  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • Jorge Santisteban PozasJ Jorge Santisteban Pozas
    Hilfe bitte. Ich kann es nicht zum Laufen bringen.
    Re-enable cpu cache.
    Rebooting...
    ets Jun  8 2016 00:22:57
    rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    mode:DIO, clock div:1
    load:0x3fff0030,len:4
    load:0x3fff0034,len:7140
    load:0x40078000,len:13856
    load:0x40080400,len:4052
    entry 0x40080688
    I (29) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
    I (29) boot: compile time 19:51:06
    I (29) boot: chip revision: 1
    I (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0
    I (40) boot.esp32: SPI Speed      : 80MHz
    I (44) boot.esp32: SPI Mode       : DIO
    I (49) boot.esp32: SPI Flash Size : 4MB
    I (53) boot: Enabling RNG early entropy source...
    I (59) boot: Partition Table:
    I (62) boot: ## Label            Usage          Type ST Offset   Length
    I (70) boot:  0 nvs              WiFi data        01 02 00009000 00004000
    I (77) boot:  1 otadata          OTA data         01 00 0000d000 00002000
    I (85) boot:  2 phy_init         RF data          01 01 0000f000 00001000
    I (92) boot:  3 ota_0            OTA app          00 10 00010000 001db000
    I (99) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
    I (107) boot: End of partition table
    I (111) boot_comm: chip revision: 1, min. application chip revision: 0
    I (118) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x4c730 (313136) map
    I (244) esp_image: segment 1: paddr=0x0005c758 vaddr=0x3ffb0000 size=0x038c0 ( 14528) load
    I (250) esp_image: segment 2: paddr=0x00060020 vaddr=0x400d0020 size=0x15f514 (1438996) map
    I (788) esp_image: segment 3: paddr=0x001bf53c vaddr=0x3ffb38c0 size=0x01860 (  6240) load
    I (791) esp_image: segment 4: paddr=0x001c0da4 vaddr=0x40080000 size=0x00404 (  1028) load
    I (795) esp_image: segment 5: paddr=0x001c11b0 vaddr=0x40080404 size=0x1ee54 (126548) load
    I (875) boot: Loaded app from partition at offset 0x10000
    I (875) boot: Disabling RNG early entropy source...
    I (876) psram: This chip is ESP32-D0WD
    E (881) cpu_start: Failed to init external RAM!
    abort() was called at PC 0x40081ce9 on core 0
    ELF file SHA256: b9ffc04c8ab59a15
    Backtrace: 0x4008e3e9:0x3ffe3c00 0x4008e785:0x3ffe3c20 0x40081ce9:0x3ffe3c40 0x4007931a:0x3ffe3c80 |<-CORRUPTED
    stephan4711
    #841
    super Projekt und super Umsetzung. Vielen Dank hierfür.
    Ich habe zwei ESP32Cams. (https://www.amazon.de/gp/product/B07SBTNMMC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1). Mit einer funktioniert es ohne Probleme, mit der anderen bekomme ich den selben Fehler wie Jorge Santisteban Pozas.
    Hat vielleicht einer eine Idee, woran es liegen könnte?
    Vielen Dank.
    Grüße Stephan
    pfriedP 1 Antwort Letzte Antwort
    • S stephan4711
      Vielen Dank.
      Grüße Stephan
      pfriedP Offline
      pfriedP Offline
      pfried
      schrieb am zuletzt editiert von pfried
      #842
      @stephan4711 Ich nehme einmal an diese ESPs sind baugleich, dann liegt es meiner Erfahrung nach an der SD Karte. Hast Du schon mal die SD Karten untereinander ausgetauscht?
      Es gibt ein Tool RescuePro Deluxe von SanDisk (für nicht kommerzielle Nutzung gratis) mit der man die SD Karten restlos löschen kann, das hat mir oft geholfen.
        mcchickents
        #843
        Guten Abend,
        hatte die Version 1 jetzt sehr lange erfolgreich laufen. Habe mir am Wocheende mal die Version 2 angeschaut. Und hätte eine Frage hierzu wenn ich den ESP Starte leuchtet sofort die weiße LED. Ich komme auch auf das Webinterface leider bekomme ich aber von der CAM keine Bilder. Jemand eine Idee an was da liegen könnte. Ein neuen ESP32 habe ich mal bestelllt. Gruss Julian
        • KnallochseK Offline
          KnallochseK Offline
          Knallochse
          #844
          @jomjol Ich habe meinen Stromzähler (Ferris) mit der ESP32-Cam ausgestattet. Läuft soweit gar nicht schlecht.
          Ich hebe hier mal ein par Zahlen zum anlernen für die Datenbank.
