  4. Motioneye Zeitliche Video Aufnahme
    6.3k
blocklymonitoringjavascript
16 Beiträge 3 Kommentatoren 3.0k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @yoda
    Hier:
    motioneye.conf
    motionEye uses a configuration file (usually called motioneye.conf) that allows customizing your setup (including paths, logging, various timeouts and other options that cannot be modified through the UI). The default location for this file is /etc/motioneye/motioneye.conf and can be changed using the -c command line switch.
    YodaY Offline
    YodaY Offline
    Yoda
    @wendy2702
    Eingabe am Raspi3 / Terminal wo Motioneye läuft:
    Gruß Yoda
    Stand 05.2025
    Raspberry5,linux,arm64,CPUs:4,Geschwindigkeit:2400 MHz,Modell:Cortex-A76,RAM:15.8 GB,Node.js:v20.19.2
    • YodaY Yoda
      @wendy2702
      wendy2702W Online
      wendy2702W Online
      @yoda so geht das auch nicht.
      Das file muss mit einem Editor geöffnet und bearbeitet werden.
      z.B.
      sudo nano /etc/motioneye/motioneye.conf
      YodaY 1 Antwort Letzte Antwort
        z.B.
        YodaY Offline
        YodaY Offline
        Yoda
        @wendy2702 soory aber die Befehle über das Terminal sind mir grade mal zu 1 % Bekannt :-(
        habe die conf. nun aufgerufen - möchte da nun aber auch nichts falsch machen - wie geht es da weiter?
        # path to the configuration directory (must be writable by motionEye)
        conf_path /etc/motioneye
        # path to the directory where pid files go (must be writable by motionEye)
        run_path /var/run
        # path to the directory where log files go (must be writable by motionEye)
        log_path /var/log
        # default output path for media files (must be writable by motionEye)
        media_path /var/lib/motioneye
        # the log level (use quiet, error, warning, info or debug)
        log_level info
        # the IP address to listen on
        # (0.0.0.0 for all interfaces, 127.0.0.1 for localhost)
        listen 0.0.0.0
        # the TCP port to listen on
        port 8765
        # path to the motion binary to use (automatically detected if commented)
        #motion_binary /usr/bin/motion
        Gruß Yoda
        Stand 05.2025
        • YodaY Yoda
          run_path /var/run
          log_path /var/log
          log_level info
          listen 0.0.0.0
          port 8765
          YodaY Offline
          YodaY Offline
          Yoda
          schrieb am zuletzt editiert von Yoda
          ich habe über WinCSP mal die Datei gesucht und gefunden:
          run_path /var/run
          log_path /var/log
          log_level info
          listen 0.0.0.0
          port 8765
          # whether motion HTTP control interface listens on
          # localhost or on all interfaces
          motion_control_localhost true
          # the TCP port that motion HTTP control interface listens on
          motion_control_port 7999
          # interval in seconds at which motionEye checks if motion is running
          motion_check_interval 10
          # whether to restart the motion daemon when an error occurs while communicating with it
          motion_restart_on_errors false
          # interval in seconds at which motionEye checks the SMB mounts
          mount_check_interval 300
          # interval in seconds at which the janitor is called
          # to remove old pictures and movies
          cleanup_interval 43200
          # timeout in seconds to wait for response from a remote motionEye server
          remote_request_timeout 10
          # timeout in seconds to wait for mjpg data from the motion daemon
          mjpg_client_timeout 10
          # timeout in seconds after which an idle mjpg client is removed
          # (set to 0 to disable)
          mjpg_client_idle_timeout 10
          # enable SMB shares (requires motionEye to run as root)
          smb_shares false
          # the directory where the SMB mount points will be created
          smb_mount_root /media
          # path to the wpa_supplicant.conf file
          # (enable this to configure wifi settings from the UI)
          #wpa_supplicant_conf /etc/wpa_supplicant.conf
          # path to the localtime file
          # (enable this to configure the system time zone from the UI)
          #local_time_file /etc/localtime
          # enables shutdown and rebooting after changing system settings
          # (such as wifi settings or time zone)
          enable_reboot false
          # timeout in seconds to use when talking to the SMTP server
          smtp_timeout 60
          # timeout in seconds to wait for media files list
          list_media_timeout 120
          # timeout in seconds to wait for media files list, when sending emails
          list_media_timeout_email 10
          # timeout in seconds to wait for zip file creation
          zip_timeout 500
          # timeout in seconds to wait for timelapse creation
          timelapse_timeout 500
          # enable adding and removing cameras from UI
          add_remove_cameras true
          # enables HTTP basic authentication scheme (in addition to, not instead of the signature mechanism)
          http_basic_auth false
          # overrides the hostname (useful if motionEye runs behind a reverse proxy)
          # server_name motionEye
          Wenn ich das Richtig lese wäre das doch ok auf True:
          Gruß Yoda
          Stand 05.2025
          • YodaY Yoda
            run_path /var/run
            log_path /var/log
            log_level info
            listen 0.0.0.0
            port 8765
            smb_shares false
            enable_reboot false
            smtp_timeout 60
            zip_timeout 500
            wendy2702W Online
            wendy2702W Online
            @yoda Ja.
