  4. ZigBee neue Version 1.4.4
neue versionzigbeezigbee neue version 1.4.0
302 Beiträge 35 Kommentatoren 119.2k Aufrufe 36 Beobachtet
  • K klassisch
    Hatte heute Nacht auch etliche Verbindungsverluste zur COM-Schnittstelle, an der die Adapterplatine hängt.
    Begann wohl gestern Nacht
    zigbee.0	2021-02-20 21:34:16.038	info	(10148) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
    zigbee.0	2021-02-20 21:34:14.443	info	(10148) Installed Version: iobroker.zigbee@1.4.4
    zigbee.0	2021-02-20 21:34:14.440	info	(10148) Starting Zigbee npm ...
    zigbee.0	2021-02-20 21:34:14.439	info	(10148) Try to reconnect. 4 attempts left
    zigbee.0	2021-02-20 21:34:04.430	info	(10148) Installed Version: iobroker.zigbee@1.4.4
    zigbee.0	2021-02-20 21:34:04.429	error	(10148) Error: Error while opening serialport 'Error: Opening COM4: File not found' at Znp.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\
    zigbee.0	2021-02-20 21:34:04.429	error	(10148) Failed to start Zigbee
    zigbee.0	2021-02-20 21:34:04.424	info	(10148) Starting Zigbee npm ...
    zigbee.0	2021-02-20 21:34:04.423	info	(10148) Try to reconnect. 5 attempts left
    zigbee.0	2021-02-20 21:33:54.412	error	(10148) Adapter disconnected, stopping
    heute Morgen hat dann der reconnect anscheinend nicht mehr funktioniert
    zigbee.0	2021-02-21 04:12:08.384	warn	(10148) Failed to ping 0xbc33acfffed57c9d FLOALT panel WS 60x60
    zigbee.0	2021-02-21 04:08:03.824	warn	(10148) Failed to ping 0xbc33acfffed7b833 FLOALT panel WS 60x60
    zigbee.0	2021-02-21 04:04:22.008	info	(10148) Installed Version: iobroker.zigbee@1.4.4
    zigbee.0	2021-02-21 04:04:22.007	error	(10148) Error: Error while opening serialport 'Error: Opening COM4: Access denied' at Znp.<anonymous> (C:\Program Files\iobroker\ioBrMain026\node_modules\zigbee-herdsman\dist\adapter\z-stack\znp\z
    zigbee.0	2021-02-21 04:04:22.007	error	(10148) Failed to start Zigbee
    zigbee.0	2021-02-21 04:04:21.997	info	(10148) Starting Zigbee npm ...
    zigbee.0	2021-02-21 04:04:21.996	info	(10148) Try to reconnect. 0 attempts left
    Heute morgen haben die Leuchten dann auch nicht mehr reagiert. Alles dunkel.
    Bin in die Adaptereinstellungen, den bisherigen COM Port nochmals aktiv ausgewählt, gespeichert und der Adapter wurde wieder grün, alle Leuchten reagieren wieder.
    Was kann ich zur Ursachensuche beitragen?
    Der Adapter hängt derzeit zusammen mit einem MX885 Drucker und einem Brother Labeldrucker an einem Hub.
    Der Gerätemanager zeigt für diesen Com-Port weder Fehler noch Warnung und hat auch kein Ereignis gemeldet, seit ich am 18.2. von ser2net auf diese direkte Verbindung umgezogen bin.
    AsgothianA
    AsgothianA
    Asgothian
    #78
    @klassisch
    Hier ist davon auszugehen das die emulation des seriellen Ports auf dem Board selber ein Problem hat.
    Welche Firmware hast du auf dem Board ?
    A.
    • AsgothianA Asgothian
      @klassisch
      A.
      arteckA
      arteckA
      arteck
      #79
      @asgothian sagte in ZigBee neue Version 1.4.4:
      ne daran wird es nicht leigen da ist die 20200211..aber hier mach ich mir sorgen es ist ein Linux system
      @klassisch hast du js-controller update gemacht ??
      @Yodameister lese bitte nochmal den Eingangsbeitrag ich habe da ein Nachtrag verfasst
      YodameisterY K 3 Antworten Letzte Antwort
        @yodameister sagte in ZigBee neue Version 1.4.4:
        Hat da jemand eine Idee ?
        Erst einmal zwei Fragen:
        • bist du wirklich zurück auf 1.2.0 gegangen ?
        • wo siehst du das die Verbindung auf false geht ?
        Hintergrund: bei batteriebetriebenen Geräten wird der „available“ state abhängig davon wann das Gerät das letzte mal gesehen wurde gesetzt. Der State kann also direkt nach einem Update nicht auf false gehen.
        Das auf der Kachel die Verbindung rot dargestellt wird liegt daran das nicht klar ist ob das Gerät verbunden ist. Das ändert sich erst wenn das Gerät eine Nachricht sendet. Ich gehe aktuell davon aus das du ein Gespenst jagst. Die entscheidende Frage ist: bekommst du von den Geräten Nachrichten wenn du sie triggers ?
        A.
