  4. [gelöst] Sayit Adapter nach Update keine Sprachausgabe
40 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
    @emblitz
    df -h
    emblitz
    pi@raspberrypi:/opt/iobroker $ df -h
    Dateisystem    Gr▒▒e Benutzt Verf. Verw% Eingeh▒ngt auf
    /dev/root        30G    9,5G   19G   34% /
    devtmpfs        1,8G       0  1,8G    0% /dev
    tmpfs           1,9G       0  1,9G    0% /dev/shm
    tmpfs           1,9G    8,7M  1,9G    1% /run
    tmpfs           5,0M    4,0K  5,0M    1% /run/lock
    tmpfs           1,9G       0  1,9G    0% /sys/fs/cgroup
    /dev/mmcblk0p1  253M     48M  205M   19% /boot
    tmpfs           383M       0  383M    0% /run/user/1000
    • E emblitz
      @emblitz
      cd /opt/iobroker
      npm list
      Da nur das Dateiende, falls da Meldungen sind.
      E 1 Antwort Letzte Antwort
        @emblitz
        cd /opt/iobroker
        npm list
        emblitz
        pi@raspberrypi:/opt/iobroker $ npm list
        iobroker.inst@3.0.0 /opt/iobroker
        +-- UNMET DEPENDENCY iobroker.admin@stable
        +-- UNMET DEPENDENCY iobroker.discovery@stable
        +-- iobroker.flot@1.10.6 extraneous
        +-- UNMET DEPENDENCY iobroker.info@stable
        +-- UNMET DEPENDENCY iobroker.js-controller@stable
        +-- iobroker.mqtt@2.3.4 extraneous
        +-- UNMET DEPENDENCY iobroker.vis@1.3.4
        `-- UNMET DEPENDENCY iobroker.web@3.2.3
        npm ERR! missing: iobroker.vis@1.3.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.web@3.2.3, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.info@stable, required by iobroker.inst@3.0.0
        npm ERR! extraneous: iobroker.flot@1.10.6 /opt/iobroker/node_modules/iobroker.flot
        npm ERR! extraneous: iobroker.mqtt@2.3.4 /opt/iobroker/node_modules/iobroker.mqtt
        npm ERR! extraneous: iobroker.vis@1.3.4 /opt/iobroker/node_modules/iobroker.vis
        npm ERR! extraneous: iobroker.web@3.2.3 /opt/iobroker/node_modules/iobroker.web
        • E emblitz
          @emblitz
          MIch irritiert dein iobroker.inst@3.0.0
          Bei mir lautet das entsprechend:
          iobroker.inst@2.0.3 /opt/iobroker
          Keine Ahnung was/warum das da krumm läuft. Mal irgendwelche Alpha/Beta-Versionen installiert?
          cd /opt/iobroker
          npm rebuild
          mal probiert?
          E 2 Antworten Letzte Antwort
            @emblitz
            cd /opt/iobroker
            npm rebuild
            mal probiert?
            emblitz
            Wollte mich zwischendurch für Deine Hilfe bedanken !
            Der Admin stand in den Infoeinstellungen auf latest. Warum auch immer. Bewust habe ich nichts verstellt.
            Habe in dann zu Beginn des ersten Posts auf Stable gestellt.
              @emblitz
              cd /opt/iobroker
              npm rebuild
              mal probiert?
              emblitz
              pi@raspberrypi:/opt/iobroker $ npm rebuild
              > iobroker.js-controller@3.2.12 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              > node lib/preinstallCheck.js
              NPM version: 6.14.10
              > iobroker.js-controller@3.2.12 install /opt/iobroker/node_modules/iobroker.js-controller
              > node iobroker.js setup first
              internal/modules/cjs/loader.js:818
                throw err;
              Error: Cannot find module 'graceful-fs'
              Require stack:
              - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js
              - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js
              - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
              - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
                  at Function.Module._load (internal/modules/cjs/loader.js:667:27)
                  at Module.require (internal/modules/cjs/loader.js:887:19)
                  at require (internal/modules/cjs/helpers.js:74:18)
                  at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js:5:12)
                  at Module._compile (internal/modules/cjs/loader.js:999:30)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
                  at Module.load (internal/modules/cjs/loader.js:863:32)
                  at Function.Module._load (internal/modules/cjs/loader.js:708:14)
                  at Module.require (internal/modules/cjs/loader.js:887:19) {
                code: 'MODULE_NOT_FOUND',
                requireStack: [
                  '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js',
                  '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js',
                  '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                  '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! iobroker.js-controller@3.2.12 install: `node iobroker.js setup first`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the iobroker.js-controller@3.2.12 install script.
              npm ERR!     /home/iobroker/.npm/_logs/2021-02-07T18_49_45_157Z-debug.log
              • E emblitz
                  throw err;
                Require stack:
                  requireStack: [
                npm ERR! errno 1
                npm ERR!
                @emblitz
                cd /opt/iobroker
                npm cache clean --force
                haselchenH E 2 Antworten Letzte Antwort
                  @emblitz
                  cd /opt/iobroker
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  Würde da
                  npm i graceful-fs
                  helfen?
                    @emblitz
                    cd /opt/iobroker
                    emblitz
                    pi@raspberrypi:/opt/iobroker $ npm cache clean --force
                    npm WARN using --force I sure hope you know what you are doing.
                    [..................] | : WARN using --force I sure hope you know what you are doing.
                    • haselchenH haselchen
                      Würde da
                      npm i graceful-fs
                      helfen?
