  4. EXPERIMENTELL: JsonL Datenbank für js-controller
    6.4k
187 Beiträge 20 Kommentatoren 40.1k Aufrufe 28 Beobachtet
  • M msauer
    Hi...ich habe einen seltsamen Fehler nach dem Update von JARVIS auf 2.2.0, wobei der Update an sich keinen Fehler erzeugt hat.
    2021-02-25 08:05:30.352 - info: host.MSNUC-IOB instance system.adapter.jarvis.0 started with pid 3993
    2021-02-25 08:05:31.387 - error: host.MSNUC-IOB Caught by controller[0]: /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:428
    2021-02-25 08:05:31.387 - error: host.MSNUC-IOB Caught by controller[0]: throw new Error(`Unknown states type: ${config.states.type}: ${err.message}`);
    2021-02-25 08:05:31.388 - error: host.MSNUC-IOB Caught by controller[0]: ^
    2021-02-25 08:05:31.388 - error: host.MSNUC-IOB Caught by controller[0]: Error: Unknown states type: jsonl: Cannot find module '@iobroker/db-states-jsonl'
    2021-02-25 08:05:31.388 - error: host.MSNUC-IOB Caught by controller[0]: Require stack:
    2021-02-25 08:05:31.388 - error: host.MSNUC-IOB Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js
    2021-02-25 08:05:31.388 - error: host.MSNUC-IOB Caught by controller[0]: - /opt/iobroker/node_modules/@iobroker/adapter-core/build/utils.js
    2021-02-25 08:05:31.388 - error: host.MSNUC-IOB Caught by controller[0]: - /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js
    2021-02-25 08:05:31.389 - error: host.MSNUC-IOB Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.jarvis/jarvis.js
    2021-02-25 08:05:31.389 - error: host.MSNUC-IOB Caught by controller[0]: at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:428:19)
    2021-02-25 08:05:31.389 - error: host.MSNUC-IOB Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.jarvis/jarvis.js:69:12)
    2021-02-25 08:05:31.389 - error: host.MSNUC-IOB Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.jarvis/jarvis.js:555:2)
    2021-02-25 08:05:31.389 - error: host.MSNUC-IOB Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1063:30)
    2021-02-25 08:05:31.389 - error: host.MSNUC-IOB Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
    2021-02-25 08:05:31.390 - error: host.MSNUC-IOB Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:928:32)
    2021-02-25 08:05:31.390 - error: host.MSNUC-IOB Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:769:14)
    2021-02-25 08:05:31.390 - error: host.MSNUC-IOB Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
    2021-02-25 08:05:31.390 - error: host.MSNUC-IOB Caught by controller[0]: at internal/main/run_main_module.js:17:47
    2021-02-25 08:05:31.390 - error: host.MSNUC-IOB instance system.adapter.jarvis.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-02-25 08:05:31.391 - info: host.MSNUC-IOB Restart adapter system.adapter.jarvis.0 because enabled
    Ich habe mal versucht bei JARVIS einen Upload oder auch zu deinstallieren, bekomme aber dann:
    $ ./iobroker upload jarvis
    ERROR: Installation broken or unknown states type: jsonl configured.
    ERROR: process exited with code 101
    $ ./iobroker del jarvis
    Hat jemand eine Idee?
    UPDATE: Jetzt ist alles kaputt....iobroker startet nicht mehr
    root@MSNUC-IOB:/opt/iobroker# iobroker start
    root@MSNUC-IOB:/opt/iobroker# iobroker status
    dslraserD Offline
    dslraserD Offline
    dslraser
    #84
    @msauer sagte in EXPERIMENTELL: JsonL Datenbank für js-controller:
    welche Version ist es denn genau ? Ich habe hier noch Jarvis 2.2.0-beta.17 laufen und hatte bisher noch kein Problem nach der Umstellung auf jsonl. Allerdings habe ich nach der Umstellung auf jsonl noch kein Update bei Jarvis gemacht.
    • dslraserD dslraser
      msauer
      schrieb am zuletzt editiert von msauer
      #85
      @dslraser Heute stand ein "normales" Update 2.2.0 in der Liste an. Das habe ich dann installiert.
      BETA/Latest
      iobroker Update jarvis from @2.2.0-beta.49 to @2.2.0
      Proxmox 3 Node HA-Cluster Mini-PC N150 mit 32 GB RAM und 3x1TB shared SSDs via Linstor. VM- iobroker ,OpenCCU / LXC - Adguard, Traccar, iSpy, Fileserver (emby, MiniDLNA)...etc.
      L 1 Antwort Letzte Antwort
      • M msauer
        BETA/Latest
        lonsimbt
        #86
        @msauer
        Bei mir ist das jarvis-Update von 2.2.0b39 auf 2.2.0 problemlos durchgelaufen. Jarvis startet ohne Probleme, keine Auffälligkeiten oder Fehlermeldungen im Log auch nicht nach einem Neustart des Containers.
        iobroker im Container (debian Bullseye) unter proxmox 7.1
        debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
        40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
        • M msauer
          crunchipC Offline
          crunchipC Offline
          #87
          @msauer habe ebenfalls gerade das Update durchgeführt, ohne jegliche Probleme
          • M msauer
            UPDATE: Ich bin per Snapshot zurückgegangen und habe JARVIS erneut upgedatet. Dies scheint tatsächlich den iobroker zu "zerstören". Die Fehler kommen wieder und iobroker lässt sich nach dem stoppen nicht mehr starten.