        YodameisterY
        YodameisterY
        Yodameister
        #80
        @asgothian
        Moin ,
        bist du wirklich zurück auf 1.2.0 gegangen ? > Ja , IOBROKER hat mir nur 1.41 und 1.20 angeboten
        wo siehst du das die Verbindung auf false geht ? > Unter Objekte / Zigbee /
        Maik
        • arteckA arteck
          YodameisterY
          YodameisterY
          Yodameister
          schrieb am zuletzt editiert von Yodameister
          #81
          @arteck
          @klassisch hast du js-controller update gemacht ?? >>> Ja , sozusagen alles zusammen , erst JS Update dann Zigbee auf 1.44
          Wenn ich gewusst hätte das ein JS Update so viel Probleme mit sich bring im Stable , dann hätte ich das wohl erstmal gelassen
          Siehst du hier den Fehler ?
          Maik
          • arteckA arteck
            YodameisterY
            YodameisterY
            Yodameister
            #82
            @arteck
            @Nachtrag da es hier zu vielen Fragen kommt
            die batteriebenen Geräte .. diese müssen sich erst melden. das dauert da sich diese selten Melden vor allem Aqara bzw. Xiaomi .. man kann es selbst antrigern per drücken des Knopfes am Gerät. erst dann sieht man die richtige Link Quality..
            Ich hatte 1 Tag dazwischen und zb der Bewegungsmelder wurde bewusst mehrfach angesteuert , hätte sich also melden müssen , passierte trotzdem nichts , das mit der LinkQualität von 10 war mir aufgefallen , ging aber schnell weg
            Maik
            • arteckA arteck
              K
              K
              klassisch
              schrieb am zuletzt editiert von klassisch
              #83
              @arteck sagte in ZigBee neue Version 1.4.4:
              Der Controller-Tag sagt
              type:zStack30x
              version:2-2.2.7.2.
              revision:20200211
              port:COM4
              channel:11
              Mein ioBroker laptop hat Win 10 Pro drauf. Win 10 kommt mit USBs problemlos klar. Oder besser gesagt, ICH komme bei Win 10 mit USB problemlos klar. Bei den Linux SBC habe ich damit mmer einen K(r)ampf.
              Auf dem Rechner läuft noch eine virtuelle COM-SW, die einen Link zu einem TCP-Server hält, mit dem ich RF-Link angebunden habe. Das läuft stabil.
              Der smartmeter-Adapter geht auch via Ethernt und TCP-Server.
              Versuche prinzipiell von den USB Verbindungen wegzukommen.
              Hatte den Zigbee-Adapter auch über ser2net eingebunden. Aber ab dem dritten Panel gab es Probleme mit dem Anlernen. Muß keine Kausalität sein, könnte auch eine Koinzidenz sein. Jdenfalls bin ich dann probehalber wieder zurück direkt auf den USB des Win PC was auch augenscheinlich sofort eine Verbesserung gebracht hat.
              Bin da noch zurückhaltend bis von berufener Seite geklärt ist, wie das mit den Win 10 Installer Varianten geht. Mein System läuft derzeit recht gut und so soll es auch bleiben. Habe zu wenig Ahnung von npm, node.js etc um da Pionier sein zu wollen.
               node.js   v10.17.0
              NPM     6.11.3
                  Typ: js-controller
                  Titel: JS controller
                  OS: win32
                  Verfügbar: 3.2.16
                  Installiert: 3.1.6
                  Ereignisse: ↦27 / ↦12
              • P
                P
                Peter213
                #84
                ich habe seit eben wie aus dem nichts folgende Fehler: Meine ganzen Danfoss Ally Thermostatköpfe koppeln sich nicht mehr.
                Hat einer eine Idee was ich machen kann?
                Version ist 1.4.4
                • arteckA arteck
                  was ist neu
                  @Ilya : man kann externe konverter einbinmden für DIY Geräte
                  @Asgothian verbesserung des Pingprozesses - hier ist auch ein Button in den Objecten dazugekommen
                  @arteck Geräte können diert aus dem Converter gezogen werden auch wenn diese bei uns definiert sind
                  @Asgothian automatisches Löschen nicht gebrauchter Datenpunkte wenn man dem Ausschluss Tab nutzt
                  so uns nu lassen die Spiele beginnen
                  nach dem Update und nach dem Adapter start sind ALLE Geräte erstmal mit einer Link Quality von 10 in der Kacheln.. nach dem sich die Geräte gemeldet haben (Router) geht die Link Quality auf das was das Gerät lifert. bleibt die Link Quality auf 10 meldet sich das Gerät nicht, dass kann mehre Stunden dauern..also Geduld
                  ausser
                  #85
                  @arteck @Asgothian
                  Dankeschön an euch Entwickler dieses tollen Adapters!!
                  Bin jetzt mit 140 Devices umgestiegen von 9 Xiaomi Gateways auf einen CC26X2R, hat auf Anhieb alles super geklappt.
                  • YodameisterY Yodameister
                    Ich habe auch Probleme nach Update auf 1.44
                    Ich habe 63 Geräte am Start , Board CC1352P , die meisten Geräte Xiaomi Aqara , Miijja
                    Nach dem Update gingen 4 ( ! ) Geräte in der Verbindung auf false. Alles Geräte die vorher ohne Probleme verbunden waren , die ich mehrfach besitze ( Bewegungsmelder , Öffnungssensor ) .
                    Ich habe versucht die Batterien zu entfernen , warten , Gerät löschen , neu anlernen. Das Geräte wird korrekt erkannt , geht aber sofort auf Verbindung false.
