    6.4k
2.9k Beiträge 248 Kommentatoren 2.0m Aufrufe 123 Beobachtet
  • C cga
    @fastfoot
    ifconfig:
    /$ ifconfig
    bond0     Link encap:Ethernet  HWaddr 00:11:32:A6:6D:63
              inet addr:192.168.178.34  Bcast:192.168.178.255  Mask:255.255.255.0
              inet6 addr: fe80::211:32ff:fea6:6d63/64 Scope:Link
              UP BROADCAST RUNNING MASTER MULTICAST  MTU:1500  Metric:1
              RX packets:3000453 errors:0 dropped:0 overruns:0 frame:0
              TX packets:2084863 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:2502052516 (2.3 GiB)  TX bytes:2213966732 (2.0 GiB)
    docker0   Link encap:Ethernet  HWaddr 02:42:A7:14:66:DC
              inet addr:172.17.0.1  Bcast:172.17.255.255  Mask:255.255.0.0
              inet6 addr: fe80::42:a7ff:fe14:66dc/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:94721 errors:0 dropped:0 overruns:0 frame:0
              TX packets:107729 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:0
              RX bytes:38336912 (36.5 MiB)  TX bytes:65414553 (62.3 MiB)
    docker50b Link encap:Ethernet  HWaddr 36:5B:A0:37:AF:18
              inet6 addr: fe80::345b:a0ff:fe37:af18/64 Scope:Link
              RX packets:81086 errors:0 dropped:0 overruns:0 frame:0
              TX packets:85997 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:38746825 (36.9 MiB)  TX bytes:11848674 (11.2 MiB)
    eth0      Link encap:Ethernet  HWaddr 00:11:32:A6:6D:63
              UP BROADCAST RUNNING SLAVE MULTICAST  MTU:1500  Metric:1
              RX packets:2760273 errors:0 dropped:0 overruns:0 frame:0
              TX packets:1188360 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:2458605638 (2.2 GiB)  TX bytes:1215169125 (1.1 GiB)
    eth1      Link encap:Ethernet  HWaddr 00:11:32:A6:6D:64
              RX packets:240180 errors:0 dropped:0 overruns:0 frame:0
              TX packets:896503 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:43446878 (41.4 MiB)  TX bytes:998797607 (952.5 MiB)
    lo        Link encap:Local Loopback
              inet addr:127.0.0.1  Mask:255.0.0.0
              inet6 addr: ::1/128 Scope:Host
              UP LOOPBACK RUNNING  MTU:65536  Metric:1
              RX packets:77760 errors:0 dropped:0 overruns:0 frame:0
              TX packets:77760 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:9984906 (9.5 MiB)  TX bytes:9984906 (9.5 MiB)
    iobroker list instances
    + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.discovery.0             : discovery             -  enabled
    + system.adapter.info.0                  : info                  -  enabled
    + instance is alive
    F Online
    F Online
    fastfoot
    #2351
    @cga sieht eigentlich alles gut aus, aber nach draussen pingen kannst du, z.B 8.8.8.8 ? Zeig auch mal noch den Portainer/ Netzwerk vom Container.
    Wegen dem Port, mach mal im Container iobroker set admin.0 --port 18081 und probiere mit dem Port im Browser
    C 1 Antwort Letzte Antwort
    • F fastfoot
      cga
      #2352
      @fastfoot
      komme nicht raus aus dem Container
      ping 8.8.8.8
      PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
      ^C
      --- 8.8.8.8 ping statistics ---
      23 packets transmitted, 0 received, 100% packet loss, time 1021ms
      Ich habe den Port via iobroker set admin.0 --port 18081 angepasst, aber erreichte die Seite dann auch nicht via 192.168.178.222:18081
      GlasfaserG F dslraserD 3 Antworten Letzte Antwort
      • C cga
        @fastfoot
        ping 8.8.8.8
        ^C
        GlasfaserG Offline
        GlasfaserG Offline
        #2353
        @cga sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
        Logo ... port mapping fehlt
        C F 2 Antworten Letzte Antwort
        • GlasfaserG Glasfaser
          cga
          #2354
          Hi @glasfaser
          welches Port Mapping? Ich dachte bei der Verwendung von macvlan ist ein Portmapping nicht notwendig?
            F Online
            F Online
            fastfoot
            #2355
            @glasfaser sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
            port mapping braucht es im hostmode
            • F fastfoot
              GlasfaserG Offline
              GlasfaserG Offline
              #2356
              @fastfoot sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
              Hääh ?
              Ich bin selber im Hostmodus und habe kein mapping ... ( Syn und iobroker haben die gleiche IP )
              F 1 Antwort Letzte Antwort
                Hääh ?
                F Online
                F Online
                fastfoot
                #2357
                Hääh ?
                das mapping braucht es wenn der Port schon belegt ist. Im macvlan braucht man es mW nicht, schon gar nicht um ins Internet zu kommen. Da ist was mit dem Netzwerk faul
                • C cga
                  @fastfoot
                  ping 8.8.8.8
                  ^C
                  F Online
                  F Online
                  fastfoot
                  #2358
                  das klingt schon anders als DNS Fehler :-) Schmeiss die Config und dein macvlan mal weg, mach es neu mit der IP ....192/32. Ist nur ein Bauchgefühl, nicht auf Wissen begründet, dauert ja nicht lange.
