  4. Test Adapter OctoPrint
adapter entwicklungadatper updatesdevelopertesten
461 Beiträge 49 Kommentatoren 151.2k Aufrufe 44 Beobachtet
  • DasLukasD DasLukas
    @da_Woody API Key jetzt nochmal neu erzeugt. Kopiert und in iobroker eingefügt. Gleiches Ergebnis.
    octoprint.0	2020-12-24 16:22:49.234	error	(523) Cannot read property 'toFixed' of null
    octoprint.0	2020-12-24 16:22:19.110	error	(523) Cannot read property 'toFixed' of null
    octoprint.0	2020-12-24 16:21:49.092	error	(523) Cannot read property 'toFixed' of null
    octoprint.0	2020-12-24 16:21:19.019	error	(523) Cannot read property 'toFixed' of null
    octoprint.0	2020-12-24 16:20:49.102	error	(523) Cannot read property 'toFixed' of null
    octoprint.0	2020-12-24 16:20:48.446	info	(523) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.octoprint, node: v10.17.0, js-controller: 3.1.6
    Hier einmal die Infos aus octoprint:
    browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0 Safari/605.1.15
    connectivity.connection_check: 8.8.8.8:53
    connectivity.connection_ok: true
    connectivity.enabled: true
    connectivity.online: true
    connectivity.resolution_check: octoprint.org
    connectivity.resolution_ok: true
    env.hardware.cores: 4
    env.hardware.freq: 1200
    env.hardware.ram: 917016576
    env.os.bits: 32
    env.os.id: linux
    env.os.platform: linux
    env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
    env.plugins.pi_support.octopi_version: 0.17.0
    env.plugins.pi_support.throttle_state: 0x0
    env.python.pip: 20.2.3
    env.python.version: 3.7.3
    env.python.virtualenv: true
    octoprint.safe_mode: false
    octoprint.version: 1.5.2
    printer.firmware: Klipper
    da_WoodyD Offline
    da_WoodyD Offline
    @DasLukas said in Test Adapter OctoPrint 1.0.1:
    sieht bei mir so aus:
     starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.octoprint, node: v12.20.0, js-controller: 3.1.6
    octoprint aktuell? war ja vor kurzem ein update...
    DasLukasD 1 Antwort Letzte Antwort
    • da_WoodyD da_Woody
      DasLukasD Offline
      DasLukasD Offline
      DasLukas
      @da_Woody Okay, node wie hier beschrieben aktualisiert. Dann im iobroker admin nochmal geschaut ob unter Adapter ein update für octoprint bereitsteht. Negativ. octoprint unter Adapter deinstalliert und per GitHub manuell installiert. Die Version 1.0.5 wird dort jetzt auch angezeigt. Großes Problem ist das es keine octoprint Instanz mehr gibt. Die Logs sagen auch nicht. Jemand eine Idee?
      DasLukasD haus-automatisierungH 2 Antworten Letzte Antwort
        DasLukasD Offline
        DasLukasD Offline
        DasLukas
        @DasLukas Selber die Lösung gefunden. Nachdem manuellen installieren über GitHub ist es anscheinend notwendig auch manuell eine Instanz zu erstellen. Bin noch neu beim iobroker.
        Jetzt läuft alles und die API läuft auch. Danke.
          da_WoodyD Offline
          da_WoodyD Offline
          @DasLukas na siehste, kleines xmas gift... ;) gern geschehn!
          jup, das ist vielen schon passiert nach einer github install... :D
            haus-automatisierungH Offline
            @DasLukas Bitte NIEMALS (außer Du willst mit am Adapter entwickeln) die Adapter per GitHub installieren. Dafür gibt es keinen Support, da Du einen undefinierten Stand ohne Versionsnummer installierst.
            Wenn Du die aktuellste freigegebene Version installieren möchtest, dann bitte den "Verwahrungsort" auf "latest" stellen.