                    Nach vielen Versuchen habe ich den Adapter downgegradet auf Version 1.20 ....siehe da alles wieder Tutti
                    YodameisterY
                    YodameisterY
                    Yodameister
                    #86
                    @Asgothian @arteck
                    Kurze Rückmeldung für Euch
                    Habe heute Zeit gefunden alles nochmal sauber zu installieren und derzeit ist alles online.
                    Vielleicht hing es mit zu vielen Updates die ich durchgeführt habe zusammen ? Im Moment jedenfalls alles wieder in Ordnung , sogar der Aqara Temperaturmelder in der Kühltruhe arbeitet wieder
                    Bleibt gesund !
                    Maik
                    • K
                      K
                      Kueppert
                      schrieb am zuletzt editiert von Kueppert
                      #87
                      Hallo in die wissende Runde,
                      ich schlage mich gerade mit der Trust ZYCT-202 herum. Angelernt bekomme ich sie. Habe sie auch im Zigbee-Adapter mal auf "Auschließen" gestellt, weil die Datenpunkte on/off und stop alle zusammen bei jedem Tastendruck aktualisiert wurden. Das ist nach dem "auschließen" nun nicht mehr der Fall.
                      ALLERDINGS werden mir die DPs für die Brightness-Tasten nicht befüllt beim Klicken. Ist die FB kakke oder kann ich da noch etwas tun? Wollte damit eine HUE-FB ersetzen:
                      Unterstützt wird die FB gem. WIKI-EIntrag bereits...
                      • K Kueppert
                        AsgothianA
                        AsgothianA
                        Asgothian
                        #88
                        @kueppert die DP sollten gefüllt werden wenn du die Tasten für heller / dunkler Kante hältst.
                        A.
                        • K
                          K
                          Kueppert
                          #89
                          @asgothian habe die Tasten heller und dunkler jetz tmal 2 Sekunden, mal 5 Sekunden mal 10 Sekunden gehalten - leider ohne Veränderung der DPs :/
                          Hab die Rmote auch nochmal angelernt und nochmal getestet (weiterhin "ausgeschlossen"). Tut sich nix bei Brightness
                          • K Kueppert
                            arteckA
                            arteckA
                            arteck
                            #90
                            @kueppert stll den adapter auf debug und zeigmal was der so sendet
                            • arteckA arteck
                              K
                              K
                              Kueppert
                              #91
                              @arteck okay, da kommt verdammt viel, ich versuche mal, nur meine Knopf-Drücke hier auf dem LOG-Download beizufügen:
                              Helligkeit up:
                              2021-02-22 16:43:50.171 - debug: zigbee.0 (9813) Received Zigbee message from '0x00158d0004ff6060', type 'commandMove', cluster 'genLevelCtrl', data '{"movemode":0,"rate":30}' from endpoint 1 with groupID 24674
                              2021-02-22 16:43:50.175 - debug: zigbee.0 (9813) Type commandMove device {"type":"device","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008630170,"_linkquality":15},"mapped":{"zigbeeModel":["\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","ZLL-NonColorController"],"model":"ZYCT-202","vendor":"Trust","description":"Remote control","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOffWithEffect"},{"cluster":"genLevelCtrl","type":"commandStop"},{"cluster":"genLevelCtrl","type":"commandMove"}],"exposes":[{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","stop","brightness_stop","brightness_move_up","brightness_move_down"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"toZigbee":[]},"name":"0x00158d0004ff6060"} incoming event: {"type":"commandMove","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008630170,"_linkquality":15},"endpoint":"[Circular]","data":{"movemode":0,"rate":30},"linkquality":15,"groupID":24674,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":37,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:43:50.184 - debug: zigbee.0 (9813) Publish {"action":"up-press","action_group":24674}
                              2021-02-22 16:43:50.445 - debug: zigbee.0 (9813) handleMessage. {"type":"commandStop","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008630445,"_linkquality":18},"endpoint":"[Circular]","data":{},"linkquality":18,"groupID":24674,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":38,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:43:50.446 - debug: zigbee.0 (9813) Received Zigbee message from '0x00158d0004ff6060', type 'commandStop', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 24674
                              2021-02-22 16:43:50.446 - debug: zigbee.0 (9813) Type commandStop device {"type":"device","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008630445,"_linkquality":18},"mapped":{"zigbeeModel":["\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","ZLL-NonColorController"],"model":"ZYCT-202","vendor":"Trust","description":"Remote control","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOffWithEffect"},{"cluster":"genLevelCtrl","type":"commandStop"},{"cluster":"genLevelCtrl","type":"commandMove"}],"exposes":[{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","stop","brightness_stop","brightness_move_up","brightness_move_down"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"toZigbee":[]},"name":"0x00158d0004ff6060"} incoming event: {"type":"commandStop","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008630445,"_linkquality":18},"endpoint":"[Circular]","data":{},"linkquality":18,"groupID":24674,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":38,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:43:50.453 - debug: zigbee.0 (9813) Publish {"action":"stop","action_group":24674}
