be type "string" but received type "number"
                            worx.0	2021-06-08 09:35:21.127	info	(29840) worx is selected
                            worx.0	2021-06-08 09:35:21.076	info	(29840) starting. Version 1.3.7 in /opt/iobroker/node_modules/iobroker.worx, node: v12.22.1, js-controller: 3.3.11
                            Host: NUC8i3 mit Proxmox:
                            • Slave: Pi4
                            hsteinmeH T 2 Antworten Letzte Antwort
                            • lobomauL lobomau
                              hsteinmeH Online
                              hsteinmeH Online
                              hsteinme
                              #196
                              @lobomau Wann genau kommt diese Meldung?
                              • lobomauL lobomau
                                tombox
                                #197
                                @lobomau Datenpunkt mal manuell löschen dann sollte es gehen
                                • T tombox
                                  lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  #198
                                  @tombox ja, genau. So hatte ich es wegbekommen.
                                  • Slave: Pi4
