  4. Test Adapter Solarlog v2.x.x latest
solarlog
76 Beiträge 12 Kommentatoren 12.7k Aufrufe 10 Beobachtet
  • J Jaschkopf
    @forelleblau Servus. Bei mir hängt sich jede Nacht um 3Uhr der Adapter auf und Startet neu. Hast du eine Idee woran das liegen kann? Hier sind die Eintrage im Log zu dem Event:
    2020-10-27 03:00:17.794 - warn: solarlog.0 (3168) readSolarlogData - Fehler in sum data inverters: TypeError: Cannot read property 'indexOf' of undefined
    2020-10-27 03:00:17.797 - warn: solarlog.0 (3168) readSolarlogData - Fehler : TypeError: Cannot read property 'indexOf' of undefined
    2020-10-27 03:00:49.855 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:49.858 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:49.860 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:49.863 - info: solarlog.0 (3168) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:49.865 - warn: solarlog.0 (3168) Mehrfach fehlerhafter http-Request, starte Adapter neu.
    2020-10-27 03:00:49.872 - info: host.iobroker stopInstance system.adapter.solarlog.0 (force=false, process=true)
    2020-10-27 03:00:49.873 - info: host.iobroker stopInstance system.adapter.solarlog.0 send kill signal
    2020-10-27 03:00:49.875 - info: solarlog.0 (3168) Got terminate signal TERMINATE_YOURSELF
    2020-10-27 03:00:49.876 - info: solarlog.0 (3168) [END] Stopping solarlog adapter...
    2020-10-27 03:00:49.876 - info: solarlog.0 (3168) terminating
    2020-10-27 03:00:49.876 - info: solarlog.0 (3168) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2020-10-27 03:00:50.388 - info: host.iobroker instance system.adapter.solarlog.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-10-27 03:00:52.886 - info: host.iobroker instance system.adapter.solarlog.0 started with pid 22887
    2020-10-27 03:00:53.963 - warn: solarlog.0 (22887) Object solarlog.0.status.yieldyear is invalid: obj.common.type has an invalid value (timestamp) but has to be one of number, string, boolean, array, object, mixed, file, json
    2020-10-27 03:00:53.964 - warn: solarlog.0 (22887) This object will not be created in future versions. Please report this to the developer.
    2020-10-27 03:00:54.059 - info: solarlog.0 (22887) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.solarlog, node: v12.19.0, js-controller: 3.1.6
    2020-10-27 03:00:54.075 - info: solarlog.0 (22887) [START] Starting solarlog adapter
    2020-10-27 03:00:54.076 - info: solarlog.0 (22887) Unterzähler - Import: true
    2020-10-27 03:00:54.077 - info: solarlog.0 (22887) Historische Daten werden nicht abgerufen
    2020-10-27 03:00:54.077 - info: solarlog.0 (22887) Forecast - Datenabruf: true
    2020-10-27 03:00:54.099 - warn: solarlog.0 (22887) Fehler Login: Cannot read property 'toString' of undefined Benuterpasswort im Solalog aktiviert??
    2020-10-27 03:00:54.100 - warn: solarlog.0 (22887) Fehler Login: Cannot read property 'push' of undefined Benuterpasswort im Solalog aktiviert??
    2020-10-27 03:00:54.102 - warn: solarlog.0 (22887) Fehler Login: The "list" argument must be an instance of Array. Received undefined Benuterpasswort im Solalog aktiviert??
    2020-10-27 03:00:54.591 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:54.595 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:54.599 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:54.604 - info: solarlog.0 (22887) Fehler beim http-request: Statuscode:503. Führe Request erneut aus.
    2020-10-27 03:00:54.610 - warn: solarlog.0 (22887) Mehrfach fehlerhafter http-Request, starte Adapter neu.
    2020-10-27 03:00:54.616 - info: host.iobroker stopInstance system.adapter.solarlog.0 (force=false, process=true)
    2020-10-27 03:00:54.616 - info: host.iobroker stopInstance system.adapter.solarlog.0 send kill signal
    2020-10-27 03:00:54.621 - info: solarlog.0 (22887) Got terminate signal TERMINATE_YOURSELF
    2020-10-27 03:00:54.621 - info: solarlog.0 (22887) [END] Stopping solarlog adapter...