                              und Helligkeit down:
                              2021-02-22 16:46:14.338 - debug: zigbee.0 (9813) handleMessage. {"type":"commandMove","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008774337,"_linkquality":10},"endpoint":"[Circular]","data":{"movemode":1,"rate":30},"linkquality":10,"groupID":24674,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":39,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:46:14.338 - debug: zigbee.0 (9813) Received Zigbee message from '0x00158d0004ff6060', type 'commandMove', cluster 'genLevelCtrl', data '{"movemode":1,"rate":30}' from endpoint 1 with groupID 24674
                              2021-02-22 16:46:14.339 - debug: zigbee.0 (9813) Type commandMove device {"type":"device","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008774337,"_linkquality":10},"mapped":{"zigbeeModel":["\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","ZLL-NonColorController"],"model":"ZYCT-202","vendor":"Trust","description":"Remote control","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOffWithEffect"},{"cluster":"genLevelCtrl","type":"commandStop"},{"cluster":"genLevelCtrl","type":"commandMove"}],"exposes":[{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","stop","brightness_stop","brightness_move_up","brightness_move_down"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"toZigbee":[]},"name":"0x00158d0004ff6060"} incoming event: {"type":"commandMove","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008774337,"_linkquality":10},"endpoint":"[Circular]","data":{"movemode":1,"rate":30},"linkquality":10,"groupID":24674,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":39,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:46:14.346 - debug: zigbee.0 (9813) Publish {"action":"down-press","action_group":24674}
                              2021-02-22 16:46:14.469 - debug: zigbee.0 (9813) handleMessage. {"type":"commandStop","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008774469,"_linkquality":13},"endpoint":"[Circular]","data":{},"linkquality":13,"groupID":24674,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":40,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:46:14.470 - debug: zigbee.0 (9813) Received Zigbee message from '0x00158d0004ff6060', type 'commandStop', cluster 'genLevelCtrl', data '{}' from endpoint 1 with groupID 24674
                              2021-02-22 16:46:14.470 - debug: zigbee.0 (9813) Type commandStop device {"type":"device","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008774469,"_linkquality":13},"mapped":{"zigbeeModel":["\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","ZLL-NonColorController"],"model":"ZYCT-202","vendor":"Trust","description":"Remote control","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOffWithEffect"},{"cluster":"genLevelCtrl","type":"commandStop"},{"cluster":"genLevelCtrl","type":"commandMove"}],"exposes":[{"type":"enum","name":"action","property":"action","access":1,"values":["on","off","stop","brightness_stop","brightness_move_up","brightness_move_down"],"description":"Triggered action (e.g. a button click)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"toZigbee":[]},"name":"0x00158d0004ff6060"} incoming event: {"type":"commandStop","device":{"ID":30,"_type":"EndDevice","_ieeeAddr":"0x00158d0004ff6060","_networkAddress":14365,"_manufacturerID":4653,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":2080,"inputClusters":[0,4,3,6,8,4096],"outputClusters":[0,4,3,6,8,4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{"genBasic":{"attributes":{"modelId":"ZLL-NonColorController","manufacturerName":"Trust International B.V.","powerSource":3,"zclVersion":1,"appVersion":3,"stackVersion":1,"hwVersion":1,"dateCode":"20150212","swBuildId":"2000-0003"}}},"_binds":[],"_configuredReportings":[],"meta":{}},{"ID":2,"profileID":49246,"deviceID":1010,"inputClusters":[4096],"outputClusters":[4096],"deviceNetworkAddress":14365,"deviceIeeeAddress":"0x00158d0004ff6060","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"Trust International B.V.","_powerSource":"Battery","_modelID":"ZLL-NonColorController","_applicationVersion":3,"_stackVersion":1,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20150212","_softwareBuildID":"2000-0003","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614008774469,"_linkquality":13},"endpoint":"[Circular]","data":{},"linkquality":13,"groupID":24674,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":40,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:46:14.480 - debug: zigbee.0 (9813) Publish {"action":"stop","action_group":24674}
                              2021-02-22 16:46:22.300 - debug: zigbee.0 (9813) handleMessage. {"type":"commandQueryNextImageRequest","device":{"ID":25,"_type":"Router","_ieeeAddr":"0x7cb03eaa00b0ac01","_networkAddress":14037,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"deviceNetworkAddress":14037,"deviceIeeeAddress":"0x7cb03eaa00b0ac01","clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":17,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.11"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018eb42ab","endpointID":1}],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"OSRAM","_powerSource":"Mains (single phase)","_modelID":"Plug 01","_applicationVersion":17,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20140331DEOS****","_softwareBuildID":"V1.05.11","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1614008782300,"_linkquality":105},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909585},"linkquality":105,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":43,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:46:22.301 - debug: zigbee.0 (9813) Received Zigbee message from '0x7cb03eaa00b0ac01', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909585}' from endpoint 3 with groupID 0
