  4. Alexa Ansagen I Telegram I EMail I Alias I VISU I HTML
    6.6k
alexaansageblocklyfensteriqontroljarvisjavascripttür-fenster-kontakt
526 Beiträge 42 Kommentatoren 162.7k Aufrufe 58 Beobachtet
  • L Online
    L Online
    Lucky_ESA
    schrieb am zuletzt editiert von Lucky_ESA
    #234
    Ich hatte auch das Bild von Luftfeuchtigkeit geändert.
    data:image/png;base64,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
    Und den Scrollbalken abschaltbar machen.
    So sieht es bei mir aus...Geilomat, danke.
    • L Lucky_ESA
      dslraserD Offline
      dslraserD Offline
      dslraser
      #235
      @lucky_esa
      das Bild ist aber an verschiedenen Stellen im Blockly vorhanden.
      Beim Blockly Start wird html_hell mit einer schwarzen Grafik gestartet.
      Beim ersten Klick auf die linke Grafik wird html_dunkel eingestellt (meine Einstellung)
      Bei einem weiteren Klick auf die linke Grafik wir die eigene_html eingestellt.
      Beim der "Erstinstallation" ist die eigene html Einstellung noch leer und wird mit Klick auf die linke Grafik mit "Standardwerten" in blau eingestellt.
      Danach können die eigenen html Einstellungen in den Datenpunkten beliebig überschrieben werden und bleiben erhalten. Das hatte ich mal so gemacht, damit man überhaupt weiß was da rein kommt.
      Die Farben bzw. html Ansichten können auch mit dem Datenpunkt 06_Trigger_Farbe_iQontrol_Fenster_Liste umgestellt werden. Diesen Datenpunkt bedient quasi iQontrol mit der linken Grafik.
      • L Lucky_ESA
        dslraserD Offline
        dslraserD Offline
        dslraser
        #236
        @lucky_esa sagte in Alexa Ansagen I Telegram I EMail I Alias I VISU I HTML:
        den habe ich bei mir nicht (MacBook pro) auch nicht auf dem Handy oder Tablet. Egal bei welchem Browser, den habe ich nicht.
        Kann es sein das Du eine Windows Maschine hast ?
        • L Online
          L Online
          Lucky_ESA
          #237
          Stimmt, dann ist das mit den Grafiken überflüssig. Hatte das mit den 3 verschiedenen Grafiken gar nicht auf`m Schirm.
          Jetzt muss ich das mit der Luftfeuchtigkeit ändern....
          Ja, ich habe Windows aber micht stören die Scrollbalken nicht.
          • L Lucky_ESA
            dslraserD Offline
            dslraserD Offline
            dslraser
            #238
            Ich hatte das sogar mal abschaltbar gemacht, aber dann konnte man in iQontrol gar nicht mehr scrollen und eine längere Liste war dann abgeschnitten.
            • L Online
              L Online
              Lucky_ESA
              #239
              Das ist wenn du das mit HTML sperrst. Das müsste man mit Java machen und in die function einbauen die öffnet und schließt.
              • L Lucky_ESA
                dslraserD Offline
                dslraserD Offline
                dslraser
                #240
                Okay, da weiß ich aber nicht wie das geht. Du ? Dann gern ein Beispiel.
                • L Online
                  L Online
                  Lucky_ESA
                  #241
                  Ich schau mal.
                  An der Anzeige sollten die Werte eventuell bei der nächsten Revision auch angepasst werden.
                  Habe ein Update der Admin Instanz durchgeführt.....hmmm
                  • L Lucky_ESA
                    Ich schau mal.
                    dslraserD Offline
                    dslraserD Offline
                    dslraser
                    #242
                    @lucky_esa
                    Meinst Du die Ausrichtung ?
                    • L Online
                      L Online
                      Lucky_ESA
                      #243
                      Nein, die dBm Werte sind fast alle falsch.
                      Habe jetzt alle 4 Objecte ausgetauscht.
                      bild21.JPG .