            Und damit lauscht er nur auf dem eigenen Interface. Wohl aber nicht auf denen die von extern kommen.
            Stell den mal auf "false" und starte Motioneye neu und teste dann mal das http kommando.
              @yoda Ja.
              YodaY Offline
              YodaY Offline
              Yoda
              @wendy2702
              ok habe es gemacht -
              • Wert steht nun auf False.
              • Neustart vom ganzen Raspi3 zur Sicherheit
              • Befehl im Blocky und auch mal im Browser ausgeführt : http://192.168.178.47:7999/1/detection/start
              x Eine Video Datei wird allerdings nicht auf dem Raspi angelegt.
              Was mich nun aber grade etwas verwundert, bisschen konfus:
              Bei einer Bewegung wird über die Kamera eigene Software ein Video (per Handy zugriff - cloud) erzeugt.
              Dieses sollte aber eigentlich auch auf dem Raspi angelegt werden. - Tut es heute aber nicht mehr.
              Ich habe hier gestern noch etwas mit der Kamera Einstellungen von Motion eye rumgespielt,
              und nie Aufnahmen gesehen.
              Heute sehe ich die von Gestern - aber nicht die von grade Aktuell.
              Vielleicht macht er also den Befehl - nur wird die Video Datei nicht angelegt?...
              Oh man was für ein durcheinander....
              Aufnahmen nur von Gestern bzw. die Nacht auf dem Raspi:
              @wendy2702 Danke schon mal, das du dir die Zeit für mich genommen hast!
              LG
              Gruß Yoda
              Stand 05.2025
              • YodaY Yoda
                @wendy2702
                LG
                YodaY Offline
                YodaY Offline
                Yoda
                ich habe hier nun noch folgendes rausgefunden.
                Stelle ich in der Motion Software den "Recording Mode" auf "Motion Trigger"
                • wird keine Datei angelegt.
                Stelle ich auf " Continuous Recording"
                • werden dauerhaft Dateien erzeugt.
                Wenn man nun die zwei Einstellungen per Befehl (idealerweise im Blocky) wechseln könnte - wäre es doch die Lösung...
                Zumindest zeigt es ja schon mal das die Berechtigungen und Pfade wie ich sie habe in Ordnung wären.
                Gruß Yoda
                Stand 05.2025
                • YodaY Yoda
                  FredFF Online
                  FredFF Online
                  FredF
                  Most Active Forum Testing
                  @yoda Ich habs selber noch nicht umgesetzt, nur den Link mir gemerkt. Hier hat das jemand mit Blockly beschrieben.
                  • wendy2702W Online
                    wendy2702W Online
                    Mit der velinkten Anleitung sollte es ja eigentlich klappen.
                    Zu Datum und Uhrzeit, sicherheitshalber auch mal die Systemzeiten der Rechner prüfen falls die noch nie gestellt worden sind.
                    • FredFF FredF
                      YodaY Offline
                      YodaY Offline
                      Yoda
                      @fredf Danke für den Link, das ist sehr passend.
                      @wendy2702 Danke auch nochmal für deine Hilfe.
                      Ich habe das soweit nun auch nachgebaut. Die Position wäre dann wohl für mich Interessant
                      Run A Command: ON .........curl <IP-Adresse ....tEventStart
                      Run An End Command: ON .......curl <IP-Adresse tEventStop
                      Im Combination mit den beiden Datenpunkten
                      javascript.0.motioneye.getEventStart
                      javascript.0.motioneye.getEventStop
                      Ist für für die externe Triggerung wohl der Richtige weg, klappt aber noch nicht bei mir- ich frage dort einmal nach.
                      https://forum.iobroker.net/topic/40016/bewegungserkennung-mit-motioneye-lösung-komplett-in-blockly
                      LG
                      Gruß Yoda
                      Stand 05.2025
