  4. Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK
    6.5k
1.0k Beiträge 16 Kommentatoren 321.4k Aufrufe 15 Beobachtet
  • G GOETSCHHOFER
    @crunchip
    Habe das ganze jetzt nochmals beim Klon-210-Influxdb durchgeführt, aber soweit ich dies beurteilen kann, ist da alles schon mal gelaufen ?
    Zwischendurch möchte ich mal vielen, vielen, vielen Dank sagen für deine Geduld und Mühe. Die Zeit muss sein !
    Current default time zone: 'Europe/Vienna'
    Local time is now:      Sat May  8 17:16:05 CEST 2021.
    Universal Time is now:  Sat May  8 15:16:05 UTC 2021.
    root@INFLUXDB:~# apt install sudo curl
    Reading package lists... Done
    Building dependency tree
    The following additional packages will be installed:
      libcurl4
    The following NEW packages will be installed:
      curl libcurl4 sudo
    0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
    Need to get 1841 kB of archives.
    After this operation, 5007 kB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Get:1 http://security.debian.org buster/updates/main amd64 libcurl4 amd64 7.64.0-4+deb10u2 [332 kB]
    Get:2 http://ftp.debian.org/debian buster/main amd64 sudo amd64 1.8.27-1+deb10u3 [1244 kB]
    Get:3 http://security.debian.org buster/updates/main amd64 curl amd64 7.64.0-4+deb10u2 [265 kB]
    Fetched 1841 kB in 0s (3715 kB/s)
    Selecting previously unselected package libcurl4:amd64.
    (Reading database ... 20541 files and directories currently installed.)
    Preparing to unpack .../libcurl4_7.64.0-4+deb10u2_amd64.deb ...
    Unpacking libcurl4:amd64 (7.64.0-4+deb10u2) ...
    Selecting previously unselected package curl.
    Preparing to unpack .../curl_7.64.0-4+deb10u2_amd64.deb ...
    Unpacking curl (7.64.0-4+deb10u2) ...
    Selecting previously unselected package sudo.
    Preparing to unpack .../sudo_1.8.27-1+deb10u3_amd64.deb ...
    Unpacking sudo (1.8.27-1+deb10u3) ...
    Setting up sudo (1.8.27-1+deb10u3) ...
    Setting up libcurl4:amd64 (7.64.0-4+deb10u2) ...
    Setting up curl (7.64.0-4+deb10u2) ...
    Processing triggers for systemd (241-7~deb10u7) ...
    Processing triggers for man-db (2.8.5-2) ...
    Processing triggers for libc-bin (2.28-10) ...
    root@INFLUXDB:~# adduser karl
    adduser: The user `karl' already exists.
    root@INFLUXDB:~# usermod -aG sudo karl
    Kalle Blomquist
    schrieb am zuletzt editiert von Kalle Blomquist
    #296
    @goetschhofer kleiner Hinweis von mir.
    Du kannst in Proxmox unter "Hinweis" Notizen schreiben, oder Befehle wie "dpkg-reconfigure tzdata".
    Hat den Vorteil, dass du dir die ganzen Befehle nicht immer neu suchen oder merken mußt, zumindest für den Anfang.
    Ich bin jetzt nicht den ganzen Faden durchgegeangen, ob es schon jemand geschrieben hat.
    Vielleicht hilft´s
    Gruß Kalle
    crunchipC G 2 Antworten Letzte Antwort
    • G GOETSCHHOFER
      @crunchip
      Ergebnis nach neuem Versuch.
      Local time is now:      Sat May  8 17:24:08 CEST 2021.
      Universal Time is now:  Sat May  8 15:24:08 UTC 2021.
      root@INFLUXDB:~#
      sudo is already the newest version (1.8.27-1+deb10u3).
      curl is already the newest version (7.64.0-4+deb10u2).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      crunchipC Abwesend
      crunchipC Abwesend
      #297
      @goetschhofer ja jetzt siehst du
      is already the newest, ein post weiter oben hatte es noch gefehlt, also hat schon seine richtigkeit
      G 1 Antwort Letzte Antwort
      • K Kalle Blomquist
        Vielleicht hilft´s
        Gruß Kalle
        crunchipC Abwesend
        crunchipC Abwesend
        #298
        @4-7kohm stimmt, kann man sich generelle Notizen eintragen, dafür war das selbst erstellte template gedacht, das man an solche sachen nicht mehr denken bzw machen muss
        aber für links, persönliche Notizen, etc ist das manchmal goldwert
          Kalle Blomquist
          #299
          @crunchip 👍
          • K Kalle Blomquist
            Vielleicht hilft´s
            Gruß Kalle
            GOETSCHHOFER
            #300
            @4-7kohm
            Hallo kalle,
            ich finde den Punkt Hinweise nicht.