                              2021-02-22 16:46:22.302 - debug: zigbee.0 (9813) Type commandQueryNextImageRequest device {"type":"device","device":{"ID":25,"_type":"Router","_ieeeAddr":"0x7cb03eaa00b0ac01","_networkAddress":14037,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"deviceNetworkAddress":14037,"deviceIeeeAddress":"0x7cb03eaa00b0ac01","clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":17,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.11"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018eb42ab","endpointID":1}],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"OSRAM","_powerSource":"Mains (single phase)","_modelID":"Plug 01","_applicationVersion":17,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20140331DEOS****","_softwareBuildID":"V1.05.11","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1614008782300,"_linkquality":105},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]}],"zigbeeModel":["Plug 01"],"model":"AB3257001NJ","description":"Smart+ plug","vendor":"OSRAM","meta":{"configureKey":1},"ota":{}},"name":"0x7cb03eaa00b0ac01"} incoming event: {"type":"commandQueryNextImageRequest","device":{"ID":25,"_type":"Router","_ieeeAddr":"0x7cb03eaa00b0ac01","_networkAddress":14037,"_manufacturerID":48042,"_endpoints":[{"ID":3,"profileID":49246,"deviceID":16,"inputClusters":[4096,0,3,4,5,6,2820,64527],"outputClusters":[25],"deviceNetworkAddress":14037,"deviceIeeeAddress":"0x7cb03eaa00b0ac01","clusters":{"genBasic":{"attributes":{"modelId":"Plug 01","manufacturerName":"OSRAM","powerSource":1,"zclVersion":1,"appVersion":17,"stackVersion":2,"hwVersion":1,"dateCode":"20140331DEOS****","swBuildId":"V1.05.11"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0018eb42ab","endpointID":1}],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"OSRAM","_powerSource":"Mains (single phase)","_modelID":"Plug 01","_applicationVersion":17,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20140331DEOS****","_softwareBuildID":"V1.05.11","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":1},"_lastSeen":1614008782300,"_linkquality":105},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4364,"imageType":39,"fileVersion":16909585},"linkquality":105,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":43,"manufacturerCode":null,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
                              2021-02-22 16:46:22.311 - debug: zigbee.0 (9813) No converter available for 'AB3257001NJ' with cluster 'genOta' and type 'commandQueryNextImageRequest'
                              Mein Zigbee-Kooridnator:
                              type:zStack30x
                              version:2-2.2.7.2.
                              revision:20190523
                              port:/dev/ttyACM0
                              channel:11
                              und ein Screen von der Fernbedienung:
                              • arteckA
                                arteckA
                                arteck
                                #92
                                @kueppert sagte in ZigBee neue Version 1.4.4:
                                @Asgothian das ist wieder so ein guppengedönz wie mit der anderen Fernbedinung.
                                • K
                                  K
                                  klassisch
                                  #93
                                  [vielleicht-OT?]
                                  eine Frage an die Runde der wissenden:
                                  Habe fetgestellt, daß ich von meinem aqara Bewegungdmelder die occupancy-Botschaft immer mehrfach bekomme. Im Abstand von wenigen ms.
                                  Ist das eine Eigenschaft des Sensors oder ist das evtl eine Multipath- Übertragung im Zigee-Netz? Oder was ganz anderes?
                                  Heute Vormittag waren es 4 Trigger pro event, jetzt sind es gerade 2 Trigger pro event.
                                  Hier ein Beispiel aus dem mitlaufenden log (Probephase) mit Ausgaben aus meinem Skript.
                                  Ich habe einen debouncer gebaut, der nach nach dem Eintreffen eines Triggers durch ein true signal die folgende Sekunde weitere Trigger abfängt, damit die Folgeprozesse nicht mehrfach ausgelöst werden.
                                  Man sieht, daß beim ersten abgebildeten Trigger der vorige ca. 500 Sekunden früher war. Dieser Trigger kommt auch durch den debouncer. Dann kommen nach 4, 11 und 12ms weitere Trigger vor dem debouncer an.
                                  Der Sensor hat die Nummer 00158d0006402123
                                  2021-02-22 10:06:22.685 - info: javascript.0 (8604) script.js.common.Kuche-Light: last motion event was ago: 509290
                                  2021-02-22 10:06:22.686 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 50 entering motion control before debounce, sensor true lux: 0
                                  2021-02-22 10:06:22.686 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 51 after debouncer. motionsensor: true
                                  2021-02-22 10:06:22.688 - info: javascript.0 (8604) script.js.common.Kuche-Light: last motion event was ago: 4
                                  2021-02-22 10:06:22.688 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 50 entering motion control before debounce, sensor true lux: 0
                                  2021-02-22 10:06:22.695 - info: javascript.0 (8604) script.js.common.Kuche-Light: last motion event was ago: 11
                                  2021-02-22 10:06:22.695 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 50 entering motion control before debounce, sensor true lux: 0
                                  2021-02-22 10:06:22.696 - info: javascript.0 (8604) script.js.common.Kuche-Light: last motion event was ago: 12
                                  2021-02-22 10:06:22.696 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 50 entering motion control before debounce, sensor true lux: 0
                                  Heute Abend habe ich mal auf Debug gestellt. Da kamen dann nur nich 2 Trigger pro event.
