  4. Iobroker nach einstecken eines CC26x2r1 nicht erreichbar
46 Beiträge 4 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • D Dani 0
    @homoran J momentan habe ich wieder nur den Conbee2 Stick eingesteckt. Diesen würde ich gerne gegen den cc26x2r1 tauschen.
    pi@raspberrypi:~ $ iobroker list instances
    Cannot read system.config: null (OK when migrating or restoring)
    Cannot find view "system" for search "host"
    • instance is alive
    @dani-0
    Versuch mal
    iobroker stop
    iobroker fix
    iobroker start
      @dani-0
      Versuch mal
      iobroker stop
      iobroker fix
      iobroker start
      Dani 0
      Iobroker ist leider immer noch nicht erreichbar
      pi@raspberrypi:~ $ iobroker fix
      library: loaded
      Library version=2021-01-23
          Welcome to the ioBroker installation fixer!
          Script version: 2020-12-07
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      OK:2 https://phoscon.de/apt/deconz buster InRelease
      OK:3 http://archive.raspberrypi.org/debian buster InRelease
      OK:4 https://deb.nodesource.com/node_10.x buster InRelease
      Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
      Es wurden 13,0 MB in 10 s geholt (1.270 kB/s).
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:~ $ iobroker start
      • D Dani 0
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        @dani-0
        Fast...
        cd /opt/iobroker
        iobroker stop
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker start
          @dani-0
          Fast...
          cd /opt/iobroker
          iobroker stop
          iobroker start
          Dani 0
          @thomas-braun said in Iobroker nach einstecken eines CC26x2r1 nicht erreichbar:
          leider noch nicht erreichbar.
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ iobroker stop
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.11
          > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          object 0_userdata.0.example_state created
          object 0_userdata.0 created
          object alias.0 created
          object system.certificates created
          object system.repositories created
          object system.config created
          object enum.functions created
          object enum.rooms created
          object system.group.user created
          object system.group.administrator created
          object _design/system created
          The following notifications happened during sync:
          - Ignoring Directory "accuweather.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "alexa2.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "daswetter.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "deconz.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "feiertage.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "find-my-iphone.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "flot" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "flot.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "fullcalendar.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "fullybrowser.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "history.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "hm-rega.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "hm-rpc.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "homepilot20.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "ical.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "icons-icons8" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "icons-icons8.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "icons-mfd-svg" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "icons-mfd-svg.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "info.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "javascript.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "logparser.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "mihome-airpurifier.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "mihome-vacuum.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "rpi2.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "schoolfree.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "simple-api.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "socketio.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "sonoff.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "spotify-premium.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "synology.0" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "synology.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "telegram.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-bars.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-fancyswitch.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-hqwidgets.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-inventwo.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-material-advanced.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-materialdesign.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-metro.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis-timeandweather.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis.0" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "vis.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "web" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "web.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "yahka.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "yr.admin" because officially not created as meta object. Please remove directory!
          Renamed repository "default to "stable"
          Renamed repository "latest to "beta"
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          + iobroker.js-controller@3.2.16
          updated 3 packages in 110.005s
          110 packages are looking for funding
            run `npm fund` for details
          pi@raspberrypi:/opt/iobroker $ iobroker start
          • D Dani 0
            @dani-0
            iobroker status
              @dani-0
              iobroker status
              Dani 0
              pi@raspberrypi:/opt/iobroker $ iobroker status
              Objects type: file
              States  type: file
              pi@raspberrypi:/opt/iobroker $ iobroker list instances
              + instance is alive
              • D Dani 0
                Objects type: file
                States  type: file
                + instance is alive
                @dani-0 Und
                iobroker list adapters
                  @dani-0 Und
                  Dani 0
                  pi@raspberrypi:/opt/iobroker $ iobroker list adapters
                  system.adapter.admin                   : admin          - v4.2.1
                  • D Dani 0
                    @dani-0
                    iobroker start admin
                    iobroker upload all
                      @dani-0
                      iobroker upload all
                      Dani 0
                      @thomas-braun ```
                      pi@raspberrypi:/opt/iobroker $ iobroker start admin
                      Cannot find any instances of "admin"!
                      pi@raspberrypi:/opt/iobroker $ iobroker upload all
                      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                      • D Dani 0
                        @thomas-braun ```
                        @dani-0
                        iobroker add admin
                          @dani-0
                          iobroker add admin
                          Dani 0
                          komme jetzt wieder auf den Iobroker. Leider sind alle meine Daten weg. Wie ist es möglich diese Wiederherzustellen?
                          • D Dani 0
                            @dani-0
                            Backup einspielen. Dafür hat man ja eins.
                            • D Dani 0
                              • instance is alive
                              HomoranH Offline
                              HomoranH Offline
                              @dani-0 sagte in Iobroker nach einstecken eines CC26x2r1 nicht erreichbar:
                              das war nicht die Frage!
                              Du hast nurden Stick getauscht, bevor ioBroker nicht mehr da war?
                              oder doch noch etwas installiert/geändert.....
                                Dani 0
                                @homoran jetzt wo du es sagst fällt mir ein dass ich noch den Zigbee.0 adapter installiert hatte.
