  4. [gelöst] Sayit Adapter nach Update keine Sprachausgabe
40 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
    @emblitz sagte in Sayit Adapter nach Update keine Sprachausgabe:
    Bitte in CodeTags posten.
    iobroker fix
    ausführen.
    emblitz
    jep soeben gemacht.
    Admin und Vis starten nicht mehr.
    "iobroker start" und "iobroker status" geben folgendes zurück
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ iobroker status
    internal/modules/cjs/loader.js:818
      throw err;
    Error: Cannot find module 'graceful-fs'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        at Module.require (internal/modules/cjs/loader.js:887:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js:5:12)
        at Module._compile (internal/modules/cjs/loader.js:999:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        at Module.load (internal/modules/cjs/loader.js:863:32)
        at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        at Module.require (internal/modules/cjs/loader.js:887:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    • E emblitz
      jep soeben gemacht.
        throw err;
      Require stack:
        requireStack: [
      @emblitz
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r
      E 1 Antwort Letzte Antwort
        @emblitz
        emblitz
        pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && who -r
        /usr/bin/nodejs
        v12.20.1
        /usr/bin/node
        v12.20.1
        /usr/bin/npm
        6.14.10
        nodejs:
          Installiert:           12.20.1-1nodesource1
          Installationskandidat: 12.20.1-1nodesource1
          Versionstabelle:
         *** 12.20.1-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
             10.23.1~dfsg-1~deb10u1 500
                 Runlevel 5   2021-02-05 17:17
        • E emblitz
          /usr/bin/nodejs
          v12.20.1
          /usr/bin/node
          v12.20.1
          /usr/bin/npm
          6.14.10
          nodejs:
            Versionstabelle:
          @emblitz
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
            @emblitz
            cd /opt/iobroker
            emblitz
            @thomas-braun sagte in Sayit Adapter nach Update keine Sprachausgabe:
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm ERR! Maximum call stack size exceeded
            npm ERR!     /home/iobroker/.npm/_logs/2021-02-07T18_26_14_022Z-debug.log
            • E emblitz
              @emblitz
              Komisch...
              cd /opt/iobroker
              npm list graceful-fs
                @emblitz
                Komisch...
                cd /opt/iobroker
                emblitz
                pi@raspberrypi:/opt/iobroker $ npm list graceful-fs
                iobroker.inst@3.0.0 /opt/iobroker
                `-- (empty)
                • E emblitz
                  `-- (empty)
                  @emblitz
                  df -h
                    @emblitz
                    df -h
                    emblitz
                    pi@raspberrypi:/opt/iobroker $ df -h
                    Dateisystem    Gr▒▒e Benutzt Verf. Verw% Eingeh▒ngt auf
                    /dev/root        30G    9,5G   19G   34% /
                    devtmpfs        1,8G       0  1,8G    0% /dev
                    tmpfs           1,9G       0  1,9G    0% /dev/shm
                    tmpfs           1,9G    8,7M  1,9G    1% /run
                    tmpfs           5,0M    4,0K  5,0M    1% /run/lock
                    tmpfs           1,9G       0  1,9G    0% /sys/fs/cgroup
                    /dev/mmcblk0p1  253M     48M  205M   19% /boot
                    tmpfs           383M       0  383M    0% /run/user/1000
                    • E emblitz
                      @emblitz
                      cd /opt/iobroker
                      npm list
                      Da nur das Dateiende, falls da Meldungen sind.