                                  Erst mal nur die Skript-Ausgaben
                                  2021-02-22 17:25:40.140 - info: javascript.0 (8604) script.js.common.Kuche-Light: last motion event was ago: 682581
                                  2021-02-22 17:25:40.140 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 50 entering motion control before debounce, sensor true lux: 0
                                  2021-02-22 17:25:40.141 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 51 after debouncer. motionsensor: true
                                  2021-02-22 17:25:40.149 - info: javascript.0 (8604) script.js.common.Kuche-Light: last motion event was ago: 11
                                  2021-02-22 17:25:40.149 - info: javascript.0 (8604) script.js.common.Kuche-Light: DBG 50 entering motion control before debounce, sensor true lux: 0
                                  Und jetzt log-Stufe:
                                  2021-02-22 17:25:40.123 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,28,68,129,0,0,0,4,155,190,1,1,0,28,0,200,99,11,0,0,8,24,52,10,0,0,33,0,0,155,190,29,115]
                                  2021-02-22 17:25:40.124 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,28,68,129,0,0,0,4,155,190,1,1,0,28,0,200,99,11,0,0,8,24,52,10,0,0,33,0,0,155,190,29,115]
                                  2021-02-22 17:25:40.124 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 28 - 2 - 4 - 129 - [0,0,0,4,155,190,1,1,0,28,0,200,99,11,0,0,8,24,52,10,0,0,33,0,0,155,190,29] - 115
                                  2021-02-22 17:25:40.124 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1024,"srcaddr":48795,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":28,"securityuse":0,"timestamp":746440,"transseqnumber":0,"len":8,"data":{"type":"Buffer","data":[24,52,10,0,0,33,0,0]}}
                                  2021-02-22 17:25:40.124 - debug: zigbee.0 (4060) zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":52,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":33,"attrData":0}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":48795,"endpoint":1,"linkquality":28,"groupID":0}'
                                  2021-02-22 17:25:40.125 - debug: zigbee.0 (4060) handleMessage. {"type":"attributeReport","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d0006402123","_networkAddress":48795,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":48795,"deviceIeeeAddress":"0x00158d0006402123","clusters":{"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}},"genBasic":{"attributes":{"65281":{"1":3045,"3":22,"4":17320,"5":8,"6":[0,4],"10":0,"11":52,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614011140124,"_linkquality":28},"endpoint":"[Circular]","data":{"measuredValue":0},"linkquality":28,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":52,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2021-02-22 17:25:40.125 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                                  2021-02-22 17:25:40.125 - debug: zigbee.0 (4060) Received Zigbee message from '0x00158d0006402123', type 'attributeReport', cluster 'msIlluminanceMeasurement', data '{"measuredValue":0}' from endpoint 1 with groupID 0
                                  2021-02-22 17:25:40.125 - debug: zigbee.0 (4060) Type attributeReport device {"type":"device","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d0006402123","_networkAddress":48795,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":48795,"deviceIeeeAddress":"0x00158d0006402123","clusters":{"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}},"genBasic":{"attributes":{"65281":{"1":3045,"3":22,"4":17320,"5":8,"6":[0,4],"10":0,"11":52,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614011140124,"_linkquality":28},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"illuminance_lux","property":"illuminance","access":1,"unit":"lx","description":"Measured illuminance in lux"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Measured illuminance in lux","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"name":"0x00158d0006402123"} incoming event: {"type":"attributeReport","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d0006402123","_networkAddress":48795,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":48795,"deviceIeeeAddress":"0x00158d0006402123","clusters":{"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}},"genBasic":{"attributes":{"65281":{"1":3045,"3":22,"4":17320,"5":8,"6":[0,4],"10":0,"11":52,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614011140124,"_linkquality":28},"endpoint":"[Circular]","data":{"measuredValue":0},"linkquality":28,"groupID":0,"cluster":"msIlluminanceMeasurement","meta":{"zclTransactionSequenceNumber":52,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2021-02-22 17:25:40.129 - debug: zigbee.0 (4060) Publish {"occupancy":true,"illuminance":0,"illuminance_lux":0}
                                  2021-02-22 17:25:40.132 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,27,68,129,0,0,6,4,155,190,1,1,0,28,0,220,99,11,0,0,7,24,53,10,0,0,24,1,155,190,29,80]
                                  2021-02-22 17:25:40.132 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,27,68,129,0,0,6,4,155,190,1,1,0,28,0,220,99,11,0,0,7,24,53,10,0,0,24,1,155,190,29,80]
                                  2021-02-22 17:25:40.132 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 27 - 2 - 4 - 129 - [0,0,6,4,155,190,1,1,0,28,0,220,99,11,0,0,7,24,53,10,0,0,24,1,155,190,29] - 80
                                  2021-02-22 17:25:40.133 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - incomingMsg - {"groupid":0,"clusterid":1030,"srcaddr":48795,"srcendpoint":1,"dstendpoint":1,"wasbroadcast":0,"linkquality":28,"securityuse":0,"timestamp":746460,"transseqnumber":0,"len":7,"data":{"type":"Buffer","data":[24,53,10,0,0,24,1]}}
                                  2021-02-22 17:25:40.133 - debug: zigbee.0 (4060) zigbee-herdsman:controller:log Received 'zcl' data '{"frame":{"Header":{"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0},"transactionSequenceNumber":53,"manufacturerCode":null,"commandIdentifier":10},"Payload":[{"attrId":0,"dataType":24,"attrData":1}],"Command":{"ID":10,"name":"report","parameters":[{"name":"attrId","type":33},{"name":"dataType","type":32},{"name":"attrData","type":1000}]}},"address":48795,"endpoint":1,"linkquality":28,"groupID":0}'
