  4. ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung
140 Beiträge 8 Kommentatoren 23.0k Aufrufe 4 Beobachtet
  • G GOETSCHHOFER
    @Thomas-Braun: Habe es auch mit SMB 3.1.1 probiert, aber auch eine Fehlermeldung.
    @jan1: Habe es jetzt mal mit dem Pfad der Netzwerkfreigabe probiert, aber ich bekomme auch eine Fehlermeldung.
    @crunchip: Einstellungen influxdb
    Danke für eure UntEINSTELLUNGEN INFLUXDB.JPG erstützung.
    LG
    Karl
    HEIMNETZFREIGABE-FRITZBOX-7590-27.3.2021.JPG ```
    Started iobroker ...
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker_backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.1/FRITZ.NAS/WORKGROUP/USB2-0-DISK-01/RSPPI3BACKUP /opt/iobroker/backups
    mount error(2): No such file or directory
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker_backitup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.1.1/FRITZ.NAS/WORKGROUP/USB2-0-DISK-01/RSPPI3BACKUP /opt/iobroker/backups
    [DEBUG] [iobroker] - host.raspberrypi 4777 states saved
    [DEBUG] [iobroker] - host.raspberrypi 5033 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-19_08_59_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Packed 26MB so far...
    [DEBUG] [influxDB] - Packed 76MB so far...
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-19_09_19_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - done
    [DEBUG] [cifs] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    crunchipC Offline
    crunchipC Offline
    @goetschhofer sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
    ich meinte die Einstellung im Backitup Adapter für Influx
    Dein cifs hatte doch oben gepasst, smb3 musst du in der fritzbox aktivieren, nicht nur im Adapter, dann klappt das auch
    J G HomoranH 3 Antworten Letzte Antwort
      Jan1
      @crunchip
      SMB3 kannst in der Fritz nicht aktivieren, nur SMB1 weil 3 ab 7.24 eh aktiv ist ;)
      @GOETSCHHOFER
      Dein Pfad hatte wohl doch gestimmt. Ich vergesse gerne, dass der Freigabe Name default FRITZ.NAS ist.
      Hat Dein angelegter User die Berechtigung auf das NAS zu schrieben?
      • J Jan1
        @crunchip
        @GOETSCHHOFER
        crunchipC Offline
        crunchipC Offline
        @jan1 sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
        stimmt, allerdings hab ich noch v7.21 (7490), ich habs auf smb3.0 im Adapter stehen, die beiden höheren habe ich noch nicht probiert.
          GOETSCHHOFER
          schrieb am zuletzt editiert von GOETSCHHOFER
          @crunchip
          @Jan1
          @Homoran
          Dies wär jetzt meine Frage gewesen, wo ich SMBv3 finde, denn man kann nur SMBv1 einstellen.
          Dieser Punkt hat sich damit erledigt.
          Ja, der User iobroker_backitup hat die Berechtigung lesen/schreiben.
            @GOETSCHHOFER
            Bitte den Screenshot vom richtigen Adadpter!
            @crunchip sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
            • G GOETSCHHOFER
              @crunchip
              @Jan1
              @Homoran
              Jan1
              @goetschhofer
              Dann fällt mir nichts mehr ein, was falsch sein könnte.
              G 1 Antwort Letzte Antwort
              • J Jan1
                @goetschhofer
                GOETSCHHOFER
                @jan1
                @crunchip
                Ich habe es jetzt über FTP versucht und da hat er bei der InfluxDB keine Fehlermeldung erzeugt.
                Weiters habe ich Grafana und Javaskript zum backup ergänzt, nur hier dürften die Einstellungen noch nicht korrekt sein.
                Was muss man denn bei Javaskript hier einstellen ?
                [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_27-21_18_29_backupiobroker.tar.gz
                [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_27-21_18_48_backupiobroker.tar.gz
                [DEBUG] [grafana] - Start Grafana Backup ...