                      Nun sieht es wieder gut aus.
                      Bin ich wirklich der einzige mit diesem Phänomen???!!!!
                      Gruß//Bodo
                      • L Lucky_ESA
                        bild21.JPG .
                        Gruß//Bodo
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #244
                        @lucky_esa
                        Ich habe das RSSI Blockly nur in Sachen Variablen in html umgestellt, sonst so gelassen wie es von Dir kam. Ich habe im Moment nur 8 Geräte zum testen als alias dafür angelegt, bei mir passte es bisher immer...
                        dirk1962D 1 Antwort Letzte Antwort
                        • L Online
                          L Online
                          Lucky_ESA
                          #245
                          Das eq3 es bis heute nicht geschafft hat diesen Bug zu beheben ist nichts neues und das Internet ist voll davon.
                          Ich bin davon ausgegangen, dass die Instanz das automatisch umrechnet aber vielleicht liegt da ein Fehler vor.
                          Habe ca. 70 Aktoren:-)
                          So kommt es von der CCU auf einem Raspi.
                          Aber egal, bei mir funktioniert es doch jetzt👍
                          • L Lucky_ESA
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #246
                            muß denn im Blockly noch was angepasst werden ?
                            bei mir sind es 85
                            • L Online
                              L Online
                              Lucky_ESA
                              #247
                              85 ist auch OK😊
                              Da ich der einzige bin der dieses Thema hat, kannst du das bei der nächsten Revision ändern.
                              Es wäre auch besser, weil du damit die Abfragen reduzierst. 1 x Datenpunkt abfragen ist besser als 2x 😀
                              • dslraserD dslraser
                                @lucky_esa
                                dirk1962D Offline
                                dirk1962D Offline
                                dirk1962
                                #248
                                @dslraser
                                Kannst Du bitte mal zeigen, wie der Alias aussehen muss.
                                Dann teste ich das auch.
                                NUC8i5 mit Proxmox; Raspberrymatic in VM, iobroker, Motioneye, infuxDB und Grafana in CT.
                                  Ich habe im zweiten Beitrag das Anrufer_Ansage_Telegram_EMAIL Blockly aktualisiert
                                  meine verwendeten Adapter sind:
                                  TR-064 Version 4.2.12
                                  Script Engine Version 4.10.15
                                  Telegram Version 1.8.1
                                  Send emails Version 1.0.9
                                  https://forum.iobroker.net/post/549502
                                  dirk1962D Offline
                                  dirk1962D Offline
                                  dirk1962
                                  #249
                                  @dslraser
                                  Anrufer Ansage April 2021 funktioniert 👍 .
                                  E-Mail und Telegram brauche ich nicht, weil mir die Fritzbox eine Mail schickt.
                                  Script Engine V 5.1.3
                                  • L Online
                                    L Online
                                    Lucky_ESA
                                    #250
                                    Hier der Alias für RSSI.
                                    createAlias('hm-rpc.0.xxxxxxxxxxxxxxxx.0.RSSI_DEVICE'/*Taster Eingang*/, 'RSSI.Schalter_Eingang', undefined, 'rssi_alias', 'number', undefined, undefined, 'Schalter Eingang', 'value.rssi', 'per Script erstellt', -256, 256, 'dBm', undefined)
                                    Stephan SchleichS 1 Antwort Letzte Antwort
                                    • L Lucky_ESA
                                      Stephan SchleichS Offline
                                      Stephan Schleich
                                      #251
                                      @dslraser In den alten Verisonen wurde noch der Raum angezeigt in jenem das Licht an ist.(z.B. Büro Licht eingeschalten)
                                      • Stephan SchleichS Stephan Schleich
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        #252
                                        @stephan-schleich
                                        ist auch immer noch so
                                          @stephan-schleich
                                          Stephan Schleich
                                          #253
                                          @dslraser aahhh, falsch benannt :) - sorry