            Unter backup habe ich den Punkt Hinweise bearbeiten ?
            • G GOETSCHHOFER
              @4-7kohm
              Hallo kalle,
              Kalle Blomquist
              #301
              Rechts auf das Zahnrad gehen, dann bearbeiten, äh und speichern
              • K Kalle Blomquist
                GOETSCHHOFER
                #302
                @4-7kohm
                Das Gute liegt so nah ! 👍
                  GOETSCHHOFER
                  #303
                  @crunchip
                  Es will und will offenbar nicht ? Fehlermeldung beim Installieren InfluxDB ?
                   karl@INFLUXDB:~$ login as: karl
                  > the exact distribution terms for each program are described in the
                  > individual files in /usr/share/doc/*/copyright.
                  > Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                  > permitted by applicable law.
                  > Last login: Sat May  8 17:39:53 2021 from 192.168.1.3
                  > karl@INFLUXDB:~$ wget -qO- https://repos.influxdata.com/influxdb.key | sudo ap           t-key add -
                  > [sudo] password for karl:
                  > E: gnupg, gnupg2 and gnupg1 do not seem to be installed, but one of them is re           quired for this operation
                  > karl@INFLUXDB:~$ source /etc/os-release
                  > karl@INFLUXDB:~$ echo "deb https://repos.influxdata.com/debian $(lsb_release -           cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                  > -bash: lsb_release: command not found
                  • G GOETSCHHOFER
                    @crunchip
                    Kalle Blomquist
                    #304
                    @goetschhofer sagte in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                    Könnte sein, dass dies fehlt?
                    E: gnupg, gnupg2 and gnupg1 do not seem to be installed, but one of them is required for this operation
                    sudo apt install gnupg2
                    • K Kalle Blomquist
                      GOETSCHHOFER
                      #305
                      @4-7kohm said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                      karl@INFLUXDB:~$ sudo apt install gnupg2
                      E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Component)
                      E: The list of sources could not be read.
                      • G GOETSCHHOFER
                        Kalle Blomquist
                        #306
                        @goetschhofer Sorry, habe Influx schon lange nicht mehr installiert. 2 mal installiert und seit dem läuft und läuft .......
                        Ich kann dir diese Doku empfehlen:
                        Link Text
                        Soweit ich mich erinnere, klappte es danach ohne Probleme. Es ist immer besser, sich auf die Doku´s vom Hersteller zu beziehen (keine Youtube) und diese ab arbeiten.
                        Leider bin ich mit meinem doch recht hohen Alter auch zu spät in Linux eingestiegen um dir bei diesem Thema bessere Hilfe geben zu können, ohne Quatsch zu erzählen.
                        Aber ich würde mal tippen, das mit deiner sources.list etwas nicht stimmt. Lesbar?
                        Gruß Kalle
                        • K Kalle Blomquist
                          Link Text
                          Gruß Kalle
                          GOETSCHHOFER
                          #307
                          @4-7kohm
                          Danke für den Hinweis.
                          Beim RSP Pi3+ hat es auch relativ rasch geklappt.
                          Ich plane ja vom RSP auf IntelNUC umzusiedeln.
                          K Thomas BraunT 2 Antworten Letzte Antwort
                          • G GOETSCHHOFER
                            @4-7kohm
                            Kalle Blomquist
                            #308
                            @goetschhofer Der Link bezieht sich auf die 1.8 Influx.
                            Hier mal die aktuelle Doku für 2.0
                            Link Text
                            • G GOETSCHHOFER
                              @4-7kohm
                              #309
                              @goetschhofer
                              Was steht denn da nun drin?
                              cat /etc/apt/sources.list.d/influxdb.list
                                @goetschhofer
                                GOETSCHHOFER
                                schrieb am zuletzt editiert von GOETSCHHOFER
                                #310
                                @thomas-braun said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                                Ich habe anstatt pve NUC stehen, könnte dies ein Problem sein ?