                [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                [DEBUG] [grafana] - Created dashboard directory
                [DEBUG] [grafana] - Created dashboards_manually_restore directory
                [DEBUG] [grafana] - Created datasource directory
                [DEBUG] [grafana] - start Grafana request ...
                [DEBUG] [grafana] - Grafana is not available: Error: getaddrinfo ENOTFOUND http http:80
                [DEBUG] [grafana] - Grafana is not available!
                [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                [DEBUG] [grafana] - Grafana Backup cannot created ...
                [DEBUG] [grafana] - done
                [DEBUG] [javascripts] - javascript directory "/media/usb/scripts" not found
                [DEBUG] [javascripts] - done
                [DEBUG] [ftp] - FTP connected.
                [DEBUG] [ftp] - Send iobroker_2021_03_27-21_18_29_backupiobroker.tar.gz
                [DEBUG] [ftp] - Send influxDB_2021_03_27-21_18_48_backupiobroker.tar.gz
                [DEBUG] [ftp] - Send javascripts_2021_03_27-21_20_07_backupiobroker.tar.gz
                [ERROR] [ftp] - File "/opt/iobroker/backups/javascripts_2021_03_27-21_20_07_backupiobroker.tar.gz" not found
                [DEBUG] [ftp] - done
                [EXIT] 0
                crunchipC RolfMR 2 Antworten Letzte Antwort
                • G GOETSCHHOFER
                  @jan1
                  @crunchip
                  [EXIT] 0
                  crunchipC Offline
                  crunchipC Offline
                  den Pfad, den du in deiner javascript Instanz angegeben hast
                  falls noch nicht geschehen, kannst du z.b. folgenden Pfad nehmen
                  /home/mirrorscript.0
                  zu Grafana
                  nur die IP eintragen, der Port steht doch rechts
                  • G GOETSCHHOFER
                    @jan1
                    @crunchip
                    [EXIT] 0
                    RolfMR Offline
                    RolfMR Offline
                    RolfM
                    schrieb am zuletzt editiert von RolfM
                    @goetschhofer sorry wenn ich mich hier einmische aber ich würde halt nur das s ichern und einstellen was du auch wirklich hast. Bei mir sieht das so aus, ich sichere problemlos per FTP auf ein QNAP-NAS.
                    • RolfMR RolfM
                      crunchipC Offline
                      crunchipC Offline
                      @rolfm sagte in ANFÄNGER ersucht um Hilfe bei backitup - Fehlermeldung:
                      macht er doch, iobroker, grafana und influx
                      RolfMR 1 Antwort Letzte Antwort
                        RolfMR Offline
                        RolfMR Offline
                        RolfM
                        @crunchip wenn ich mir die Bilder ansehe schaut es aber jedes mal anders aus, immer andere Einstellungen
                        • RolfMR RolfM
                          crunchipC Offline
                          crunchipC Offline
                          @rolfm weils oben ein Missverständnis gab, da es nicht am Pfad liegt, sondern an der InfluxDP Einstellung im Backitup Adapter, jedoch immer noch keine Antwort diesbezüglich
                          • G Offline
                            GOETSCHHOFER
                            @crunchip
                            ja, den Fehler bei Grafana mit dem Port habe ich heute morgen schon gesehen, gestern Abend war ich offenbar schon zu blind. 😊
                            Gestern hat er bei Grafana einen API Key verlangt. Ist der API Key wirklich notwendig ?
                            In den Einstellungen bei backitup bei Javaskript habe ich als Pfad /home/mirrorscript.0, wie empfohlen, eingetragen.
                            Ich möchte nur iobroker, influxdb und grafana sichern, denke dies ist notwendig ?
                            Habe nun einen neuerlichen Versuch gestartet.
                            Was haben denn die Fehlermeldungen bei Grafana noch zu bedeuten ?
                            Müssten im Sicherungsordner nicht diese 3 Dateien erscheinen ?