                  • F fastfoot
                    Hääh ?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #2359
                    @fastfoot
                    Deshalb meine Frage oben , ob er den Admin ansprechen kann ,
                    denn die Meldung
                    hash changed or no sources cached => force download of new sources
                    sagt aus , was sich schon öfterst rausgestellt hat ,das der hinterlegte Verwahrungsort bei einigen nicht funktioniert , so wie bei mir ,( gibt es schon ein Thread dazu )
                    denn nur diese funktionieren bei mir , sonst kommt die oben genannte Meldung .
                    http://download.iobroker.net/sources-dist-latest.json
                    http://download.iobroker.net/sources-dist.json
                    nach der Umstellung auf Bridge von Ihm hat er ja eine Verbindung laut Log
                    • F fastfoot
                      cga
                      #2360
                      @fastfoot
                      ja, definitiv. Hatte bisher nicht versucht direkt die IP zu pingen... hm
                      Hab jetzt alles umgestellt auf *.192/32 --> Leider selbes verhalten, keine Änderung
                        @fastfoot
                        denn die Meldung
                        F Online
                        F Online
                        fastfoot
                        #2361
                        @fastfoot
                        denn die Meldung
                        das kommt bei mir immer mit einem brandneuen Container, da ist noch nix gecached und sources existieren auch noch nicht. Aber unabhängig vom iobroker muss er mit macvlan ins Internet kommen. Habe das eben auf die Schnelle konfiguriert und funktioniert, allerdings habe ich nicht gebondet, das ist mir jetzt zuviel Aufwand, sollte aber funktionieren. Mit der IP habe ich mich wohl geirrt, funktioniert mit 222 auch
                        • F fastfoot
                          @fastfoot
                          denn die Meldung
                          cga
                          #2362
                          @fastfoot
                          Das wundert mich halt auch. Mein Bauchgefühl sagt mir irgendwie das es genau an dem Bond liegt. Stellenweise habe ich aber auch gelesen das Leute macvlan an nem Bond nutzen.
                          Danke auf jeden Fall für die Verifizierung dass es eigentlich gehen sollte.
                          Ich hatte auch schon in der FRITZ!Box geschaut, da ist nichts geblockt. Die synology hat auch kein dhcp an und auch nicht als extra DNS eingetragen. Wobei man ja jetzt gesehen hat, dass es kein DNS Problem sein kann.
                          • C cga
                            @fastfoot
                            F Online
                            F Online
                            fastfoot
                            #2363
                            @fastfoot
                            ich würde es jetzt auch auf den bond schieben, werde das auch mal testen, aber so auf die Schnelle zerschiesse ich mir damit meine komplette Config. Habe das aber auch so gelesen bzw verstanden dass es funktionieren sollte.. Bin leider nicht so der Netzwerkexperte dass ich weitere Lösungen hätte :-(
                            Dir bleibt momentan eig. nur unbonding und dann auf eth0/1 gehen, oder der hostmodus
                            C dslraserD 2 Antworten Letzte Antwort
                            • F fastfoot
                              @fastfoot
                              cga
                              #2364
                              @fastfoot
                              Ich muss mal noch etwas weiter testen. Unbonding wäre wirklich die letzte Alternative 😞
                              Danke au jeden Fall
                              • F fastfoot
                                @fastfoot
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                #2365
                                Ich denke daran liegt es nicht !
                                Ich meine @Samson71 hat das auch so laufen (kann mich von einem Chat jedenfalls so drann erinnern)
                                F Samson71S 2 Antworten Letzte Antwort
                                • dslraserD dslraser
                                  F Online
                                  F Online
                                  fastfoot
                                  #2366
                                  @dslraser sagte in [HowTo] ioBroker unter Docker auf Synology DiskStation:
                                  ja möglich, wir haben aber 'alles' durch was wir wissen.
                                  @cga schau dir mal noch das routing mit ip route an
                                  • C cga
                                    @fastfoot
                                    ping 8.8.8.8
                                    ^C
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    #2367
                                    @cga
                                    was hast Du da eigentlich für das bond eingetragen ? (bond0 ?)
                                    Ich habe das bisher auch noch nicht mit einem bond probiert...
                                    • C cga
                                      @fastfoot
                                      Danke au jeden Fall
                                      F Online
                                      F Online
                                      fastfoot
                                      #2368
                                      @fastfoot
                                      Danke au jeden Fall
                                      habe es doch noch getestet und es funktioniert wie erwartet. So kannst du ein macvlan auch ohne Portainer erstellen. Dieses hier hat Platz für 32 Container(192-223). Wie ist der Portainer denn eigentlich angebunden?
                                      docker network create \
                                      		--driver macvlan \
                                      		-o parent=bond0 \
                                      		--subnet 192.168.178.0/24 \
                                      		--gateway 192.168.178.1 \
                                      		--ip-range 192.168.178.192/27 \
                                      		iob_public
                                      Mit docker network rm iob_public ist es auch schnell wieder weg.
                                      Die Container sollten immer auch einen DNS Server enthalten
                                      C 2 Antworten Letzte Antwort
                                      • F fastfoot
                                        @fastfoot
                                        Danke au jeden Fall
                                        		--driver macvlan \
                                        		-o parent=bond0 \
                                        		iob_public
                                        cga
                                        schrieb am zuletzt editiert von cga
                                        #2369
                                        @fastfoot
                                        Wow, danke fürsvredten. Ich schau mir das dann gleich mal noch an. Ich hab bisher das macvlan i immer über portainer angelegt. Versuch es dann mal wie du über die Shell.
                                        Mit die Container sollten immer ein DNS bekommen meinst du da den portainer screen mit dem Network tab (siehe Screenshot oben)
                                        Portainer läuft ebenfalls auf der Synology in Hostmode
                                        • C cga
                                          @fastfoot
                                          Boardy
                                          #2370
                                          @cga es gibt doch so schöne Anleitungen...
                                          80e0a9f3-bf15-4adf-b534-d14341b26dcb-grafik.png http://www.stueben.de/mehrere-vlans-mit-einem-netzwerkadapter-auf-der-synology/