                                login as: karl
                                karl@192.168.1.177's password:
                                Linux INFLUXDB 5.4.106-1-pve #1 SMP PVE 5.4.106-1 (Fri, 19 Mar 2021 11:08:47 +0100) x86_64
                                Last login: Sat May  8 18:25:12 2021 from 192.168.1.3
                                karl@INFLUXDB:~$ cat /etc/apt/sources.list.d/influxdb.list
                                deb https://repos.influxdata.com/debian  stable
                                karl@INFLUXDB:~$
                                • G GOETSCHHOFER
                                  login as: karl
                                  karl@INFLUXDB:~$
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #311
                                  @goetschhofer ggf die
                                  editieren
                                  und ersetzen mit
                                  "deb https://repos.influxdata.com/debian buster stable"
                                  bzw machs so
                                  sudo apt update
                                  sudo apt install -y gnupg2  wget
                                  wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                  echo "deb https://repos.influxdata.com/debian buster stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                  installieren
                                  sudo apt update
                                  sudo apt install -y influxdb
                                  Dienst aktivieren
                                  sudo systemctl enable --now influxdb
                                  Status prüfen
                                  systemctl status influxdb
                                    editieren
                                    und ersetzen mit
                                    bzw machs so
                                    sudo apt update
                                    installieren
                                    sudo apt update
                                    Dienst aktivieren
                                    Status prüfen
                                    GOETSCHHOFER
                                    #312
                                    @crunchip said in Anfänger sucht Hilfe bei Install. proxmox auf INTELNUC8i3BEK:
                                    sudo apt update
                                    Wie kann ich dies editieren und ersetzen ?
                                    Ich bekomme bei sudo apt update bereits eine Fehlermeldung ?
                                    karl@INFLUXDB:~$ sudo apt update
                                    E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Compone        nt)
                                    karl@INFLUXDB:~$
                                    • G GOETSCHHOFER
                                      sudo apt update
                                      karl@INFLUXDB:~$
                                      #313
                                      @goetschhofer
                                      Die Zeile muss so aussehen:
                                      Kannst du mit
                                      sudo nano /etc/apt/sources.list.d/influxdb.list
                                      editieren.
                                      G crunchipC 2 Antworten Letzte Antwort
                                        @goetschhofer
                                        Kannst du mit
                                        editieren.
                                        GOETSCHHOFER
                                        #314
                                        @thomas-braun @crunchip
                                        Ich denke dies war die Lösung des Problems, vielen Dank an Euch beide. 👍 👍
                                        Oder seht ihr hier noch ein Problem ?
                                        Da ich ein neugieriger Mensch bin und auch dazulernen möchte, würde mich interessieren, warum gerade das Wort buster die Lösung war ?
                                        karl@INFLUXDB:~$ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                        OK
                                        karl@INFLUXDB:~$ echo "deb https://repos.influxdata.com/debian buster stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                        Hit:1 http://ftp.debian.org/debian buster InRelease
                                        Hit:2 http://security.debian.org buster/updates InRelease
                                        Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                                        Get:4 https://repos.influxdata.com/debian buster InRelease [4737 B]
                                        Get:5 https://repos.influxdata.com/debian buster/stable amd64 Packages [1067 B]
                                        Fetched 5804 B in 0s (13.7 kB/s)
                                        All packages are up to date.
                                        karl@INFLUXDB:~$ sudo apt install -y influxdb
                                          influxdb
                                        0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 64.5 MB of archives.
                                        After this operation, 175 MB of additional disk space will be used.
                                        Get:1 https://repos.influxdata.com/debian buster/stable amd64 influxdb amd64 1.8.5-1 [64.5 MB]
                                        Fetched 64.5 MB in 14s (4579 kB/s)
                                        Selecting previously unselected package influxdb.
                                        (Reading database ... 20916 files and directories currently installed.)
                                        Preparing to unpack .../influxdb_1.8.5-1_amd64.deb ...
                                        Unpacking influxdb (1.8.5-1) ...
                                        Setting up influxdb (1.8.5-1) ...
                                        Created symlink /etc/systemd/system/influxd.service -> /lib/systemd/system/influxdb.service.
                                        Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service -> /lib/systemd/system/influxdb.service.
                                        karl@INFLUXDB:~$ sudo systemctl enable --now influxdb
                                        karl@INFLUXDB:~$ systemctl status influxdb
                                        * influxdb.service - InfluxDB is an open-source, distributed, time series database
                                           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                                           Active: active (running) since Sat 2021-05-08 19:25:25 CEST; 14s ago
                                             Docs: https://docs.influxdata.com/influxdb/
                                         Main PID: 3046 (influxd)
                                            Tasks: 10 (limit: 4915)
                                           Memory: 10.5M
                                           CGroup: /system.slice/influxdb.service
                                                   `-3046 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                        karl@INFLUXDB:~$
                                          @goetschhofer
                                          Kannst du mit
                                          editieren.
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #315
                                          @thomas-braun kleine verständnisfrage meinerseits, wenn die Datei editiert ist, fällt doch eigentlich die Zeile weg, da nicht mehr benötigt
                                          wenn der echo Befehl trotzdem abgesetzt wird, passiert dann nichts, weil schon vorhanden, oder wird die Zeile ein zweites mal eingetragen?