                            [DEBUG] [ftp] - Send iobroker_2021_03_28-11_59_34_backupiobroker.tar.gz
                            [DEBUG] [ftp] - Send influxDB_2021_03_28-11_59_53_backupiobroker.tar.gz
                            [DEBUG] [ftp] - Send javascripts_2021_03_28-12_01_19_backupiobroker.tar.gz
                            Anbei nochmals alle Einstellungen.
                            Danke im Voraus.
                            [DEBUG] [iobroker] - host.raspberrypi 4783 states saved
                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_28-11_59_34_backupiobroker.tar.gz
                            [DEBUG] [influxDB] - Packed 34MB so far...
                            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_28-11_59_53_backupiobroker.tar.gz
                            [DEBUG] [grafana] - Grafana is available ... Status: 200
                            [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
                            [DEBUG] [grafana] - start Grafana backup compress ...
                            [DEBUG] [grafana] - cannot found Grafana Backup files
                            [DEBUG] [javascripts] - javascript directory "/home/mirrorscript.0" not found
                            [ERROR] [ftp] - File "/opt/iobroker/backups/javascripts_2021_03_28-12_01_19_backupiobroker.tar.gz" not found
                            [EXIT] 0
                            • G GOETSCHHOFER
                              @crunchip
                              Danke im Voraus.
                              [EXIT] 0
                              crunchipC Offline
                              crunchipC Offline
                              @goetschhofer
                              • ja der Api key ist notwendig
                              • pfad für javascript auch in der javascript Instanz selbst hinterlegen
                              • ja, Sicherung von iobroker, grafana und influx ist sinnvoll
                              • dein Pfad bei FTP ist direkt **/ ** ? hast du keinen Ordner dafür angelegt?
                              • Fehlermeldung für Grafana bedeutet, entweder Benutzername/Passwort oder api key falsch
                              G 2 Antworten Letzte Antwort
                                @goetschhofer
                                GOETSCHHOFER
                                @crunchip
                                Danke für die rasche Rückinfo, werde ich gleich mal versuchen umzusetzen.
                                **"dein Pfad bei FTP ist direkt / ** ? hast du keinen Ordner dafür angelegt?"
                                Ich habe in einem kurzen Video gesehen, dass man nur / angeben muss, da er aufgrund der freigegebenen Datei im Benutzer sowieso nur dorthin sichern kann.
                                Aber du hast natürlich Recht, ein Pfad wäre treffsicherer u. eindeutiger.
                                Kann ich hier den gleichen Pfad wie bei NAS eingeben ?
                                • G GOETSCHHOFER
                                  @crunchip
                                  @goetschhofer
                                  Auf einer Fritzbox sieht das bei mir so aus:
                                  FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobroker_backups
                                    @goetschhofer
                                    GOETSCHHOFER
                                    Hallo Thomas,
                                    den Ordner iobroker_backups muss ich aber vorher anlegen ?
                                    • G GOETSCHHOFER
                                      Hallo Thomas,
                                      @goetschhofer Ja, den legst du zuvor auf dem NAS an. Und dann kann man den freigeben.
                                      Bei mir werkelt allerdings smb/cifs, nicht FTP.
                                        @goetschhofer
                                        GOETSCHHOFER
                                        @crunchip
                                        Vielen Dank Crunchip nochmals für die Hilfe, jetzt habe ich alle 4 Bereiche: iobroker, influxdb, javaskript und grafana über FTP in der täglichen Datensicherung.
                                        "Fehlermeldung für Grafana bedeutet, entweder Benutzername/Passwort oder api key falsch"
                                        Ich habe irrtümlicherweise bei der api key-Erstellung den unten angeführten Key reinkopiert, anstatt den oben angeführten, dies war das Problem.😄
                                        • G GOETSCHHOFER
                                          @crunchip
                                          crunchipC Offline
                                          crunchipC Offline
                                          @goetschhofer also, läuft nun auch das Backup? Somit wieder eine Baustelle weniger😉