    2020-10-27 03:00:54.622 - info: solarlog.0 (22887) terminating
    2020-10-27 03:00:54.622 - info: solarlog.0 (22887) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2020-10-27 03:00:55.135 - info: host.iobroker instance system.adapter.solarlog.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2020-10-27 03:00:57.627 - info: host.iobroker instance system.adapter.solarlog.0 started with pid 23039
    2020-10-27 03:00:59.251 - warn: solarlog.0 (23039) Object solarlog.0.status.yieldyear is invalid: obj.common.type has an invalid value (timestamp) but has to be one of number, string, boolean, array, object, mixed, file, json
    2020-10-27 03:00:59.252 - warn: solarlog.0 (23039) This object will not be created in future versions. Please report this to the developer.
    2020-10-27 03:00:59.624 - info: solarlog.0 (23039) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.solarlog, node: v12.19.0, js-controller: 3.1.6
    2020-10-27 03:00:59.636 - info: solarlog.0 (23039) [START] Starting solarlog adapter
    2020-10-27 03:00:59.637 - info: solarlog.0 (23039) Unterzähler - Import: true
    2020-10-27 03:00:59.637 - info: solarlog.0 (23039) Historische Daten werden nicht abgerufen
    2020-10-27 03:00:59.637 - info: solarlog.0 (23039) Forecast - Datenabruf: true
    2020-10-27 03:01:01.644 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
    2020-10-27 03:01:01.644 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
    2020-10-27 03:01:01.644 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
    2020-10-27 03:01:03.643 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
    2020-10-27 03:01:03.644 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
    2020-10-27 03:01:03.644 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
    2020-10-27 03:01:05.644 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
    2020-10-27 03:01:05.644 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
    2020-10-27 03:01:05.644 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
    2020-10-27 03:01:07.644 - warn: solarlog.0 (23039) Nicht alle WR/Zaehler gefunden
    2020-10-27 03:01:07.644 - warn: solarlog.0 (23039) Fehler, noch nicht alle Unterzaehler angelegt
    2020-10-27 03:01:07.645 - warn: solarlog.0 (23039) Adapter SMA STP10.0-3AV40 nicht vorhanden
    2020-10-27 03:01:07.645 - warn: solarlog.0 (23039) Adapter Verbrauchszähler nicht vorhanden
    Gruß Jaschkopf
    forelleblau
    @Jaschkopf Hallo Jaschkopf. Das sieht aus, als würde der Adapter nicht erreichen. Startet ev dein Solarlog jede Nacht neu? Oder ein Gerät dazwischen?
    • F forelleblau
      Jaschkopf
      @forelleblau Soweit ich das beurteilen kann eigentlich nicht. Der SolarLog sowie der iobroker hängen direkt per Kabel an der Fritzbox. Kann das etwas mit der zwangstrennung der Internetverbindung Nachts zu tun haben?
      Gruß Jaschkopf
      F 1 Antwort Letzte Antwort
      • J Jaschkopf
        Gruß Jaschkopf
        forelleblau
        schrieb am zuletzt editiert von forelleblau
        Aktuelle Test Version 2.1.4
        Veröffentlichungsdatum 26.8.2021
        Github Link https://github.com/iobroker-community-adapters/ioBroker.solarlog
        v2.1.4
        Neu werden auch bei Solarlog 500 - Geräten die History & Selfcons - Werte korrekt ausgefüllt.
        J Agria4800A 2 Antworten Letzte Antwort
        • F forelleblau
          v2.1.4
          Jaschkopf
          @forelleblau Habe neue Erkentnisse. Im Ereignisslog des SolarLog erkennt man, dass sich jede Nacht um 03:00:48Uhr der Modbus Zähler für ca. 1min trennt. Woran das Liegt kann ich noch nicht sagen, scheint aber eine Art "geplanter Neustart" der Modbus Schnittstelle zu sein. Ich habe SolarLog dazu eine Mail geschrieben, in der Hoffnung, dass sie mir dazu mehr sagen können.
          Alternativ könnte man den Fehler "überbrücken" wenn man in den Adaptereinstellungen das Verbindungstimeout erhöhen könnte. In meinem Fall auf 90sek ca. Dann würde der Adapter das Problem einfach "vertuschen". Vielleicht kannst du das mit einem Update integrieren? 🤓
          Gruß Jaschkopf
          • J Jaschkopf
            Gruß Jaschkopf
            Jaschkopf
            Ich habe gerade schon eine Antwort vom Support erhalten:
            Sehr geehrter Herr Jaschkopf,
            der Solar-Log™ macht jede Nacht um 3 Uhr einen Neustart, daher die Trennung der Verbindung.