                        @emblitz
                        cd /opt/iobroker
                        npm list
                        emblitz
                        +-- UNMET DEPENDENCY iobroker.admin@stable
                        +-- UNMET DEPENDENCY iobroker.discovery@stable
                        +-- iobroker.flot@1.10.6 extraneous
                        +-- UNMET DEPENDENCY iobroker.info@stable
                        +-- UNMET DEPENDENCY iobroker.js-controller@stable
                        +-- iobroker.mqtt@2.3.4 extraneous
                        +-- UNMET DEPENDENCY iobroker.vis@1.3.4
                        `-- UNMET DEPENDENCY iobroker.web@3.2.3
                        npm ERR! missing: iobroker.vis@1.3.4, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.web@3.2.3, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.js-controller@stable, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.admin@stable, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.discovery@stable, required by iobroker.inst@3.0.0
                        npm ERR! missing: iobroker.info@stable, required by iobroker.inst@3.0.0
                        npm ERR! extraneous: iobroker.flot@1.10.6 /opt/iobroker/node_modules/iobroker.flot
                        npm ERR! extraneous: iobroker.mqtt@2.3.4 /opt/iobroker/node_modules/iobroker.mqtt
                        npm ERR! extraneous: iobroker.vis@1.3.4 /opt/iobroker/node_modules/iobroker.vis
                        npm ERR! extraneous: iobroker.web@3.2.3 /opt/iobroker/node_modules/iobroker.web
                        • E emblitz
                          @emblitz
                          MIch irritiert dein iobroker.inst@3.0.0
                          Bei mir lautet das entsprechend:
                          iobroker.inst@2.0.3 /opt/iobroker
                          Keine Ahnung was/warum das da krumm läuft. Mal irgendwelche Alpha/Beta-Versionen installiert?
                          cd /opt/iobroker
                          npm rebuild
                          mal probiert?
                          E 2 Antworten Letzte Antwort
                            @emblitz
                            cd /opt/iobroker
                            npm rebuild
                            mal probiert?
                            emblitz
                            Wollte mich zwischendurch für Deine Hilfe bedanken !
                            Der Admin stand in den Infoeinstellungen auf latest. Warum auch immer. Bewust habe ich nichts verstellt.
                            Habe in dann zu Beginn des ersten Posts auf Stable gestellt.
                              @emblitz
                              cd /opt/iobroker
                              npm rebuild
                              mal probiert?
                              emblitz
                              pi@raspberrypi:/opt/iobroker $ npm rebuild
                              > iobroker.js-controller@3.2.12 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                              > node lib/preinstallCheck.js
                              NPM version: 6.14.10
                              > iobroker.js-controller@3.2.12 install /opt/iobroker/node_modules/iobroker.js-controller
                              > node iobroker.js setup first
                                throw err;
                              Require stack:
                                requireStack: [
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! iobroker.js-controller@3.2.12 install: `node iobroker.js setup first`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the iobroker.js-controller@3.2.12 install script.
                              npm ERR!     /home/iobroker/.npm/_logs/2021-02-07T18_49_45_157Z-debug.log
                              • E emblitz
                                  throw err;
                                Require stack:
                                  requireStack: [
                                npm ERR! errno 1
                                npm ERR!
                                @emblitz
                                cd /opt/iobroker
                                npm cache clean --force
                                haselchenH E 2 Antworten Letzte Antwort
                                  @emblitz
                                  cd /opt/iobroker
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  Würde da
                                  npm i graceful-fs
                                  helfen?
                                    @emblitz
                                    cd /opt/iobroker
                                    emblitz
                                    pi@raspberrypi:/opt/iobroker $ npm cache clean --force
                                    npm WARN using --force I sure hope you know what you are doing.
                                    [..................] | : WARN using --force I sure hope you know what you are doing.
                                    • haselchenH haselchen
                                      Würde da
                                      npm i graceful-fs
                                      helfen?
                                      @haselchen
                                      In meinem System:
                                      ├─┬ fs-extra@7.0.1
                                      │ ├── graceful-fs@4.2.4
                                      │ └─┬ jsonfile@4.0.0
                                      │   └── graceful-fs@4.2.4  deduped
                                      Da scheint mir neben graceful-fs auch noch anderes schief zu sein.
                                        @haselchen
                                        In meinem System:
                                        ├─┬ fs-extra@7.0.1
                                        emblitz
                                        Ist es nicht einfacher ioBroker komplett neu zu installieren und dann ein Backup zu rückzuck spielen?
                                        Ich hab noch ein Backup auf der Arbeit. Komme ich aber erst morgen ran.
                                        • E emblitz
                                          @emblitz Dann mach das so.