            Vergiss einfach den Button mit der OctoCat und klick da im Produktivsystem nie drauf ;) Dann ist alles gut. Siehe auch https://www.youtube.com/watch?v=rPR_QRGhAzM
            📚 Meine Dokumentation
              da_WoodyD Offline
              da_WoodyD Offline
              #66
              @haus-automatisierung hast ja recht, aber, no risk, no fun! ;)
                #67
                @da_Woody sagte in Test Adapter OctoPrint 1.0.1:
                Das Problem ist, dass viele Anfänger das als Standard-Weg für sich entdecken und dann nur Probleme haben. Gibt ja auch etliche YouTube-Videos wo das als Lösung vorgeschlagen wird. Daher stelle ich das gerne direkt richtig ;) Von mir ist ja auch die Meldung im Popup, dass man das besser gerade nicht machen sollte.
                  Andre R.
                  #68
                  Beim Update auf 1.0.7 kommt alle 5 Minuten "api not Connected" lässt sich auch nicht mehr einstellen. Kannst du da mal schauen?
                  • A Andre R.
                    #69
                    @andre-r sagte in Test Adapter OctoPrint 1.0.5:
                    Beim Update auf 1.0.7 ...
                    Aktuell ist 1.0.8
                    Hast Du das Verhalten da auch? Mit welcher OctoPrint Version?
                      Aktuell ist 1.0.8
                      Andre R.
                      #70
                      @haus-automatisierung kommt bei 1.0.8 auch. die Meldung kommt nur wenn der Drucker inkl. Octoprint aus ist.
                      • A Andre R.
                        da_WoodyD Offline
                        da_WoodyD Offline
                        #71
                        @andre-r na wenn der drucker und octoprint off sind kommen immer meldungen
                        octoprint.0	2021-02-08 20:55:32.311	info	(18308) timeout of 2000ms exceeded
                        edith: vorher einen drucker abgedreht, kommt auch die selbe meldung. adapter gelb und
                        octoprint.0	2021-02-08 22:35:53.745	info	(18308) OctoPrint API not connected
                          Andre R.
                          #72
                          @da_woody man konnte aber den Aktualisierungsintervall einstellen wenn der Drucker offline ist. Die Einstellung ist zwar noch vorhanden aber wird ignoriert.
                          • A Andre R.
                            da_WoodyD Offline
                            da_WoodyD Offline
                            #73
                            @andre-r ist eine info meldung im log, nix weiter. kein warn, kein error, so what. schnurzpiepegal.
                              Andre R.
                              #74
                              @da_woody das ist mir schon klar. Die Meldung kommt alle 5 Minuten und spammt mir den Log zu, das stört mich.
                              da_WoodyD -cs-- 2 Antworten Letzte Antwort
                              • A Andre R.
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #75
                                @andre-r alle 5min und zuspammen? wenn du meinst... du kannst den adapter aber auch stoppen wenn der drucker nicht läuft. dann gibts auch keine meldungen.
                                • A Andre R.
                                  -cs-- Offline
                                  -cs-- Offline
                                  -cs-
                                  schrieb am zuletzt editiert von -cs-
                                  #76
                                  Und warum stellst dann die Logstufe nicht auf "warn"?
                                  Instanzen -> Experteneinstellungen aktivieten ->
                                  Log-Stufe auf warn
                                  Dann kommen die Infos nicht.
                                  • -cs-- -cs-
                                    Log-Stufe auf warn
                                    bishop
                                    #77
                                    Habe das OctoPrint-Enclosure Plugin am laufen mit dem ich Lüfter und Beleuchtung steuern kann. Es gibt dafür auch eine API, ist es möglich das in den Adapter zu integrieren?
                                    https://github.com/vitormhenrique/OctoPrint-Enclosure/wiki/API-Control
                                    • B bishop
                                      #78
                                      @bishop said in Test Adapter OctoPrint 1.0.5:
                                      Nur leider erweitert das Plugin nicht die offizielle API, sondern stellt eine separate bereit. :(
                                        bishop
                                        schrieb am zuletzt editiert von bishop
                                        #79
                                        ist es vielleicht möglich die json in den adapter zu bekommen um die daten zu verarbeiten?
                                        Oder wie bekomme ich z.b. die Temperatur oder das Relais in iobroker?
                                        Die Temperatur kann ich mit "http://ip.octoprint/plugin/enclosure/inputs/1" auslesen.
                                        • B bishop
                                          #80
                                          @bishop sagte in Test Adapter OctoPrint 1.0.5:
                                          Ja, dann mach das doch z.B. mit einem Request-Baustein per Blockly.