            Das Verhalten lässt sich nicht konfigurieren und ist wichtig für die Reorganisation des Systems.
            Gruß Jaschkopf
            • F Offline
              forelleblau
              @Jaschkopf Danke für den Input. Das ist wohl das einfachste, dass ich den letzten 'Retry' etwas rausschiebe. Werds mal einpflegen, wenn ich dazukomme.
              Herzliche Grüsse forelleblau
              • F forelleblau
                Aktuelle Test Version 2.2.x
                Veröffentlichungsdatum 25.2.2023
                NEU: 'forecast - Fehler behoben
                V2.2.6 - github/latest
                'forecast' Fehler behoben.
                V2.2.5
                Keine zusätzlichen Funktionen. Anpassungen im Wesentlichen in der Programmierung. Verschiedene Fehler (z.B. falsche Objektformate). Ready für js-controller > 4
                V2.2.1
                Da 'request' nicht mehr weiter unterstützt/ausgebaut wird, setzt der Adapter neu auf 'got' für die http-requests beim Solarlog. node.js wurde auf >=12 angehoben.
                V2.1.2
                JS-Controller 3.3.x - Kompatibilität sichergestellt.
                V2.1.1
                Neu werden alle Werte aus der Grafik im Cockpit und die Anzeige einiger Icons und Fehlermeldungen (resp. ob OK steht) importiert.
                V2.0.2
                Neu werden die Smart-Energy Schaltgruppen mit Name, verknüpfter Hardware (inkl. Untereinheit wo vorhanden), Schaltereinstellung (on/off/auto) und Schaltzustand im Adapter abgebildet. Voraussetzung ist der Import der 'Wechselrichter und Gerätedaten' in den erweiterten Einstellungen.
                V2.0.1
                Da beim ersten Start des Adapters immer mehr Daten aus dem Solarlog geholt werden, sind Fälle aufgetreten, in denen das Timing zwischen Datenbeschaffung und Objekte anlegen im Adapter nicht mehr passend war. Dies wurde korrigiert.
                Danke den Meldern.
                V2.0.x
                Die neue Version bringt eine ganz neue Struktur der Kommunikation mit dem Solarlog. Die Anzahl Anfragen an den Solarlog kann damit massiv reduziert werden. Es wird gebündelter und gezielter abgefragt. Beide Systeme werden so weniger belastet.
                Zudem werden neu ein paar technische / Systemdaten abgerufen und im .info - channel bereitgestelt und es werden aus den im Solarlog eingetragenen Daten eine Tages-, Monats(laufender und alle)-, und Jahressollwert berechnet und zur Verfügung gestellt. Die Werte sind im .forecast-channel zu finden und sind mit 'setpoint' bezeichnet um sie von 'forecast' - Werten, die optional von forecast.solar abgerufen werden können abzugrenzen (mit besten Grüssen an @hmanfred ). Die Sollwerte funktionieren auf jeden Fall bei Einzelanlagen. Besteht eine Anlage aus mehreren Anlagegruppen, stimmen die Werte möglicherweise nicht. Sollte dies der Fall sein. bitte ich um Feedback hier oder im Issue zum Thema auf github.
                V.1.3.x
                Mit der neuen Version 1.3.x kann nun im Solarlog das Benutzerpasswort aktiviert / gesetzt werden. Gleichzeitig muss in den Adaptereinstellungen das Häkchen dafür gesetzt und das Benutzerpasswort vom Solarlog angegeben werden.
                Will man auf die Solarlog - UI (per solarlog-ip im Browser) zugreifen, sollte der Adapter aber gestoppt werden, da sonst Authentifizierungsprobleme entstehen. Ebenso sollte nicht von mehreren Instanzen gleichzeitig auf den Solarlog zugegriffen werden. Für den 'Mehrfachzugriff' empfiehlt sich nur die Variante mit deaktiviertem Benutzerpasswort.
                Danke fürs Testen und für Feedback an dieser Stelle, freue mich auch über positives.
                forelleblau
                mauseb
                @forelleblau said in Test Adapter Solarlog v2.0.x latest:
                Aktuelle Test Version 2.1.x
                Veröffentlichungsdatum 04.04.2021
                NEU: Werte aus Cockpit-Grafik und LCD-Display
                V2.1.1
                V2.0.2
                V2.0.1
                Danke den Meldern.
