  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. eqiva Türschloßantrieb
    5.9k
26 Beiträge 13 Kommentatoren 6.8k Aufrufe 11 Beobachtet
  • U Offline
    U Offline
    UwesSmartHome
    schrieb am zuletzt editiert von UwesSmartHome
    code_text
    ```pi@RaspiMaster:~ $ keyble-registeruser -n 7 -q M001A22098C33K7E57A65F118662D9E3B425DA66D6ED2FNEQ1058982
    internal/modules/cjs/loader.js:1057
      return process.dlopen(module, path.toNamespacedPath(filename));
    Error: The module '/usr/lib/node_modules/keyble/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/bluetooth_hci_socket.node'
    was compiled against a different Node.js version using
    NODE_MODULE_VERSION 64. This version of Node.js requires
    NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    the module (for instance, using `npm rebuild` or `npm install`).
        at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        at Module.require (internal/modules/cjs/loader.js:887:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at Object.<anonymous> (/usr/lib/node_modules/keyble/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)
        at Module._compile (internal/modules/cjs/loader.js:999:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)```
    code_text
    • U UwesSmartHome
      code_text
      code_text
      @uwessmarthome
      Node sauber?
      Konsolenmeldungen bitte nicht als Screenshot sondern als Text in CodeTags ins Forum.
      U 1 Antwort Letzte Antwort
        @uwessmarthome
        Node sauber?
        U Offline
        U Offline
        UwesSmartHome
        codpi@RaspiMaster:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        /usr/bin/nodejs
        v12.21.0
        /usr/bin/node
        v12.21.0
        /usr/bin/npm
        6.14.12
        nodejs:
          Installiert:           12.21.0-1nodesource1
          Installationskandidat: 12.21.0-1nodesource1
          Versionstabelle:
         *** 12.21.0-1nodesource1 100
             10.24.0-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
             10.24.0~dfsg-1~deb10u1 500
        e_text
        Thomas BraunT U 2 Antworten Letzte Antwort
        • U UwesSmartHome
          /usr/bin/nodejs
          v12.21.0
          /usr/bin/node
          v12.21.0
          /usr/bin/npm
          6.14.12
          nodejs:
            Versionstabelle:
          e_text
          @uwessmarthome
          Bitte CodeTags verwenden.
          Und das System auf Stand halten.
          sudo apt update
          sudo apt dist-upgrade
          sudo reboot
          Für node12 ist keine Paketquelle / kein Repository angelegt. Lies den Kram zu node aus meiner Signatur.
          • U UwesSmartHome
            /usr/bin/nodejs
            v12.21.0
            /usr/bin/node
            v12.21.0
            /usr/bin/npm
            6.14.12
            nodejs:
              Versionstabelle:
            e_text
            U Offline
            U Offline
            UwesSmartHome
            @uwessmarthome
            Hab es heute nochmal versucht, leider erfolglos. Diese Fehlermeldung bleibt. Node Modul Version falsch?
            • U Offline
              U Offline
              UwesSmartHome
               keyble-registeruser -n 7 -q M001A22098C33K7E57A65F11xxxxxxx        425DA66D6ED2FNEQ1058982
              Error: The module '/usr/lib/node_modules/keyble/node_modules/@abandonware/blueto        oth-hci-socket/lib/binding/bluetooth_hci_socket.node'
                  at Object.<anonymous> (/usr/lib/node_modules/keyble/node_modules/@abandonwar        e/bluetooth-hci-socket/lib/native.js:6:15)
              • U UwesSmartHome
                U Offline
                U Offline
                UwesSmartHome
                /usr/lib/node_modules/keyble/node_modules $ sudo npm rebuild
                > @abandonware/noble@1.9.2-11 install /usr/lib/node_modules/keyble/node_modules/@abandonware/noble
                > node-gyp rebuild
                gyp ERR! clean error
                gyp ERR! stack Error: EACCES: permission denied, rmdir 'build'
                gyp ERR! System Linux 5.10.17-v7+
                gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                gyp ERR! cwd /usr/lib/node_modules/keyble/node_modules/@abandonware/noble
                gyp ERR! node -v v12.22.1
                gyp ERR! node-gyp -v v5.1.0
                gyp ERR! not ok
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! @abandonware/noble@1.9.2-11 install: `node-gyp rebuild`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the @abandonware/noble@1.9.2-11 install script.
                npm ERR!     /root/.npm/_logs/2021-04-11T10_57_26_697Z-debug.log
                • U UwesSmartHome
                  > node-gyp rebuild
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  @uwessmarthome Nicht als root rumhampeln, npm nicht in Verbindung mit sudo einsetzen.
                  U B 2 Antworten Letzte Antwort
                    U Offline
                    U Offline
                    UwesSmartHome
                    @thomas-braun ```
                    pi@Master:~ $ keyble-registeruser -n Use -q M001A22098DF0K676641D845A53AB9481166DDAF024C9ANEQ1058450
                    Press and hold "Unlock" button until the yellow light flashes in order to enter pairing mode
                    Registering user on Smart Lock with address "00:xx:22:09:8d:xx", card key "676641d845a53aXXXXXXddaf024c9a" and serial "NEQ1058450"...
                    Habe es auf dem einem System geschafft die Fehlermeldungen kommen nicht mehr. Leider ist eine Anmeldung nicht möglich, es bleibt immer stehen nachdem der Button am Türschloss gedrückt wurde. Die QR Daten habe ich schon x-mal geprüft. Die Bluetooth Adresse ebenso, auch das Schloss ganz nahe am Raspberry bringt keine Anmeldung zustande. Noch eine Idee?
                      bambo587
                      habe das gleich problem wie @UwesSmartHome.
                      Da fehlt die halbe Ausgabe.