                      @haselchen
                      In meinem System:
                      pi@raspberrypi:/opt/iobroker $ npm list graceful-fs
                      ├─┬ fs-extra@7.0.1
                      │ ├── graceful-fs@4.2.4
                      │ └─┬ jsonfile@4.0.0
                      │   └── graceful-fs@4.2.4  deduped
                      Da scheint mir neben graceful-fs auch noch anderes schief zu sein.
                        @haselchen
                        In meinem System:
                        ├─┬ fs-extra@7.0.1
                        emblitz
                        Ist es nicht einfacher ioBroker komplett neu zu installieren und dann ein Backup zu rückzuck spielen?
                        Ich hab noch ein Backup auf der Arbeit. Komme ich aber erst morgen ran.
                        • E emblitz
                          @emblitz Dann mach das so.
                            emblitz
                            okidoki. Hoffentlich ist das Backup i.O. !
                            Melde mich auf jeden Fall morgen .
                            Bis hierhin ein dickes Danke für eure Mühe !!!!
                            LG
                            emblitz
                            • E Offline
                              emblitz
                              Hallo Forum,
                              hier mein Feedback zur Lösung:
                              Ich habe den Downgrade von dem (verbuggten?) Vis-Adapter von der 1.3.7 auf die 1.3.4 nach langem Tüfteln nun endlich geschafft.
                              Das direkte Wechseln der Versionen über den rechten Button in der Adapterliste führte dazu, dass ioBroker mit den o.g. Fehlern nicht mehr zu starten war. Eine Reparatur war für mich, auch mit den o.g. Hilfen (VIELEN DANK dafür !) aus dem Forum, nicht mehr möglich.
                              Nach Wiederherstellen eines Backups habe ich den Vis-Adapter erst über die Mülltonne deinstalliert, dann Neustart und über den "+Button" am rechten Rand in der Vers. 1.3.4 installieren können. (Die Buttons waren nach einigen Neustarts irgendwann wie beim Flot-Adapter wieder da.)
                              Der Vis-Apapter ist im Auslieferungszustand und alle erstellten Vis-Oberflächen sind dann weg ! Ich habe vorher mit der Vers. 1.3.7 das Projekt aus dem Vis-Editor exportiert und in die Vers. 1.3.4 wieder importiert.
                              Die Vers 1.3.7 war dafür verantwortlich, dass Sayit keine Ton- oder Sprachausgabe ausgibt.
                              @ wendy2702: Vielen Dank für den Tipp. Deine Vermutung war genau richtig.
                              Merkwürdig ist, dass ein Zurückspielen eines Backups mit dem Backitup-Adapter bei meinem ioBroker noch nie richtig funktionierte. Hier werde ich nochmal testen.
                              Ich habe mit den externen Backups und dem Tool von https://www.elzershark.com/ super Erfahrungen gemacht. (Ich hoffe, ich darf das hier schreiben.)
                              Auch hier zeigt sich, wie wichtig Backups sind. Das ist zwar jedem klar, wird aber in der Praxis, wenn allles funktioniert, bei mir meistens veschlammpt. Auch ein gesonderter Export der Skripte und der Vis-Projekte kann nicht schaden.
                              Nochmal vielen Dank für die Hilfe in diesem super Forum !
                              LG
                              emblitz
                              • E emblitz
                                Hallo Forum,
                                LG
                                emblitz
                                @emblitz
                                Von dem windigen Tool vom Elsterhai würde ich die Finger lassen. Das ist Mumpitz.
                                  @emblitz
                                  emblitz
                                  schrieb am zuletzt editiert von emblitz
                                  ok..., das wusste ich nicht. Das Tool ist aber genau das was Noobs wie ich benötigen😳 .
                                  Nicht jeder und ich schon gar nicht, hat Infomatik studiert und kennt sich mit den Konsolenbefehlen aus.
                                  Ich nutze bereits einigen Jahren den ioBroker echt gern, aber wenn etwas klemmt, komme ich beim Fehlersuchen trotz intensiver Einarbeitung und "gutem Basiswissens" schnell an meine Grenzen.
                                  Eventl. kann man ein Standardprocerdere als Anleitung für defekte ioBroker entwicken mit dem bis zu 90% (oder gern mehr %) der bekannten Fehler abgedeckt werden ?
                                  Erst nach erfolgloser Abarbeitung dieser Wiederherstellungsstandards wird dann die Hilfe des Forums benötigt und die tollen Unterstützer diese Forums haben mehr Zeit für die "wichtigen Dinge" beim Support.
                                  Das auch hier der Teufel im Detail steckt, ist mir klar. Der Mehrheit der Nutzer würden aber genau diese Standards helfen. Wenn es sie bereits gibt ,habe ich sie übersehen und nehme alles zurück.
                                  LG
                                  emblitz
                                  • E emblitz
                                    LG
                                    emblitz
                                    @emblitz sagte in [gelöst] Sayit Adapter nach Update keine Sprachausgabe:
                                    Das "Tool" macht es nur schwieriger und hilft genau Null.
                                    Nutze den Backitup-Adapter, der ist wesentlich besser.
                                      emblitz
                                      Alles klar, danke für den Tipp.
                                      In wenigen Tagen kommen die neuen SD-Karten. Ich tausche sie gern einmal im Jahr bevor sie Schrott sind. Eine gute Gelegenheit den Backitup-Adapter auszuprobieren.
                                      Wie ist Deine Meinung zu meinem Vorschlag bzgl. der o.g. Anleitung für defekte ioBroker?
                                      LG emblitz
                                      • E emblitz
                                        LG emblitz
                                        @emblitz
                                        Gibt es nicht. Und von daher ist das auch Wunschdenken.