                V2.0.x
                V.1.3.x
                forelleblau
                Hallo, ich bin ganz neu bei ioBrocker und teste gerade mein Solarlog 300.
                Soweit ich es nun sehe scheint eine Verbindung zum Solarlog da zu sein.
                Leider weiß ich noch nicht wo die Einträge stehen, dachte ich kann es mit History mir Sichern und dann Anzeigen lassen. Der speichert aber nur true/false ab.
                Bekomme dieses nun angezeigt.
                Hat jemand damit schon Erfahrungen und kann einen Neuling helfen ?
                Danke im voraus
                Björn
                1d25555d-05d7-4566-8ec5-b141a703ca1c-Bildschirmfoto 2021-04-09 um 21.36.26.png
                • M mauseb
                  V2.1.1
                  V2.0.2
                  V2.0.1
                  Danke den Meldern.
                  V2.0.x
                  V.1.3.x
                  forelleblau
                  Danke im voraus
                  Björn
                  forelleblau
                  @mauseb Hallo Björn
                  Da sollten natürlich Zahlen stehen und nicht true oder false. Hast du im solarlog die json-schnittstelle aktiviert? Benutzerpasswort aktiviert oder nicht und im Adapter entsprechend e8ngetragen?
                  Lieber Gruss Marcel
                  • F forelleblau
                    @mauseb Hallo Björn
                    Lieber Gruss Marcel
                    mauseb
                    @mauseb Hallo Björn
                    Lieber Gruss Marcel
                    Hallo Marcel,
                    vielen Dank für den Hinweis. Hatte überhaupt nicht mehr an das Webinterface von SolarLog gedacht. Hatte dort noch eine Firmware von 2013 drauf. Update drauf und nun kommen dort auch die Daten.
                    Danke nochmal, tolles Forum
                    jetzt gerne noch eine tolle Vis und ich wäre glücklich
                    Gruß Björn
                      schmuh
                      Hi Marcel,
                      zur Info, falls du es noch nicht mitbekommen haben solltest. Nach dem Upgrade de js-controllers 3.3.1 (Latest Rep.) gibt es viele Warnungen im Log.
                      Man sotte dies dem Entwickler melden: https://forum.iobroker.net/topic/44624/js-controller-3-3-jetzt-im-latest
                      NACH der Installation
                      Falls im Log Warn-Meldungen auftauchen mit dem Hinweis diese an den Entwickler zu senden, dann bitte schauen welcher Adapter es ist und entsprechend dort Issues bitte anlegen!
                      Logs:
                      solarlog.0	2021-04-30 15:09:40.000	warn	(9274) State value to set for "solarlog.0.INV.SMA STL 8000-20.PAC" has wrong type "string" but has to be "number"
                      solarlog.0	2021-04-30 15:09:40.000	warn	(9274) State value to set for "solarlog.0.INV.PV-Erzeugung.PAC" has wrong type "string" but has to be "number"
                      solarlog.0	2021-04-30 15:09:39.999	warn	(9274) State value to set for "solarlog.0.INV.Eigenverbrauch.PAC" has wrong type "string" but has to be "number"
                      solarlog.0	2021-04-30 15:08:53.985	warn	(9274) State value to set for "solarlog.0.forecast.tomorrow" has wrong type "number" but has to be "string"
                      solarlog.0	2021-04-30 15:08:53.984	warn	(9274) State value to set for "solarlog.0.forecast.today" has wrong type "number" but has to be "string"
                      solarlog.0	2021-04-30 15:08:53.586	info	(9274) Alle WR/Zaehler gefunden
                      Viele Grüße
                      Werner
                      • S schmuh
                        Hi Marcel,
                        Logs:
                        Viele Grüße
                        Werner
                        forelleblau
                        @schmuh Danke für den Hinweis, Werner. Habs noch nicht mitbkommen. Werd mich drum kümmern, wenn ich dazukomme, kann aber paar Tage dauern.
                        Grüsse Marcel
                        • F forelleblau
                          Grüsse Marcel
                          forelleblau
                          @schmuh
                          Hallo Alle
                          Die aufgetretenen Fehler sind behoben (sollten behoben sein) mit V2.1.2. die ab sofort im latest / auf github verfügbar ist.