                                Thomas BraunT D 2 Antworten Letzte Antwort
                                • D Dani 0
                                  @dani-0
                                  Gerade der zigbee-Adapter ist etwas 'tricky' in der Installation. Bzw. die abhängigen Module. Das wird ggf. neugebaut und wenn man da zu ungeduldig ist und mit dem System rumspielt bevor das fertig kompliert ist kann das zu komischem Verhalten führen.
                                  • D Dani 0
                                    Dani 0
                                    Bin gerade dabei gewesen ein altes Backup aufzuspielen. Jetzt komme ich wieder nicht auf den Iobroker drauf. Backup ist von vorgestern. Im Backup wurden auch nur die Daten vom Iobroker gesichert.
                                    • D Dani 0
                                      @dani-0
                                      Entsprechende Befehle zum Status siehe oben.
                                        @dani-0
                                        Dani 0
                                        Hat super funktioniert. Mein Altes Backup läuft jetzt auch wieder. Danke euch nochmal. Werde nächste Woche nochmal probieren den Zigbee.0 Adapter zu installieren.
                                        • D Dani 0
                                          Dani 0
                                          Irgendwo ist bei mir noch der Wurm drin. Habe zwischenzeitlich auf eine andere microSD Karte, NodeJS mit Version 12.21.0 und mein Backup aufgespielt. Funktionierte eigentlich ganz gut, bis auf das mein Uhrzeit vom Raspi (heute morgen erst bemerkt) eine Stunde nachlief.
                                          pi@raspberrypi:/opt/iobroker $ node -v
                                          v12.21.0
                                          pi@raspberrypi:/opt/iobroker $ npm -v
                                          6.14.11
                                          Heute war allerdings der Strom weg und bei erneutem Starten stand ich wieder vor dem Selben Problem. Also wieder das Letzte Backup aufgespielt und Interessehalber über den Befehl
                                          Iobroker neu gestartet. Und wieder Stehe ich vor dem Gleichen Problem, das Iobroker nicht startet und unter Adapter list wieder das Gleiche Kommt.
                                          hatte eigentlich nie das Problem gehabt das nach einem Stromausfall mein Iobroker nicht mehr gestartet hat. Habt ihr mir einen Tipp?
                                          Das müsste der Log nach dem Neustart von Iobroker sein.
                                          2021-03-16 19:15:56.092  - info: host.raspberrypi instance scheduled system.adapter.ical.0 */30 * * * *
                                          2021-03-16 18:50:36.839  - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                                          2021-03-16 18:50:36.845  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                          2021-03-16 18:50:36.846  - info: host.raspberrypi hostname: raspberrypi, node: v12.21.0
                                          2021-03-16 18:50:36.846  - info: host.raspberrypi ip addresses: 192.168.178.5 fd01:9303:5c70:2:d114:582f:ec61:b274 fe80::81d2:fd57:4ccb:b830
                                          2021-03-16 18:50:36.919  - error: host.raspberrypi-Server Cannot load /opt/iobroker/iobroker-data/objects.json: /opt/iobroker/iobroker-data/objects.json: Unexpected end of JSON input. Try last Backup!
                                          2021-03-16 18:50:36.922  - error: host.raspberrypi-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: /opt/iobroker/iobroker-data/objects.json.bak: Unexpected end of JSON input. Continue with empty dataset!
                                          2021-03-16 18:50:37.007  - error: host.raspberrypi Cannot read system.config: null (OK when migrating or restoring)
                                          2021-03-16 18:50:37.018  - error: host.raspberrypi-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                                          2021-03-16 18:50:37.141  - info: host.raspberrypi connected to Objects and States
                                          2021-03-16 18:50:37.228  - warn: host.raspberrypi logger system.adapter.admin.0.logging was deleted
                                          2021-03-16 18:50:37.230  - warn: host.raspberrypi logger system.adapter.javascript.0.logging was deleted
                                          2021-03-16 18:50:37.230  - warn: host.raspberrypi logger system.adapter.logparser.0.logging was deleted
                                          2021-03-16 18:50:37.244  - info: host.raspberrypi added notifications configuration of host
                                          2021-03-16 18:50:37.251  - error: host.raspberrypi Cannot find view "system" for search "instance"
                                          2021-03-16 18:50:37.252  - error: host.raspberrypi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                                          2021-03-16 18:50:37.270  - info: host.raspberrypi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                          2021-03-16 18:50:37.322  - error: host.raspberrypi Cannot find view "system" for search "host"
                                          2021-03-16 18:50:37.330  - error: host.raspberrypi Cannot find view "system" for search "state"
                                          2021-03-16 18:50:37.331  - error: host.raspberrypi Cannot find view "system" for search "instance"
                                          2021-03-16 18:50:37.333  - error: host.raspberrypi Could not collect system.host.raspberrypi states to check for obsolete states: Error: Cannot find view "system"
                                          2021-03-16 18:50:37.334  - error: host.raspberrypi _design/system missing - call node iobroker.js setup
                                          2021-03-16 18:50:37.547  - info: host.raspberrypi Created UUID: ae43de24-f240-c0a5-5261-bb8bda21d4a0
                                          Danke schon mal für eure Hilfe.