                                  2021-02-22 17:25:40.133 - debug: zigbee.0 (4060) handleMessage. {"type":"attributeReport","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d0006402123","_networkAddress":48795,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":48795,"deviceIeeeAddress":"0x00158d0006402123","clusters":{"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}},"genBasic":{"attributes":{"65281":{"1":3045,"3":22,"4":17320,"5":8,"6":[0,4],"10":0,"11":52,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614011140133,"_linkquality":28},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":28,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":53,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2021-02-22 17:25:40.133 - debug: zigbee.0 (4060) zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
                                  2021-02-22 17:25:40.133 - debug: zigbee.0 (4060) Received Zigbee message from '0x00158d0006402123', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":1}' from endpoint 1 with groupID 0
                                  2021-02-22 17:25:40.134 - debug: zigbee.0 (4060) Type attributeReport device {"type":"device","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d0006402123","_networkAddress":48795,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":48795,"deviceIeeeAddress":"0x00158d0006402123","clusters":{"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}},"genBasic":{"attributes":{"65281":{"1":3045,"3":22,"4":17320,"5":8,"6":[0,4],"10":0,"11":52,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614011140133,"_linkquality":28},"mapped":{"zigbeeModel":["lumi.sensor_motion.aq2"],"model":"RTCGQ11LM","vendor":"Xiaomi","description":"Aqara human body movement and illuminance sensor","meta":{"battery":{"voltageToPercentage":"3V_2100"}},"fromZigbee":[{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"]},{"cluster":"msIlluminanceMeasurement","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[],"exposes":[{"type":"numeric","name":"battery","property":"battery","access":1,"unit":"%","description":"Remaining battery in %","value_min":0,"value_max":100},{"type":"binary","name":"occupancy","property":"occupancy","access":1,"value_on":true,"value_off":false,"description":"Indicates whether the device detected occupancy"},{"type":"numeric","name":"temperature","property":"temperature","access":1,"unit":"°C","description":"Measured temperature value"},{"type":"numeric","name":"voltage","property":"voltage","access":1,"unit":"V","description":"Measured electrical potential value"},{"type":"numeric","name":"illuminance_lux","property":"illuminance","access":1,"unit":"lx","description":"Measured illuminance in lux"},{"type":"numeric","name":"illuminance","property":"illuminance","access":1,"description":"Measured illuminance in lux","unit":"lx"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}]},"name":"0x00158d0006402123"} incoming event: {"type":"attributeReport","device":{"ID":18,"_type":"EndDevice","_ieeeAddr":"0x00158d0006402123","_networkAddress":48795,"_manufacturerID":4151,"_endpoints":[{"ID":1,"profileID":260,"deviceID":263,"inputClusters":[0,65535,1030,1024,1280,1,3],"outputClusters":[0,25],"deviceNetworkAddress":48795,"deviceIeeeAddress":"0x00158d0006402123","clusters":{"msIlluminanceMeasurement":{"attributes":{"measuredValue":0}},"msOccupancySensing":{"attributes":{"occupancy":1}},"genBasic":{"attributes":{"65281":{"1":3045,"3":22,"4":17320,"5":8,"6":[0,4],"10":0,"11":52,"100":0},"manufacturerName":"LUMI","powerSource":3,"zclVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20170627","swBuildId":"3000-0001"}},"ssIasZone":{"attributes":{}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"LUMI","_powerSource":"Battery","_modelID":"lumi.sensor_motion.aq2","_applicationVersion":5,"_stackVersion":2,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20170627","_softwareBuildID":"3000-0001","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{},"_lastSeen":1614011140133,"_linkquality":28},"endpoint":"[Circular]","data":{"occupancy":1},"linkquality":28,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":53,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}}}
                                  2021-02-22 17:25:40.140 - debug: zigbee.0 (4060) Publish {"occupancy":true}
                                  2021-02-22 17:25:40.145 - debug: zigbee.0 (4060) User stateChange zigbee.0.bc33acfffed7b833.transition_time {"val":1,"ack":false,"ts":1614011140142,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1614008901731}
                                  2021-02-22 17:25:40.149 - debug: zigbee.0 (4060) Change state 'transition_time' at device 0xbc33acfffed7b833 type 'L1529'
                                  2021-02-22 17:25:40.149 - debug: zigbee.0 (4060) State changes. dev: 0xbc33acfffed7b833 model: L1529 states: [{"stateDesc":{"id":"transition_time","name":"Transition time","role":"state","write":true,"read":false,"type":"number","unit":"sec","isOption":true},"value":1,"index":0,"timeout":0}] opt: {"state":false,"transition_time":1}
                                  2021-02-22 17:25:40.150 - debug: zigbee.0 (4060) entity: {"type":"device","device":{"ID":11,"_type":"Router","_ieeeAddr":"0xbc33acfffed7b833","_networkAddress":1526,"_manufacturerID":4476,"_endpoints":[{"ID":1,"profileID":49246,"deviceID":544,"inputClusters":[0,3,4,5,6,8,768,2821,4096],"outputClusters":[5,25,32,4096],"deviceNetworkAddress":1526,"deviceIeeeAddress":"0xbc33acfffed7b833","clusters":{"genBasic":{"attributes":{"modelId":"FLOALT panel WS 60x60","manufacturerName":"IKEA of Sweden","powerSource":1,"zclVersion":3,"appVersion":17,"stackVersion":87,"hwVersion":1,"dateCode":"20201102","swBuildId":"2.3.068"}},"genOnOff":{"attributes":{"onOff":0}},"lightingColorCtrl":{"attributes":{"colorCapabilities":16,"colorTempPhysicalMin":250,"colorTempPhysicalMax":454,"colorTemperature":250,"startUpColorTemperature":65535}},"genLevelCtrl":{"attributes":{"currentLevel":174,"onOffTransitionTime":5,"startUpCurrentLevel":255}}},"_binds":[],"_configuredReportings":[],"meta":{}}],"_manufacturerName":"IKEA of Sweden","_powerSource":"Mains (single phase)","_modelID":"FLOALT panel WS 60x60","_applicationVersion":17,"_stackVersion":87,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20201102","_softwareBuildID":"2.3.068","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"meta":{"configured":2},"_lastSeen":1614011098624,"_linkquality":36},"mapped":{"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["effect","alert","flash"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]}],"meta":{"configureKey":2},"zigbeeModel":["FLOALT panel WS 60x60"],"model":"L1529","vendor":"IKEA","description":"FLOALT LED light panel, dimmable, white spectrum (60x60 cm)","ota":{}},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0xbc33acfffed7b833"}