                          Grüsse
                          Marcel
                          • F forelleblau
                            @schmuh
                            Hallo Alle
                            Grüsse
                            Marcel
                            schmuh
                            @forelleblau
                            Hi Marcel,
                            wie immer, klasse Arbeit. Funktioniert perfekt! 👍
                            Beste Grüße
                            Werner
                            • S schmuh
                              @forelleblau
                              Hi Marcel,
                              Beste Grüße
                              Werner
                              forelleblau
                              @schmuh Danke Werner! Freut mich wenn alles läuft.
                              Schönes Wochenende, Marcel
                              Agria4800A S 2 Antworten Letzte Antwort
                              • F forelleblau
                                Agria4800A Offline
                                Agria4800A Offline
                                Agria4800
                                @forelleblau : Auch von meiner Seite aus als "stiller Nutzer" ein DANKE an dich 👍
                                Ach, na gut, wenn ich schon dabei bin, dann auch gleich mit ne Frage!
                                Ist es für dich ein großer Aufwand, alle DP außer Aktuell von Watt in kW zu ändern?
                                Ich mache das aktuell mit JS, dabei generiere ich mir noch den Eigenverbrauch pro Monat(indem ich die Tageswerte addiere) und verrechne somit diese mit Verbrauch und Erzeugung, sodass ich den Bezug und der Ertrag erhalte. Das wäre natürlich auch ein Traum, wenn das der Adapter leiten könnte...
                                Okay, jetzt sind es schon 2 Fragen... 😊
                                • F forelleblau
                                  schmuh
                                  @forelleblau
                                  Hi Marcel,
                                  es kommen noch ein paar kosmetische Logs, guckst du:
                                  solarlog.0	2021-05-16 09:25:05.046	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
                                  solarlog.0	2021-05-16 09:25:05.046	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
                                  solarlog.0	2021-05-16 08:25:06.267	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
                                  solarlog.0	2021-05-16 08:25:06.267	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
                                  solarlog.0	2021-05-16 07:25:03.636	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
                                  solarlog.0	2021-05-16 07:25:03.635	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
                                  solarlog.0	2021-05-16 06:25:03.860	info	(25442) State value to set for "solarlog.0.forecast.tomorrow" has to be type "string" but received type "number"
                                  solarlog.0	2021-05-16 06:25:03.860	info	(25442) State value to set for "solarlog.0.forecast.today" has to be type "string" but received type "number"
                                  Nicht schlimm, aber wenn du mal wieder eine Änderung machst, geht es vielleicht in einem.
                                  Schönes WE
                                  Werner
                                  • S schmuh
                                    @forelleblau
                                    Hi Marcel,
                                    Schönes WE
                                    Werner
                                    forelleblau
                                    @schmuh Hallo Werner
                                    Ist in der der github-version schon behoben. Hab es nur noch nicht als Version publiziert, weil ich noch etwas warten wollte, ob noch mehr Fehler kommen.
                                    Ev. muss du aber die bestehenden Objekte vor der Installation löschen, damit sie als 'number' neu angelegt werden.
                                    Danke vielmal für deine Aufmerksamkeit und herzliche Grüsse
                                    Marcel
                                    • Agria4800A Agria4800
                                      forelleblau
                                      @agria4800 Hallo Agria4800
                                      Danke für die Anregung. Mit ändern bin ich da lieber zurückhaltend. Da haben wohl etliche noch Visualisierungen oder eigene Berechnungen hintendran, die dann alle geändert werden müssten.
                                      Zudem arbeite ich lieber mit Watt, da diese Werte so als Integers im Solarlog geholt werden können. So kann jeder mit den Originalwerten arbeiten.
                                      Wenn du einzelne Werte gerne zusätzlich als kW im Adapter dargestellt hättest, kann ich das als Zusatz bei Gelegenheit machen, dann sag mir bitte welche.
                                      Falls jedoch viele/alle lieber kW statt Watt hätten, kann ich das schon ändern, bisher hat aber für mich nichts dafür gesprochen.
                                      herzliche Grüsse
                                      forelleblau
                                      • F forelleblau
                                        Marcel
                                        forelleblau
                                        @forelleblau Hallo Werner. Ist jetzt mit v2.1.3 im latest-repo publizeirt.
                                        Grüsse Marcel
                                        • F forelleblau
                                          Grüsse Marcel
                                          schmuh
                                          @forelleblau
                                          Hallo Marcel,
                                          Super! Wie du geschrieben hast, musste ich die DP einmal löschen.
                                          Beste Grüße
                                          Werner