                      System neu geupdatet, sogar mit Node 14 ausprobiert, wg. Fehler wieder bei node 12.
                      Was fehlt da??
                      • B bambo587
                        Was fehlt da??
                        @bambo587 sagte in eqiva Türschloßantrieb:
                        Was fehlt da??
                        Meldungen aus deinem System fehlen da...
                        • V Offline
                          V Offline
                          Vocaris
                          ich überlege gerade, ob ich das Türschloss von Homematic kaufen soll oder das günstigere von eqiva.
                          Der eqiva hat ja nur BT. Scheint also mit einem ioB zu gehen, wenn dieser BT hat. Zumindest verstehe ich das hier so.
                          Kann man es auch direkt mit Alexa verbinden?
                          Was meint Ihr so? Besser HM oder Eqiva.
                          PS: Wenn der ioB aus wäre (z.B. abgestürzt) könnte ich das Schloss von HM ja nicht öffnen. Bei Eqiva könnte ich immer noch per BT öffnen. Aber ist BT ggf. einfacher zu "knacken"?
                          • ElzersharkE Elzershark
                            Über Katze den Adapter installieren:
                            https://github.com/oyooyo/ioBroker.keyble
                            Raspberry 4 - Putty:
                            sudo apt-get -y install bluetooth bluez libbluetooth-dev libudev-dev
                            sudo npm install --update --global --unsafe-perm keyble
                            sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                            Raspberry MUSS in der Nähe sein vom Schloß. Am besten daneben stellen.
                            App installieren auf Handy und Schloß einrichten.
                            Danach Bluetooth ausmachen vom Handy.
                            keyble-registeruser -n IrgendEinName -q XXXXXXX
                            IrgendEinName = Ein Name halt
                            XXXXXXX = der QR-Code von dem Schloß. Einfach mit nem QR-Code Scanner auslesen (Handy)
                            Danach beim Schloß 4 Sec. öffnen drücken bis es blinkt.
                            Putty beobachten. Da steht dann username_1 oder so. die Zahl merken. MAC merken. user key merken.
                            Eintragen in den Adapter. Fertig
                            Smartphone App und gleichzeitig iobroker funzt nicht. Das Schloß kann sich nur mit einem Gerät verbinden.
                            JayP79
                            @elzershark bei mir kommt nach "Registering user on Smart Lock wird address... " keine Rückmeldung mit username_1 etc.
                            Hat jemand einen Tipp für mich?
                            Viele Grüße
                            JP
                            Ich beiße nicht, ich will nur spielen. ;-)
                            • J JayP79
                              Viele Grüße
                              JP
                              JayP79
                              Jetzt bekomme ich immer die Meldung: TypeError: Cannot read properties of undefined (reading 'get_discovered_characteristic')
                              at /usr/lib/node_modules/keyble/keyble.js:878:56
                              • SchaxxeS Offline
                                SchaxxeS Offline
                                Schaxxe
                                Das Ding wird scheinbar nicht wirklich weiterentwickelt und gefixt oder?
                                Ich dachte, ich nutze einen BT Dongel in einer VM unter Proxmox, bekomme aber die Selbe Meldung wie JayP79 und kann keinen Benutzer anlernen.
                                Wenn ich einen alten Pi neben dran halte, bekomme ich User Key und einen Benutzer angelegt, dann kann ich in der eigens dafür angelegten VM genau EINMAL erfolgreich den Status des Schlosses abfragen, dann geht nie wieder irgendein Befehl (VM neu aufsetzen, dann gehts wieder, genau einmal)...Das ist dann die Antwort:
                                Error: TypeError: Cannot read properties of undefined (reading 'get_discovered_characteristic')
                                Ist die "Lösung" wirklich einen Pi mit Bluetooth neben das Schloss zu nageln, obwohl mein Proxmox mit BT nur ca 2m weiter hinten steht? Wenn ja, nicht sehr sexy
                                • SchaxxeS Schaxxe
                                  @schaxxe sagte in eqiva Türschloßantrieb:
                                  Dieses bitte auf Github beim Entwickler nachfragen.
                                  Das ist kein ioBroker-Projekt
                                  Sieht aber so aus, als ob die letzte Aktivität 3 Jahre her ist
                                  • Marc_el_KM Offline
                                    Marc_el_KM Offline
                                    Marc_el_K
                                    Falls auch noch jemand Interessa dem Github Projekt mittels ESP32 hat, würde ich mich freuen, wenn ihr den Beitrag mit +1 pusht :-)
                                    https://forum.iobroker.net/topic/68563/anfrage-für-programmier-code-anpassung-gesucht
                                    • Marc_el_KM Marc_el_K
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      @marc_el_k sagte in eqiva Türschloßantrieb:
                                      den Beitrag hier im Forum oder Dein Issue auf Github ?
                                      Lehrling seit 1975 !!!
                                      Marc_el_KM 1 Antwort Letzte Antwort
                                      • DJMarc75D DJMarc75
                                        Marc_el_KM Offline
                                        Marc_el_KM Offline
                                        Marc_el_K
                                        @djmarc75 diesen hier: https://forum.iobroker.net/topic/68563/anfrage-für-programmier-code-anpassung-gesucht
                                          rza
                                          @elzershark said in eqiva Türschloßantrieb:
                                          Hallo @Elzershark, vielen lieben Dank schon mal für deine Erläuterungen.
                                          Magst du einmal sagen in welchen Adapter die Daten eingetragen werden müssen.
                                          Der Adapter in IOB hat ja "noch" keine klassischen Textboxen.
                                          • HomoranH Homoran hat dieses Thema am aufgespalten
                                          • NegaleinN Negalein verschob dieses Thema von ioBroker Allgemein am