                                  2021-02-22 17:25:40.150 - debug: zigbee.0 (4060) Mapped Model: {"exposes":[{"type":"light","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE","description":"On/off state of this light"},{"type":"numeric","name":"brightness","property":"brightness","access":7,"value_min":0,"value_max":254,"description":"Brightness of this light"},{"type":"numeric","name":"color_temp","property":"color_temp","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"}]},{"type":"numeric","name":"color_temp_startup","property":"color_temp_startup","access":7,"unit":"mired","value_min":250,"value_max":454,"description":"Color temperature after cold power on of this light","presets":[{"name":"coolest","value":250,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warm","value":454,"description":"Warm temperature (454 mireds / 2200 Kelvin)"},{"name":"warmest","value":454,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"type":"enum","name":"effect","property":"effect","access":2,"values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","brightness","brightness_percent"]},{"key":["color_temp","color_temp_percent"]},{"key":["transition"],"attr":[]},{"key":["rate"],"attr":[]},{"key":["effect","alert","flash"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["colortemp_move","color_temp_move"]},{"key":["brightness_step","brightness_step_onoff"]},{"key":["color_temp_step"]},{"key":["color_temp_startup"]},{"key":["level_config"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]}],"meta":{"configureKey":2},"zigbeeModel":["FLOALT panel WS 60x60"],"model":"L1529","vendor":"IKEA","description":"FLOALT LED light panel, dimmable, white spectrum (60x60 cm)","ota":{}}
                                  • arteckA arteck
                                    AsgothianA
                                    AsgothianA
                                    Asgothian
                                    #94
                                    Ist es, ist aber in diesem Fall unwichtig, da die FB nur jeweils einen Knopf für auf und abdimmen.
                                    A.
                                    • AsgothianA Asgothian
                                      A.
                                      K
                                      K
                                      Kueppert
                                      #95
                                      @asgothian @arteck soll ich ggf nen Github-Issue bei Koenkk aufmachen hierzu?
                                      • arteckA arteck
                                        was ist neu
                                        ausser
                                        gelberlemmyG
                                        gelberlemmyG
                                        gelberlemmy
                                        #96
                                        @arteck so wollte ein paar Glühlampen löschen, da ich andere einlernen wollte. So leider konnte ich keine mehr danach neu einlernen. Habe den ti cc26x2r1. Entweder hat er gar nichts gefunden oder nur undefined. So IObroker neu gestartet. das Board einmal vom USB genommen. hat alles nicht genutzt. Also habe ich den Adapter einmal neu installiert. Aber jetzt geht da wirklich nicht mehr viel. Ich stelle den Adapter ein. Dann gehe ich auf speichern. Jetzt bekomme ich die Mldung" das jetzt meine Einstellungen verworfen werden, obwohl ich auf speichern gedrückt habe. Adapter bleibt gelb. So wenn ich jetzt einmal danach in die Einstellungen gehe, sind alle meine Einstellungen vorhanden. Möchte ich einmal einen Kanalscan machen, dann wird mir gesagt ich muss vorher speichern und den Adapter neu starten. IObroker Fix auch schon gemacht. Anbei auch das Log File von IO Broker.
                                        Kannst Du mir da einmal weiterhelfen ?
                                        zigbee.0	2021-02-23 14:27:30.603	error	(4887) Cannot read property 'getEntries' of null
                                        zigbee.0	2021-02-23 14:27:30.603	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at Zigbee.emit (events.js:315:20)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:273:31)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                                        zigbee.0	2021-02-23 14:27:30.603	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
                                        zigbee.0	2021-02-23 14:27:30.603	error	(4887) TypeError: Cannot read property 'getEntries' of null
                                        zigbee.0	2021-02-23 14:27:30.600	error	(4887) unhandled promise rejection: Cannot read property 'getEntries' of null
                                        zigbee.0	2021-02-23 14:27:30.599	error	(4887) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        • gelberlemmyG gelberlemmy
                                          AsgothianA
                                          AsgothianA
                                          Asgothian
                                          #97
                                          @gelberlemmy
                                          Bitte früher im Log schauen. Das was du da gepostet hast sind Fehler die auftreten wenn der Zigbee Adapter versucht sich zu beenden ohne das er sauber initialisiert wurde. Der eigentliche Fehler tritt vorher auf.
                                          A.
                                          gelberlemmyG 1 Antwort Letzte Antwort
                                          33.2k
                                          84.3k