          Würde mich freuen, wenn du die Bilder zur besseren Erkennung mit aufnehmen könntest (bitte keinen Stress, so wie es passt)
          Stromzähler.zip
          Mega Projekt. Habe die verschiedenen Versionen seit Anfang an im Betrieb, und immer noch begeistert.
          • MierscheidM Offline
            MierscheidM Offline
            Mierscheid
            schrieb am zuletzt editiert von Mierscheid
            #845
            Mahlzeit,
            ich habe den Thread durchsucht, soweit ich die SuFu der Site verstanden habe, konnte aber nichts über mein Problem finden:
            ESP32-CAM ist geflasht, SD-Karte läuft, Device ist im WLAN und anpingbar.
            Nur ist der Webserver weder über Port 80, 81 noch 8081 erreichbar.
            Was mache ich falsch?
            Edit: So ein ESP ist keine Rakete, ist klar, aber ist das normal?
            66 packets transmitted, 39 received, 40% packet loss, time 65717ms
            rtt min/avg/max/mdev = 1.363/234.536/1870.686/301.235 ms, pipe 2
            Edit 2: OMG! Das ist kein Packet loss! Die Hänger sind vermutlich ein dauernder Reboot und das Anmelden an das WLAN.
            Habe ihn nun einige Male neu gestartet und die Bootzeit passt ziemlich genau zu den Lücken im Ping.
            5 Sekunden Bootezeit und bis zu 23 Sekunden, eher aber nur sechs bis acht Sekunden alive.
            Alter, was ist das Ding schnell oben und am WLAN angemeldet. Irre.
            Aber was mag das verursachen?
            Das Log sagt nix, das ist nur damit voll:
            2021-02-24_16-28-44: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
            2021-02-24_16-28-44: =============================================================================================
            2021-02-24_16-28-44: =================================== Main Started ============================================
            HasontH 1 Antwort Letzte Antwort
            • MierscheidM Mierscheid
              Mahlzeit,
              HasontH Offline
              HasontH Offline
              Hasont
              schrieb am zuletzt editiert von Hasont
              #846
              @mierscheid
              Hallo, kann nur aus meiner Erfahrung sprechen!
              Passen die Versionen und die Files zur SD Karte sauber zusammen?
              Hast du schon mal eine andere SD Karte versucht?
              Wenn er dauernd im Reboot hängt lag es bei mir meist an Fehlern mit der SD Karte oder bei der Erstkonfiguration.
              Welche Art von Zähler hast du. Konntest du schon mal ein gutes Bild vom Zähler erkennen?
              Gruß Horst
              MierscheidM 1 Antwort Letzte Antwort
              • HasontH Hasont
                @mierscheid
                Gruß Horst
                MierscheidM Offline
                MierscheidM Offline
                Mierscheid
                #847
                @hasont Danke für Deine Antwort.
                Da musst Du Jomjol fragen, woher soll ich das wissen? 😲
                Ich habe gerade keine < 16 GB zur Hand. Warte noch auf die Lieferung.
                Die Karte habe ich nun erneut formatiert und die Dateien darauf kopiert. Hilft nichts.
                Er kommt bis zum NTP-Sync, den er vermutlich nicht einmal abschließen kann. Nix Webserver.
                Edit:
                OMG... das kann nicht sein. Mit dem zweiten neuen ESP, schnell noch geflasht, gegengecheckt. Der geht.
                Kreuztausch Kamera und ESP32-CAM-MB auf den ersten ESP gesetzt: läuft.
                Kameramodul angesehen.
                ICH BIN SCHULD!
                Bin mit dem Skalpell abgerutscht, als ich die Linse lösen wollte. Ist ein Schnitt über zwei Leiterbahnen. Wer denkt da an so einen Reboot-Effekt?
                Edit 2:
                Also, das hat alles super geklappt, @jomjol! Vielen Dank für dieses Projekt! Wie der ESP32 aus spiegelnden Doppelbildern noch den Stand der Zeiger erahnen kann, ist schon sehr beeindruckend! Habe es auch als Anfänger schnell in ioBroker integrieren können.
                Jetzt muss ich nur mal sehen, ob man da irgendwie den aktuellen Wasserverbrauch errechnen und in Flot visualisieren kann. Aber ich denke, das funktioniert nicht, bei den langen Aktualisierungsintervallen, die der ESP braucht, oder?
                • pfriedP pfried
                  stephan4711
                  #848
                  @pfried Danke für deinen Hinweis, hat leider auch nicht funktioniert. der esp startet nicht, auch nicht ohne sd-karte. ich habe mal einen neuen bestellt. mal schauen ob es damit besser funktioniert.