            UPDATE2: Ich bin noch weiter zurückgegangen, also vor der JSONL Umstellung. Dann funktioniert der Update. Schon seltsam..
            #88
            @msauer Wie hast Du jsonl denn installiert? Nach der Anleitung oben??
            • apollon77A apollon77
              msauer
              #89
              @apollon77 ja, exakt daran gehalten...umgestellt von redis/file auf jsonl/jsonl
                msauer
                #90
                @apollon77 wow..ich kann es jetzt sogar reproduzieren...
                Bin ja per snapshot zurück und habe diesmal jsonl/files umgestellt. Nach Neustart war alles gut. Habe dann einen Adapter "alias-Manager" installiert. und siehe da
                $ ./iobroker upload alias-manager
                wenn ich jetzt neu starte, geht garantiert wieder nichts mehr..
                Ein Adapter restart reicht schon, das diese die oben genannte lange Fehlermeldung bringt
                  Kueppert
                  #91
                  ohoh...bin auch gerade eben auf jsonl ^^ hab aber natürlich nen Backup gemacht vorher :D
                  • M msauer
                    crunchipC Offline
                    crunchipC Offline
                    #92
                    @msauer hast du bei der Umstellung eine Migration angestoßen oder ohne?
                      msauer
                      #93
                      @crunchip Hier der Log meiner "Taten"
                      jsonl_inst.txt
                      • apollon77A Offline
                        #94
                        Ich würde eher frage in welchem Verzeichnis und WIE genau er die nom pakete für die db installiert hat ...
                        Wirklich
                        cd /opt/iobroker/node_modules/iobroker.js-controller
                        npm i @iobroker/db-states-jsonl @iobroker/db-objects-jsonl
                        • M msauer
                          jsonl_inst.txt
                          #95
                          @msauer Ok, ds sieht an sich alles ok aus ... keine ahnung warum npm her die pakete wegwirft
                          M 2 Antworten Letzte Antwort
                            msauer
                            #96
                            @apollon77 Es funktioniert ja auch alles danach. Auch Reboots funktionieren fehlerfrei..Sobald ich aber einen Adapter installiere/update kommen die Fehler.
                            Danach ist dann aber auch alles weitere nicht mehr möglich.
                              Kueppert
                              #97
                              Ich habe gerade testweise nach dem Wechsel auf jsonl auch meinen HM-RPC-Adapter upgedated. Alles problemlos verlaufen.
                              Hatte vorher auch redis und file und nun beides auf jsonl...
                                msauer
                                #98
                                @apollon77 sagte in [EXPERIMENTELL: keine ahnung warum npm her die pakete wegwirft
                                Könnte es an NPM Version 7.5.4 liegen? Sind vielleicht nicht alle notwendigen Dependencies installiert worden?
                                • M msauer
                                  crunchipC Offline
                                  crunchipC Offline
                                  #99
                                  @msauer ich lese hier, du hast node14 und npm 7.5 das ist wahrscheinlich dein Problem
                                    msauer
                                    #100
                                    @crunchip ja, das denke ich auch...mit redis/file funktioniert die Version, mit jsonl nicht, da wohl einige Abhängigkeiten nicht mit installiert werden. Sollte also Oben als Hinweis vermerkt werden, bloß nicht npm 7 zu nehmen...oder die Abhängigkeiten anzupassen.
                                      msauer
                                      #101
                                      @crunchip ich habe mal versucht auf npm 6.14.11 zurück zu gehen. Da bekomme ich dann npm Fehler bei der Installation von Adaptern...ich denke ich gehe wieder auf meinen Snapshot zurück und warte, das dies alles mit npm 7 auch funktioniert..schade eigentlich, aber ja meine Schuld..bin halt manchmal etwas zu uptodate.
                                      crunchipC apollon77A 3 Antworten Letzte Antwort
                                      • M msauer
                                        crunchipC Offline
                                        crunchipC Offline
                                        #102
                                        @msauer soviel ich weiss, sollte aktuell npm7.x noch gar nicht genommen werden und alle Adapter sollten mit 6.x funktionieren.
                                        • M msauer
                                          #103
                                          @msauer ich sage es mal so: npm 7 steht in den js-controller 3.2 Infos als grosses "DO NOT USE IT" drin ... also ehrlich: schau wie Du auf npm 6 zurückkommst.
                                          Wir haben zwar inzwischen den iobroekr installer mit npm7 im Griff, aber es sind jetzt zwei Themen bereiche bekannt wo es "spinnt":
                                          • github installs verhalten sich teilweise komisch
                                          • und das issue hier das er scheinbar denkt das pakete unused sind und wegräumt ...