                  • S stephan4711
                    jomjol
                    #849
                    @stephan4711
                    Ohne SD-Karte startet die Firmware nicht, bzw. macht sofort wieder einen Reboot. Kannst du mal den ESP32 mit FTDI-Adapter starten und die ersten Ausgaben auf der seriellen Schnittstelle posten?
                    Dann schaue ich mir das mal an.
                    • KnallochseK Knallochse
                      Stromzähler.zip
                      jomjol
                      #850
                      @knallochse sagte in Wasserzähler - Version 2 - all-in-device:
                      Stromzähler.zip
                      hier mal ein erstes Update mit neuem tflite:
                      dig0810s3.tflite
                      Ist aber noch ungetestet und ich habe vor am Teaching noch etwas zu optimieren, daher kein Upload auf Github zunächst.
                      pfriedP KnallochseK 2 Antworten Letzte Antwort
                      • J jomjol
                        Stromzähler.zip
                        dig0810s3.tflite
                        pfriedP Offline
                        pfriedP Offline
                        pfried
                        #851
                        @jomjol
                        Guten Morgen, hast Du meine "3" auch mit aufnehmen können (post vom 10.02.2021)?
                        Liebe Grüße Paul
                        • J jomjol
                          Stromzähler.zip
                          dig0810s3.tflite
                          KnallochseK Offline
                          KnallochseK Offline
                          Knallochse
                          #852
                          @jomjol Test läuft. Bis jetzt sieht es gut aus. Vielen Dank für deine Bemühungen. 👍
                            pfriedP Offline
                            pfriedP Offline
                            pfried
                            #853
                            @knallochse Ist das File dig0810s3.tflite bei Dir auch nur 63kByte groß? Die "alten" dig.... Files waren alle wesentlich größer (200kByte bis 760kByte).
                            Liebe Grüße
                            Paul
                            KnallochseK J 2 Antworten Letzte Antwort
                            • pfriedP pfried
                              Liebe Grüße
                              Paul
                              KnallochseK Offline
                              KnallochseK Offline
                              Knallochse
                              schrieb am zuletzt editiert von Knallochse
                              #854
                              @pfried ja, Größe ist gleich (63kb). @jomjol hatte was von Optimierung geschrieben. Geht aber bis jetzt gut
                                pfriedP Offline
                                pfriedP Offline
                                pfried
                                #855
                                @knallochse Ok, eingespielt, mal sehen! 👍
                                • J jomjol
                                  @stephan4711
                                  stephan4711
                                  #856
                                  @jomjol Hallo Jomol, jetzt gehts, hab einen anderen bekommen. Ich denke der andre ist kaputt.
                                    Edit:
                                    ICH BIN SCHULD!
                                    Edit 2:
                                    pfriedP Offline
                                    pfriedP Offline
                                    pfried
                                    #857
                                    @mierscheid Hier mein Blocky Script:
                                    Wasserverbrauch.txt
                                    Du musst nur unter Javascript noch die einzelnen Variablen anlegen und schon geht es los!
                                    Ich speichere wöchentliche, monatliche und Jahreswerte ab (wie im Script), zwar unter der Homematic, du kannst aber genauso diese Variablen unter javascript.0 anlegen. Dann History einschalten für diese Variablen und du hast den Verbrauch in 5 MInutentakt und so weiter ..... LG Paul
                                    PS.: Im blocky ist rechts oben eine Importfunktion
                                    MierscheidM MichMeinM 2 Antworten Letzte Antwort
                                    • pfriedP pfried
                                      Wasserverbrauch.txt
                                      MierscheidM Offline
                                      MierscheidM Offline
                                      Mierscheid
                                      #858
                                      @pfried Vielen Dank, Paul. Das schaue ich mir an und baue es zum lernen nach. Du wirst lachen, aber nachdem ich Dein Script öffnete, kann ich jetzt in die mathematische Formel auch Variabeln einfügen. Warum auch immer.
                                      • pfriedP pfried
                                        Wasserverbrauch.txt
                                        MichMeinM Offline
                                        MichMeinM Offline
                                        MichMein
                                        #859
                                        @pfried und @Mierscheid
                                        Dafür kann man doch den SourceAnalytix Adapter von @Dutchman bestens verwenden. Ich nutze ihn mit höchster Zufriedenheit für Strom, Gas und Wasser. Top.
                                        Gruß Michael
                                        Sofern Beiträge hilfreich für Dich sind, nutze das Voting unten rechts.
                                        MierscheidM M 2 Antworten Letzte Antwort
                                        • MichMeinM MichMein
                                          MierscheidM Offline
                                          MierscheidM Offline
                                          Mierscheid
                                          #860
                                          @michmein Ich finde den nicht. Der ist nicht in den Sources (oder wie man das nennt) von ioBroker?
                                          Edit: Aha. Github geht auch... interessant.
